View Full Version : Forced Induction
- What else necessary?
- h22 turbo issue
- Recived my numbers today!!!
- Sporatic VTEC problem
- reliablity 81.5 mm cp
- FI Engine Builder list???
- SSAutoCrap...... The reason NOT to buy SSAutochrome AKA ebay turbo kit
- Does b18 and b16 share the same oil pan????
- should i get this???
- 12psi D16: Keep internal wg or go with a external?
- Catch can for valve cover? Need opinion on size
- help quick!
- what headgasket for o-ringed h22
- 91 civic b16 turbo?...
- garret t3 3 bolt flange?? need help
- should the log manifolds from stealthmode be mig welded or tig
- jacksonville, FL.....need to know if there are any GOOD tuning shops
- cams on b16a
- Haha, guess what i did
- Clutch/Flywheel for Turbo gsr
- Turbo parts for sale..you name the price.....
- Headgasket leak?
- best turbo for 250-300whp
- T-BOLT CLAMPS, WHERE??
- 14b problems(little long)
- t3/t67 vs t4/t67
- JRSC boost question
- gsr turbo in dc ?
- traction bars + inercooler pipes..
- Two Wastegates?
- gt40r LOOK
- silencer for my muffler?
- help me pick a turbo manifold
- D15 missing link
- calling all driver side (compressor) setups... where is your air filter?
- Where to get turbo xs bov flange?
- silicon connectors at local shops....
- What to do with tanabe G power exhaust????
- Has anyone here used the new Mahle H22 pistons?
- where can i find this stuff?,need help!
- questions about install on a jrsc
- who wants to give up their maps (b18b 18g kit)
- Where can I find the NGK BKR7Es?
- New Setup + Dyno numbers
- B20B Boost
- 5th gen prelude options
- which pistons for boosted b16b with itr crank and rods?
- Charateristics of t3 on d16a6
- How much power will a "LSD" Type R transmission hold?
- Uberdata users, OBDII Knock Sensor
- any news on the new omniman master cylinder
- what size intercooler piping 3 or 2.5
- Wastegate Clearance
- 10.5 CR/83.5mm GSR.........
- question on cam gears
- jdm h22 timming.... stupid noob question...
- Let's talk about intercoolers: air to water vs air to air...
- I have a greddy kit with the oil return that came with the kit. would you keep it or upgrade?
- why does a AFC help with boost? also why run FMU and AFC together?
- Looking for uberdata bin file for these specs
- Name that turbo link?
- ever seen a setup like this ?
- LS turbo manifold
- crome/efi questions
- turbo and a.c
- Intercooler pipe pops off at full boost.
- Rev .5mm oversized valves same size as stock valves?
- blue smoke??
- The best gauges???
- J/R supercharger ?????
- 2 BOV??
- Drag, Rev Hard, Greddy, Or Jackson Racing?????
- Need a turbo for D series with characteristics similiar to Apexi kit...
- total timing on d15b turbo
- Tial wastegate spring set at 7psi, why is my car running 10?
- what is the max boost a stock B16 wil handle-(T3-T04E)
- good tranny for a boosted 99 Si
- list of good tuning electronics for turbo?
- XS turbos
- Bolt pattern for t3..???
- Question about zex kit
- needed knowledge on fi
- boost taking forever
- what is the max you can boost on a JRSC
- Tech Edge WBo2. Where do V1-V3 RPM and T1-T3 go?
- Turbo Rebuild
- To: Those to make Ram-Horn Manifolds, read///
- what cams are you running on your JRSC
- LS-T, want to add nitrous.
- 4 bolt t3 turbo down pipe
- Building a turbo kit 92 DA
- ran into trouble and need help making a decision. D16 Turbo, Please check in! (turbo clearance)
- Intercoooler question...nid help
- Intercooler clearance issues?
- Who makes turbo kits for S2000 or should I put my own together?
- b16 or ls/vtec
- quick coupler question
- RSR GT2 Turbo Application
- Which Fuel Filter Fitting??
- Fuel management questions for small turbo setup
- Any experiences with wraps and heat shields?
- Colder Spark Plugs for D16z6, i need a part number.
- Boost creep ?
- selling VERY complete sohc turbo kit. whats it worth??
- will this downpipe and manifold fit a t3???
- any tuning needed?
- Need help with S2000 Turbo Project?
- Does anyone have info on INNOVATIVE SS61? Dealers please chime in!!
- Re-dynoed with H.0. T3/67
- VTEC Malfunction - Accord Turbo
- 310cc Peak & Hold need resistor box?
- All nitrous guys here!!!
- whats the rising rate of a jackson racing fmu?
- want to increase boost on my turbo D. but have few questions about the emanage.
- how do i hook up a greddy catch can?
- Question Blitz DD BOV
- je 84mm 10.5:1, flat top?
- Installed 750cc's, getting sporacic CEL's
- Head gasket with AEBS sleeves on an h22a
- About to get my h22a block built? Advice needed please
- Car idles but wont stay running!? help
- Launch from all-motor to force Induction (Difference)????
- what thickness of steel for downpipe?
- Received Moroso oil pan...pro and con of this part?
- VAFC/SAFC good for turbo or S/C setup?
- Tuners in/ around Indiana
- drag turbo kit install question
- is overfilling ok?
- best head gasket for sohc zc? building for boost
- fan switch
- need help on timing settings
- Mercedes T3. Wierd Internal wastegate. How to lower boost?
- 90-93 Integra Intercooler Piping Pics...
- Tight space issue - noob turbo install - HELP
- Coolant temp gauge fluctuating pretty bad.
- greddy tuneing
- How much boost/power? on 10.5:1 compression built motor and 92 octane?
- gauge ?
- Mase in Maryland
- When using a very large turbo - should one consider a log mani?
- 57trim / stage3 / .63 AR compressor maps? where can i find one?
- Need Turbo H22 Help
- What brand of injectors?
- IhI Rhb5 4 bolt probe turbo oil lines?
- Looking for high HP turbo tuner in va/md/dc area
- Hawaii?
- ??? psi on stock jdm gsr?
- Question about the greddy turbo manifold???
- what do u think having a jackson racing for my GSR?
- WMS wideband?
- how much would i be looking at of getting a iron sleeved block honed? (searched)
- Precision 600hp intercooler mounting
- Tuning session with Precisonh23a in UPSTATE South Carolina June 18th...
- 81.5mm vs.84.5mm
- How To Build Boost Quicker.
- 3" downpipe?...
- GReddy kit on a 92-95 civic wastegate sounds??
- Hesitates when I begin boost
- Rev Hard cracked Mani
- oil broke need help
- Is 8-9 Psi t3 60trim stock b16 block ok ?
- Suggested design to slash cut to induce Bernoulli effect?
- Gonna be spraying a 50 shot NOS on B16...is a Civic SI fuel pump enough?? Anybody kno the LPH the SI
- boost gauge
- just boosted.... few problems
- oppinions on problem.....
- BOV install
- b20@8 psi ... approx HP gains>??
- turbo b20 questions
- Need an "OK" on my timing before I start street tuning
- intercooler pipes for 94 civic..4 or 6" center line radius U bend?
- Boosted so what camshafts to used?
- d15b2 people whats your managment ???
- Mostly Stock B16a2 looking for boost recomindations
- am i overheating or not
- O2 sensor... need it or swap it for a WB sensor ?
- compression ratio. with a 0.74 gasket
- big question about to install
- What are all the engine management systems out there?
- all you nitrous guy's
- problem...
- anyone know what kind of BOV this is? video
- Tial Wastegate
- intercooler piping size for b16 t3 60 trim
- plx m-500 wideband , is it ok to have close to motor?
- just finish turbo setup
- Tuned by Evans today... good shit.
- benson + earl + onefab + autologic + st00pid = one happy customer 358 hp 230 lbs
- K-series: Custom 90mm JE's "Supercharged" application
- .5mm, 1mm oversized valve daily driving
- oil return line - shallow end?
- turbo b17
- How many psi in MM is 1 psi in IN
- I done got myself an interfooler
- Garrett TB03 Experience
- What D-series turbo manifold is this?
- takeing off my Manule boost controler can i jut put the vacume line that came off that back into the
- Greddy manifold... How to tighten the left/bottom bolt?!
- what a/f out of boost? what a/f in boost?
- turbo problem
- Went to the Dyno...Impressed
- What is your EGT reading?
- WTH? accord vs. turbo coupe...
- Anyone use an X02 intercooler??
- Is My Manifold For My Setup Wack Juice ?
- Why do DSM's run smaller turbos than hondas?
- Type r turbo question
- Anyone have a spare CP piston wrist pin C-clip ?
- Is it worth it? boost a d16?
- turboing the b16
- Fuel pressure issue!!
- MPRD Equal Length Manifold. Ceramic coated (reliable?)
- check out this d series dyno sheets coming soon
- what are the best traction bars out there right now
- Aquamist Alchy Injection System
- Bad gas or tune up
- No oil leaks, but some from the manifold...
- quick feedback... LM-1 or PLX wideband...
- What happeed to the turbo mafia?
- nitrous question
- Anybody heard of simmons injectors?
- is there any wideband unit with a EGT in it?
- 634 WHP turbo del sol and still room for more!
- i'm new here and i wana a help
- Cleaning inside of intercooler
- STR ThrottleBody...Is it any good?
- Type-R LSD Question....
- Smoking under boost
- HELP...is this a good setup
- Compressor surge issues
- AEM EMS
- Turbo manifold question
- best tranny for single cam turbo?
- turbo install = engine codes!!!!
- OK to run 550's without turbo for a little?
- Help in Clocking turbo
- just boosted solid cel runs great
- Anyone use the Greddy Boost Sensor from the emanage for the AEM EMS
- downpipe / flange questions
- hks evc question
- how to rewire injector wires after removing resistor box
- Where to get exhaust flanges for Downpipe?
- Turbo problem
- ACL Bearing Reusable?
- Difference between GT28RS and GT2871R (pic comparison)
- GT3767S Information
- vortech blow off valve question
- will a jrsc for a y8 fit a a6 block with a z6 top end
- first boosted plugs
- GOING TURBO!! GSR or Type-R?? built? Lsd?? Suggestions please!
