View Full Version : Forced Induction
- Blue smoke issue
- Oil pressure problem?
- New to tuners.
- Anyone running a catchcan can help?
- Boosted high HP DDers? chime in!
- 5857/5858 on H22
- Turbo failure breakdown: Why proper maintenance is critical on turbo motors
- Real World GTX3076
- Any thoughts on the Garrett's GTW lineup
- blown turbo oil seal?
- How much YOU made with NIPPON vitaras?
- Very Rough Idle NEED HELP!!
- DT race division vtec lock kit
- Chose to boost my D16. Advice vets?
- sx400 rebuild kit
- My B16 turbo build looking 500whp
- Best D16 non-vtec head for turbo?
- b18b1 stock timing map
- Looking to Turbo a Honda
- Water cooled lines setup
- Fully built Turbo help with shifting/traction
- Garrett GT2871r .035 oil restrictor BANJO TYPE
- (laskey)99 civic ls/vtec s 300 randomly won't start
- Ls (B18B1) Turbo T25
- Advanced Online Turbo Calculators
- TURBO 101 - BASIC Information for 1st Timers
- lsv turbo
- Garrett GT2871r turbo
- fuel press reg and boost gauge vacuum
- mini me turbo crx issues
- E70 winter blend question
- P2W clearance?
- 1999 SI B16A2 Stock Trans. Which route worked best for you to have longer 2nd gear?
- y7/y8 minime turbo questions
- My new turbo b16a2 setup barely making 300hp after tune??
- turbo question
- Boosting Stock Z6
- performer x injector holes porting/blending
- Troubleshooting Turbo Integra
- JRSC Rebuild help!!!
- Fender exit exhaust
- B20v tapping noise
- d16z6 stock. turboed.
- D16 Turbo build, need input.
- New Turbo Needed...Looking for 400 whp with Good Midrange. Input Needed
- Power level estimate with similiar setup?
- Random issue of starting/dying...fuel related maybe??
- high comp nitrous
- Help with break in of new motor
- Wastegate exhaust covered?
- Opinions on good shops for head work, and compresion ratios for boosting with a JRSC.
- d16 turbo build
- 1996 b20b turbo civic
- divided vs undivided a/r
- oil cooler?
- B16A Del Sol Turbo Build
- need help to identify turbo *pics*
- question about Precision turbo
- What may be the most powerful Roots-blown Honda in the world?
- how much power
- Ignition breakup (aemv2, k coils, epm)
- walbro 416 lph intank
- 1996 Civic ek
- 94 accord turbo question.
- ok honda tech 'splain this to me
- >>Hondata s300 Rolling Anti Lag <<
- bwr manifold question
- I'll Be Back....
- Vanjen clamps for IC piping.
- bwr manifold v2.0
- Turbo Kit
- High compression boost question
- 125whp out of a 75 shot on a 300+whp K24
- B20vtec tapping noise
- A comparison of a billet 5731 and a billet 3076
- Confused about the type of turbo I have?
- What cc injectors for h22 turbo (SC60-1)?
- Routing rad expansion hose across turbo?
- Wastegate flutter? compressor surge?
- 1994 Del Sol SI options
- BRMS Ramhorn manifold pros /cons
- vacuum block manifold
- 921HP K20 PTE 6870 Mr2
- gsr main bolts?
- D16z6 TURBO DOWN PIPE 02 SENSOR PLACEMENT ECU CONFIGURATION/DATALOG O2
- Greddy boost and EGT go for?
- oil return slope. good enough?
- which IM better? blox(itr) AEBS victor-x or other?
- What turbo to use !!
- turbo advice
- evo/dsm manifold on h22?
- Build Advice (H22)
- Electronically 'turn off' turbo?
- help with internal wg actuator
- n/a cam in vitara d16 turbo
- Turbo LS-VTEC Civic - Idle surge
- B18B turbo daily, reliable questions
- Garrett Turbo Questions
- D16 turbo setup...what spark plugs to use?
- Product review for Calyx
- quiet exhaust for B18C turbo ITR
- precison 66266BB divided vs undivided i have both exhaust housings
- Right setup for a B16A2 with 10:1 pistons and spools around 3000rpm
- my LS turbo, power to cost opinions?
- HELP?!!?!?
- using the rsx retainers on boost. .
- GM Style MAP Sensor - Please Help Identify
- B16a2 oil pump
- Gas Mileage? what you got
- questions about 12.5mm lift VS on gsr cams
- D16 Turbo Kit for 2004 D16W7
- D16z6 75.5mm vitara pistons/eagle rods knock re build.
- Turbo D16Y5
- EGT sensor with s300
- Turbo Civic
- spooling and boosting late
- finnally hit the dyno and actually survived.
- Front bumper exit exhaust
- Shopping Parts list to install an Ebay Turbo?
- 95 eg turbo not revving past 5k need some advise
- moving along on build contemplating e85
- What happened to synapse turbo /Motorsports
- help me pick right pistons
- ZC SOHC 1.6 VTEC turbo questions?
- boosted d16a
- rotor to cap gap, spark blowout issues
- More power. Turbo upgrade?
- Supersilver's DC2-New Build questions: new goal 677whp
- T-Bolt Clamps
- new d16z6 turbo build but smoking?!
- Compressor Map Assesment Help (Little-No spoonfeeding needed, promise!)
- Want more power, should i go e85?
- Engine build time...
- D16z6 turbo rebuild?
- Opinions on a draw through turbo system
- B16A3 Turbo Build - Double Check Before I Start Buying
- natural gas injectors repurposed for turbo?
- Question for turbo build on piston rings.
- The feeling of 'loss'
- leak down test results and considering rebuild Qs
- high IAT with Supercharger
- Want to Turbo
- Best Throttle Body for Victor X???
- Oil Squirters for Turbo??
- B18C stock ignition good for 300 whp?
- my new garrett
- blocks and boost
- Suggestions on intercooler/WG/BOV setup for 400whp
- Fuel rail with injectors question and FPR question
- Golden Eagle or Edelbrock Victor X
- My d16 turbo build finally finished!!
- 14 psi on Nippon pistons ok?
- Help with my fuel setup for 500whp to 550whp
- Forced Induction Detonation Damage?
- Turbo b16 build suggestions
- POOR PERFORMANCE
- honda noob needing advice
- B16 LS Vtec Turbo
- TiAL MVR issues with bwr dumptube.
- B16a2 want to turbo
- Good turbo or junk? Help
- College student TURBO Build!
- from all motor to forced induction?
- Idle and drivability of 2000cc injectors. Are these to big to run on pump gas ?
- What is the best cams for turbo
- who makes pistons with less than 30mm compression height in 84.5mm diameter?
- new howling noise under light boost
- Turbo for 05 accord v6? Where to find! Possible?
- Compression ratio for s/c
- B16B TYPE R BOOSTED SAFE WITH STOCK INTERNAL?
- Looking for hard to find part...On center turbine
- Turbo Integra Oil/Antifreeze smell
- B series parts
- 500hp crank hp turbo reccomendations
- JDM B18C-R Turbo questions
- EXACT COPY of the Inline Pro Manifold??
- GT2871 - Is this turbo suitable for me?
- Peakboost Topmount - what turbo are you running?
- GSR Steel Billet Crower Rods
- Clutch and fuel setup ?
- Greddy 15g kit
- who assembles your engine?
- GSr tranny vent leaking help
- NEED HELP PLEASE READ
- OK GUYS I'm NEW TO THE HONDA GAME
- EG B16 build turbo suggestions
- H22 Turbo Build Suggestions
- Any Turbo Build Suggestions On My Setup?
- Why not oem pistons
- H22a1 bearings ???
- What size oil restrictor for my turbo?
- eBay rods
- TRACTION!!!
- skunk2 megapower good for boosted?
- first d16 turbo build
- Stock Sleeve Build....Turbo?
- Does it look legit? (KKK turbo, need help here)
- Help me pick a cam. turbo B18C-R.
- precision turbo rebuilds
- Ls vtec not holding boost at high RPM's
- e85 on a stock boosted b16?
- b18b1 engine rebuild, turbo set up
- Boost controllers
- 9:1 SRP PISTONS
- b16a2 vs evo. gtr. v8
- BOOST CREEP.....
- Boosted eg hatch code 22 after 5k rpm
- Closed deck block.
- 00 civic b16a2 turbo build questions
- VHT flame proof rattle can for turbo.
- FIC 2150cc injectors
- NA goes 10's Now What?
- Turbo set up for F20B DOHC?
- Clutch selection (Tq-capacity vs. material, surface-are and pressure)
- Replacing turbo 5831 or .60 trim
- Throttle cutting out!!
- 98 Integra Built B18 T3/T4 on 10psi. 310hp What Clutch?
- Making oil feed and return h22
- need help choosing injectors
- 92 hatch wont rev past 4k
- 96 ek boosted b16a
- High Compression Jrsc B20vtec Build
- Gringo's new found power. PTE 6466 827whp/479tq @29.8 psi!
- Skulled's EJ6 Turbo Single Cam Build
- Kinugawa Billet Adjustable Turbo Actuator
- Relocating bseries oil cooler / mounting and black breather box?
- d15b vtec stubles under boost
- help with NX wet kit install
- vortech 2 liter civic on hondata webpage. mounting
- 500bhp Civic EK Drag Car advice
- 92 civic turbo - noise
- Idle issue after a pull
- Injector size question
- itr ctr cam losing hp with mini ram and log?
- Boost creep problem
- What rings to use?
- 93 delsol built turbo will not idle
- How to remove dry sleeves?
- '88 sedan Turbo B20V boost control question
- B20B GSR Head Help?
- SOHC Hesitation in the Higher RPMs
- tfw ethanol in cold weather (help) (E85)
- Turbo Parts List
- Turbo B16a2 Build
- GT35R with T4 Exhaust Housing?
- Precision 6766 JB thrust bearing failure.
- Does the oil return have to be steel braided hose?
- b16a2 turbo build
- Turbo casting
- Adjustable Cam Gear Questions
