View Full Version : Forced Induction
- intake manifold question?
- want to go lst... need help..
- Valves for FI
- Evans tuning turbo kit
- 1600CC GOOD OR BAD?
- Searched.. MBC
- Stock b16b - lowering compression?
- SOHC turbo owners
- Adjusting Greddy Type-RS BOV
- Turbo Manifold Coating in Northern California
- New to building a turbo motor..need info
- How Much Power Are You Making At What Boost?
- Civic turbo fully built motor - Water in Oil
- blaast performance online anyone know?
- JRSC 6 p.s.i. D16y8 tuned on P28 and I got an exhaust question
- Need turbo help
- Precision SC61 vs. Garrett GT3076R
- New built motor, first start + first 1000 miles on stock injectors/ecu. Should i run wideband? to se
- car is not starting
- Supertech valvesprings and retainers
- Differneces in these turbo's please
- Changed my dizzy today and now have a proplem.
- Loose mani bolts
- .80 a/r on the compressor housing?
- Evo III Big 16g on 93 Accord
- ignition system for 800hp
- Too many Oil Lines
- B18C Turbo runs too rich...
- GSR or ITR tranny???
- Weird aeromotive fpr problem.
- air density psi question ...
- JUST finnished greddy turbo install... problem!
- supercharger-engine surge
- Turbo Decision ?
- What turbo would be best for my application?
- boost falling off
- b16 rebuild questions
- 1000cc injectors for stock b16 ok for now but goen to use when swap built gsr!
- CATCH CAN AFTER INTALL SMOKING? help
- 200 to 230 whp d16z6
- Help?
- Peakboost TOPMOUNT KIT + Prec SC61 BB Turbo???
- some1 please give me a list of seals/gaskets for my ls/vtec-T build
- delsol exhaust
- rsx turbo
- precsion ball bearing sc series?
- JRSC on a GSR, is it any fun???
- couplers
- vacuum lines
- Ebay intercooler
- please check
- H22A-35R
- Turbo manifolds - TunerToys, SLS, _____?
- Need help selecting ecu
- GSR TURBO SYSTEM SETUP
- Re-route wastegate into downpipe
- Moroso oil pan leaking on turbo motor.
- Falling out of boost between quick shifts. Big cams?
- B16A2 Turbo project , advice needed...
- B16a turbo smoking crazy
- JDM P8R Head $250
- Crower 402T cams and Spring/Retainer Kit $500
- Timing Belt keeps jumping teeth. Search engine is down.
- ***D16Y8 turbo tuning thread***
- engine immediatly floods wen i go to start
- b18c1 problems?
- ARP rod bolts hitting main cap bridge on D16y8
- Oem half size rad enough?
- spark plug question for ls turbo guys
- how exactly do i wire my injectors to a resistor box on my obd2 civic?
- My Setup....need some advice
- killer vtec cams for boost
- VJ14/VJ11 hybrid vs. Garret, Mitsu, etc
- holset turbo setup question!!1
- new to the turbo game
- ball bearing turbo vs journal bearing
- B18-t wont start
- tach miss reading while street tuning???
- B16 Buildup
- anti-lag
- pump gas drags viper pics
- tuner in vancouver bc with dyno
- Ebay turbo kit???
- Motorola 2.5 bar map sensor problems
- tuner in MN or WI
- Is this a junk "ebay" turbo, or is this a legit garrett turbo?
- HELP oil blows out breather on catch can
- Need a tad bit of help H-T...
- Non honda setup.
- hondata,fuel injectors ? setup question
- what happened to synapse wastegates and BOV?
- BW s366 or Gt4088r
- What should I set my timing at? spark plug gap? feels like it's dying in the higher rpm's
- Looking for head flow rates and cam profile info
- Question regarding cams & boost..
- AFI Turbo Kit...some comments anyone?
- ATI damper users chime in please
- need help finding some turbo parts
- buddy club valvetrain for boost
- Aftermarket FPR vs Dual OEM
- Jackson racing supercharger compression ratio?
- A very interesting "budget" topmount manifold...
- crankcase thought..
- Tempest
- fuel injector question
- gt25 or gt28r for autocross? Which turbine AR?
- Cracked in topmount manifold :(
- hp numbers with a GE sleeved block eagle rodes aftermarket piston
- downpipe bolts on garrett turbo keep coming loose, pissing me off please help
- Peicing Together A Turbo Kit
- Alternator solenoid valve fuse blew
- Best turbo pricing from our sponsors
- GT2860RS oil line ??
- b16a swap into 93 dx questions...
- What engine changes needed for JR intercooled s/c
- what exactly is sleeves sinking?
- New guy here
- How to sell Edelbrock 1st generation polished Intake Manifold GSR
- Walbro in tank fuel pump question
- Nitrous express honda nxl direct port kit
- ecu selection
- Skunk 2 Pro 1 Cams
- 0.065" Head Gasket on D16y8?
- biggest turbo on stock sleeve d16?
- B16 EM1 turbo questions.
- peak&hold to saturated injector
- post your vacuum block pictures
- new to forum/ here is my car
- where should i mount my intercooler ...
- New records on the Vitara's again!
- Exact modes needed for d16z6 block with y8 head
- HONDATA intake manifold gasket . Whats this plastic called?
- Max boost Questions.
- sohcT new dyno numbers
- Omni valves, never again!!!
- GT35R....Capable of 9's in DC2 ???
- endyn breather kit setup
- 4" Intercooler Too big?
- any body running with to4's ?
- ek intercooler setups
- hondata calibrations for gsr turbo
- Blow Off Valves - CHECK YOURS TODAY!!! Damage pics inside!
- help i need pistons and i cant pm anybody
- 06 RSX S - Custom turbo kit, S256, pics and dyno graphs inside!!
- Spoolin Peformance Exhaust
- Turbo drain to oil pan drain plug???
- What fittings for hard line to connect Tial 44 mm wastegate to compressor housing?
- oil seals blowin out
- ceramic coating, turbo rebuild questions
- help car wont start please
- Blue smoke fix? turbo b16
- Mike Belben
- turbo setup
- Which plugs for a H22
- turbo Oil Leak
- Hondata
- Started my project : PMR-T
- Car bogs when hitting boost
- gt35r on a b18c, where do I connect the coolant lines for turbo?, also endyn breather Q
- 255 or 255hp
- ITR Cam lobe worn? Normal?
- 96 chassis, 95 intercooler piping
- turbo feed line(d16z6)
- EJ1 Turbo Manifold Question
- What kinda washers/o-rings do you use for your AN fittings on the fuel rail?
- no power to fuel pump after complete rebuild
- Building Boost but Insufficiant Power?
- cylinder wall scratch....
- Who can machine the valve reliefs on a set of LS pistons for me? I've searched with no luck.
- head gasket blown after two weeks?
- Inline Pro vs Ramhorn
- Greddy Air Diversion Plates? Do they work??
- Omni valvetrain? any good?
- First time turbo set up
- head rise
- Cam choice for mild-mid boost?
- My turbo S2000 (pics)
- step it up in the game
- 85mm gsr turbo.
- Brian Crower internals... no Crower!
- B16A Del Sol Turbo Project - From the UK
- Need to know for emanage... OBD2B, Injector ground goes to...?
- Help with wiring AEM EMS, non Honda application.
- lowering comp. affect idle?
- Twin scroll manifold and single 60mm gate?
- Inovative/logworks users chime in please!?
- Will this change my tune ?
- fan cool turbo
- National Speed S2000 Time Attack Build Progress
- AEM Boost Solenoid Issue
- What WG spring with MBC????
- twin wastegate set up for twin entry turbo a must?????
- opinions on Turbonetics Turbo kits
- PLeaSe Help Me>> Need to install A/F ratio gauge
- JDM B16 Turbo Setup
- VALVES VALVES
- Turbo trouble.
- Changing 35r from t4 to t3 flange?
- what fuel setup would u recommend for a 600whp ls/vtec-T
- Normal A/F ratio for a stock Honda?
- the overheating battle
- fuel set up for 7 psi?
- 2-step on crome?
- Greddy Type RS. yes or no?
- All noob questions answered!!!
- GE LS-Vtec conversion leak
- how much power do you think i can run??? what psi should i stay in???
- Needed: 3inch - 4.5 inch reducer
- HAS ANYONE DONE LS/VtEC Supercharged?
- t67 rebuild options??
- smoking problem
- fuel setup problems
- Rebuild Questions..
- N2O Question
- MASTER POWER TURBO?
- where to get AEM o2 Sensor???
- Trimming Bumper for intercooler
- 500whp too much for Crower Econo-Billet rods?
- Skunk2 Pro1 or Rocket M22X cams with JRSC?
- tranny??
- Topmount with A/C & P/S compatible..anyone done it?
- Shooting for 425 whp.
- low compression pressure on one cylinder on turbo type r setup
- anyone know the tq. spec for a golden eagle sandwich plate?
- turbo on a b series
- Qestion about turbo?
- Head gasket thickness for boosted ls/vtec
- My first EF build
- Peakboost ramhorn manifold turbo & WG placement is off. Is this normal?
- Budget turbo build, map sensor problem
- t3/t4 size
- Do I need torque mounts with my hasport engine mounts?
- gt35r coolant lines
- DSM Injectors pluggin into Honda obd2 plugs ......
- EG Half Rad Fitment in EF (PICS)
- Could the drag wastegate placement cause burt valves???
- wastegate vacuum line question
- *Pic Request* Hot side charge piping- EF Civic/Crx
- High EGT @ Idle
- 2000 Vortec SI makes no boost.
- custom turbo piping
- clutch question
- Help with installing a ebay turbo timer on ef civic!!!!
- another high HP build
- wastegate problem?
- MSD DIS-2 2 step question
- If I was to rebuild again...
- dsm 450 horsepower??
- subaru turbo
- Oil Control Ring Gap
