View Full Version : Forced Induction
- need a good manifold
- GReddy Blue box help
- Nitrous system dealers...anybody know any canadian shops and URL's?
- a/f ratio question
- Anyone going to Street legals on the 16th in Fontana?
- Damn wastegate bolt came off again...
- apexi safc for turbo?
- Anyone use MSD Injectors.. If so any I would like some opinions..
- Thoughts on a Paxton FMU
- Turbo R Owners
- Vortech fmu 12:1 disc w/ 14psi
- Changing From TD40H-15G to TD05H-18G possible
- b20 jrsc ??
- can some peepz post timeslips from your LS turbo's and GSR turbo's???
- questions re: slicks and camber
- nitrous question
- Supra 550cc injectors, anyone use them?
- Smog check time...
- built ls head
- Hondata
- 94 ls turbo?
- how many shot cant a b18c cant handle?
- Custom Turbos
- modifying LS head for turbo??
- drag manifold
- HELP! Engine decision???? B16a2 with 84mm or 81.5 mm with Ls crank(Built with turbo setup)???
- wastegate sizes?
- Help with Turbo install (LONG)
- M&H slicks - info?
- concering the APEXi AFC and boost...
- help with nitrous kit
- Big Brakes on your Turbo Car What are you using ?
- Which Manfiold? SFP, MaxRev, etc?
- VX crank pulley OK on turbo D16Z6?
- Best price on bogart rims
- FMAX or DRAG?
- Fuel parts for turbo
- underdrive pulleys effect on turbo...
- DRAG III turbo specs
- importturbos.com anybody have onfo or experience with them???
- fuel pump flow rates? Where? I forgot
- Hondata?
- Drag II or Greddy?
- supercharger. easy?
- Radiator Cap (overflow)
- head gasket?
- Question for Eagle Rods
- which cams (ctr,itr,crower,...) should i use with my JRSC?
- Hondata for '01 GSR
- Oil pump replacement?
- Nitrous works? Anybody running this system?
- taking the plunge soon with pistons and rods...
- turbo questions(compressor map related)
- anyone know what the shift light for the apex EL tach looks like?
- how much compression will i have?
- IMPORTBUILERS.COM are they good?
- Looking for good 14x6-6.5".. anyone have?
- Manifolds
- USING Aluminum Soldering Rods to join intercooler entanks to the core??
- If you have a nitrous question...
- How long will a stock clutch last with a turbo?
- OT: Ben Gets A Lil Crazy
- greddy turbo kit owners... i have a question
- Where to buy K&N?
- DSM Injectors
- Previous JG cam problem - just wanted to mention it.
- How do you pack your block and who do you send it through?
- Hotter cams with turbo?
- what maintness to do with turbo???
- I have a 1g DSM Eclipse Talon Blow Off valve for sale
- I have a set of 1g DSM Eclipse Talon 450cc injectors for sale
- I have 2 DSM Eclipse Talon intercoolers for sale
- quick question about hondata and the boost option..
- Dyno in NYC
- I have -10 steel weld fittings.
- Can u boost in reverse..???
- what gauge pod for apex EL gauges.
- Parting out turbo parts
- waste gate spring??
- h22a turbo rebuild. best setup?
- FS: Eagle Rods, ARP, Block Guard...
- sohc running 12's
- Who drives what??
- inline pro head gasket
- Any you turbo gurus know KKK turbos?
- Speaking of Clutch's
- I can't make up my mind...ACT HD or XT????
- Clutch for Boost???
- Anyone got a 15psi HF manifold T-25?
- Zex and Jrsc
- Who needs a turbo?
- what is the function of the...
- wanted b18c1 short block running or not
- 3" stainless piping...where to ge it?
- Looking for a part need help
- efficiency rate on a turbo, anyone?
- Turbo Manifolds - Cast vs. Tubular
- What does the nut do on my deltagate if i loosen/tighten it?
- gsr turbo timer instructions
- load fluttering sound...
- Garret GT turbos on H22a?
- stock clutch???
- OBD Question
- Inline pro Stainless Steel Turbo manifold
- About an Greddy Type S BOV
- Rebuilding a Turbonetics T04/T3 ?
- Anyone know anything about tuning a standalone for a JRSC?? (AEM EMS)
- WHAT SHOULD I RUN?????
- Expected 1/4 time on my new setup?!
- What would this run?
- Adjustable cam gear on SOHC turbo?
- ne1 use a TD05-14B?
- Quick question about bolts on exhaust housing
- how many hp expect from a b18c at 16.5 psi whit a (td04hl-16t)
- AEM EMS
- a mitsubishi td04hl-16t good turbo or not? for a b18c or a b16a
- Hondata Dealer in NJ
- P28 ECU and Knock Sensor Q?
- Dyno Dya in NYC this Saturday Feb 16 ...
- defi gauges...opinions
- Downshift w/ turbo?
- what size slicks
- How To Adjust The HKS Racing BOV Type2????
- is this a good idea? for a turbo setup
- why is this with the TIAL wastegate?
- P28 ECU chipping for boost
- only 4psi???
- EGT gauge or A/F gauge?
- More Block Boring Questions !!!! how does ya engine know ya bored ! ?
- Compression test , help :>
- Technical spec... B18B long block weight?
- i have some boost probs...
- Turbo Time...
- Mugen Revealed - The secrets of the OBD I computer chip.
- I know someone asked this already but I cant find it
- Oil Pump Gear / Oil Pump?
- Fuel pump requirements with AEM EMS
- Tom, I need CRV block
- Turbo timers: APEX'i vs. BLITZ (pics)
- What characteristics make a good turbo intake manifold
- Name that TURBO
- stock b18c1 engine w/7psi?
- ITR LSD will fit my LS?
- Turbo Kit
- LS Tranny in a GS-R w/JRSC?
- IMPORTANT HONDATA GROUP BUY INFORMATION
- Car Won't Start...need help
- kamkazie header for jackson charger?
- Got ripped off by TurboDC2?
- How difficult is it to change my turbo from a T3/T4B to a T3/T4E?
- Whats better Turbo or Supercharger?
- quick Q on Airtex fuel pump...please help.
- HOW LONG HAVE YOU HAD YOUR TURBO?
- 1G DSM turbo manifold on D16Z6
- stupid question.. what does "ttt" mean??
- Does nitrous put the same type of wear on the motor as boost?
- Fluidyne Radiator fitting?
- Bay Area people (again) exhaust for turbo.
- CAI or short ram-air
- Wideband O2 Sensor Tailpipe probe
- Just dynoed my street car....
- i need help FAAST lik right now!!
- Windy riding
- AF ratio-graphs taken from sniffer...
- Not because of F&F but can someone explain "misfiring system"?
- Am I good to go?
- Tial WG open preasure change?
- JRSC and 50 shot
- austrian type-Rīs engine built up #1
- NoN Honda related: DSM fuel pumps
- Hey, Anyone who has tried to reach me for the past 4 days...
- Can blowby cause a turbo to blow?
- Beaks Mounting Kit for ITR Rear Sway Bar on a 5G Civic...Where to Buy???!!!
- DUMB A$$ CAR THEIVES!!!!!!!!! FOUND MY CAR!!!!!!!!!!
- I think I feel dumb, please tell me this is the problem.
- is it possible to get a CARB plate for a greddy turbo kit without buying the kit?
- Intercooler + cooling fan
- Headgagsket recommendations...
- Boring and HeadGasket sizes ????
- Looking for a CRV block for turbo
- CEL help needed. !!! Greddy turbo
- OT: Axles. Figured you guys would be the guys to ask.
- my oil pressure test
- Greddy type R BOV
- Anyone use Holley Injectors?
- Car smells like gas when I floor it.
- D16Z6 turbo
- car died out on street, help !!
- Turbo H22 civic gear ratios?
- Properly tuned...9psi is fine for an LS, right?
- reuse a stock headgasket?
- Car is hesitating...help me please.
- wideband o2 sensor help
- Whats the best sounding BOV?
- Did a search.. i'm frustrated.
- Help with Turbo Timer wiring
- Oil in Cylinder #3 & #4... Please Help
- Zdyne Gold ECU
- Just bought a new boost/vacuum gauge
- big turboooo
- Cartech FMU wrt wideband 02 values..
- B18B
- building boost earlier and holding it?
- D16Z6 head gasket for turbo
- Block Guards, Head Gaskets? Greddy Turbo in D16z6
- blew motor once again...JE pistons BROKEN...
- Anyone using an Innovative Turbo?
- You guys thing my block is still usable/fixable?
- FS: Manual Boost Controller and RC 250's
- Ok...so smoke coming out from Oil dipstick and valve cover breather hole...
- Safe PSI level for STOCK LS engine
- To anyone with the Autometer Z gauges...what do they look like at night?
- LS turbo w/mileage?
- Will my 12:1 FMU be fine wit....
- MaxRev Turbo kits. Questions on service, product, etc....
- need explanations on turbo size: A/R, trim, t3/t4
- spooling up t4 on b18c1
- anyone pushing 400+ HP?
- sleeving ls block
- Will a stock clutch effect dyno #'s on my turbo ls?
- turbo gurus please help
- Timing for 2000 Si
- know about JIC Magic stand alone??
- anyone with pic,s of type 26 or type 31 Greddy intercooler?
- swapping turbo center sections
- Exhaust question...
- what would you do in my situation???
- AEM EMS Review in Turbo
- my turbo LS dyno!
- Smog Check!!!
- has anyone done this?
- Pic of my 3' Custom Stainless Exhaust
- Would a "slight" blown headgasket = low compression?
- Low compression, but NO signs of OIL anywhere...
- RC injector O rings
- Please Help
- Test pipe w JRSC?
- JR map controller
- How common is belt slippage?
- Saab 9000 Turbo FMIC on a CRX...........?????????
- integralink ecu's
- best place to buy fmax or drag turbo kit??
- :******( MY CAR JUST GOT STOLEN!!!!!!!! :*(
- b20b with turbo. Help guys??
- Boost problem
- Alarm? Starter??
- need working cat from socal person
- OT: ATTN Si owners with bottom of bumper(grill) cut out:)
- Kinda off topic but FI related
- Looking for Supercharger basics
