View Full Version : Forced Induction
- Anyone boosting on SOHC DX motor. And how much.
- It came!!
- where to get endtanks modified for starion intercooler
- Who out there has an AUTOMATIC TURBO, please step up...
- TURBO!!!!!!!
- I/C questions for a B16A2+turbo
- please help---> hondata related question <----help please
- Where to buy rubber couplings
- Headgasket seeping??
- **ATTENTION** All 3" Magnaflow Muffler Users!!!!
- king of all CLUTCHES thread
- need info on GReddy FCU(bluebox) for obd1 ecu
- Need custom manifold for a T62-1?
- Why wont my rc 440cc's fit in my STR comp. fuel rail???
- Help me understand EBCs and their features...
- Is my manifold messed up? -> pics inside
- would longer gears help?
- what kind of compression, how much boost, ets.....(b18b)
- building a custom turbo
- Oh my GOD this is so tiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiite!
- who makes a turbo for the 3rd gen Eclipse??
- Will the hondata solve detonation problems at high altitude?
- smc controllers
- What Precision Turbo for my setup?
- **HF and VX** manifold on B series for TURBO project
- Might be getting this new boost controller, story goes with it
- Oil Feed / Drain Kits
- Need help IDing turbo inlet and outlet holes.
- Standalone tuning question
- Sinking sleeves? (Golden Eagle please respond also)
- gas mileage...what is happening help me out
- will car start up if msd ignition unit is defective?
- cold air intake for turbo?
- What spring(deltagate) comes with the drag gen 2 turbo kit for the 5th gen prelude
- Is there anyway to move the front ac lines behind the center radiator support ?
- Would this D16Y8 kit work for my D16Z6?
- rubber hoses for charge pipes???
- What spring comes with the deltagate wastegate for the drag gen 2 kit for 97+ preludes?
- Boost timing retard??
- SMC changing fuel curve too quickly?
- kms block guards
- another happy automapper.
- Will a Hondata and harness for 97 GSR work on a 99GSR?
- pressure drop from adding intercooler..
- How does a dry shot deliver fuel on a honda???
- DEI's New Cry02 Intake System..Opinions.
- F I Cam for Sohc Turbos???
- Intercooler Size
- T.O.O. -- "Membrane IC" and IM volume theory
- Has anyone ever heard of this electronic boost controller???
- two questions
- Need help and info on endtanks for custom fabricating a FMIC???
- Need a good dyno place in Philly or near by...
- Big turbo, no space.
- largest injectors you can use with hondata?
- Compression test - accurate without throttle wide open?
- Good news, she fits y0!
- What intercooler fits a 94 Integra rs? HELP!
- the new SRT-4 ?'s
- need help on custom intercooler
- My new toy!!!!!!
- LS (only) crower cam users (info needed)
- which way do you have your 14b facing?
- thought it was just a headgasket..help..anybody...
- ? For the Inline-Pro Guys...
- how much boost(Stock D16Y8)
- Integra owners in Cali....
- Turbo pros Help! Question about a/r ratio
- Is it worth it to port exhaust side of turbo?
- Engine bearings and seals
- D16a6 turbo setup...HOW is it
- quad turbo, not honda
- can someone measure there tial spring?
- what am i forgeting?....custom turbo kit
- Turbo F22B Owners
- is this a good deal??? need help
- Phantom Boost Leak
- Chra turbo center section.?
- Question: DSM 450 injectors
- What to do, what to doType R spoiler makes motor go boom.
- LED mufflers?? Fake flame throwing exhausts??? I think this tops them all! LOL
- DSM Injectors in B18 Tubro
- hondata basemap question...
- Normal EGT readings? Experienced informative post only please!
- has anyone ever had there motor built by inlinefour?
- What to do first?
- Mini "NOS" kit-found their cartridge source
- Precision Turbo SC63 Pics!!
- Timing question
- 2k1 civic turbo fuel
- Help! Can't tame EGTs!
- Hondata+N20
- am i getting a good deal on this???? i need YOUR input
- Value of Drag 3 Intercooler piping?
- names of speed shops?
- Post your Enginemanagement on D16A6 Turbo
- Garrett Oil Drain Flange with 5/8" hose barb fitting from Road Race Engineering
- spool
- People with black intercoolers....
- Will a Garrett t3/to4s 60-1 fit an inlinepro manifold w/ a turbonetics 5-bolt flange?
- can you run a o-ringed block without the orings?
- How do I learn how to tune?
- 14b oil feed
- wrapping turbo pipings???
- Welding problem!
- CRVTurbo - How many PSI is safe for my setup??
- what is the visual diffrence between cometic gaskets?
- d16y7 crank and d16y8 crank
- Would you be able to weld...??
- Piston matching question, help ASAP
- Whats the MAP sensor wiring?
- what spark plugs for boost?
- fpr question
- Is this a decent welder?
- whats BAR???
- Water cool turbo question?
- What is the BEST bolt on turbo kit for my Daily drivin Bseries?
- Engine Builders please analize this blown LS block
- For the n20 fed peeps how big of a shot are you running?
- Can some revhard dealers on honda-tech help me..???
- resistor box wiring?
- Overheating with turbo back on???
- Cheap new 720's? Where is a good place for injectors? Maybe become a dealer?
- Turbo header for F22A
- BMW 328i + psi...
- how much can i run?
- TD05 12G rebuild kit
- Full T4 on a b-series street/strip
- Engine Management
- questions on turbo install of course
- wastegate test
- An EK and a FMIC: a love story
- OT: I need help guys, references for me please
- Is my oil return okay?
- T60-1, T3 or T4 exhaust side?
- Need Pics of a Front Mount I/C on a 92-95 Civic with A/C
- wtf can I get a 1/8 NPT to 1/8 BSPT adapter
- I need help from the ls/vtec turbo people? Best fuel options for a built ls/vtec?
- High comp + turbo=???
- Where's the best place to buy a F.A.S.T management system?
- Placement of Blow Off Valve.. Looking for opinions..
- Boosted TypeR video (Please Post!)
- Will there be enough room to fit this?
- IAT technical specs?
- oil return question
- JG Edelbrock Manifold Installation?
- Injector question.
- How much is too much power for a Civic without Quaife?
- Whats this manifold and whats it worth?
- How do you get your block so *bling* bling*?
- Help: Dsm 450s
- fouling spark plugs
- FS: jackson racing FMU.
- Dyno plots @ INLINEPRO
- What valves and guides????
- My day at the dyno.
- ecu upgrade for boost
- Problem with Valve train Wear???????
- JDM 4-1 w/Jackson
- 9psi+ 12:1 Fmu + stock injectors= Your thoughts?
- turbo kit checklist (searched)
- Who has used Delphi Injectors?
- Fuel Delivery System for 500-550hp Turbo car
- LS/PR4 pistons in a B16?
- Does this look correct to you?
- Just t00ned: B16 60-1/T3
- wastegate question
- anyone using a maxrev dumptube?
- Finally decided on my setup and it's underway - A couple of ?'s
- who's done high boost /high whp w/oem head bolts
- buying used turbo's
- All I have is the FMU, what else do I need? (parts)
- Resistor box part number?
- Question about some injectors
- My Powdercoating and Jet Coating pics...
- my fuel milage sucks..
- cheapturbo.com is also CHEAPTURBOS.com
- some parts you guys might be interested in..
- 7 pound Jackson pulley?
- Turbos web pages
- Spool up time?
- O-ringing a block question
- Microtec engine management
- How much boost can i run????
- What turbo?
- DIY Additional Injector Controller?
- does the starion fmic have fitment problems on 94 civic?
- Manifold problem or gasket prob?
- Why does a turbo at 8psi make more HP then a SC at 8psi?
- In business, just got baby hondata. have some questions.
- EGT Questions
- PWR air to water cooler question(earl?)
- how do i get 300whp out of a turbo 2nd gen B16a
- Civic Si VS. S13
- OBDII Turbo tegs please stand up !!
- Who's Turbo'd Preludeengine Bay is This?
- Question about installing sleeves
- Turbo B16a Decisions
- Advantages running this T3?
- to those with msd and stock coil, how did you do it?
- ARP head studs for B16
- oil found on exhaust side?
- whose running this turbo?
- Saab Turbo Manifold?
- complete gsr 18g greddy turbo kit w/intercooler for sale...
- dallas meet sat. 25th @ 5:00
- Anyone running a b16 with around 1 bar or higher in an Ek, How fast? any ideas?
- JG Edelbrock Intake Users, I need some assistance please read
- OT, but FI related: Before Hondata and PFI came into fashion...
- Whats up with homemadeturbo.com??
- wiring of greddy turbo timer to 99-00 civic ecu
- Hondata question
- Smoking Rebuild Poll
- For the turbo peeps, how much boost are you running on a stock motor, what motor?
- Greddy Power Extreme II 3inch exhaust for gsr
- AFter your block got resleeve...Linebore....
- How much boost on a LS slightly built
- Simple nitrous question...
- Check ou the new turbo set-up
- revhard or maxrev manifold/dp
- MSD BTM necessary?
- Greddy Profec E-01 interests?
- what is this part?
- My friend picked up a new turbo.....have my doubts.
- 3/16" big enough?
- IMPORTANT: Can i shave more of the block?!?!?
- yet another hondata question...
- How much boost on a b18c5
- Wacky oil drain fitting
- b16a 00si & drag III?
- How Long did it take to tune your hondata.....
- Spooge coming out of turbo...
- T3/60-1 .82 A/R efficiency issues (searched)
- 250 miles and Boosting at 5psi
- Off Topic: Forced Induction Related topic. Supra vs Supra *Video*
- greddy vs turbonetics
- Is anyone on honda-tech an HKS Dealer?
- Reference page: vouch for me.
- need help finding a turbo manifold for my B16
- damn oil leaks :thumbdown:
- HP limits of stock sleeves and pistons?
- greddy blue box or black box....????? whats the difference
- BIG D-series problem, FPR help!
- turbo oil return line leaking
- Skunk2 Manifold on a b16 head / gsr block with boost - worth it?
- Dumb ? - Is the FMU still used with the VAFC hack?
- Larger Downpipe causes boost creep?
- Drag Dealers come here!
- JRSC CO2 manifold cooler
- Which lightweight flywheel will not grind????
