View Full Version : Forced Induction
- I've got an oil leak
- Just did a turbo upgrade last night..........(OT Saab)
- Not sure what happened... B18C5 pop
- How many of you have sponsors??????
- Easy Hondata Question
- a little OT, but...I finally have my PATENT!!!!!!!!!!!!
- good place to buy GReddy turbos???
- im about to replace the rings ,suggestions ?
- need help finding a good turbo manifold for a h22
- OT:stripped interior, how did you get the tar off cleanly?HELP!!!!
- block guard bending sleeves???
- another update on my turbo setup....
- hard decision A crvtec BOOSTED?
- 96 Accord with h22 vtec.. looking to add turbo.. only can do part by part.. help w/ list
- got oil cooler....now what? :(
- How much boost can i run safely with stock internals???
- Missing Gaskets for DRAG kit??
- OT: Good news!!
- 2.5 or 3 for FI?
- compressor tap
- How many of you got your injectors cleaned, balanced, tested?
- Parts checklist for turbo D-motor
- What causes play in the shaft?
- Question on Profec-B and Tial External
- turbo comparison
- J&S Safeguard v.2 install
- idle fuel pressure
- Budget Turbo Kit
- What turbo to buy?
- venting EVO hoods are finaly in!
- hospital grade nitrous VS automotive grade
- fuel pressure wont hold!!
- controlling an internal wastegate....
- Hi Everyone...New to H-T and some pics
- 14b Turbos
- Corrected Hondata Sale Information!!!!
- Update on H22 ARP Head Studs
- Boost Controller question..
- where to get kiwi manifold?
- Exedy Organic clutch for my Drag3 stock GSR?
- turbo differences
- joe p manual boost controller
- Running without coolant lines to IAC and T/B ?
- help with the turbo
- Oil pressure guage question
- Blitz SBC-iD version 2
- Installing Injectors Question
- everything i need for the stage 2 hondata? what about chips
- 16G manifold?
- what is an aem ems system
- Anyone interested in an AEM PnP for a 99-00 Si?
- Clutchnet Stage 2 Clutch ????'s
- For those of you with the Rev Hard Kit.. Intake Question.
- LS Turbo or Allmotor??
- Please forgive this stupid question... What is the oil filter thread size on B-series engines?
- Those who said there were oil pumps for $89....where?
- Fmax or Drag???
- Relocation of A/C compressor for 3" downpipe...anyone do this?
- Twin 02 sensors 1st gen B16 with turbo, where to mount them?
- Pics of boost controler & Turbo timer installs. . . .
- For Sale!!! Never used Hondata!!!!
- WTB:intercooler
- Garrett GT series turbochargers....
- What to do immediately when engine overheats?
- Which is the 'signal' line on a 4 wire honda O2 sensor?
- too much fuel with new injectors
- what mods is needed for a eg SOHC vtec with preferably a JRSC to break into the 14.3-14.7 mark?
- Question for those with Nitrous
- Touching the blade on your turbocharger.
- Need help. If I can move the pistons while they r in the block, is it bad?
- hondata
- igntion problems, questions
- Going Turbo or N20???
- Clutch Swap for D16
- Those with cometic head gasket?
- Turbo Manifold
- Very Interesting Question On Wastegate
- ignition question
- injector question
- Are DSM 450cc injectors sufficient for 8-10psi?
- im having overheating problems. please help.
- Turbo.. What do i need !!?
- N20 or Turbo?????????
- Current Importparts.com Specials
- apexi power fc opinions
- drag 3 intercooler
- avcr and injector duty, can't get the hookup
- Oil leak within the turbo!
- oil blow by coming from breather filter
- The fitting that taps into the oil pan is just a pipe.
- Cheapest Place to get Tial Wastegate
- my block is OUT!
- integra non vtec looking for more power?
- VAFC instead of FMU on JRSC car ????????
- LS with boost question...
- My RANTS on Golden Eagle... :(
- people using profec-B.
- Are stock spark plug wires solid core wires??
- Quick question - Can the side port off the wastegate go after the blow off but before the Throtle pl
- EMERGENCY! I need a fuel rail NOW!!! Where to get one in Pa/De/NJ area?
- Profec A
- Best turbo kit
- joining the boosted club but...
- Where do I get a .48 T3 turbine housing for cheap?
- damn fast DSM video
- hondata or the new aem ecu
- oil ports on turbo..
- Best motor for Turbo....
- HP from 93 GS-R turbo?
- LS Turbo setup question....
- How much NOS for my D16
- OT: For what stand TT --->
- Where does the wastegate hook up?
- Want more spool
- The age old question again....should I go LS VTEC with my turbo?
- Need some help...
- Turbo mounting question.........
- Whats going on if white smoke blows out of exhuast and valve cover breather?
- 99 Si Alternator Problems
- any supercharger kits for a B16 CRX/Civic?
- my contribution on hood venting
- Coolant leak and IAC... stuttering idle ?'s
- AEM EMS Base Maps
- 12's with greddy turbo kit
- Good place to get a downpipe
- Ok..i know everyone on here is big turbo fans, but....
- venom nitrous problems, please help
- VS racing will be out at atco this weekend
- Oz DIY-WB - Wideband AFR Meter HELP
- an idea? running DSM 450's with some smaller secondaries? instead of larger=$$$$$
- tranny blanket instead of scattershield? look inside...
- Fuel Injector control wire on ECU of 92 Integra RS
- pepl w/ Greddy Kit
- Apex I AVCR Injector Duty Setting
- intercooler for 92 hatch
- Custom turbo piping with REV HARD MANIFOLD FITS ANY B16 AND B18 MOTORS....
- Custom Turbo piping with a REV HARD manifold for any b16 and b18 motors
- g2-hybrid-noob-soon 2 be----- pssssssssssssssshhhht!!! HELP!
- DSM 450's?
- best/cheapest place to get turbo installed in CA.
- turbo d16y8 timing retard?
- Vortech FMU
- Engineering Performance guys- Hondata vs EFI PMS
- Questions on Fuel for FI
- HELP ASAP........Injector Signal Wire on ECU
- Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium?
- ANyone using the Crowrer 63401T turbo cams on a gs-r?
- buying used ProfecB...
- Nylon tubing experts, i need help.
- More problem with turbo
- sohc turbo cant go pass 100mph
- Apex'i turbo on 95 Civic stock motor, MAX boost?
- Turboing my D15
- Slick size...22" or 24.5"???
- explain this to me
- jyt guys need help...
- More engine rebuild Questions. Experienced builder's advice needed. Pics inside.
- Which axle to get?
- MADE my own CATCH can..
- b18c1 rebuild
- Link gauges for FI. Need help.
- DSM 450s for sale.
- New to FI forum, Just saying Hi........
- machine shop in houston, tx
- Video of the dude in the Hatch with LS/Turbo
- NHRA Sport Compact Nationals, Houston Raceway Park Baytown, Texas June 1-2
- A story you should read
- ? about top fuel
- Greedy gauges?
- Why is low compression Betta!?
- Got my Helms...engine removal questions.
- assistance pls(choices have to be made)
- OT: I need some opinions on the best pull truck/suv
- Anyone who is familiar with hot side of Greddy TD05-18G...
- Turbo this weekend, quick question and THEORY!
- missing link vs electronic map limiter
- Bad news with my turbo teg..
- Nitrous
- who's boosting a SOHC VTEC?
- baker precision messed up my order, will this elbow fit the MAX-REV set up? (filter?)
- Stock fuel system, can I drive my car?
- Import Performance Show (in PA)
- b18b,b18c,or b16
- Maryland Inspections........
- nos question
- Got some pics of my new LSturbo setup
- vtec or no vtec w/ turbo
- ls or gsr w/ turbo
- common cause of turbo engine failure (w/ and w/o detonation)
- Suggestions on turbo coolant lines?
- open or closed loop
- CEL code when cruising and not in boost.
- Another injector question
- got the price breakdown on the Bogarts/Lensos/M&H slicks.
- Flywheel Thoughts
- What plugs to use with Turbo B18A?
- My new filtered recirculating valve cover breather thingie
- Engine Work With Turbo
- Just went closed DP..
- blue box question?
- ITR intake cam with JRSC?
- WTB: Working Good Condition 4-Wire O2 Sensor
- T-3 vs. T-25 FLANGE
- a lnkwaste gate conversion..
- HKS Turbos: Huh???
- newbie inline fuel pump question... dealing with relays... help me =(
- where can i get ClutchMasters stage3 for cheap
- ok to use rubber nitrile connector on turbo compressor outlet?
- what to do before turbo
- Which trans should for LS/Turbo EG
- No downpipe...lots of smoke normal?
- Need new Clutch. Needs to HOLD BIG POWER?? Advice?
- OK Guys FirsT POST Check it oUT
- MSD 2 STEP? Anyone use it?
- JRSC or NA which one?
- Back from the dyno with the h22a turbo, pretty happy :)
- Max-Rev...anyone have their kits up and running yet?
- Would a CX tranny work good with my turbo?
- anyone have a successful turbo h22?
- NHRA "Super Bracket" anyone heard of this before???
- Prelude IC piping question
- SAFC Help....Anyone???
- oil feed and return line....T3 super 60
- Update on QUAIFE group buy--They are on the way!
- AHHHHHHHH....I dropped a piston on the ground, now a little "ding"...problem?
- stock civic fuel pump
- Just put on the turbo not getting any boost !!! please help
- threaded hole on turbo
- retard timing
- another plug gap question
- what should i get next?
- Hondata with GM 2bar sensor
- Pics of my new setup (Inline Pro Manifold) =)
- Destroying clutch friction disc - WHY?
- 20psi on 370cc injectors??
- how poeple recieved their turbo from the garrett GB..
- help with fuel pump, fmu.
- BOV question
- anyone know how to get more boost out of JRSC?
- turbo muffler?
- Turbo timer problem
- any way to test out a blue box?
- Hondata Users/Tuners Directory
- LS turbo guys...which spark plug did you like better?
- Need help with specs for block build h22
- Potentially stupid question...why can't you use a radiator as an intercooler?
- FS: OS Giken Clutch
- Searched, but how do you know....
- Deltagate settings
- need pics of check valves
