View Full Version : Forced Induction
- LS/VTEC Turbo 9psi 310 HP
- B18C Turbo DYNO 303 11.5 psi.
- ITB's with FI
- Help...does anyone do deck plates (extensions)?
- colder plugs?
- What oil to use with boost?
- whats better for sc'ing?
- Two accesories off same RPM signal, different functions?
- Pivot full auto turbo timer wiring?
- Do I need to bore/hone?
- Debate over Fuel Injectors! Some do a write up *PLEASE*
- How the hell am I gonna get a bumper over this???
- TURBOEDIT!!!!!
- B16A turbo DYNO 301HP 200TQ 11.5psi
- Those running the Golden Eagle or STR Intake manifold
- what causes gunk/sludge to appear around the Throttle valve???
- ordered some JE pistons got a question
- customizable SOHC turbo kits?
- Cleaning out the garage lots of stuff everything OBO and some turbo stuff.
- What does this have to do with forced induction?
- 350 whp @ 18 psi - Sound right?
- GSR turbo help
- What Turbo Set-Up Should i apply to this Stock Compression built H22?
- My b16 turbo dyno vid
- Integra Turbo
- Zydne users....so who is running the biggest injectors in here with it?
- ProDrive USA name change
- vafc vs safc
- Running to rich question
- question
- Greddy pos toy TD04 turbo finally bit the dust... What to do with it?
- best way to keep check light away and tuning tips
- Need HELP! What is going on?? Need all turbo experts and motor specialist on this one.
- Suggest a turbo for my setup
- Do I need Boost Retard w/ only 8 to 10 psi boost??? w/ SAFC, 450cc injectors..??
- question about full-race turbo kits and wastegate dumptubes
- Oil Pressure issue (look y0, it won't take long)
- Broken Mounts
- anyone have a FET turbo timer?
- tuning timing map, need some input plz
- Intank and inline fuel pumps together
- Dodge Daytona Map Sensor
- JDM ITR Cams good for turbo or buy other cams for turobo?
- GSR Block Reconmendation Sleeves for turbo
- B16A2 With Greddy Turbo What kind of numbers are you putting out?
- short and sweet, what paint to use....
- Leaning out for ~30 seconds then it goes back to pig rich..help...ready for turbo install
- Ball Bearing Turbo Noise?
- How many pounds of boost can i push with an LS Vtec?
- Downsides of turbo
- What size of injectors good for 350-450hp
- Teflon tape on return line fittings
- trust fmic intercooler ic
- 366WHP@10LBS stock internals....(56k beware)
- what other manifold places turbo where DRAG KIT does????
- Has anyone ran the areomotive fuel pump this way?
- HELP car starts but wants to die.....
- Dent in bottom of intercooler effect performance?
- car shuts off unless i boost.
- SC34+D16Z6=???????? anyone running one on their d-series?
- simply bad ass
- Heat Rap for drag 3
- I'm tryin to build a 500 HP or more car, and someone told me that i'm gonna be going thru Tranny's.
- Plan on buying a turbo soon...
- Oil return? Wrong or Right? *Pics*
- Anyone try this Wideband - Zeitronix $279!!!
- SSAC Turbo's
- B16A2 Going for a turbo which one is best? FMAX, DRAG 3, REV HARD??
- B16 Turbo Tires and ET:s
- wastegate hookup ?
- Calling All Tuners
- About to boost a 120,000 mile B18A motor.. is it okay???
- Turbo done! What next mod for most hp gain?
- how to clock a turbo.....need help
- Does trim size determine power??
- any one know where to get good turbo manifold for a good price
- GSR block or LS block???
- Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots?
- boosted f22a1 or h22
- Is 350whp possible on Ls/Vtec with AFCHack
- do you need a bigger fuel pump with zex?
- Where can i get sohc dowels....
- HELP!!
- ++++++ CALLING ALL TURBOED D16Y7+Y8S +++++++
- jdm d15b rods weaker than the d16's?
- Greddy Turbo Kit...
- recent spoolin projects/ customers
- Analog Turbo Timers
- jdm B16a how many deg. do i retard per psi.(timing issue)
- INTEGRA'S AND CIVICS WITH TURBO....LOOK...
- Problem with Actuator Arm on Internal Wastegate TD04H...
- noob here need a lil help picking parts
- breaking in a new motor build...
- sc44 .63 a/r - 76 trim on ls
- Stroker Kits?
- Hehe...O yea! FIRST TIME BOOSTING IN 3 YEARS! YAY!
- Wont turn over :(
- How to setup my ECU for turbo? (I'm a newbie)
- full-race.com...
- Valves...need opinions
- Holset HX40 help
- Greddy 15g kit on EK
- hondata Base map
- 86mm bore on boosted b20 dartblock will it last?
- T3/T67 worth it on a stock block LS/VTEC?
- stock b16 turbo or stock ls turbo??
- Downpipe Questions
- Interchangable head items
- HELP-jrsc-d16y8-91si
- nitrous on stock ej8
- Turbo size question..
- Green tops or blue tops?
- just got Tuned...*hack*
- LS turbo running a p28 with hondata issues
- Would a TD05H-18G fit a...
- tell me what you think?>???????????????
- Long starts after turbo install...help
- FMIC and fog light cleareance.. searched but cant find it!
- gsr fuel pump good for greddy turbo kit?
- EFI UNIVERSITY NEEDS A HOST SHOP FOR SEMA/PRI
- integra intercooler mounting?? please help!
- any USDM B18C5 turbo?
- Valve stem seals - should i replace ?
- Boost leak?
- whats the biggest turbo with stock bore gsr
- who runs a 60-1 turbo and tell me a little about it
- White Smoke? Turbo or Engine Blown?
- knock sensor connected to oil adapter
- Question About P28 Using Uberdata and IAB??
- Tial 44mm Vband Wastegate problem, and project update. AEM EMS YAH!
- Base map needed
- Turbo B17 Daily Driver
- Turbo for daily driver
- noszle system
- Huge Problem with Mahle Pistons Quality...anyone else?
- Hondata led light turns off???
- Those with Greddy kits, where do you get replacement gaskets?
- Hondata and irregular idle....
- anyone using these mufflers or know how they sound
- boost on LS bored 20 over and no sleeves????
- can i turn up my boost??
- could u tune out of boost fuel maps using info from apexi turbo timer a/f settings?
- Ever Purchased From Car life inc?
- question about tial wastegate...
- Supercharger vs. Turbocharger on B16A2 in a 99 Civic?!
- limit of d16a6 head??
- Need spark plug help, did a search already a few actually
- Anyone w/ burner near cen. ca.? Left mine at my other place and need burn asap
- Unusually low oil return line / turbo placement... need wisdom...
- piecing together d series kit need help!!
- MISSING LINK
- Edelbrock 65mm Throttle body with Performance X Intake Manifold
- lean after inline fuel pump and fmu?
- nitrous express fuel tee
- seating cast piston rings vs moly
- How would a JDM ITR LSD hold up in a high horsepower GS-R?
- who uses electromotive total engine control units(tec)?
- Piping problem with a 96 ls, need help ASAP
- Mystery Oil Smell, HELP
- PWR barrel type intercooler
- anyone have the specs on b18a1 nonvtec ls JG301'S
- t3/t4 turbo, boost leak
- HELP!!...my XS dual stage has a mind of its own.
- Ls/vtec with jackson racing super charger?
- OBX Resonated Test Pipe Fitment Question
- T3/T04e exhaust flange
- clutch masters stage 3 firmness on d-series...please look
- good or bad for boost
- 2.5" or 3" exhaust sc34, b18c1
- Ferrea or REV valves ???
- Need advice on car running super rich
- How do you know if you broke ring lands
- misfiring @8200rpm tiil redline!
- Maxed out 720cc injectors at 12lbs?????
- resistor box install
- compression with 8.8-1 pistons in a zc
- oil cooler qeustion
- GREDDY INTERCOOLER! URGENT!!!!!
- CP 7018 Pistons 84.5mm 9.7:1 (Pictures)
- help (not a honda)
- Andy's Autosport California Type R Bodykit Light Question?
- D16 gasket question
- My D16
- SC50 horsepower
- HELP: fuel pumps
- Anyone here had success with Cometic 0.078" or greater gaskets
- HELP: Saturated or peak/hold?
- anyone have a picture of that fat ass muscle car that was posted in the FI forum?
- turbo f22a6
- BOV on a supercharger?
- is timing retard necessary for 7 lbs on stock b18c?
- Are stock oil pumps good or not??
- MAP Sensor Reading Peaks Out - Not Matching Mechanical Gauge
- Precision Injectors question
- Looking for that yellow civic video, hatchback, eg (sorry)
- my 10 psi GSR versus Emissions. another Kill
- IC pinping
- What kinda pistons?
- What kind of Studs, Bolts, Nuts etc... for Turbo Setup?
- My Garrett is done... what turbo should I buy now?
- ATN: ALL GURU Turbo FOLKS Need Major Help Motor/Fuel/Tuning Problem.
- your opinions on after market ignition system
- Supercharging stock 94 Civic
- what manifold options are out there for the 18G Greddy turbo?
- SSAutochrome turbo manifold for b-series... any good?
- Stripped oil plug in moroso oil pan?
- going to build the bottom end of my d16z6 to handle just 10-12 psi what pistons should i get?/where
- will fuel injectors from a turbo talon fit on my turbo civic d16?
- act 6 puck->flywheel damage??
- Smoking dipstick? help...
- greddy pc. where do i get this pc?
- uberdata/chrome, etc parts list?
- Adjustable Internal wastegate question
- **Recieved my BMC turbo Manifold today**
- baseline turbo settings
- what to do to switch from hondata stage 2b to S200? need help!!!!!!
- what is optimal psi range for drag III T3/T4 57 trim turbo????
- Help with turbo setup
- What have you turbo'd that was'nt a Honda?
- Instuctions for a dry NOS kit?
- Garrett t3/to4e 57trim hybrid turbo?
- The difference between a 35mm , 38mm, 40mm wastegate??
- any turbonetics representatives on this board by any chance?
- Do I need cam gears?
- how do i check injectors/resistor box
- b16 turbo manifold and a prelude b20a5... compatible?
- looking for all motor vs boost vs boost articles (read the whole thing before telling me to search!!
- strange ignition timing
- compression test/ white smoke/ i know i complain alot...but please help
- Hondata Basemap for Vortech Supercharger
- Converting from FPR/FMU to Hondata
- s I need for tuning? egt and wideband o2 Are they used for the same thing?
- Z-10 Catch Can questions?
- Good turbo size for my setup?
- Who says the 2001+ series civics have no power??
- Sorry for being away!!!
- What is the best turbo for b18c
- Boost Problem need some help...
- Help! Injector clips
- Jackson Racing Fuel Enrichment Relay
- mild or stainless
- How to tell between boost creep and boost leaking?
- HELP! vacuum connections for wastegate
- How to tell if my FJO is reading correctly?
- Cam Gears
- is this the HONDATA i need for a turbo . ..
- yay or nay for this kit???????????????
- WTB: fuel pump and injectors
- how many lbs can stock b16a2 handle??
