GT2860RS with e85
Old Aug 26, 2015 | 11:58 AM
Boostage's Avatar
Default GT2860RS with e85
Would there be any benefit to this on a street car? its a b18c. Im asking because Im about to buy injectors and needed to know if I should get biggers ones for e85 or smaller ones for 93 octane. I plan on maxing out the turbo.
Old Aug 26, 2015 | 12:01 PM
DC4KiD's Avatar
Default Re: GT2860RS with e85
Just get 1000cc injectors and be done with it.
Old Aug 26, 2015 | 12:05 PM
Boostage's Avatar
I have no problem getting 1000cc but has anyone been able to squeeze a little more power out of a disco potatoe on E?
Old Aug 26, 2015 | 12:49 PM
turbohatch96y7's Avatar
You can only push so much air with any given turbo <br /><br />you might be able to squeeze a small amount more since e85 slightly bumps the compression up and allows more timing <br /><br />I wont think itll be crazy amounts tho <br /><br />What ems you running tho?
Old Aug 26, 2015 | 12:50 PM
Boostage's Avatar
Haven't decided. Thinking of hondata
Old Aug 26, 2015 | 03:22 PM
wantboost's Avatar
Who is Mr Robot?
That turbo won't perform much differently than on 93 octane. You might be able to run more timing in places with E85 or 93 with water/meth injection but you will easily reach the limits of that turbo on 93 octane.
Old Aug 26, 2015 | 03:32 PM
B20VtecVillain's Avatar
Agreed. ID1000s are great injectors. As far as E85 vs gas with that turbo it really isn't worth the trouble for an E85 build unless you plan on going bigger in the future. I was nearly maxed out running a disco potato on my built SOHC using straight 93 Pump and 750cc injectors a while back.
Old Aug 26, 2015 | 03:58 PM
Boostage's Avatar
Is 10.5:1 ok to max out the turbo on 93?
Old Aug 26, 2015 | 04:39 PM
F22Master's Avatar
Do you already have the turbo?
Might want to look into upgrading the comp wheel, but that will still run you several hundred dollars...
Old Aug 26, 2015 | 04:54 PM
Boostage's Avatar
No I didnt buy it yet. But Im looking for response more than top end. And from what I have seen there seems to be no other turbo that provides this kind of response it being a 35 lb per min wheel and all.
Old Aug 26, 2015 | 07:30 PM
wantboost's Avatar
Who is Mr Robot?
You won't make 350 though. Remember that's basically rated at crank power. You might get 220-230whp out of it at most.
Old Aug 26, 2015 | 07:34 PM
Boostage's Avatar
Are you sure? A few people here have made 350whp and I think rcmacdaniels made 380. Either way a 35 lb a min turbo should make at least 300whp
Old Aug 26, 2015 | 08:22 PM
TheShodan's Avatar
Moderator
320whp is the limit at just a bit over 20psi at the outer edge of efficiency range, regardless of intercooler... Anything else is reading high on a dyno.
Old Aug 26, 2015 | 08:23 PM
TheShodan's Avatar
Moderator
Turbine wheel is what makes the top end power. Compressor wheel affects boost threshold behaviour.
Old Aug 26, 2015 | 08:45 PM
Geis's Avatar
Originally Posted by TheShodan
320whp is the limit
lol?
Old Aug 26, 2015 | 09:25 PM
wantboost's Avatar
Who is Mr Robot?
I hit the wrong key
5speeder
Sep 22, 2010 05:51 PM
ghostofnyc
Oct 11, 2005 04:07 AM
dohcter g
Dec 18, 2004 12:17 PM
QuarterMileMaster
Nov 18, 2004 12:15 PM
patdemps
May 11, 2004 07:57 PM
