View Full Version : Forced Induction
- dyno tune help
- Turbo exhaust options?
- please help
- short shifter question
- The Turbocharged/Supercharged B20 Thread
- What should I be hittin?...
- injectors????
- Fullrace turbo manifold question
- EF Turbo Kit For Sale 500+whp
- oil pressure to low?
- is there going to be a huge difference?
- Attn Miller from NRG tech
- NSX thread
- ok i need an ignition coil.
- vtec engagement point and turbo spool - directly related?
- 5bolt internal wastegate flange needed
- remote mount turbo
- Thieves caught in the act
- please help me! newbie here!
- Untuned turbo, make sense it's slow?
- need an explanation
- KINK
- Lumpy idle after warm up.
- 1.5" or 2" resonator in SS who cares them ?
- anyone sellin a dual stage manual boost controller?
- Edlebrock VictorX,Holley 68mm TB throttle cable question....
- rev-hard kit help
- forced induction help!
- Tubular Manifold for TD05 B16 that Keeps AC/PS!!
- where to get b18b1 head studs?
- Saturated 550?
- just started my turbo for the first time. couple of problems
- any 450cc DSM injector?
- plxm300 wideband not working...?
- A quick Question???? someone please help!!!!
- Boost gauge goes crazy in 5th gear
- Looking for 1 eagle rod
- ARP headstuds interchangable? B16 - B18
- Several questions on gaskets & sealant (IM, TB, turbo & mani, oil fittings)
- low power question???
- b20b vtec max HP?
- gsr pistons help
- New motor and tunning question.
- methanol
- Alcohol injection help asap please.
- wideband O2 sensor
- dyno chart.......is it good....help.
- identify these sleeves really quick for me, thanks!
- B16a with T3/T4 hybrid turbo, just bought the car and it has stock fuel system, what size injectors
- Please post pics of your DRAG turbo setup (civics and integras with b-series)
- can i run a 4.4 fd in a ls trans? anyone do this?
- junkyard turbo
- Want to Boost, need help
- sleevein
- Braille light weight racing battery...GARBAGE
- do i have to wire in a resistor box from 95 accord?
- turbo kit question
- Boost+timing+milled head....
- Anyone have any experience with Probe SRS pistons?
- tapping ls oil pan?
- gsr and b18b piston help
- LOOKING FOR MACHINE SHOP_NEED YOUR INPUT!!!
- gsr help
- Turbo b18b question
- LST help!!!!
- valve seals bad??? please help
- what fuel pump?
- ls turbo, oil help
- cp pistons vs je pistons
- What boost controller
- car running on 2 cylinders help
- leaking fluid please help
- Gauge advice
- Will stock b18b cams make power to 8k?
- increasing turbo efficiency / decreasing lag. . .
- T67 on a B16, will my TiAl 38mm be able to do it's job?
- has anyone turbo a b18c1 with a 14b.
- Seached the FAQ. What's better for intercooler style
- shattered thrust bearing on built motor???
- Gsr oil pan question
- precision 780cc injectors good for 450whp?
- saab .42/.48 to small for stock block gsr
- trans question
- Innovate Wideband Troubles..
- Bad TDC sensor?
- SPEC TWIN DISC CLUTCH KIT
- GM 3 Bar Map Sensor with my 68mm Holley TB
- obd2-obd1 Passing ny state inspection
- Anyone had their PLX start getting out of calibration?
- what WG size do you run on GT35Rs
- WIDEBAND
- ARC / Greddy BOV flange
- attention profec b spec II owners!
- Signs of a bad wideband sensor?
- Whats the Point OF dual WG?
- engine just shut off on highway??
- For you turbo guys
- Weary of LS turbo daily driver, advice?
- Silicone Rad hoses who else makes them then SAMPCO
- blown head gasket?
- K20A type-R jdm engine for sale
- Turbo ID help
- Turbo pieces?
- Borg t04B Turbo In B16a
- which manual boost controller should I buy? Searched
- 807 WHP STI
- blew my turbo... trying to figure out why
- gasket inbetween turbo mani and turbo... where to buy
- boosted stock sleeve b20?
- which cam should i go with my setup
- Clutch Kits
- Too Rich How much Power Loss
- GT3071R on a GSR???
- ? mapsensor
- How much boost can my stock block hold?
- turbo comparison garrett T3 60 trim vs. Td05 16g?
- Replacing pistons and rings or just replace the rings?
- F22 Pistons & Rods Help
- Interested in Wideband setup options have questions regarding PLX m300
- H22 specific oil feed line question *searched*
- Got a turbo with no name on it?
- Tuning control
- hot under the hood, custom vents?
- setup safe???
- is there anyone around the nj/pa/ny area that wants to help me install a turbo kit?
- What next?! Turbo b18a
- Garrett T3 a/r 80 on B20vtec
- any boosted cars running a 4.7 FD
- Turbo Help!!!!!!!!
- Peak Boost top mount manifold kit @ work!
- wut manifold to go with for 60-1
- surge at full boost
- JRSC GSR setup???
- extending oil pressure sensor wire.........
- can trigger kits for H22 pics/info please
- Fuel Management...what do I need???
- turbo problem
- With my set up what kind of hp?
- low compression numbers good for boost
- Question About Portmatching WG Port + Manifold Port
- exhuast setups?
- which is the best intake manifold for a 84mm turbo b18c,b16head
- another injector size question
- Put some numbers dwon last night...: )
- Track time 85mm B16a 14.5psi
- Treadstone Turbo Kit?
- mounted nitrous bottle measurements?
- boosting B18C5??
- Turbo LS running rough. Any ideas??
- is it worth boosting a d16y7 including vtec????
- Turbonetics vs. Tial for my wastegate choice v. 38mm
- Wastegate spring and it's limits?
- Hey yo...how much power can I make on 1 stock vr4 turbo?
- is this turbo 2 big 4 me?
- prelude h23 ecu not able to tune?
- Congrats to Newt Dawg (Vance)!!!!! 10 Second Single Cam - 100% street car!!!
- Ebay HKS STYLE BOV = Piece of junk
- boost cut?
- Reoccuring Warlboro Pump failure issues....?? The story...
- dump tube location????
- built turbo d16 help needed bad!
- Quick EGT question not mani or DP
- fuel injection help
- Where'd all the cheap eBay turbos go?
- RACE GAS Question?
- Need HELP ASAP!
- best place to get amsoil mtf ?
- To sleeve or not to sleeve, that is the question.
- Thoughts on this intercooler:
- boost gauge hook up before throttle body
- 1jz flywheel
- Need help, BOV diaphragm separated, what glue to use??
- Copper O-ring and SS headgasket.
- which BOV?
- ring gear bolt question?
- problems after swapping back in stock fuel system please help!
- looking for advices on turbo's d16z9 with vitaras.
- HKS SSQV Copper Line broken off (pic)??
- my car completly stopped.... Ectune ??
- What gasket set to use for .25mm over??
- Need SAFC2 wire schematics
- silicone coupler on turbo outlet??
- Quick Head Gasket Question
- fuel filter
- turbo b16 oil problem. any help?
- Tony 1 PLease HELP...HAHA
- weird bogging problem
- JR Supercharger + Hondata ????!!!!
- What Kind of race gas to run..
- fmu question
- They keep on tellin me...
- A ride in the turbo sandrail **VIDEO**
- dyno tune help
- gsr turbo help
- Ball Bearing Rebuild or Other Cause?
- b16 84mm. which head gasket?
- bored.......jrsc
- looking for used turbo
- Real quick question about the wastegate.
- Greddy Type s and rs "top hats" interchangeable?
- skunk 2 pro series question
- How would my gsr take boost??
- How does the AVC-R boost duty cycle work
- stock injectors
- type r oil cooler with oil block adaptors need help!
- 523 hp stock sleves thankyou tunning factory !!!!!56k have a lunch!!!!
- Product Review For FI Parts.
- not making full boost..
- Wastegate dump tubing?
- Garrett t3 t4 60mm trim question
- Turbo D16Z6
- Turbo Cams
- boost question
- REAL CIVIC TYPE R JUST GOT FROM JAPAN
- a couple questions about cooling the car down
- Crome experts help! idle issues
- rule of thumb for necessity of aftermarket FPR??
- skunk 2 intake manifold
- Rocket valve springs and crower turbo cams???
- d15b jdm fuel rail upgrade needed? turbo setup
- -3an feed line + restricter
- Eagle rods
- GT2871r or GT3071r???
- To vent or not to vent my hood.
- Just Recieved 84mm ERL block b18a check it out.
- stock block question
- So my car was on the dyno yesterday and...
- stock clutch
- rundown on gaskets for turbo
- Skunk @ Pro 1 cams going in tomorrow
- Arias piston question
- Hondata S200 good enough?
- Low Boost application (5-6psi) - do I still need a quick spooling turbo?
- New turbo from garrett for K series..
- help with plug selection bkr7e-11 ?
- What size injectors?
- white smoke but there is alot more to it.
- T3 5 bolt downpipe flanges?
- cheapturbo.com
- Is this bottom end good enough to hold 400whp?
- difference between wet sleeves and dry sleeves?? Pros&Cons
- coolant problem!!
- lovefab mani.
- some oem PCV black boxes with and some without baffles?
- Turbonetics Ball Bearing 62-1
- Problems with turbo falling off - really
- quick question about a boost controller. . .
- Looking For a tuner! *Knoxville,TN* <CROME>
