View Full Version : Forced Induction
- Will I need these?
- innovative wb discount
- Dumb Question
- turbo????
- timing question/problem..plz help
- Fitment questions...Down pipe, block grinding, AC
- arp exhaust mani bolts
- Low compression Head Gasket
- where can i find a throttle body to match my edlebrock intake manifold?
- When should you upgrade you Intercooler piping.
- Garrett Dual Ball Bearing Turbos
- who makes speed/gear based boost controllers
- field settings w/ zex kit
- moved: something I saw the other night: got questions
- Exhaust Cut out - Post facts Please!
- thinking about tubro
- Has anyone used one of these as a boost controller?
- tubo ls nitrous
- pistons n rods?
- 3 bar map
- High Compression Low Boost -- VS -- Low Compression High Boost
- DOHC ZC BUILDUP need help guys...
- JDM b16a sir2 turbo question
- what do you turbo guys do for traction?
- how much power is too much on the streets?
- Turbo for a d16y8
- CCA 31" x 6.5" x 2.75" intercooler.... good for 400+whp?????
- no oil getting to turbo..
- What lines do i need for my JRSC.
- Do I have everthing I need.
- Head Studs/Cometic Headgasket on stock Block GSR?
- PCV line questions What to do with the CCV system
- OMGITRUNS! Specs, Pics & Questions!
- NEED HELP! Huge OIL leak after rebuild....
- injector resistor box wiring REVERSAL
- B18C1/5 crank in a B16a3 USDM shortblock?
- T3 on a B18C1 (how much is too much?)
- Jacksson racing on ITR 10 PSI
- Dropping .2 liters...
- d16 sohc log turbo manifold t3 flange
- h22 adding garret turbo, engine mods needed?
- Resistor Box Question for when using DSM 450s
- D-series manifold info needed
- **Need some help with turbo spec questions**
- Where to get a oil restrictor at for cheap?
- Introducing Flat-Rate B18 Twin Turbo (56k not today)
- DENVER TUNING SEMINAR JUNE 5-6, 2004
- HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions
- civic si turbo vids
- newb at turbo
- what lsd to buy?f
- nitrous civic
- h23 oil tap
- turbo manifold????
- B20 turbo. runs lean, please help!!
- integra turbo filter ?
- Help..First time tapping a oil pan
- C0-2 Intercooler spray?
- wat turbo did i get with my rev hard kit
- I need help puting together a custom turbo kit
- car sputters after a few gears of boost
- enough fuel?
- will turbo fit on gsr motor in 91 hatch?
- help!! is this wastegate hooked up correctly?
- Lean, Rich or What?! Timing?
- quality manifolds
- 14b fitment issue
- 2 vacuum fittings on greddy type r blow off?
- Apexi AVC-R in metric WTF?
- SRT-4 Intercooler on an EG?
- Code 19 !!!
- Greddy Turbo kit HELP!!
- im just about to turbo my car,am i ready?
- topline pistons?anyoneing useing? any good 4 nitrous
- My Setup!!
- highest hp here?
- what kind of turbo is this??
- Got a cool toy...(pics)
- wastegate or boost controller?
- What size turbo for 450whp on Built b16 block? Good spooled up
- Broke a exhaust housing bolt, and cracks by wastegate opening
- revhard stage 2 b18b
- Easy Gauge Wiring Question
- Length of Brake Booster Vacuum Line with Vacuum manifold??
- question on management on a d16z6 . . . ???
- turbo inlet problem
- Where can i find all the stuff for a backyard turbo kit?
- Fuel Pressure Regulator Adjustment.
- SMC500 troubles...
- is this intercooler any good?
- Part throttle & boost & closed loop
- vaccum line keeps coming off WG!...wtf
- a-pillar gauge pod...what brand is best??
- turbo question
- Air Filter Replacement
- ls turbo
- JRSC intake manifold temp guage?
- nos bottle
- what is your air flow for your boosted engine?
- wiring vtec
- hks evc...???
- going to the dark side
- Turbo Kia Project .. Who would of thaught..
- 92 octane pump
- stock cars with external wastegates??? (preferably junkyard)
- Need a little help with gauges!?
- how to swap internal gat to external?
- t-25 turbo internals for greddy ??
- 4-Rib belt on JRSC for a D16Z6
- Need Help Starting with Standalone (Autronic)
- a/c with turbo
- the hotest new thing on the market(56k no way)
- Crank Pulley same on 1gen/B16a as B18C?
- turbo. keeping a/c with compressor on the driver side?
- Will a hone fix this?
- Drag manifold + tial wg with .5 spring is overboosting
- clutch net
- How much extra work is it to maintain a turbo daily driver?
- New England area tuners (uberdata). Need some help.
- engine builder suggest this....
- AEM gauge type - no longer working after using race gas
- oh yes, I have an GT30R in my hands *droooool*
- Need wastegate elbow for hks wg, who can help?
- NOS kit questions
- Turbo where can i get it rebuild at
- Tilton Clutch Master Cylinder?
- Need info on wrx turbo
- Drag gen 3 question.............???????
- Major Problem (weird circumstances)
- turbo and emission
- all JRSCed GSRs tell me your setup
- d16 head torque specs
- Question for the turbo and exhaust experts
- Can't get this 3-bar to idle correctly..?
- A few questions about FI on my 99 Integra GSR
- AEM UEGO with hondata compatability
- What size turbo/manifold bolt for Inlinepro mani?
- Welding intercooler tabs to bumper support??
- d15 turbo help!
- Injector Questions
- anyone in nj/ny area looking to get tuned by mase???
- AVCR: Please help!!! GRRRRR.....
- dsm injectors? please look
- TiAL BOV rubber seal
- Drag turbo t3/t4 info.. Please help..
- Back from dyno. I'm happy.
- arp studs, giving them that extra turn...good or bad
- 2nd time busting belt
- Timing belt snapped bottom end gone. I'm done
- turbo kits
- b20b or ls motor for turbo
- Where can I get a T4 to T3 flange adapter?
- should i turbo my EM1? need tips
- YO, NEED HELP WITH TURBO B16, CUSTOM T3 KIT----WHITE SMOKE
- equal legnth. what are the benefits?
- new problem with drag kit install
- Integra Hondata on Dyno today, Problem!!!!! Plz help
- JR supercharger in 98 ls in eg question
- oil return line and oil feed line?
- Upgraded clutch master cylinder?
- Please Inspect my Return Line (56K YES U CAN!)
- can somebody give me a hondata basemap?
- Hondata street tune???
- turbo oil lines witch ones whitch ???
- would it be better to replace my t28 with a t3?
- what piston and comp. ratio size for stock bottom?
- whats the best tranny for ls motor....?
- turbo setup...
- Which motor
- How much boost would you run?
- ..Just got back from the machine shop; motor setup inside with 20 pix! :)
- where to get acl rod bearings?
- Running To lean . . . . . Why?
- ALTC wire and hondata?...
- ~Need some advice on guages~
- Temporary fix for oil feed?
- Uh Oh! Another exhaust thread... But this is different
- anybody ever get their manifold flame sprayed?
- precision sc61 too big?
- Is there a "failure" point for Drag Manifold? How much power can it withstand?
- Wich muffler? (searched)
- Turbonetic t3 to4e - 2 1/4 inch exhaust side. What should I do for a 3" downpipe?
- What HP level is a Tial 35mm HP good for?
- Detonating still....
- Safe AF for 50/50 water/methanol solution?
- at what point do the stock axles need to be replaced?
- more boost when e-cutout is open....normal?
- Gsr Turbo... need help ????
- **what RODS are you using**
- oil pressure
- How to check to piping leak??
- Precision SC54 or switch to an Innovative SC61 Killer?
- Question about upgrading my t3 turbo..
- Is this piston slap? (video)
- Oil light problem
- Who makes a nice liquid filled fuel pressure gauge?
- Rev Searching / Jumping Idle still Help Please!!
- Probably going to get hondata, but...
- CEL #5..
- Exhaust cutout plate .. ...
- Here's a small clip of a direct port nitrous system spraying.
- connecting rod bearing sizes for crower rods?
- What's best way to check for air leaks in ic piping?
- !!!!!! WHAT INTAKE MANIFOLD FOR TURBO?? !!!!!!!!!
- b18c5 + greddy turbo kit (18g) - suggestions and comments?
- Which timing belt to use for this setup?
- Wired AVCR, won't turn on?????
- Tire spin too much, help...
- Just Got a weird Garrett t3; help!!...Pics inside
- MY FIRST HOW TO: making a flange for the Apexi Filter *PICS*
- wierd problem after injector install
- anyone running a T3 super 60 on a Lovefab SHorty while keeping AC. D-series
- RC 550s, basemap burning, and cost
- B18B Swap/Turbo Install Woes...
- Did some street WB tuning with Uberdata today!
- April 18th Import Showoff race in Louisiana
- b18c1 turbo, and upgrades
- i need a shop that installs turbo kit in los angeles. do you know any?
- My new turbo b18b project
- how much is a hondata setup
- exospeed cams?
- OT:I knew I smelled something.......
- Any one here rebuild there own turbo.
- Bosch FPR any good?
- bunch of dumb questions
- anybody make long distance road trip on their FI honda?
- eg with ls motor and turbo track times?
- s2000
- What charge pipe connectors for <10psi
- Attention: DRAG Turbo Kit Owners
- any comments on this T3 60-1
- Will this be ok?
- greddy turbo kit install help
- Easy Air Filter Solution even in tight spaces!
- Anyone know how to tig weld that can help me out?
- Torque to yield
- compression question
- CP and Wiseco same bore?
- please vote....conpression ratio w/: turbo Question
- 3-bar map sensor on low boost
- Boosted R with a Hondata or an AEM EMS??
- New project
- What kind of hp numbers are you getting with your JDM b18c w/turbo?
- Raise the boost? Stock bottom end B18B.
- Quick question for hondata owners
- What are the limits of the D serie IM ?
- Hondata and VAFC-II
- Anyone using the AEM wideband yet? With Hondata?
- WINDOWS INTERACQ Software for EFI
- any retired turbo fanatics?
