View Full Version : Forced Induction
- Boost sensing FPR??
- AEM Fuel RAIL
- Need help with crx zdyne tune 100% lost
- b20 turbo or b16 turbo?
- Who would be interested in improving low end torque w/o big investment?
- forged internal stock sleeves? input? experiences?
- Rotating center section of garrett t3 turbo
- best current rom burner
- what psi?
- What Bearings to Use.
- Need info on stock WRX STI IHI VF39 Turbo
- POWER ON DRAG KIT
- Omni Titanium Rods + boost...
- arp head studs stock in block
- T3 turbo Super XS power
- 12-15psi plus NX on stock GSR?????
- AEM EMS - now i need info on getting the wideband...
- KMS engine development ??
- Buid racing block
- Boost controller problem. Already searched!!!
- Picture Request: Turbonetics "T-series" T67 turbocharger
- Need Advice on Next Mod Options
- will this turbo satisfy my needs..............
- video of my car from oct/2003
- fuel pressure questions
- GReddy GSR Turbo kit - psi?cost?hp?1/4 times? Reliable????
- screen vs filter (searched)
- Dry + Boost
- why is my car boosting passed boost cut?
- Greddy FMU(blue box) on 99 GSR. Can I use obd2-obd1 harness and chipped P28?
- PLX M500 Wireless Wideband 02
- How to polish a turbo?
- turbo question
- Honda oil pan material.
- turbo h22 head question
- Dyno'd the GT28 B16 today.
- Someone please check my calcs. with this compressor map please! TIA
- What happend to HTM.com
- Break in period w/ tune?
- boosted crx guys help
- p75 ecu uber install...no r54 port for the resistor....help
- bov leak have a question..................
- how much boost can gsr stock internals handle
- Limiting boost
- B18B Turbo Setup, What Numbers to expect on DYNO??
- Does the AVC-R control fuel?
- wastegate spring installation
- Are these rings good?
- Bad piston ring or bad valve, need help!
- JRSC D16Z6 HELP!! What else do I need???
- Emissions testing?
- Dip Stick
- Compressor map for GT40/67
- OBDII + uberdata = failed emissions?
- t3/t04 question.
- turbo exhaust manifold
- to the guys who rememeber my blown headgasket prob
- Uninstalled turbo..now very bad idle
- spark plug gap?
- t3/t4 and exhaust manifold
- b series turbo kits
- SMOKE!!!!! From under the hood.
- how long has your race engine lasted.......
- JRSC + Nitrous
- Has anyone cc'ed a 84.x mm chamber PR3 head?
- 4 bolt downpipe turbo...
- turbo charging my b16a
- Gauges for JRSC-equipped EM1
- how many miles you spooled w/o a major problem on your f/i engine
- exhaust size and tuning
- Advice needed please
- hondata datalogging option?
- Forced Induction Goods Supplier
- Hooker aero chamber for a 4 cyl???
- my t3 60-1 crapped out on me. suggestions on what turbo i should buy now!?!?!?
- Greddy turbo + no emanage = ????
- revhard filter
- new fuel rail?
- SOHC Clutches
- Endyne Carbon Manifold..
- parts needed to pop a vtec head on supercharged car?
- Cold Weather effecting Boost ???
- Any chops rebuild trannys for performance needs
- Sidewinder with Full Race Traction Bars - IC Pipe?
- Crower/Pauter Rods also good for high Rev Setups?
- Performance Hicup...
- JRSC Stepper Pulley - need description! Special-Problems!
- Power differences in DP flare locations? help me out
- tach trips out after installing turbokit....
- Anyone know anybody that works at Moss Motors ? (Manufactures of Jackson Racing) I need something!
- Anyone else running the StreetRays "Greddy look alike" MBC?
- My d16 fully built....Should be out of the shop tomorrow
- Apexi kit carb legal yet?
- a good radiator to replace OEM factory radiator?
- Apexi Power FC is burning my ecu fuse. Help
- Lost motion Assembly????
- Anyone running a Polished hot side?
- D15 BuildUP
- injector size for turbo prelude
- Which Engine?
- Downpipe question
- Oil return question
- what are the limits of pump gas and boost?
- What turbo to upgrade too!
- SOHC-T owners there is one question unanswered?
- Which Turbo For GSR?
- Cuts in my Turbo manifold!???! <--- uber confused.
- can anyone help me tune my safc 2
- New setup! Neukin Manifold w/pics
- whats the best radiator for $300??
- my car in the new spec add in modified mag
- b20 vtec blockguard question
- OT. . . . My new FI Toy
- apexi tuning
- Full Race, Five lug, Fast ass hatch is complete (pics and video)
- Venom intake mani,,, No provisions for AIC. How the hell does that work?
- Car not running right
- Looking at this turbo but don't know the brand?
- Anyone run 7.5-8:1 on a D15/16.
- check valve AND vafc returned no results
- boost b18 or b20?
- Who carries the Felpro wideband o2 at the best price?
- How much HP will this give me...
- question about this picture.. fuel pressure regulator wiring??
- SC34+D16Z6=???????? anyone running one on their d-series?
- Spool of Sc61 /or GT3255e
- Surging after injector swap.
- Turbo for my F22A...
- Will downpipe fit?
- junkyard turbo?
- Spool Time: T3 vs. T4
- Difference Between Blow Off Vavle and Wastegate... For Those Who Do Not Know:
- eagle ge sleeved block having problems sealing help!
- NEED HELP WICH SLEEVES FOR D16 BENSON,AEBS,DARTON,GOLDEN EAGLE ????
- How many companies make a/c compatible equal length manifolds?
- sock injectors or 270cc?
- should i run gsr cams in a b16a
- should i run a 3inch open downpipe?
- friends TURBO ITR on dyno
- **Turbo guru's, Ouick question**
- where to get a to4e i/c 2" to 2.5" 90 bend
- Help with intercoolers
- cannot raise boost above 7psi
- How often do you change your plugs?
- Greddy civic kit on an integra?
- weird ticking noise
- High hp H23VTEC (work in progress)
- exhaust manifold question
- help:: whats this mean????????? pics inside
- How much did you pay for just your turbo?
- About to hit the dyno:built h22... numbers???
- Turbo or supercharger
- need help on getting car started
- cently need help on getting car started
- ok im fuk'ed now what???
- *Turbo mani comparison questions!!!!!!
- Precision SC61 or SC34 question????
- b18c1 with b16 head...which turbo
- parts list: turboing ITR
- Turbo intake manifold ??
- Need opinion on turbo for my setup
- driving my jrsc on a turbo hondata tuned map...............help!
- who runs, or heard of ZOOM clutch?
- Boost B18 Tranny
- Skunk2 versus Edelbrock versus Stock Intake Manifold
- tuned car, sometimes runnin extrem lean under part throttle
- f22a6 accord motor w/ stock dsm turbo setup
- quick question, evap system
- Boost With ALL MOTOR CAMS, Skunk Stage 2 +
- Opinions on this Intercooler
- have u ever seen a turbo setup like this
- dyno numbers for my sohc
- b20 arp question
- 513whp '05 STi inside... i know, its not a honda.
- torque specs on arp studs for 25+psi???
- Higher HP spark plugs? 400whp+ (searched)
- WTB: d15 rods
- Why are 40mm tials so hard to find?
- didnt change settings on boost controller... but now its going higher than before
- clutch recomendations???
- oil feed and oil pressure
- A darton Built block, it a good idea? look at link? anyone hear any good or bad!?
- b16a turbo help
- Dyno numbers on my cursed Civic
- Turbo Lotus Elise.....Part2...lots of pics
- BOV'S.........Which ones sound the best?
- what motor is better to turbo ?
- Is this hole supposed to be on this Jackson Racing S/C Manifold for the Map sensor controller?
- ihi rhb5
- Turbo Accord love...
- Turbo manifold question
- ls/vtec or b16 for boost?
- Charge Piping Fitment
- oil squirting out when i turn on my car?
- t3 60 trim turbo
- Misfiring, cel, MAP sensor, running rich
- Cody (tinker219) just cant stay all motor. no 56k
- Emissions Time for my Turbo Type R (Need advise)
- my setup, so far
- d16 turbo?
- a formula for HP!! hot rod magazines feature. is it accurate? find out
- SC61 vs SC44 for 350whp on a b16
- Pics of my GSR autopsy.. ewwwww! *56K die!*
- SS Autochrome.....quality?
- Narrowband on Techedge
- back door intercoolers
- K-series turbo question.
- major power loss, need some help/ advice
- my new turbo for sport fwd car
- Open deck sleeves in closed deck engine?
- good deal for this turbo kit? why is it soo cheap?
- church automotive testing
- Running Synthetic in a turboed car
- Stalling after BTC installation on a JRSC'd GS-R (detailed)
- Is it necessairy to balance new Eagle Rods?
- what did you pay for your custom ic piping?
- Charge pipe pro's, share some love
- machine shop in dallas
- My Custom IC Specs, Opinions?
- Turbo built block running with no turbo?
- Need clutch advise..Please help!!
- throttle body for jrsc CRX
- P28 & 6th gen accord
- T25---> T3 fitment question
- Installed turbo now code4 and engine won't start????
- My list of crap to swap out, or try to help my missing problems...
- best wideband for aem ems ???
- Crank Pulley Question
- what do you guys think?
- What do you guys think of this intercooler?
- boosted integra question this is been bothering me for a while
- Final steps in 2 minds t3/t4e or t3/67?
- h23 turbo manifold
- DALLAS TX Uberdata???
- Low/Full Boost .. weird
- newbie here with a newbie question i think??
- Distributor?
- Blitz FATT DCIII
- Injectors seem to be cutting out sporatically under light load?
- Vitara pistons in D16A6. Too Low C/R?
- I have been Neptune'd!! And it is GOOD!!!!
- are these slicks good for my setup??
- Experiences with coatings? and other engine bay stuff
- 2000 Integra FMIC fitment issue.
- Where to get HONDATA
- turbo size question
- Am I thinking possibility or in my dreams?
- unstable boost ?
- turbo rebuild
- Budget turbo hatchback 1/8th mile video
