View Full Version : Forced Induction
- Anyone have problems with the HKS SSQV?
- Who has the Greddy SOHC civic intruction manuel?
- What Spring
- how bad is a turbo for your engine?
- should i go twin disc? help asap feedback please
- DC Sports on JRSC Lude, good idea?
- Fuel Cell pics needed.....what is legal and what is not?????
- what are these b16
- anyone running an external fuel pump (single standalone pump, not inline)
- I need someone to host a really good wideband article!
- rad question?
- aerodyne inline pump?
- will HONDATA work with a VX ECU?
- 3" exhaust system or just piping
- Anyone with a Greddy kit?????
- light flywheel helps?
- atpturbo cutout
- Anyone using crower stage 2 turbo cams??
- Inline Pro Turbo Cams, anybody use them?
- Rebuilt turbo questions
- Oil Feed Question
- anyone know about the tuner shop in mechanicsburg,pa
- oil coming out of my breather
- 440s + Hondata - turbo = driveable?
- An apology concerning the VSV guys on H-T
- Car sputters....d16z6 with Greddy Turbo...
- Burns Stainless/ Saturn Motorsports Turbo Manifold
- Nut size to cap EGT bung
- crankcase breather filter?
- would a t3/t4 from a drag 3 kit be good for my ls?
- AEM EMS Tuning ? about timing vs base timing
- best motor oil for boost
- How do you make a Vaccum Manifold?
- small radiators without problems?!?
- Question for Moates burn1 / Uberdata…
- which is the biggest injectors i can run without a resistor box?
- another ssautochrome turbo problem
- Question about rotating the turbine housing!!! HELP
- b18c5 turbo
- h22 dilemma...
- Smoke from a new turbo?
- 65-60mm d16 t/b. Any gains?
- Nitrous jetting question
- Autometer mechanical water temp gauge???
- that call for help
- smaller pulley for comptech supercharger
- What is .3 Bar In PSI?
- Here's what i got... which to go with...
- mobil 1 stops oil consumption?
- Helpful TIPS
- BLKCRX Autosalon Review 400kw CRX ;-) + 700 Pics
- CAT or resonated test pipe to quiet exhaust???
- does race gas clog fuel filters? Leaning out real bad
- d16z6 missing under boost
- Turbo build
- Fuel pressure problem HELP!!! ASAP
- Arp head studs worth it? or just hype?
- vht flameproof coating... jet-hot coating alternative... what do you think?
- how much boost should i be able to run?
- Lowering the compression on an h22
- Please Help! differences between 5 Bolt flange?????
- turbo help
- this t3 69 trim any good(sohc)
- Precision Intercooler
- JRSC Removal help
- B20/Turbo or Ls/Turbo?
- How many or you...are running a CX manifold?
- DelSol DualCore Slim Fan--Where to buy?
- Which fuel pump?
- OT: Rear Crossmember 4link setup on 240SX
- Blowing out the spark on a semi-high hp setup....
- im having a problem with the o2 sensors on my header
- question about ports and installing turbonetics godzilla blow off valve
- Garrett T3 Intake flange
- PLX readin problem........need some help please
- Car wont stay at a constant boost level above 10psi ---help!!
- jackson supercharger question
- need help wideband experts
- Crower 403 cams with boost?
- Has anyone tried to upgrade a Hondata?
- Thats it, its been long enough...internal build is going out the window...
- Site for tuning the AFC
- twin blowing a 1.6
- Emanage problem (already searched) please help.
- SOHC turbo soldiers get your ass' in here.
- Dyno #'s of my b16a2
- sve conversion harness
- F22 Turbo Manifold? (tubular, polished...)
- Turbosmart e-Boost controller, anybody use it?
- wasgate troubles
- replacing final drive gear -
- blox/wicked fmu?
- how big of a difference will 3" piping make instead of 2.5"
- Sensor settings for V-AFC with 3bar and Hondata?
- B20 Vtec 8lbs of boost
- Clutch problem....
- Greddy turbo timer instructions
- Darton MID sleeves
- Who makes a..
- launch problems
- fan relay keeps going.....overheating
- T3 .60/.63 Can I push 300whp out of a built motor with it?
- What makes one intercooler more efficient than the other?
- oil feeds question
- vacuum line routing for turbo
- Damn Stupid Hillbilly
- D-Series HG Question!
- have to make decsion today!
- d16y8 turbo or b18b turbo
- 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP!
- HKS BOV Fluttering: No Pshhhh
- Worth Cutting Bumper?? (PICS 56k ok)
- any have the smc instructions?
- milled head with turbo??!!
- Stock MAP sensor and AEM EMS
- rookie needs help
- T25 question
- Trying to disconnect my vafc for uberdata
- Party Time in W. Palm Beach for Nopi races...
- Engine Break-in with turbo...?
- Stock GSR(Full race kit) back to the track
- Uberdata Tuners in SOCAL?
- too much overlap cause lower compression test results?
- NGK BCPR7ES-11 Spark Plug Gap?
- Turbo or not.
- 2 switch or not 2 switch
- Just changed y oil and...
- PLX Wideband question (datalogging)
- anyone have problems with autometer egt gauge?
- Accord EMS?
- Turbo/Hondata help
- Another video! (been playing with fcp and motion)
- oil feed line help
- car won't idle
- Blue Box Questions.
- a few concerns about my new turbo set up.
- Map sensor?
- Interesting comparison and am I done for? Spark plug related.
- MAP sensor
- Tuning Advice
- Oil in coolant burning oil.
- Oil in water fill tank
- Adios 4th....
- anyone on here make there own 4" exhaust?
- High Comp, High Rev, Nitrous Fed D16. How To Manage Ecu/Fuel/Timing?
- Where can i tap for oil besides the sensor? -searched-
- main relay problems after a walbro install?
- TIMING question on a turbo B16A HELP ME
- Omnipower Coilovers good for future boosted Teg?
- 1996 civic B18C1 pushing 500+hp question
- help with finishing my turbo kit
- Hondata tuners in Europe
- D15 + Turbo ?
- Installing a supercharger to a d16z6?
- boosted f22 or h23
- probe rods- anyone use em ?
- Greddy Blue Box Wiring instructions
- traction problems ! i need help?
- Please help Diagnose my problem. Engine stalls and dies.
- Suggestions for keeping tires down
- turbo install pics
- help! 450cc injectors running like crap, car sputters/hesitates
- Turbo Start ?'s
- turbo manifold on B16a with 2 O2 sensors
- would timing map be the same?
- Need help with custom turbo build
- More problems! This time injectors
- by pass valve
- What is the correct thing to do...
- Ringlands -- All four broken (Pics)
- What clutch to use on daily driven turbo ITR
- how can you tell if you have dsm injectors?
- OIL/COOLANT in my EXHAUST......
- Question about turbo specs for what i want to achieve
- the new setup is underway!!@!
- Clocked Turbo, Now Shaft Play?!?
- Akari Motorsports Dry Film Lubricant 100miles No Oil Test
- who makes a 15x4 inch rear drag rim other than bogart??
- Need Advice on setup
- My BIG TURBO Post. High HP D16-T Inside
- HELP need part number for greddy oil return flange???
- $400 homemade turbo kit
- WASTEGATE Greddy Kit on a b16 what are the problems?
- anyone have a dry nitrous chart size....for ZEX, i need a 35 shot
- Greddy intercoolers type 24 or 31?
- b18c1 help
- hondata s200b and dsm 450 idle issue....
- Think test pipes don't make a difference? Think again!
- When to upgrade to 4" exhaust?
- Gah... oil lines too small?
- turbo rebuild. is it difficult?
- crack in wastegate tube what would that cause
- Other upgrades for more power?
- could i keep my a/c and power steering ?
- Better tranny for turbo? LS or B16? Y?
- ~Fastest JRSC'd car?~
- Northern Alabama Tuners
- t25 or 14b?
- wideband? Need help asap
- need advice on head build for boost
- getting a boost increase when vtec hits
- Greddy Turbo Timer
- whats the maximum amount of boost if any that can be ran safely on stock injectors and uberdata?
- Shaft Play, How much?? (no jokes)
- My review of the Zeitronix wideband
- 7lbs of boost and not going anywhere...
- Car dies after I press the clutch in, NEED HELP!!!
- when I reach that amount of boost or at low boost for a while in high rpm the car will hesitate the
- D16y8 - vafc - 7 psi -injector size???
- Where do I get full fiberglass civic shells for my rolling chassis?(carbonfiber ok)
- my newb question for the day
- Lowering Compression using headgasket???
- Blitz Dual SBC Spec S Vacuum/boost Hose diagram or how to?????
- PSI vs HP
- inline resister install and rev's question
- is this considered a fmu for turbo?
- Does this make sense?
- Blitz Boost Controller Install
- T3/T4 with .60 Comp. A/R and .80 Turbine A/R - To big for built nitrous D?
- how long will i last?
- anyone running a 16g on a b18b?
- Anyone running 3" dp with love fab with A/C?
- Here's the Compressor map what the hell does it all mean?
- Question about Vortech 12:1 FMU
- D15 Turbo
- gm 3 bar map sensors
- --- Questions about Handata and maps---
- Need Hondata Dealers Help!
- Running crazy rich, help! Borrow a WB anyone?
- boost + map sensor = HELP!!
- 2001+ Civic D17 Turbo Kit
- I'm going to get tuned....
- poor mans type R and turbo
- What options are there for h22 t4 turbo manifolds
- LS turbo Not spooling help needed ASAP
- t28 what flange?
- Vacumn source
- How many of you daily drive your boosted hondas?
- SHOULD I PUT 310CC INJ UNTIL I GET TUNED?
- revhard kit
- Engine Lab of Tampa
- Anyone have tips on mounting JRC intercooler to g3 integra?
- Any of you FI'ers going to be at Battle (Joliet)?
- Question About Motor Mounts
- check engine light
- Emanage with FMU????
- My motor is dying :(...
- retard timing affect performance ?
- Couple questions that need answers for a newb.
- 10 psi on stock b16, want to turn it up.
