View Full Version : Forced Induction
- Aeromotive question??? Help me please
- Advice in SuperCharging and Turbo setup (Frankenstein)
- Turbo choice for Nissan Ka24DE 4 cyl (2.4) 500whp
- waste gate elbow
- Hondata s100b price changes
- T25 turbo bolt up to a t3 flange?
- When does the walbro struggle
- good stock sohc headers
- Combinding 2 wastegate springs
- dohc zc turbo ek
- E85 is the shlt, C16 can go down the drain
- MAP Problems, No CEL..?
- Small Fuel Filter Question
- ZC DOHC Head Gasket
- When did you switch to syntec after break in
- heat wrap
- turbo teg questions ::emissions::
- FMU on d16z6 greddy turbo
- taking a turbo apart
- F22B1 manifold
- vband clamp
- IC piping and windshild washer fliud bottle... eg,ej???
- Hondata intake manifold gaskets push coolant??
- Is this possible?
- ls vtec turbo setups chime in
- H1E turbo for b16?
- knockoff bov on ebay
- Who's A good Person to buy a basemap from?
- What size Front mount intercooler fits EG without cutting?
- best intake manifold
- Question about valvetrain
- Fuel Pressure? (95gsr jrsc)
- wastegate elbow
- Cam gear question
- Vacuum guage sluggish? GSr tb
- 400 whp question log mani and sc61 turbo
- Turbo id help and need some tech ?'s answered. ****
- Intercooler pipes for turbo B Series EG?
- Code 36
- what's goin' on?
- q bout clocking turbo for return line
- Wiring three wire TP sensor/ on a four wire harness (DSM ?)
- bad idle 1800-2000 RPM ??? searched!!!
- EGT ?
- golden eagle rods?
- FMIC on 5th Gen Hatch w/H22?
- boost spikes in cold weather, GReddy Profec B 2, or mechanical problem?
- dsm metal bov
- What inline fuel pump is this
- Walbro 255 Fuel Pump
- 84 mm b16 boosted numbers
- Wiring and installing an aem 5 bar map sensor
- Quick question about ressistors
- hondata s300 2 step
- turbo smart e boost 2 any info???
- -12an oil cooler lines too big?
- 355whp 340tq oh my....
- burning out igniters........
- first turbo set up
- EGT
- SCE gaskets!!
- i got a problem my wastegate blew off my manifold!
- need mad crazy help!!
- Computer Tuning Programs that i can *Buy*
- 9.0:1 cr in b18c, what would that be in a b18b
- Replacing valve seals?
- Still breaking up...h22 peakboost kit
- supercharged b18a?????
- CRAP i put the valve seal on the wrong side...how to remove safely!?
- any one useing this fuel pump
- how much turbo cost
- Machine Shops in S.D.
- help me gather the right parts...
- itr dual valve springs & ret. vs After market???
- what flange are greddy turbo kits?
- Quick catchcan question
- why would my 0bd0 ls not need a ML and my zc does?
- h22 turbo kit
- 22t water pump on LS. gsr timing belt?
- Intercooler question help please
- EG turbo install HELP! DSM injector wiring
- lsvtec teardown: help me make sense of my deck, sleeves and pistons
- my lsvtec turbo set up . 295whp / 199tq.. hella weak
- quick question about hondata
- Injector harness question
- Got an idea. What do ya'll think?
- best IM/TB for turbo
- Turbonetics Godzilla BOV vs. Tial BOV....................
- ARP Nut's and washers?
- B18c1 block with a B16 head?
- Compression
- Do my plugs look fine?
- How can a turbo make no boost? plz help
- I know is not an Honda but...
- jackson racing s/c
- question on a turbo manifold
- Is there a possible way of makin 350whp on this setup on a b18c1
- can someone justify using a GT35R to make 450 whp
- Cant Rev past 7k.
- Tuned setup leaning out?
- Platinum Ir Fusion plugs??
- has anybody achieved 450+ whp reliably with 93 octane?
- rise in oil pressure?
- if you had 1800.00 what parts would you buy to build a 91 crx si b18c1
- Best A/R ??
- please help gm 3 bar map info needed
- Building Turbo Dart, Mahle Pistons, Pauter Rods, Eagle Crank
- K series build up AFI manifold
- Finally finished my setup!!
- WTF is this thing?
- Help==>Black smoke,,,,,searched!
- ls vtec turbo overheating
- power gains with JG IM
- Mid sleeves VS Flanged Sleeves.... whats the difference
- Car sputtering ?????
- Bigger Injectors?
- serious question help please
- WTF water spraying outta my BOV ON DECELERATION AGAIN HELP???
- headgasket question poll
- b16b turbo headgasket questions
- Street Sleeper - GT28RS (SSAC) Is this turbo perfect?
- Factory oil cooler????
- What Turbo Kits?
- Turbo max hp
- Wiseco 81mm GSR piston rings?
- can you fix a manual turbo xs boost controller
- Precision 1000's + Resistor box readings= Correct??
- t25 bolt on a t3 flange ?
- where can i get a dp flange?
- anyone turbo a zc
- 93 EX LS-T almost complete! ah lil help please ;)
- gt4294 SFWD civic update as of 11/9...BoostedJeff...get ya some!
- weird idle
- tilton hydraulic release bearing or stock honda hydraulic fork? which do you use and why
- Non vtec turbo buildup advice
- anyone using one the the 14b flanged ssac manifolds
- Need some Serious Advice on Tuning my JRSC CR-V with a crappy setup
- need one rc 500 injector
- How do you know when the clutch is slipping at higher RPMs?
- ACL race bearings or ACL reg bearings?
- turbo teg radiator question
- Full-Race music video?
- Directions to Evans-Tuning???!?
- Looking for mandrel bent 4 inch exhaust
- whats wrong with my valve/rocker arm?? b18b motor. pics inside
- HELP WITH GREDDY OIL RETURN LINE
- is this an SFP manifold?
- wont idle with 3 bar map
- Probably a very, very stupid question about SS oil returns (bought from stan)
- Low Idle problems
- ZEX 59300 cam
- D15B7 with H22A injectors?
- turbo experienced people wanted...integra ls turbo stock
- Twin turbo Ford GT
- Greddy Manifold Cover?
- where to find custom catchcan
- value of this blowzilla. T3/GT40
- World Motorsports PBC-1, anyone bought one yet besides me?
- Built GSR Turbo or Built POOR MANS ITR Turbo ??????
- OBD-0 450cc injectors
- 750CC Injectors
- need opinion
- Exhaust Scavenge for Catch Can
- help!!!!!!!!!!!! g2 craps out after 4 grand in 2nd
- Drag kit on gsr swap....boost creep/spike driving me crazy..Help!!
- GT28RS "disco potato" on an S2000?
- LS idle prob after turbo install
- Turbo oil presure help B18C1
- Ls/Vtec piston question....
- strongest honda rod ?
- where can i buy a battery relocation kit or a 97 civic coupe?
- Who can get Carrillo rods part number #CAR026
- Hondata S200 Question
- thermostat opens idle. not under load.
- GE intake manifold
- Injectors, what kind??
- max psi
- Turbo LS - why is my car soo damn hot? ac blows hot air, even with ac off, blows hot air
- timing with TILTON clutch
- head studs
- Setup any good?
- Finally found a supercharger comparable to a turbo setup in power
- Fuel pressure question ???
- Is a muffler like this one going to kill power
- Any experience with this turbo?
- S200B VS S300 User Friendly
- ARP Head Studs: Taper, Dog Nose, Dimple etc
- need guidance
- Vibrant Performance SEMA Turbo Engine Stand
- Preparing D16 for boost.
- installing bwm turbo on d16z6 stock engine
- manifold studs broken
- boost without forced induction?
- IS THIS POSSIBLE?!
- Engine builders: Do you prefer a thermal or oem intake manifold gasket?
- safe to drive car?
- ls vtec question
- ? with nitrous fuel solenoid
- I think my engine is running rich...AEM files corrupt?
- breather fitting question
- LS-T or LS wit spray????
- Is 9500 safe on a B18C with boost
- Built Z6 started making a weird noise. Any ideas?
- Place that sells the cheapest Reducers/Expanders?
- Bad ECU?
- post your water-air intercooler setups!
- 4g63 Civic hb, Why??????????
- Vacuum fitting........
- Water/Methanol Injection Set-Ups
- Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!!
- jackson racing supercharger question
- H23VTEC Turbo build with tech by ludesleep
- T4/T67,T3/T67 or a GT4088
- best upgrade from a t3 garrett 60 trim??
- Is 2600 For a Sleeved engine W/ Arias Pistons and Eagle Rods good ?
- is it possible to have an equal length turbo manifold on a h22 ek civic while keeping AC?
- wiring help, conversion harness
- using 8:5:1 pistons?
- How much boost/WHP before I need Catchcan?
- JRSC PLUG GAP QUESTION.!!!!!????
- KMS vs. ITR/GSR
- wategate spring advise
- rod bolts?
- can u run an N/A motor with s200b?
- oil feed line and return line location....
- Can somebody point me in the right direction? I need a stock SC pulley for....
- what to do...
- Blip the throttle in idle and bov does not whistle...
- Mega Squirt Standalone
- b20-vtec or ls-vtec with jrsc????
- My built LS Vtec Turbo Motor..... let me know what you think
- how much HP can stock ignition handle?
- Backdoor vs Traditional FMIC... Pro's and Cons
- anybody have a g2 teg with pics of their ic piping im stumped
- What turbo manifold will fit best on a B-series civic with A/C
- Nitrous + 5th gear question.
- Turbonetics T3/T4 turbo- do i need oil restrictor?
- 8:8:1 Pistons...
- plx wideband install resistor
- methanol aem ems
- Oil Filter thread problem. How would you fix this situation.????
- need help new to hondas
- injector questions
- 84mm Sleeved GSR
- 10-20 PSI JRSC setup
- dyno graph and setup
- HP Guess.. No dyno here :(
- different piston-to-wall clearances in one and the same block?
- noobie injector question. i tried searching.
- Flex pipe lenght
