View Full Version : Forced Induction
- Quick Radiator question...
- the block is finally done!!
- I want an exernal wastegate..............can I?
- SR20DET, help on turbo pick
- where can i get a good turbo kit for cheap?
- what boost levels can d16 pistons take....what happens when they fail
- SMC Tuning
- how do you raise the psi on jrsc?
- Forced induction with high compression
- dsm injectors...how much boost
- el cheapo wastegate,anyone seen these?
- VAFC Settings for D16z6
- Need ECU for Hondata
- Found out while my tranny blew - Blown diff
- can a b17 be turbo charge ..
- junkyard turbo
- hardlines vs. braided lines for oil & fuel
- Owned by white smoke!
- H22a turbo dyno #'s
- I know it's beaten to death but... really.. i have d series motor, do i use zr or br spark plugs?!?!
- OT: Mods I Apologize Chip Programmer Orlando/Gainsville
- Tial Fire ring gaskets?
- This one's for Full-race
- Help! What can i do with this??
- will a 3" dp fit in here
- DSS axle grease?!
- strange hondata issue... hondata's support didn't help
- Making my own octane booster
- California Hondata Tuners???
- d series question
- Anyone have a deal on rods and pistons??
- jackson racing supercharger kit require hondata?
- ls/vtec plus a little bit of nitrous...need nitrous advice
- wastegate size... is 40mm big enough?
- WTF! Boostin lean!
- largest turbo's
- My car seems slow as dirt
- AEM Calibrations
- Tial wastegate question?????
- Can you use a Boost Controller w/ internal wastegate turbo?
- EMS help...
- Ngk's and turbo.
- 14b, dsm450, smc500, walbro255lph pump
- Turbo ZC?
- intercooler piping
- Can someone please post a picture of their check valve setup?
- Inline or Intank fuel pump?
- How much boost on stock GS-R rods?
- anybody know where i can get these cheeep!!!
- Defi A/F gauge????
- What size injectors with afc hack?
- Can anyone tell what oil pan this is?
- White smoke at idle only on cold start, yes i searched.
- OT: 97 GS-T oil in charge pipe? help
- Help with Greddy turbokit install
- Experience with Endyn stepper pulley with JRSC?
- help!!! need to figure out what is wrong with my turbo
- Saturated vs Peak and Hold
- greddy turbo install help please ;]
- Which of these weld fittings can i do for my oil return on TURBO?
- What injectors to run with JRSC?
- Oil fittings kickn' my ass
- golden eagle cam gear torque?
- BSPT to NPT adapter for back of block
- where to buy wastegate springs?
- fixed blown turbo... starts to stutter under boost.
- Race Enginerring???? GOod or Bad?
- Best bore for GSR Turbo Setup
- What's wrong with this picture? Headgasket
- ... planning stages... - 12 sec - 50 state street legal - crx - ... on a budget...
- 2.5 DP and 2.3 piping!!
- Accel DFI Gen 7 Sequential Stand Alone
- my car doesnt want to start ... :(
- more and more questions
- JACKSON RACING PRELUDE: WHAT KINDA AFTERMARKET INTAKES FIT?
- Blowing....FI E/M fuse...
- sleeve it or not?
- ebay manifold
- How to chip OBD1 ECU
- hondata + greddy turbo kit
- Power FC
- need turbo advice.
- need help, dont know what is going on
- Anyone use one of these manifolds?
- B18B into 92 Si - Help needed on parts etc...
- what fmu for homemade turbo kit on stock b16
- a few concerns about the greddy SOHC kits...help please
- Vibration with 3" downpipe?
- Need helping hooking up a Blitz Fatt old style turbo timer for integra
- Here's it is, GATOR RACING AXLES !!!!!!!!!!
- sc-61/.76 trim. is it good.
- What would you do....i need some help!!!
- Precision screwup?
- Car just recently started Shutting off while at idle(sometimes) what could it be???
- Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male
- mike @ majestic turbo #1
- What coolant W/ copper headgasket?
- what kind of sleeve is this??
- Advantage of divided exhaust housing?
- hondata
- Supercharger?
- Do you HAVE to run a filter on your turbo? Please post pics!!
- CPR injector fit issues...
- Last Day Before PWR Price Increase!
- headwork on turbo engine vs. N/A engine
- t3/60-1 Help/info needed...
- turbo or not to turbo? gsr trans or ls trans for turbo?
- Who in Arizona needs their car tuned?
- Need help hanging intercooler on 94-97 integra
- tial wastegate w/ turbo xs mbc setup
- Turbo question (n00bie)
- Going From 81mm to 83mm, which Headgasket?
- went to the dyno SpeedPhreak Help ...
- Head Gasket Sizing with bore?
- OT: How To Package a Turbo Kit to Hawaii
- What can I use 5/16" Stainless line for? What -AN is that?
- reliability?
- noob just starting
- MBC problems: it will spike to 7 psi then go back to the normal 5 psi that I run
- oil lines
- Help 15:1 a/f on 95 gsr with drag gen 2 kit
- how to prime a turbo correctly? help here!!!!
- vsracing gone? where can i get some 720cc injectors?
- MSD BTM #5462 Universal
- :: smc500 users, i need directions/instructions ::
- need opinions on options for break-in!!!
- What's the "blue wire mod" does it work? Is it good?
- started turbo install: ?'s Reg. VAFC install and turbo/manifold bolts.
- can u guys post results and experience w/SC61 or SC63 turbo
- Turbo Sol Burning some oil?
- compressor maps for precision turbos?
- **Does Painting an Intercooler Black, Decrease Performance??
- Who makes Climax fuel rails?
- ... tire recommendations for daily driven street use and occasional track use...
- WTB Hondata For JRSC
- O2 @ 0.1 and lower during idle, safe to drive?
- Need Help w/Dishcharge Flange
- intercooler hangs too low
- Got another turbo today...and have no idea what specs it is
- d-series turbo, How much hp?
- Hondata Small Chip Required?
- Pics of T3-60-1 on B18C1 block
- turbo timer 12v constant location???
- Nitrous Blow down tube placements? Any ideas?
- LOOKING FOR HIGH TECH EXPERIENCE. MY CAR WONT START
- Misfiring w/ Greddy Blue Box
- B18C Project Turbo Motor Build Up
- How often should i change my ngk v-power copper plugs? Turbo prelude....
- Greddy Heat Shield Bolt
- how much boost are the ford smic good for?
- Interested on people's thoughts about the Greddy turbo kit for a 97' GSR. Any good?
- obd I conversion, now detonation and cant boost. >>
- for the big boost heads
- Video request: JRSC Civic / Integra
- hondata trouble, won't connect, did connect once before
- 440cc+FMU+Missing Link+VAFC = Too much?
- D-series turbo & A/C possible?
- Bad Day for Burke!!
- My car is running without a fuel pump HELP
- just a little turbo clocking practice I've been doing lately and T3 work :p
- Thread pitch for honda head exhaust manifold studs?????
- A Complete How-To and Guide: Aeromotive FPR / Injector / Stainless Lines Install / Parts List
- and good hondata tuners in upper FL
- putting stock o2 sensor before turbo,good/bad?
- When will the DBS System Be Available
- Dumb noob question
- finally
- Anyone have a GSR block with LS crank in it?
- Hmmm.....boosting on stock GSR pistons. How far do I take it?
- Aluminum for exhaust?
- cam shaft installation
- anyone have pics of fuel sump with external fuel pump?
- what is the best material for a manifold?
- Is this a good Flow Chart
- FMU???
- any truth to the vafc hack using sensor type 14?
- lets talk diy dual stage boost controllers
- Need help finishing my custom turbo kit.
- ***OBD-2 96-00 Civic EK DSM 450cc Injector and Resistor Box INSTALL***
- Help on what engine to build....
- JRSC type R @ 10PSI= 245whp/170wtq
- turbo setup, need answers
- Whats the formula for figuring out injector size?
- Weird problem while tuning hondata s200b
- Hondata Base Map
- cold air intakes for the turbo
- No love.....
- turbonetics godzilla
- need help with zex kit
- missing link questions
- turbo b20 a bad idea?
- Shows Boost on gauge but doesnt feel fast ?
- Where can i get lower heat range spark plugs in TORONTO
- high comp management
- blue box or afc hack with greddy kit?
- whats a better jrsc setup...
- SUPERCHARGING: Boost Timing Controller and MAP Controller question...
- civic downpipe question
- Help with my turbo setup
- e-manage greddy kit sohc quick q.
- Going for my goal for this yr, need advice
- PIC of all yal goodies Honda out there!!!!!
- My Full Race Christmas in July!
- p28, hondata, how to check codes? crx
- Stumbling in boost and sometimes idle
- Won't run on 75lb injectors...
- D16y8 turbo problems...?
- will d16z6 JRSC fit onto y7or y8???
- alternator stepper pulley install JRSC
- AEM EMS 1.03
- Is it possible to detonate in vaccum?
- does the msd sci really make a difference on boosted cars?
- fuel pressure dropped then back 2 normal
- o2, 4 wire, white, white, grey, black, will it work with P28 + hondata?
- where to get copper header gasket?
- anyine in NJ/NY/PA/VA/MD/DC that can part with a b16/gsr trans? PLEASE!!
- clipping a turbo
- SSautochrome 1992 - 2000 Integra Type-R 4-1 Race Header = Kamikaze???
- How can tell 1g DSM BOV is crushed?
- Just installed my Turbo here are some pix
- need h22 turbo manifold
- SSAutoChrome make a kamikaze header???
- Were can I get a Male to Male 1/8 BSPT Fitting, locally?
- Water temp @ the drag ?
- dsm450 14b resistor car wont start
- Help - ARP Rod bolt torque spec
- How to Clean the Engine Bay w/ a turbo kit?
- can't boost past 3psi all of a sudden
- How much boost can stock headbolts take??
- turbo project numba 2 lots o pics
- finally started up but some problems occuring!
- adding a BOV to the greddy charge pipe
- jg IM throttle cable too short
- grinding the block?
- post up about your STOCK motor Boosted wonder !!!
- EG Fuel Pressure Question
- saab t3 turbo??/
- Is It Possible?
- intercooler piping question
- Ls/vtec ..and turbo
- max power with 550s
- d16y7 turbo guys, quick question?
- Two plug questions: Who long does it take a plug to get color? Whats the difference in carbon and al
- Uhhh.. Is it my car or has my EGT gauge gone nuts?!
- representing Honda Turbo Power on the real TRACK (circuit), VIDS and PIX
- Intake Question!
- Leave homemade log manifold raw or engine paint black
- oil in my intake?
- Nitrous do's and dont's ????
- Suggestions for FI?
