View Full Version : Forced Induction
- act GSR clucth into b18b???
- HELP!!!! OIL STREAMING OUT FROM HEAD/BLOCK UNDER DISTRIBUTOR!!!!!
- my new motor build up after disaster
- 300whp w/ Turboedit?
- nitrous on low compression
- whats a good turbo for a stock b16?
- New turbo - anything to prep before install?
- lowering boost VS retarding ignition (power losses)
- Greddy Turbo Kit
- basic turbo tuning question
- Needs some specs on this turbo! .60 comp .80 turbine t3/t4??
- Intercooler questionnow where
- Building a DOHC ZC
- motor rebuild
- 2003 Impreza WRX turbo.
- Piston Questions, J.Davis (Read)
- Are my turbo seals going after only 4k miles?!
- Bergenholtz old parts for sale......
- tial wastegate in crx doesn't clear hood....what do i do?
- Car gives map code(3bar) when decelerating when cars cold
- PWR Halfsize Radiator Owners...What slim fans are you using?
- Tunning uberdata on a D15Z1.. lol
- building head only, bad idea?
- t3/t4 outputs
- Eagle Rods code. HELP
- Some questions about 86 Thunderbird T3 turbo??
- NEW KSERIES INTAKE MANIFOLD..!!!!!!
- Can i run my turbo off my safc or do i need an fmu?
- Boreing out injector seals to fit dsm 450's, question
- Greddy boost gauge stuck
- Need info about a TB swap ! ( H22A on a D16 )
- K20 turbo dyno sheets?
- Well here she is.
- 150 shot single fogger
- **High Volume or High Pressure Fuel pump???**
- VX injector size.. 240's, or smaller?
- Hondata tuners in Eastern WI?
- Moates.net USB burner and Uberdata...
- What did you all use for installation hardware?
- Need a good answer on the injectors I bought
- Surging Idle after JRSC
- Diagnosing The Problem...official Update thread........
- B20b with B16 head w/jun3camssprings/ret. VS. b16a2 w/jun2 camssprings/ret. with turbo ?????
- Carillo H-Beam connecting rods
- obd0-obd1(b18a-b18b)question??
- Cheap way to add power to a 1.6 liter daily driver?
- which turbo kits are A/C compliant?
- velocity stacks, where can I find one?
- 99 si turbo exhaust leak??
- accord running lean
- T3 60-1 .48a/r too big for a d16z6
- T25 on B20?
- max boost in 2nd?
- DIY "bang bang" (anti-lag system)
- Questions/Suggestions on Turbos/Build
- DOHC vs SOHC
- help with mbc.....
- hp limit of stock block JDM B18C?
- Boost Lag Question
- Quick question to all D16 turbo ppl!
- b20vtec turbo. where do i hook up the oil to go to my turbo?
- TD04HL
- Dynoed at 176 whp @7psi on a mustang dyno
- I cant get Uberdata to open > help
- Drag Racing Video from Valdosta Import Shoot out.
- What are the ill effects of having too large an oil feed line?
- AWD vs FWD controversies
- which spark plugs??
- hondata tuners in the north east area ...mass or@this area
- Mase Coming Back to California
- egt temp question
- Where to get turbo oil feed restrictor
- Help, car will not run!!
- 6,7 or 8 spark plug
- Are those bar and plate intercooler on ebay good or bad?
- turbo 89 crx b18a
- Oil feed line leaks after switching to synthetic?
- boost creep
- Dump Tube on Tial WG with GS-R/Rev Hard Mani...
- Turbo maintenance Q's - oil & such
- ERL (Darton) Superdeck's....40psi?
- where to get p28
- Hondata, P28, Basemap, enough?
- Looking for a SoCal DX turbo
- comp. ratio with boost
- i need help ???
- Junkyard Turbo First timer Help
- SC32 or SC34 D-series.
- opinion on using this for intercooler piping
- is this turbo bad?
- T3 turbo question (48/42 vs 48/60)
- 5th gear boost
- Tap dseries oil pan on shallow end?
- how to upgrade t3 --> t3/t4
- choosing the perfect setup
- How do i do a safc hack??
- turbo leak
- Help with JRSC
- Losing Boost Past 5000 RPM's with Greddy Kit *REVISITED*
- PT-67?? Anybody have a dyno chart with it??
- Greddy turbo timer acting up!
- Ford Probe 310cc injector install on D16z6
- fluidyne fullsize and blox turbo mani...
- any of u turbo gurus near west palm beach fl??
- Need Help I'm kinda Confused
- CEL #16 after thermostat install
- car won't rev past 3500 rpm
- she almost back !!
- Write up: Greddy Profec B install....results and my opinion
- messed up pistons and compression test...
- z6 pistons in 2000 y7??
- I think my boost gauge is broken *vid*
- Boosting Motor
- Turbo SOHC
- Anybody running a volvo Fmic?eg?
- Well here it is... Dyno graph of Hybrid Performance Project DC2
- Exhaust leaKs...
- Need turbo advice(RSX)
- How to keep Intercooler Pipe Temp down???
- Heatwrap
- nitrou jetting
- ok to run just a btm for now?
- It's so close I could taste the 10's best 60' 1.586
- I know it is a cheap kit But
- boost gauge and manual boost contorller, or a greddy profec?
- sandwich plate
- need info on my jrsc
- Uberdata basemap run like stock w/ dsm 450cc
- no room for filter on hatch
- SC61
- HAve any one bought this intercooler be 4?
- Need help with silicone reducer
- Whats the best intank size for ic and Y need help urgently
- Drag Racing results 500 WHP on PUMP GAS!!! also made the 600 WHP CLUB
- High & Low boost tuning possible?
- STOCK B16 turbo choices. Choose my turbo for me :)
- 99 D16 turbo issues, searched
- Headgasket -- Is this the right way?
- Wastegate Dump tube question
- 600whp civic times!
- turbo questions, kinda confused
- Greddy Kit
- sohc greddy blue box help 2 weeks reserch and got nowhere
- Apex-i S AFC
- Good place to buy a 3" DP? (d16z6)
- vafc+fmu?
- i need to trade in my turbo upsize time
- Turbo Question (2000 Si)
- low compression after lots of blow by
- thoughts on PEAK BOOST TURBO KIT ?
- d series people with 300whp
- Experiences with Cometic Gaskets ?'s
- anyone lean out in deaceleration?
- 400 hp turbo setup
- Fan questions
- rev valvetrain?
- EGT temp raised after installed new spark plugs.
- Group Dyno @ R&D today..
- is it safe? (sohc ninja help)
- Greddy e-manage on 91 teg
- compression test after 5months of boosting.....
- Lean in Higher Gears
- No spark and No fuel help please
- going to the darkside...need help badly
- building boost with different trannys
- To rebuild myself or not? (mitsu TD04H turbo)
- eagle rods dont have holes for oil for lubing the bearings....
- What i need to do to lower compression
- oil problams
- im sure its been covered before, but it would be nice to have it all in one place
- Turbo? Yes / No
- motor gets crazy hot!
- dyno'd today
- > Anyone running the BLOX mani yet?
- oil looks milky....????
- 89 crx w/ lsvtec turbo question...
- d16 turboes?
- Custom intake manifold for 1.8t (and some other pics.)
- Precision SC63 or Garrett GT40???
- boost is creeping
- Greddy Type R BOV
- kg/cm Bar and pounds. Whats what?
- cheap management
- where are you guys running your wideband wire through the firewall?
- Can you feel shaft play?
- UBERDATA chipping! NEED HELP!!!! PLEASE!!!
- FMIC...where????
- Oil return line not connected?
- RFL OR TIAL 50 mm BOV?
- Idle issues...(DSM 450CC's...SEARCHED)
- Oil Return Line Replacement for GReddy kits?
- My Experiences with Endyn
- Finally..block is back (56K go away)
- can a stock b18b sleeves handle 400 hp?????
- Nitrous troubles
- oil cooler possibilities
- Radiator overflow tank filled up.. !?!
- Exhaust Manifold Design ??'s - and pics of one we made.
- dyno charts+ set up of my turbo b16a
- Greddy turbo timer schematic needed...
- Where to get aluminum tubing for intake manifold?? prefer in atlanta??
- what happens u (+) the fuel correction on an afc controller???
- D-Series I Turboed this past weekend.
- DSM BOV Flange
- turbo a sohc vtec?
- blown seal = oil return setup?
- RPMs drop, car almost stalls..
- wide band options
- M62 Eaton blower manifold for D series
- Those 24$ turbo timers on ebay
- Inline Pro Manifold: Can turbo sit on Driver side
- jackson racing sc in h22/integra
- my turbo setup progress almost finished
- Spring too weak on the Wastegate?
- TD05H-14b Spool up Time
- pics??
- Can anyone suggest an exhaust setup for me that might be quiet?
- t3/to4e upgrade to SC60???
- Boost leak
- What is the best turboand turbo manifold for the h22a4?
- codys- mini me mani help!
- Almost done with my Evo twin scroll turbo setup.
- Will T3 60 work for 275whp on stock b18b?
- Turbo?
- dumb axel\diff question
- 6puck+lightweight flywheel
- What's a good hood to use? (pics 56k)
- What makes a turbo kit A/C compatible?
- Tires
- h22 turbo civic project!!!!need help!!!!
- Engine builder in the Pacific Northwest
- how much boost is unsafe in a USDM b16?
- nitrous questions?
- Anyone using OBX generation 2 manifold?
- this sound like a complete setup? (sohc ninja!)
- HELP!!! Trying to get B16 with RC 550's, AEM FPR, Walbro 255, stock B16, T3/04, stock plugs to IDLE!
- how to check a bov
- Help!! sohc to dohc apex-i turbo fitting apex apexi
- d16 turbo guru's l00k!
- HKS camp?
- Honing Question
- Exhaust manifold pressure (Full-Race Manifold)
- PSI Level, @ 9.8.1 Compression?
- This just isnt for me.
- gsr cams
- Boost Controller Q: What is the Ratio Function For?
- max boost of the blitz bov....
- wastegate problem?
- Help Me Out I Need the following pics: H22, D16, B16 4-1 turbo manifolds w/measuring....just read th
- FMU or hondata
