View Full Version : Forced Induction
- CHECK THIS OUT!!!!!!!!!!!
- Weird turbo... Advice please?
- Socal shop for lsd and clutch install?
- My car is being screwey. Help! :(
- Come by and see us at Nopi , LHT Performance will have 12 + cars there
- Stand alone engine managment PLEASE HELP
- Gauges+Clutch+Exhaust+Hondata??
- DSM 450's into D16Y8 problems.
- Is there any negative effects of re-sleeving a block that has been sleeved before?
- which spools FASTER, t3/t04e or 18g??
- turbo manifold
- 3 Bar Map Sensor Q.
- Tial Blow off valve sound comparison?
- Dyno Help
- 2 boost settings. Hondata users.
- b16 IM on a gsr..??
- bov sounds like a stuttering bird???
- Help on choosing cams for the B16 turbo....
- thought on turboing d16z6?
- How do I post pics???
- Question about E cutout location, and welder question
- Searched - Can you use a bleeder valve as a Boost Controller?
- :: techedge v1 install question, please help, installing right now ::
- anyone heard of this
- Precision SC61 + Precision AIC-600 FMIC (Thirty-Six 5.24 Megapixel Pictures Inside)
- ::Boosted RSX JRSC pics::
- SFP turbo manifold
- tial or turbocanetics?????
- 3" turbo piping and 2.5 exhuast????
- how much boost?
- Adding injectors to D-Series Intake Manifold
- what are the clearance specs for rod bearings and main bearings(b16a1)
- closed loop bov (searched)
- built d15 bottom:how much boost???
- t28 turbo
- the sea level affect the afc hack???
- jdm p30 ecu okay for Hondata?
- Question about octane
- still in need of help! hondata peeps!
- Overboosted after aftermarket cat install
- Just need some clarification. Fuel line fittings.
- Question about GM 3-bar MAP sensor and Hondata
- where to buy cometic 84mm headgasket ...asap?!
- Intercooler pipe sizing
- gsr injectors and si injectors the same? ****urgent! drop everything! i am that important!****
- What plugs should I run in a Ls/vtec turbo with msd ign.
- Anyone running EF-1 Springs and Retainers?
- changing out turbo manifolds?
- Help with the greddy turbo kit for a 99 civic ex.
- Backfiring when i let off the gas
- 3" catalytic converter
- Video of me at the Drag strip a few weeks ago.. 11.68
- low compression pistons bogging??
- Fuel Pressure gauge.... regular vacume VS. Liquid filled
- full-race forum
- spark plug threads getting worn out
- Calling all MAXREV OWNERS!!!
- running rich, affect water temp. ?
- h22 vafc hack setting questions
- Greddy downpipe problem.
- Zex kit ( dry ) and 5 psi non-intercoolered ??
- nitrous question
- Alright im not sure if this is covered but i have a few questions about the DSM hack
- Identify My Turbo....
- F Max turbo kit for 88-91 civic/crx w/bseries?
- what can i do to my b18c1 head , if i want to rev to 9500rpm
- LoveFab sidewinder pics on ITR
- My GF's Sol that ISNT going to NOPI... :(
- Open DP Questions
- exhaust
- Tony1 what do you think i should do...
- Head Work
- Crower B Series Stroker Kit?
- Increasing Stroke?
- Best location for blow off valve
- hot start problem?
- Stone Racing Turbo
- d16 t3/t04e boost on stock sleeves
- DSM 450's Clicking???
- Is 420-450whp enough for a 10.99999 in my car?
- What is a good turbo for a stock b16?????
- :: is it possible to clean carbon deposits off spark plugs? ::
- ITR Cams for turbo B18C1 Build
- :: gsr with ls cams = non-vtec??? ::
- Tial 35mm wastegate spring question?????
- Should I swap to an EX tranny?
- Dynamic Autosports vs. Autolink Motorworks
- How many turbo people run 10+ psi on stock internals?
- Mazda Mx6 Turbo setup on a F22B1?
- need help picking out turbo exhaust
- HELP!!! Engine still misfiring!!!
- GS-R is sold... but in it's place....
- Timing belt on my GSR broke.. Will I need to pull the head?
- Love Fab sidewinder is installed and working
- ATTEN: Welding Geeks!!
- NPT fitting size on bottom of DRAG/turbonetics turbo
- Are you guys running -10 or -6 Feed lines now? Im tryin to decide
- Procharger kit for civic SI: defective Blower?
- turbo kits for b16
- Compression test problems.
- Custom fuel line. What size banjo???
- Custom Exhaust question. Apex Universal N1
- drag kit vs. custom
- BOV mounts to intercooler
- spark plugs
- putting my greddy gsr turbo kit onto an ls... can it be done?
- Code 13 on VAFC Hack???
- Is 8:5:1 Compression ratio to low
- S-AFC question?
- installed turbo now going to need clutch?
- GTI Turbo KO3
- Stock Greddy Kit???
- Greddy DOHC turbo....
- NEED TURBO++ INSTALL. WILL PAY FOR HELP
- Clearance Issues with inlinepro?
- Greddy kit....any way to raise charge pipe off ground?
- Help!! Hondata people!!
- Anyone tried autolite racing plug?
- Raise Compression with Headgasket???
- Accord homemade turbo question
- Peak & Hold or saturated
- anyone seen J.DAVIS?????
- Who has tried water weter and what do they think of it??
- Car doesn't idle right...Need Help ASAP
- parts
- 3rd gen rx7 secondary injectors?
- Axle Question
- HONDATA tunnes for D16 turbo anyone have some ???
- Questions about turboing integra LS
- Anyone know where to get 14mm x 1.5 nipple barb fittings?
- PISTON question
- QUARTER MILE times???
- Can someone help me design my fuel system?
- diy b16 turbo kit near completion need help
- bov question
- Detonation noise...
- what size inline fuel pump?
- h22 injectors and vafc hack???
- Running LEAN!! problem areas= Hondata+3Bar+O2+RC 550 p&h
- Drive to tunner with huge injectors?
- is those brass fittings good enough to hold temps under engine ???
- I no I no, but I have to ask....
- endyn fuel pressure releif mod
- injector flowtesting?
- Greddy Turbo does not hold boost at 15 psi???
- Rattling Exhaust Help
- 2.5" to 2.25" Reducers for intercooler
- what do you think of my internals? also what wastegate?
- what would you guys pay for this kind of car???
- Turbocharging a Honda CRV
- AEM v2 + jackson racing supercharger....possible?
- APEXI AVC-R Boost controller
- Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- turbo kits
- 3 inch Installed on my sol PICS
- 2nd gen dsm boost controller?
- omni
- Is this stuff any good
- when i up the boost on my ls turbo,,should i do a head gasket,,and head studs??
- first time gapping piston rings. need some help from the pros!!!
- rsx turbo setups
- S2k boost + nitrous?
- Custom kit: how cheap is it possible
- D16 turbo piping?
- Just got my setup and have Questions! idle, etc. HELP!
- Greddy E Mangment Unit SETTINGS?????
- White smoke, between shifts or high RPMs. What's going on?
- d16 turbo: Edelbrock vs Greddy kit
- custom intercooler piping
- boosted b20b
- Is it me or there's a lot of Hondata problems???
- IAT Sensor In Greddy Kit
- ef turbo guys .....i have a question
- what should be changed to hit a 10.9?????
- Autolink Motorwork Turbo Install?
- are shorty/log type manifold's any good
- Ebay intercoolers
- egt in downpipe
- Stock Turbo
- Inline pump or intank pump with FMU IN 94 CX HATCH pump never changed.
- OPEN LOOP?
- Does this oil return line look ok to you guys?
- Anyone used this? (DTAFast)
- Solenoid ???
- Situations with Tial 35mm wastegate, and joe P MBC. please help!!!!!
- hack questions
- afc whit 310cc work??
- Got a big decision: Turbocharger or Supercharger.
- B20/ Vtec ??? how much boost can it handle ...
- missing link? bypass valve..
- Which fuel pump??
- Is this junk?
- Fluidyne - Turbo Setup
- Edlebrock d16y8 fit d16z6?
- Clutches, I know it's been beaten to death...
- boosting hesitation
- manifold....
- uberchip+s-afc=retarded or advanced ignition
- What next, before boost?
- Anyone try ( or plan to try ) edelbrok's new SOHC intake ?
- good d manifold for 300?
- Well I finally drove my Turbo'd SE-R!!
- Is your FMIC big enough?
- i want the WRX BOV sound
- Best Turbo muffler to buy?!
- turbo EXHAUST question..HELP!!!!
- PREVENT blowing motor on turbo car
- HOrrible sound from transmission..diff bearings?
- why top fuel cars run supercharger instead turbocharger ?
- Holy monster muscle, Batman!
- which type of walbro fuel pump???
- Starting my turbo project...
- help! what transmission set up to use, when boosting?
- finally boosted!
- Ghetto underhood IC ?
- HELP! I just drilled into my block! *Dumbass of the month award*
- limp mode 2500 rev-limit after skunk2 intake mani install.
- what is everything u need to install a turbo in ur car?
- how much boost can stock B18B sleeves hold with block guard?
- Intank Fuel pump - troubleshooting
- PICS OF MY PROGRESS! (Turbo)
- stock B20B + blockguard vs. BOOST
- JRSC/Alternator install problem.
- built turbo motor question
- Engine Whining Sound - Please Diagnose *VIDEO*
- When to stop boosting .....
- BOV on intercooler?
- Weird fuel problem with Hondata
- HKS BOV ?'s
- 190lph or 255lph HELP
- Large Intercooler
- Reliability
- what size turbo for b16
- Oil line too close to dumptube = no good?
- drilling fuel rail please help
- Best bang for the buck fuel management on ZC DOHC turbo 15-19 psi
- new turbo
- Lightened flywheel for turbo y or n?
- Welded Diff in RWD application? (repost from Tech)
- Question: Turbo wants to spool but car hesitates and bucks under acceleration
- FMU/Fuel Pump Problem
- AFC HACK ?'s
- Need some Advice on a D16Z6 Setup
- Opinions on High Compression Setup
- Injector brand...do they really make a difference?
- help me identify these injectors, pics inside - please!
- Aeromotive fuel pump ?'s
- Crane cam for SOHC
- who makes 3.5" inlet muffler ?
- most prob. with custom kit!!
