View Full Version : Forced Induction
- How Accurate?
- help wit turbo
- tubular and cast differnces?
- Sunday May 04 Milwaukee Mile "Drive the mile" event!!
- wet nitrous
- My turbo build (from Bahrain)
- AFI top mount kit or the Peak Boost kit?
- good tune
- Pic Request of Ramhorn with GT42 or S372
- HKS BOV blow off valve not working no sound
- HP limit for Crower Econo-billet rods
- throttle bodies ????
- DSPORT Magazine Wants you!
- Precision SC61 E and S compressor housing
- spark plugs you would recommend for my setup?
- boost spike?
- Close up pics of a Bullseye/BW S256
- Overheating after 20 mins of hard driving on a hot day normal?
- AiResearch t04 rebuild
- .63 ar and .82 AR difference GT35R. Revving to 9000 RPMs
- help with an h series drag turbo kit
- SOHC TURBO TRANNY QUESTION...
- turbo exchange?
- Endyn VS Stiegemeier for supercharger porting
- ls vtec
- GSR Headgasket Size Question.
- Help finding block fittings!!
- blockguard yes or no
- Oil out the exhaust?!
- how to Identify excessive smoke as turbine seal leakage?
- GSR Turbo
- nal im planning to boost a single cam
- Turbo advise please !!
- Turbo Cam's (4 Options) Whats the best?
- How much vacume? (bigger cam guys)
- HELP: F23, getting fluid in my breather line and pcv line is clean and dry
- turbo build
- CIVIC TURBO BEATS A SKYLINE GTR R35 - VIDEO !!!!!
- weird idle problem after redoing vacuum lines...
- LS Boost power goals
- requesting a distributor connector pic
- over heating under boost
- TURBO PICTURES post some photos
- Where can i get this part
- i feel dumb but...
- idle problem
- Does this boost solenoid diagram look right?
- Need some help - Ostrich not working (Timing out)
- Oil pressure port on back of block....how much pressure?
- Little intercooler question
- need help with jackson racing SC map control
- New downpipe?
- boost creep t3/t67ho ramhorn
- Oil Kit for a TD04 - Quick Question
- Boosting a b18c1
- Anyone running the omnipower 4 bar map sensor yet ?
- what is the correct rc injector for victor x gsr mainifold?
- Help Please having problems
- how to get rid of boost spike
- is 400whp obtainable on 15 psi?
- heres what im doing
- GT35R and T3/T4 Turbine Housings Compatible?
- Which sohc block?
- Where do I route the coolant return line?
- forged pistons?
- oil and coolant lines
- does my type-s knockoff sound correct to you??
- TOP LINE or OEM oil pump for tubro b16a2
- P/W clearences in b16a2 and cp
- BrianCrower stg III NA cams, too big for boost?
- OIL LEAK near pan and oil pump
- Prob clocking my gt35r
- what kinda power???...k20 turbo
- boost question?
- LS.V Turbo Set Up - Opinions
- edelbrock turbo kit questons
- Installing an O2 sensor, plese help!!
- Precision injectors not fitting in JRSC GSR manifold.
- Edelbrock Victor X intake mani
- stock d16 240hp @ 221 ft.lbs
- D series help
- 75mm edelbrock throttle body tps question?
- Will these injectors work?
- b16 turbo
- LSVTEC TURBO INJECTOR HELP
- Turbosmart FPR ? feedback anyone ?
- Non honda Project....
- Learning boost need more info
- Oil Dip Stick
- waste gate
- magnus intake manifold for S2000 *look inside* is it any good?
- car won't hit boost
- b18b Ls Supercharger, is there any fast ones out there.. need some quick info
- Deciding which boost controller. Help!
- Please help identify these cams?
- basemap questions ( phearable customers )
- BEST NGK SPARK PLUG FOR D SERIES BOOST???
- JRSC w/ A/C?
- b20 turbo help! gt30 vs gt35
- ROSS RACING PISTONS
- need help to identify this turbo
- greddy profec b/s
- Wastegate not closing. Any ideas?
- need advice... beat by a cobalt = embarassing
- LS/Vtec Short Block
- How long did Competition Clutch last you??
- Stock temp. gauge going Quazy.... or crazy
- Anyoner Ever Use a Vibrant Ultra Quiet Resonator in a System?
- arp head studs didn't retorque
- Anatomy of a Blow off valve anyone?
- Q31 on P28 ECU FRIED! help!
- 11:1 to high?
- Heating problem with boosted LS vtec need help
- GT30R vs GT35R
- need help with vacum line on my turbo ls!!!!!!!
- Venom 720cc injectors.. any users?
- turbo xs manual boost contoller not working???
- em1 turbo b16 ??'s
- D15b head on a6 block will not enagaing vtec lose much power?
- b18c1, 9:1 pistons, forged rods, block guard, limits?
- Nitrous Oxide Sniper Wet kit
- Started up my build today...Coolant/Oil Mix...Pix Inside
- Turbo Prelude
- Best laptop for tuning?
- Whats going on with my turbo?!
- Watercooled turbo questions where do the lines go
- t3 t0 14b adaptor plate problem
- boosted auto tranny help
- Full-Race/T1 Turbo Setup on my S2000
- Competition Clutch twin disk stripping spines out of 1 friction disk????
- Tial BOV...slight compressor surge
- All u 350-450hp 11-10seconds guys, "what clutch kit ur using?"
- boostin but question on intercooler n fogs on 00 civic
- Tial 60 not big enough, seriously....
- plz help
- cometic gasket problems, need expierinece (searched)
- Looking for cylinder head opinions
- D-series
- This is weird and it keeps happening
- f/t : new b series turbo kit for ls jrsc
- tuning question for h22
- Built D16 Y8, what turbo to get?
- obd1 tuning pgmfi logworks
- Garrett or BW??
- Super fast h22 coupe vs streetbikes, gt500, c6 vette, more
- cam cap bolts snap
- Car is cutting out. HELP!
- Boost 1st time Semi-Fully built Need help
- Hard to get into 2nd gear from 1st-2nd shift at WOT
- SOHC VTEC TURBO TIME!!!!!!!
- LS/Vtec Supercharged
- Fresh Rebuilt B18B - Sleeved - Cooling Issues? Need Some Help!
- Picking a turbo for my b18c1
- Synthetic to Natural oil????
- AEM F/IC vs. E-Manage Blue
- Shaft play
- Blower for s2000?
- boost controller install, quick question.
- JRSC Screw wear?
- AC Log Manifold
- Lower compression pistons on a stock ECU. Rich or lean?
- DOHC ZC w/55 shot vs. D15B vtec w/55 shot
- looking for turbo... unsure of my BEST options
- distributor king
- Boost problem
- Clutch To Match MY Boost...
- Dyno'd my b16 today.
- boosted 01 accord makin VERY low power! HELP!!!
- retune for bigger exhaust ?
- building a eg hatch b18 turbo, but im new to boost need some info please
- Oil feed line from Head on VTEC motors??
- Could anyone tell me why a ramhorn manifold makes more power?
- B16A-T help with oil pressure
- question about wastegate diaphragm
- Oil around #4 Exhaust Port?
- Help with building/tuning Gsr turbo
- *Turbocharger vs. Supercharger*
- d16y8 turbo?.. edelbrock
- Building boost off the line with Crome?
- newbie question???
- wastegate?
- CRYO TREATING....i searched and came up empty
- d16y8 turbo question
- turbo manifold question....
- wiring in greddy emanage
- random ls, lsvtec and gsr dyno tunes ive done in the past
- why do i have this dip in my dyno graph??
- Oil in one intake/head port what's the cause?
- where is the Oil pressure sensor (for turbo)
- looking for answer on AFPR
- d16z6 oil pan
- why is my check engine light go on when im boosting?
- Comments please
- Oil weights
- what piston compression for turbo setup/bolt on setup can be use?
- B16a Peakboost kit
- B16a Peakboost.
- Boosting b16a Wat Valvetrain
- Anyone using 0w 50 Oil with their boosted setup?
- looking into a turbo upgrade and need opinions
- what i need for tuning
- What size turbo does my buddy have
- Urban Indians Civic Coupe 2.0 GSR - 750whp build
- NOS!!!
- crome?
- Cool down time after some hard runs at the track
- overheating......sometimes
- want your opinion on this turbo
- Where can I find 5/8" Turbo Oil Drain line?
- Turbo on angle can cause bearings to fail??
- Are Turbonetics turbos any good?
- rc injector help.
- Where to buy a s366 oil feed flange...
- Need Info for turbo related parts
- FI HG question
- my boosted integra
- keep jdm foglights on a turob eg
- Thermocouple in exhaust stream significant restriction?
- CIVIC TURBO vs SKYLINE GTR R35 (DYNO MOVIE TRAILER)
- WOW... absolutely the craziest setup on a street honda... MUST SEE!
- Blox intake manifold??
- Glasspacks on a 4 cyl turbo? Will this exhaust sound like crap or not?
- VAFC Neo VS. CROME (Need Advice)
- Quicky Compression question
- anyone know the part# of a oem threded intake air temp sensor?
- list of ccw superchargers...
- Looking for a reason why a roots style s/c cannot be "piped" in?
- gsr head studs b16 head?
- Question about widebands and gauges...
- b18c1, 81.5mm itr pistons running 6-8psi. safe??
- B16A boost problems
- fresh build, same tune?
- turbo teg boggin....
- MSD pro Billet + AEM EMS good or bad?
- Fuel Pressures Effect On Power
- high oil presure?
- My turbo LS project
- 84.5 headgaket issues
- PR and other info on b18c1 for turbo sizing via maps?
- Vaccum line size
- a few questions...
- greddy profec b spec II
- turbo manifolds
- EDYNE or THEOLDONE is there anyone on here from there shop ?
- Looking to Turbo my D16y7...first time booster...
- Turbo vs. Supercharger comparision - Dyno graphs inside!!
- Looking for best price on MSD pro-billet distributor
- Need help B20 head
- Borg/bullseye 259
- How to install a manual Boost controller to an external wastegate, from turbo fitting?
