View Full Version : Forced Induction
- stainless steel ball bearing or ceramic ball bearing?
- B-16 Greddy 18G manifold which other turbo's can I use with this manifold ? ? ? ?
- GSR turbo.....help?
- inline pro mani and sc63 placement
- Turbo hp increase what do you think
- i did a compression check...
- H22 Blockguard enough to run 15psi daily?
- pr3 pcm with boost possible wit turboEDIT?
- Built bottom B18b with a good turbo for 400HP-450HP?????? HELP
- F.A.S.T. Bank to Bank Injector harness?
- motor & turbo install
- Is this turbo too much for my set up?
- throttle body bottle neck or not
- Incorrect Block Guard install>>?>>
- frankenstein turbo kit
- clocking turbo
- ve a
- 2.5" downpipe with 3" exhaust.........will the dp suffice?
- bigger injectors and fuel pump a must?
- hrmmmm Ecutout always open=- water out the exhaust ?
- what kind of oil to use with boost?
- Greddy Turbo Timer
- t3/60-1 vs. sc61
- BLITZ BOV flanges, difference from newer version and previous?
- can't gap my spark plugs to .030
- NEED: 2" to 3" test pipe
- Blitz bov makes some kind of fluttering sound???
- D16a6 Project Car
- Where are people getting stock bore forged pistons?
- Does b20 go good with turbo
- jrc intercooler question...
- anybody dealt with JG Engine Dynamics blocks?
- misfires - too rich?
- what rings for H22?
- Exedy Hyper Single? good for 250tq?
- T3 3-Bolt Discharge Flange (Internal Gate)
- Question about boost controllers special Greddy E01
- Quick question. How do I find out what the ratio is on my JR FMU?
- cheap mani
- help with injectos for D16 turbo
- Stainless steel Or Mild tubing for IC piping
- Blown turbo?
- what fuel pressure to run?
- Just Bought My First Turbo Kit ....
- OT: Supra TT - AEM EMS, Twin T60's, etc.... (plots)
- help with my setup!!!!!!!!
- JRSC Alternator Stepper Pulley Size
- b16 sir2 what size turbo?
- what difference is between gt3035 and gt35r?
- what turbo is this? help needed pic inside
- sleeves
- Guess my Tubrooooooo (pt2)
- Are there B-16,s out there running a greddy 18G turbo ?
- Is any one pushing low boost without an intercooler ?
- tuboxs MBC. which one should i get? standard or high performance?
- wastegate, boost controller, boost gauge, bov vacuum sources
- to fmu, or to not?
- NOS JET QUESTION
- driving on a previously tuned hondata. not my specs...
- how much of a loss n/a with a 3" exhaust
- spark plug heat range and gap??
- CIVIC "D" GReddy STYLE TD40H-15G TURBO KIT (SSautoChrome)
- *nutha shitty gas milage question*02 related..
- Turbo exhaust question
- ngk spark plugs
- idle up and down after new motor? Whats wrong?
- ground wire for oil pressure gauge....
- Greddy Turbo 7psi Do i need to do anything with my ignition?
- HELP!HELP! turbo installed-Smoke, AHHH
- blow off valve not sufficient... just buy another and have 2 or one good one?
- greddy turbo timer install..speedo wire???
- SS collector
- Turbo setup in works on d-series...please help
- recently installed turbo kit, wont boost past 6psi
- 3rd gen prelude turbo
- SSAUTOCHROME has a new turbo manifold
- Whats a good piston/rod setup for a stock 81 mm bore B-16 ?
- What 5bar map sensor too use with Hondata?
- most power with vitara pistons
- need help for settings on greddy emanage for rsx type s
- Annalyze my motor...
- Boost solenoid and the Aem ems?
- Is Something Missing?
- cam lobes?
- Opinions on T4 .70/.82 on Ls/vtec
- rust inside charge pipes
- Peak Boosted SI Dyno
- whats the best b.o.v??
- Removing tuned JRSC. Can hondata be ran with a stock setup?
- Rear mounted Turbo!
- no muffler ticket... :/
- dsm 450cc and the manifold?
- max CC for SAFC?
- T3 turbo...what to get...4 bolt 5 bolt? What does A/R mean...what inlet/outlets are good?
- 3" cat
- what muffler?
- RC Injectors Question
- Stock Greddy Downpipe w/ Thermal exhaust
- How to install a greddy profec b spec2 boost controller in an EG?
- Analyse my clutch...New clutch,Flywheel and LSD installed
- F20B Boosted.
- anyone make their own manifold?
- Which pistons r better with ZEX?
- greddy oil filter sandwich adapter for feed line?
- 88 crx sohc turbo
- discrepancy: peak and hold injectors using resistor box vs wiring resistors inline.....
- what wideband?
- $ for $
- b16a2a Turbo
- Injectors that require no resistors inline/box?
- Half Core Radiator with Peakboost turbo kit?
- Zex Man's Transmission?
- OBX Intake used for High Boost and Direct Port??
- Any Ideas on how to cool Intake Temp of Supercharged B18C1?
- how do u make a hyperlink?
- boost goes from 8-4 psi at high rpm
- need help ?
- AEM EMS Tuners - MSD and coil dwell... another MSD bites the dust
- Why didn't my larger wastegate spring increase my boost?
- HKS EVC III BOOST CONTROLLER PROBS....
- HKS T51R on street integra
- t3/t04e oil reutrn fitting size?
- smoke
- Going from JRSC FMU To Untune Uberdata>
- limited boost issue
- not a honda, but just wanted to show everyone... MKIII 20v t3/t4
- plx m300 wideband question???
- can the revhard manifold replace the drag mani in the drag kit?
- oil burning ?
- Suggested spring rates for my 400whp+ ITR.
- 310cc injectors
- turbo for 250whp on a gsr?
- Short Tubular Manifold from Rank1?
- Ironman Strip Series 1680 clutc....Got ?'s...
- Greddy EManage, just want it to work!!! HELP
- greddy sohc kit! wiring diagram needed desperately
- any supercharged d series
- The "CORRECT" LS/VTEC Headgasket
- Exedy makes ACT clutches???
- check engine probs when boosting
- Need help. who should I go with for a sleeve job?
- Brake Specific Fuel Consumption
- ZEX
- emmisions somthing wrong!
- water injection people
- Opinions on exhaust idea
- uberdata question, my p75 doesnt have an r54 to solder into
- .::What do I use to Burn my own chips, using Uberdata??::.
- Darton Sleeves 1.6 SOHC
- Highest HP on a SOHC turbo.
- Accord V6 Comptech SC suggestions?
- Hey guys, what's the tech. name for my engine?
- How much boost is safe for my car?
- Turbonetics Turbo Manifold?
- Looking to Boost my Civic Hybrid B18b1 with JDM B16 tranny, what turbo would you recommend?
- D series rods for turbo build....what to buy?
- Should i boost?
- where to mount oil sender....
- "closed,open" deck block?
- Cusco oil catch can?
- Greddy Oil return line SOHC size *learn the hard way*
- does drag have their own line of turbos?
- clutch question
- Buck02 Limit straps & 3.5 and 4inch Exhaust
- 802whp SPFWD !!!!!!!!!!!!!!!!!
- solid 6puck on daily driven ls???
- which turbo for a ls turbo
- After turbo install, getting check engine light.
- Urgent!: Code 14 IACV after turbo install. rough idle
- D series Oil Pan Q's
- Zeitronix Zt-2
- ls sc61 peeps
- wat if i
- ANOTHER blown d16 headgasket?
- b20vtec turbo..
- My car is shaking? and What happened to turbod16.com?
- Any Experience on a full-race T3/T67 H.O. on a B series motor
- keep my turbo or go bigger?
- Shopping list for Full Race Kit 1GT, management/controllers, etc.
- F20B Turbo
- Idle problems after boosting???????HELP
- Is my IAT sensor going bad or something?
- gettin ready to turbo the ls/vtec....
- how much did your turbo setup cost you
- ALL Nitrous, what header?
- Does it matter where I drill my oil pan .. if it's as high as possible on the deep part?
- Thread size - T3TO4E Garret
- does it matter which way the BOV is facing?
- Dyno Preperation
- Supercharged GSR exhaust question
- GSR turbo questions
- JDM d15b n aftermarket d1b7
- b20vtec project
- need help quick cp piston ring question tapered side up or down.
- engine management besides(uberdat,hondata)?
- greddy knock off
- Did i get scammed? used turbo timer
- Which AEM EMS to use for K20Z1 (2005 RSX-S)?
- turbo h22
- ls turbo or ls vtec
- Spiking with 3"DP on Greddy 18G?
- what oil for turbo d16 ? (Castrol .V.s. Royal Purple)
- What Else Is there...
- best clutch from exedy for a 95 integra ls turbo...
- M300 or equivalent pointless to have long before tune?
- JDM b16a themostat and temp sending unit??
- Full Lenght Tubular Manifold with no Brand Name on it.
- turboedit please help
- H22 Turbo Head Gasket Blown?
- Oil backing up solution.
- emission problem on stock b16a2
- d series obx intake manifold? (new style)
- most ls engine whp
- MSD Knock Alert discussion
- Quick Diameter check
- What else do I need?
- project complete pics inside re-dyno soon LOOK!!
- greddy profecB vac line help
- Saturated or peak and hold? gt28rs turbo on b18c1
- Copetition Traction Bars
- Spoolin' Dyno Numbers - Stock JDM B18c
- Stock Boosted H22A...blew pistons and rings...what should i replace with? Tune/No Tune?
- What flange is the holset hx35?
- Header ? for all the JRSC/Vortech owners
- flat top pistons?
- what letters are stamped on non vtec 402t cams?
- Confused about head bolts and studs(searched)
- is there something wrong w/ my walbro 255lph???
- GT28RS Housing Nipple?
- Car No Startie Startie!
- My new setup ...
- car fucked up, what to check,
- Got my GT40 turbo in today. Comparison pics to my 60-1 turbo
- SC61, stock jdmb16+ shitty vacuum line= not good
- how is important is the gasket between the turbo and the downpipe?
- Apexi oil retun line?????????
- spark plug pic, this mean's lean right?
- Is my PCV theory correct?
- Attaching BOV on chrage paipe
- JRSC won't boost sometimes
- where does the wastegate nipple ont he 18g connect?
- JRSC ITR intake fitment problem!
- welcome back ben@importparts
- insulating engine from excess turbo heat.
- moates.net burn1 problems he wont reply my emails need help
- d16z6 on 75 block, do I need a obd1 dizzy?
- Uberdata dyno tuning? in the southeast (SC?)
- Which Drag Radial
- Anyone in Jacksonville NC?
- Ignition Setup what to chose?
