View Full Version : Forced Induction
- IHI RHB5 VJ11 turbo need to know the drain flange size 38mm? 44mm?
- quick question about water cooled turbo
- has anyone ever heard of this company??
- AEM Tuner needed, SoCal (Orange County)
- apex map sensor
- Built B16
- 3bar map sensor
- I have a b16a, what do I need to turbo ANY ADVICE,
- saab t3 turbo on my accord?? too small??
- Question about turbo a/r and trims being too mismatched
- 320whp on DRAG kit (tried searching)
- Identifying Honda Injectors
- Ok Big Problem - Overflow EXPLODING When I Boost Hard. Solution?
- greddy e-manage install
- resistor ?
- Has Anyone Heard of this Manifold?
- turbo guru's i have questions before i buy a new turbo (a/r, and trim)
- The Official SOHC Supercharger thread...
- rambling/question
- Wideband datalogging question re ECU pins and wideband
- Help needed putting in my turbo(how to put in oil pressure gauge and oil adapter) searched!
- How can you tell you have a walbro 255 pump?
- James, where are u? BMC RACE
- over torqing oil feed fitting into turbo??
- injector?
- Stock Gsr cams Vs Skunk Stage 1s
- Boost Gauge Reading
- Missing Link
- DIY BOOST CONTROLLER question
- flex pipe with no flex?
- A few pro blems
- b16a2 / peakboot straight bolt on?
- head gasket
- Aynone know of a way to replace the plastic straw on ebay catchcans??
- turbo h22 burning oil
- 2JZ 240sx
- Turbo Question...
- Will the t3/t04e .60 trim with a .63 ar be sufficient for 8500 rpms and 300 whp
- need advice on boosting a b18b
- Should I use an LSD additive or not?
- alluminum epoxy/welding/intercooler question...
- crx b16 t20 turbo HP numbers help
- D16Y7 Turbo?
- Garretts GT37R - The Ball Bearing ones .
- Boosting a stock b18c5
- d16z6 with garrett t25 = possible blow motor HELP ME!!!
- SOHC TURBO MOTOR , WHERE TO FIND
- Will these turbos work for a low budget build?
- need advice on turbo kit
- NEW Fuel Setup, problems with tuning...HELP???
- ehaust leak
- Turbonetics Valve Seat/Ring(Fire Ring) Help please
- LS VTEC questions
- Boost for a stock GSR (simple question)
- NOS dry setup questions
- NOLOGY WIRES
- ***** Another b20/vtec question regarding zex nos kit *****
- Turbo almost got destoyed.........
- how much boost for setup
- hi compression turbo
- Need clutch for Turbo GSR, will this work?
- drag manifold wastegate elbow (pictures)?
- Long time no Post
- $5,000 ls-t buid....
- Tuning Tips
- anybody use a top mount with t3/t4?
- ngk blue vs oem?
- Leaking oil out of my sandwhich adapter! Help! :(
- B18B1 Turbo Misfire...
- Need help picking a turbo
- Change Cams
- What turbo for d16z6...max goal of 300whp
- gt35r on b18b1
- tilton flow control for hydraulic line
- wide open throttle symptoms, what could it be ?
- greddy type s BOV...2 vacum hose nippls?
- Quick Question? How much power should I make with this setup???
- Huge fuel and boost problems
- 98' with OBD1 good in England?
- AFC, do thre work?
- IAT on a JRSC...
- WOW... So this is why we are all addicted to boost (where Turbos are from)
- when is the 38mm wastegate a restriction
- which turbo should i look for 400-450HP (B16A2 9:1)
- Brand new motor- Overheating/smoking/burning coolant
- Blowoff valve placement?
- Need help with my Greddy Boost controller!!!
- My new turbo!
- Built Motors
- turbo manifold
- Good CR for Gt35r
- Nitrous d16y7 questions.
- ls turbo questions
- what size injectors?
- Question about cracked block
- D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH
- Need Help , I think i fied my car !!!!
- how does intercooler piping length affect horsepower
- Oil Sandwich adapter and oil pressure gauge....
- Is This Normal? (D16 cylinder imperfection?)
- 48ar exhaust w/ 60ar 50 trim comp on b18c
- Need help with Restrictor....
- should i bother with the turbo?
- sohc boring questions
- I need info on this innovative turbo. Please help
- I'll mail you a six pack to get my vtec working.....Please help! Serious Question!
- 300 whp whatc clutch
- which fuel pump? i want specific storries. good bad and indifferent.
- Nitrous Wet kit: Zex vs. NX vs. NOS vs. Venom
- how much horse can i expect?
- What size primaries?
- how many channles can i log with the rpm converter? and which?
- Boosted D series guys do you find ur 3rd to 4th shift the worst?
- Injector question....?
- Anyone heard of this? DTAFast Engine management
- Help building a turbo 93 SI
- killed my clutch
- Going to tune soon... is 280whp achievable???
- Full-Race Time attack S14
- Some more E85 tuning... turbo this time
- need some input on turbo for gsr, sc61 or gt35r
- Garrret T3/Super 60 vs. T3/4 46 trim w/.48 A/R housing on stock GSR, best low end?
- weird rpms
- Turbo B18 non-vtec Wires and plugs?
- o2 sensor for dyno jet: What PN# are you using?
- limitations of a gsr intake mani?
- forced induction question
- do i need a oil catch can?
- Mounting intercooler, how have u done it??
- B18b boosted with b16 tranny
- Lookin to get 350hp out of a b18c1. What setup should i go with?
- How close is your downpipe to the radiator?!
- Honestly How much will this effect my spool time.
- Forged Compression???
- How much oil to put into a turbo GSR
- anyone running this wastegate
- advice/ help with my ls/v-t build
- Help! Weird Idle (videos)
- who was smoked by a talon in new mexico?
- boost creeping
- Civic Rad in GSR questions
- mpg dropped after exhaust change?
- Emanage Compatibility Question...
- Is my fuel system be good enough for 600+whp?
- OT: Removing MSD 6A ignition and returning to stock?
- tuned on crome, can i use uberdata to datalog????
- lc-1 wideband, p72 ecu
- oil problems
- Newbie lookin to boost my 99 Si....Please help. (searched)
- Why is my boost spiking?
- NGK ZFR6A-11 Sparkplugs?
- surging/sweeking problems with typeS style bov
- Oil pressure sender question
- help with ls/vtec wiring
- wideband dosent work??!?!
- We are go for turbo...but weird casting on head????
- what gonna happen (already searched)
- Oil Feed adapter for my gt4088r?
- turbo oil restricter
- 02 sensor issue... help needed....
- anyone
- Where to buy oil restrictors?
- Some more nitrous questions...
- Perfect Power - SMT6
- Turbo kit Question
- So. I am finally getting a JRSC for my 00 EM1. Sleeper style with questions?
- Evans Tuned 500+ HP DD RSX Type S!!!
- intercooler, too big???
- Help - Bad Tranny - what to do ?
- Look at this 2jz swap
- intercooler core for watercooler ??
- Need opinion on h22 turbo manifold
- JRSC experts please
- just finished turbocharging my del sol b16a2 BIG PROBLEMS !!!!!!
- longevity d16z6
- calculating values for turbo selection
- boost gauge
- Any harm in boosting with a leaking downpipe?
- just opened up wastegate look what i found ( pics)
- which wastegate spring so i have? (pics)
- Strange oil pressure problem...faulty oil valve relief?
- T4/60-1 questions..??
- Will I mess up my turbo if I...
- ebay radiator
- Should I use this headgasket?
- do i need to retune when adding intercooler spray?
- head gasket-question
- Surging at steady throttle
- anybody every hear about using h22 injectors for a small turbo setup?
- Questions on the Greddy Informeter
- Swoosh turbo timer
- LoveFab Turbo NSX buildup thread...
- code 23 hondata s300 problems
- best intake manifold/ good mani
- anyone need some brand new 550cc RC injectors?
- turbo or swap?
- H22 or B16 need you to bare with me on this one. (long)
- post up your ls/vtec-t setups
- gsr turbo feed pics
- need help.. rebuilt motor smoking!!
- running lean
- b18a1 with an IHI turbo
- can I make my t3/t4 a T4 ?
- clutch chatter 6puck
- How to: Remove the Oil control orfice from the Block?
- HT search doesnt work.
- Is the GT35R overkill for my purpose?
- few questions on my LM-1, cause innovate forum is slow as my D14.
- Does a smaller turbine housing decrease v.e. as it starts to restrict?
- which tranny for boost?
- quick wastegate question?
- Traction bars how do they work?
- Turbo wont fit my 00' GSR
- Car Not Boosting Need Help
- Best//Easiest way to get car up and running after putting in turbo.
- Turbonetics manifold with precision turbo?
- Air rushing sound through IC piping
- bov whistle
- Full-Race cam gears...
- Turbo XS BOV Question???
- tial 38mm
- need some help strange problem
- Where can I get the O-ring that goes in the comp. housing?
- water temp gauge help.
- Ls head porting
- 96-98 civic-Who has a front mount & fog lights
- B16A Head Damamged, Fixable?
- Jackson Racing High Boost Kit on a JDM B16
- Best Motor Oil ?
- What is everyone going with???
- what size oil line does everyone use for their oil inlet?
- please look at this turbo,
- NEED HELP ASAP
- can anyone vouch for S@nt0s aka snowflake.
- i need to make a exhaust for my car.... should i go with "2.5 or "3 ?
- Air/vac leak???
- Upgrading Charge pipes and intake manifold, is it worth it at only 10/12psi?
- 57 trim preferred over 50--Why? *SEARCHED*
- Intercooler efficiency question...
- DARTON SLEEVES WET OR DRY
- Intercooler Paint *Searched*
- car is misfiring at high revs
- Turbo size for built B18C1.Please double check my stats.
- APEX-I Auto Timer
- BLOX IM sugg.
- Who makes this????
- B series turbo sites
- gt3582r problem!
- 81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm?
- Advantages with a Top Mount ?
