View Full Version : Forced Induction
- Faster spool t3 .63 a/r or t4/ .58 a/r ?
- hondata + nitrous injector question
- Wastegate installation direction?
- John Deere tractor diesel turbo?
- Is this just a fancy mbc?
- low profile air filter?
- Ported shroud
- resistor box question
- turbo not spooling
- tial 38mm wastegate
- neptune/hondata ppl help me out
- anyone ever break a twin disk clutch? Exedy, Titlton...
- B16a2 with JRSC in an EJ1 chassis
- new turbo
- Where to merge dumptube back into downpipe?
- Where can I buy 3 inch or larger exhaust flanges?
- H22a Turboed, but which transmission?
- Wtf? my fan wont turn off????
- what can i expect with this setup?
- where to buy lines for oil pressure sender unit?
- how much hp out of sohc without sleeves?
- Looking for a place that sells turbo shafts, and a question about balancing.
- ticking noise.. what could be the problem
- Building a z6... what pistons??
- anybodys turbo honda eat WHEEL BEARINGS or just mine
- OFFICIAL K.I.S.S. DIY: Forced Induction Greddy/NRG Cathcan Install on B16 / B17 / B18!!!
- equal length manifolds do the runners have to be equal
- Forced induction H22 Civic
- ssac at it again, air-water ic
- ramhorn to fit in a crx? pics?
- JRSC Setup Tips needed....
- how to install catch can ??????????
- another dumb q? how to install intank fuel pump
- Valve seal leaking? Could it do any turbo damage?
- possible hp on stock b16a2 ?
- Input on my turbo setup
- Fab Works where are you!?
- what about laskey racing?
- fmic piping Q
- Intercooler fins crumbling
- will these bends from a hatch work for a coupe?
- need help on picking new turbo !!!
- Question bout hi afr's on ls turbo setup
- Wisconsin members....
- how many people have cracked h22 sleeves?
- intercooler question
- My turbo del sol setup
- Del sol turbo quarter mile times
- turbo smoke at idle....normal?!?!?!
- JRSC question
- hole in turbine housing?
- t3/t4 capability question
- adequate valvetrain?
- options for getting turbo manifold heat coated?
- Fuel System Help
- the perfect turbo for stock ls
- B16 power capabilities?
- Is this crank fixable? +more bearing questions..
- Which filter for turbo
- td05 flange question
- +400whp + stock sleeves = HG problem?
- Has anyone ever used a mercedes supercharger on a honda?
- Intercooler PIPING SIZE
- Injector wiring question -- OBDIIa to OBD1
- Greddy sohc turbo worth?
- I THINK I'M CRAZY
- 300 whp guys.....
- Quick queston about DSM injector install.
- quick headgasket question
- Need advice on stock internal b16 turbo
- At what point does merge collector become critical?
- Engine builder's please chime in!
- 2 ferris wheels. yes 2 of em. not a honda but bad ass. 92mm garretts.
- problems with my oil feed line/fitting
- drag kit installation
- Breaking Altinator Belts on Missshift, what about timing belt.. help?
- Shops/Tuners in NW FL, Lower AL?
- To Resurface head or not ???? ITM head gasket ????
- B16a2 Turbo it or Trash it?????????
- dip tank IM?
- keep air bubbles out of coolant system?
- Injector Help!
- "PINKS" Full-Race style
- CR Comparison Graphs
- Top Mount turbo manifolds
- Wiseco Piston ring gap question?
- t3/t67 opinions needed..
- s2000 Cylinder Wall Coating,(F20C) Woes, Need Experienced Help.
- power packages
- EK's with 24x12x3 FMICs....
- MAP sensor placement???
- JRSC maintenance/upkeep?
- Car problems
- crank pulley any good?
- ? about oil seals
- What Compression Ratio for 40PSI on gas?
- dsm 450 cc injectors
- Best spoolin turbo for my SOHC to get 300 whp and more torque ?
- Smoke coming out of the 4th cylinder....after taking spark plug out???
- Drilling & tapping of stock pan??
- turbo smoking? normal?
- Need solution for Turbo Inlet filter!!! No room for normal filter
- Keep my b18b turbo or switch to gsr turbo
- anyone used this piping? looks sufficient enough....
- Obx/morosso Type pan input/advice required
- AEM WIDEBAND 02 GUAGE TYPE INSTALL GONE WRONG???
- boosted B18c1 cams selection (OEM)
- Biggest BOV???
- Peakboost Turbo Question
- Theory: Exhaust housing A/R does not matter.
- almost done..siiike..
- Procharger vs jrsc vs vortech sc
- Turbo ON ITB IS IT POSSIBLE?
- Turbo D16Y5
- GIVE ME YOUR IMPUT ON MY TURBO SETUP PLZ PICS!!!!!!!!!
- building a B20b and need some advice
- comp ratio in reference to boost?
- crushed exhaust and re-tuning
- t3/t04e 57 trim .50a/r cold .48a/r hot ...accord
- How much is my car worth?
- D-series Unorthadox pulley on block build....if you balance?
- "new" to turbo, help me set up.
- Turbine Housing
- turbo?
- diy turbo rebuild
- Where to by rebuilt T3 turbo's just the center section?
- how much power will a jdm ys1 with lsd hold
- any one using a PROCHARGER out there?
- Can i interchange t3 exhaust housing's
- Return line question and concern
- DSM injectors, From what cars?
- Oil Feed and Return Lines?
- Tuning B20 Turbo project
- competition stage 3 clutch
- small ar turbine housing vs. big ar turbine housing
- New Turbocharged Production Acura!
- What can take boost alot better?
- Will a 15G turbo work well on a DOHC ZC?
- Oil on intake valves, is this normal?
- Turbo help
- Question about TURBO
- NEED HELP!!!!! Taking out Resistor Box off a 95 Civic!!!!!
- Budget Turbo Kit?
- Need help with turbo sizing
- Valve Lash for Skunk2 Turbo Cams??? (searched)
- stupid injector question. what clips do precision injectors take?
- I need a compression conversion calculation
- Turbonetics Wastegate Question
- NJ/NY/PA turbo B-series guys, want to increase your 1/4 mile time for free?
- HKS SSQ BOV Maintenance
- top mounts
- TPS Sensor on Edelbrock 70mm TB
- Rev Hard kit
- Oil pan tap?
- garrett .42/.48 good for SOHC???
- D16Y8 - SOHC Mounts - What are you running? >>
- which car to drop built B18C into? 88-91 CRX or 94-95 GSR?
- For those that know me... leaving the east coast for socal!
- Fuel Pump Regulator... is it needed?
- I need to know who are certified peakboost sellers
- RE:Hondata Installation ID / Registration ID....I can help with the Hondata installation/registratio
- Bigger turbo on cast manifold?? No luck searching....
- Profec B spec II user manual...modified.
- Wastegate leak?
- Injectors
- Cheap Turbo Kit
- turbo rebuilding
- Used 18G Greddy buyers, where'd you get the shorter manifold bolts?
- FI question, please help me.
- Innovative GTS Turbos
- Need advice cage builders, no luck in welding forum!
- Crank Cleanup/Polish - Quick Easy Cheap Way? Scotchbrite?
- compression and leakdown test results
- greddy 15g: how much can you push it?
- turbo making some weird howling noise... :(
- help sohc confusion
- special tools needed for engine building..
- i need to install my quaife lsd in my tranny help
- Turbo manifold to hood clearance?
- New Nokia Datalogging cable (mini write up)
- Oil resictor
- ECU upgrade for turbo build?
- T04E rpm boost range
- T3/t67 vs GT40r
- charge piping: which is "better" bigger or smaller??
- anyone bosot a d-16 i have some fuel questions
- Re-tuned my car
- Turbo+ cams I need professional Advice, FACTS!
- Which is better? te04h or T25? and why.
- cam timing
- Installing Hondata w/ JRSC. Still use fuel enrichment relay??
- tunning Q
- blox IM w/turbo?
- Need help ASAP: in process of build
- Neptune and building boost while staging
- has any1 seen a turbo manifold for an a20a? (86-89 accord)
- My first FI build
- need help quick with s300
- DA Integra Turbo Plans
- sohc turbo setup?
- D-series turbo
- supercharger compression ratio
- Car wont start at all
- Can I get by without using my front motor mount?
- Ultimate
- Precision GT4067R?
- Fluidampr Q??
- Odd wideband readings
- Heat shield for turbo kit question.
- Can GSR cams support 700 hp?
- Power of a Drag Turbo
- painting intercooler?
- Is This Okies Or Bad Turbo
- what turbo
- My vacuum at idle for 8:5:1 compression
- K20 hatch vs 383 lt1 on spray.
- need help identifying a turbo .48/.60
- Where do you get the Vband for turbo outlet like on a GT42R or Holset HY35?
- Help identifying turbo pistons...
- Max oil pressure to turbo?
- All FMU users, please look.
- The BLITZ® DTT (Dual Turbo Timer) DCll ?/
- Where to find a 4-->3 inch coupler
- witch mine-me swap for turbo
- What manifold works with fullsize koyo radiator in a DC2?
- Has anyone ever done this before?
- Will an f22b1 rom work as a baseline or to make a baseline for a f22a1 h23head swap?
- My setup so far
- What can my set up SAFELY make on a stock engine GSR---------->
- I need some ECU help
- I have a tuning MAP sensor question. . .
- where to buy turbo's
- Best turbo manifold for T3T4
- b18 block
- how am i supposed to fit a fastener in here......
- kteller downpipe..
- Anybody here running Megasquirt?
- turbo parts, shipping quote
- pic of a volvo 760 TURBO?
- Please comment on my H22A turbo build list
- Greddy E-manage question
- Stock fuel tank vent
- Del Sol Intercooler Piping with a c1
- Searching for different kits. Can i get your opinions on this kit please.
- how do you guys keep ps and ac and how do you mont your slim fans
- Question about boost controller
- prepping the motor for turbo, any tips?
- Look at my set up.....Help please(already searched)
- CAN I MAKE 350whp with this?
