View Full Version : Forced Induction
- Help: Just finished turbo on a friends civic *PICS*-- fpr/wastegate questions...
- what type of size housings should i be lookin for in a turbo
- People with D16 Maxrev manifold, quick question about A/C
- Does oil feed line size matter?
- Help!!! Leaking oil from headgasket after tune
- D16Z6 dies with no start after warmup until completely cold again....HELP!
- Fuel management for h22 turbo
- Quick question about HKS BOV...
- Where to buy Inlinepro manifolds???
- fuel pressure problem help!!!!
- will these injectors fit
- wiring injectors backwards....what would happen???
- Opinions on Jacobs Nitrous Mastermind
- Custom made intake manifold!!!
- FI 0-60 mph times
- turbo kit
- Dumb Q. What load points do you choose?
- g3 turbo axle question....
- GTSeries Turbo and Water Lines on a GSR motor...?
- How much to gap the spark plug?
- LS greddy turbo!!
- So, has anyone else cleaned their compressor blades before?
- Zex jets, Can I use...
- JRSC help, fluttering bogging ???
- my supercharged G35 with pics...check it out.
- Longetivity of Vtec Engines - Lets Gather Some Information
- How much boost on......
- Timing question?
- One or more cylnder dies on me after warmup???...please help!!!
- need help with gsr w/ drag gen 3 kit.
- V-AFC II NEED HELP PLEASE Cant find 3 wires.
- Not your typical Eagle Rod post.
- got spark got fuel no codes won't start
- Intercooler piping setups?
- Well I had to ask...PCV setup/removal questions...
- losing boost..
- Injector Removal Question
- should i use these bearings ?? .25" undersize ....
- Attn: people with F-MAX manifolds...
- going boost soon..compression test results.
- looking for some 440's and a missing link any one know the best place
- Need a little expert advice
- Turbo for 2004 civic?
- anyone running the sc34 on the d-series??
- ATTENTION: anybody with integra jdm front and drag turbo kit
- Full Race turbo kit vs. Jackson Racing Supercharger?
- slower spool at cold temperatures?
- 14b compressor charge pipe question
- Anyone Have A Supercharded DX???
- Power FC Idling Problems :((
- !!!!!!!!HELP MY SUPERCHARGED INTEGRA SUCKS LOW WHP!!!!!!!!!!!!!
- Got Hondata tuned, But!!!!!!
- inline pro manifold that much better than drag manifold?
- Has anyone boosted an HX????
- main studs/head studs; waste of money? good insurance?
- LsVtec oil pump questions???
- Which EMS for my 96 Civic
- upgrading turbos and need help on understanding different A/R #'s
- post pics of your sheetmetal intake manifold....
- lowering boost / internal wastegate T25...
- planning on turbo...question
- how much boost on stock b16a1
- 330cc big enough for 10psi?
- Check out this "little" number- not your average t3/t4 here
- rollcage and tilton installs
- How thick of a head gasket?
- cannot decide turbo size...
- wanting to know if this will work or not...
- How to install a Harmonic Damper by Fluidamper
- Lucas Injector Trouble ~HELP~
- newby question about turbos
- bosting a 95mm crank
- Some preview pics of my new motor!...and a little update on my CRX...
- FMU's
- what turbo for my b20 with ls head?
- oil return causing smoke?
- strange coolant issue
- NewB turbo install questions
- big turbo for street car
- intake and exhaust valves
- Does the new S-AFC 2 with Hgh/Low settings fix hack bogging issues
- best tool to cut off bumper
- A couple questions on turbo selection and purchasing.
- fastest sohc 1/4 mile times?
- tuners help please.
- Help, Need Precision SC61 (Preferably New)
- best turbo for D series? need help fast
- need stuff for hondata stage 3 only have blue box
- how much boost can i run
- Need help!!! with AEM EMS and 3bar GM map sensor?
- NYS INSPECTION!!!!
- HX 02 sensor
- What belt to use with a b20 crank pulley for a supercharged b16A?
- hooking up a techedge 2.0 wideband to a hondata s200???
- Flooded motor with tons of fuel last thursday
- block gaurd
- Fuel pressure?
- What are advantages of hondata over zdyne for crx.
- videos of hks SSQ or greddy type S bov, please post them.
- Im stuck to decide?
- cheapest place to buy a HKS wastegate
- Bigger Injectors on Turbo-H22 w/ V-AFC/255 Pump & FMU?
- 550cc peak and hold injectors good for 400whp?
- Has anyone heard of/ seen a "No Limit Motorsports" turbo manifold?
- When does the AFC lose it's memory ?
- EMPLOYMENT OPPORTUNITY with EFI UNIVERSITY
- Center section Q: oil feed hole not tapped.. can i tap and blow center section out with compressed
- I need someone who has used the 300z T3!!
- Manifold for 14b on d16z6
- DIY turbo kit---what intercooler?
- Boost Guru's: Please Help asap, need to know your opinion
- Website for kamikaze headers?
- Has anyone ever ran 460cc rx7 injectors with their turbo setup?
- balancing a crank/engine?
- how much are you guys paying for custom exhaust?
- Making a Hondata Basemap
- Bearing question
- tial wastegate 38mm taller than tial 35mm?
- my jrsc story
- new motor issues...
- B18C Dyno
- How to determine a REAL HKS SS BOV from a fake one!
- Hondalogger w/ uberdata?
- BORGWARNER T3/T04E, T4 TURBO'S! I have heard good things about them!?!
- spun a connecting rod bearing..
- 255lph fuel pump good for 18psi?
- Which machine shop bores headgaskets to match overbores?
- tubonetics turbo kit
- Problem with car missing in boost
- anyone using kim fab traction bars with DRAG intercooler piping?
- Intercooler Piping??
- Installing a Blitz FATT Turbo timer
- 81mm bore vs bigger bore (under high boost)
- Weak points?
- torque in turbod sohc?
- what size down pipe are you using??
- which oil pressure gauge???
- Who sells greddy turbo manifolds?
- Downpipe question
- STOLEN INTEGRA ALERT - DFW
- Turbo Manifold for K-series in DC2 chassis.
- Has anyone made an adaptor plate for greddy mani & a t25 turbo?
- Fuggin Theives
- carbon smell.. cant make it go away...
- where is the best place to rebuilt my Garrett T3/T4???
- 400 hp B16 with Uberdata?
- Quick question about the Lovefab SST.
- What kind of engine management with JRSC?
- Turbo & manifold swap.. have to retune???
- 4th Gen Prelude intercooler piping question
- best forced induction cams for b20 with ls head?
- supercharge or turbocharge my b20?
- I normally wouldn't brag....but
- I got tired of my real project so did a side "junkyard" project *PICS*
- b20???
- no filter
- how wastegates actually work....? supercharger wastegated??
- ATTN Greddy SOHC users with Johnnyracecar intercooler
- Just bought a turbo!!Please help identify!!
- blocking off internal wastegate???
- Question about re-boring block
- What is the smallest turbo for a stock H22 that won't fall off up top...250-300whp
- hey everyone, new here
- b series dry sump?
- just got my new toys
- Anyone ever seen this article a custom turbo kit?
- smoke when shifting help!
- oil pressure question
- OBD2 to OBD1 conversion question
- Installing a turbo kit?!?!?!
- EVO8 Intercooler...maybe?
- Greddy gaskets.
- I don't hear my bov sounds like the wastegate dumping when I shift
- Can I get away running injectors like this? Pic inside
- How much Piston to Wall Clearance for 600-700whp
- Look at my plugs, whats going on?
- Need Greddy 18g help
- BOV and Wastegate help??
- hondata data logger software
- Good place to postion the wideband sensor in a setup?
- flat spots on JG 9006 turbo cams...?
- B18c Nitrous Setup!?!?!?!?!?!?!?!?
- Which FPR?
- She's getting there!!!
- oil pressure question???
- t3/t04b flow?
- Sparkplugs for motor break in?
- Charge pipes.
- My turbo dilemma! (need help)
- Enough bends?
- CMI spring jam results......for 2.0liter gsr-turbo
- Need help! Problems installing CPR 440cc injectors and the dreaded block grinding!!!
- changing map sensor: tuning needed?
- Who has Pauter rods in stock??
- Dumptubes, is urs loud??
- greddy 18g max power output ????
- are my plugs too hot?
- b20 turbo help!
- burping in my overflow bottle..Blown HG?
- horsepower vs quarter mile times
- ok to T into Profec vac line for boost gauge?
- Difference between bearings?
- Who can tune aem?
- another greddy kit question
- INLINE T-4 TURBO MANIFOLD
- is there any symptoms of headgasket going bad??
- Bone yard boost on d16z6.
- i need an EMU should i go hondata or aem ems??
- Turbo gas milage??
- are inline fuel pumps good
- update's of the coupe build. HX baby
- thinking about going with a ecutout got a question
- how to build a block
- Clutch/flywheel combo w/ stock pedal pressure
- AEM Fuel rail
- New turbo build in progress......
- Could someone break down the parts of a turbo?
- what fmu to use
- EFI 101 in DALLAS May 22-23!! Who is going?
- Auto Gage boost gauge, Q's?
- what guage - guages for boost
- She's done... and so am I.
- leakdown on k20a2
- rubber hoses as intercooler pipes???
- lowest compression OEM d series pistons?
- Turbo D16
- Simple question....
- Alternative Hondata tuner in SoCal?
- is there a down side to this setup? 15psi from idle to redline!!
- Turbo or Supercharger?
- need help on boosted d16
- garrett turbo question
- Can fouled plugs cause a consistent misfire at a specific RPM?
- Those with A/C, intercooler mounting problem
- RC 310 or RC 440
- Thermal 3" exhuast
- turbo seals just quit. is there anything "I" can do to fix them?
- Quick Bov question?
- 14b wastegate?
- chipping ecu... need help with fuel system FPR? FMU?
- How much for a D16z6 build (turbo)
- Couple pics of the build up...
- What's too lean?
- Update pics of my D16 turbo del sol. From BAD to good. :) Hint: ugly-ass bumper
- Opinions on a turbo size?
- MSD RPM window switch prob
- What hpns when boost gets over 11psi with obd0 map sensor???
- turbod sohc???
- Eagle rods
- Boost tappers off
