View Full Version : Forced Induction
- turbo b16b no tunning, bad idea?
- best exhaust for turbo?
- 86 jetta
- garret 18g turbo for ef b16?
- new dyno numbers finally
- Pics of my new Gt40...............202!!
- full-race stage 1 turbo kit (a/c compatible) opinions?
- Any one use the BLOX turbo cams? I see it a lot on NA cars but not on TURBO
- oil line kit, will this work?
- I have a problem.. need advise
- NEED SOME HELP ON MY SC GSR
- cold start aem ems need help/ideas.
- anyone have a firing order pic?
- sometimes lower rad hose cold.
- firing engine for the first time questions..
- b16 turbo with stock ecu, now running very badd, help!!!!!!
- Anyone running this exhaust with their turbo setup???
- Need some help fellas: p06 ecu trying to get basemap made
- which BOV to get??????
- need help getting to dyno
- Street Tune/Dyno Tune
- Precision PT70?
- HELP return line kit?
- Putting motor back together, need some help
- This is what i am considering any opinions on it or suggestions and what do you think of the price
- whats missing?
- Motor smoked on dyno now problems.....
- water line qyestion
- Can you identify this valvetrain? skunk2? dohc vtec
- need help identify my turbo trim + stage lot of pics
- first steps before goin turbo need help
- boostin ls
- Just ordered The beginning of my new build... Turbo Elements Top Mount!
- Anybody turbocharge an automatic Ls??
- clutch/flywheel reccomendation for boost
- What size in mm is the SC61 inlet? *need help and dont have the turbo with me*
- Ebay boost controller ????
- real quick question about resister boxes.
- Just dynoed my homemade turbo stock block sohc
- Oil Send Line Flange???
- Lost on Tuning Hondata s200......
- help! need seals for a t3t04e
- BASIC HONDATA TUNING QUESTION
- weird issue with boosted d16
- Fan won't turn on??
- Cheap Adapter Plate Wanted!!
- Daily Driven Built Motors w/ FI
- FMU?
- turbo xs DSBC????
- greddy E-01 boostcontroller VS apexi avc-r
- How can I tell if my wastegate is still good?
- Pulled apart turbo , oil leaking out the exhaust housing WTF
- I wanted to say thanks to Jeff Evans.
- K>B
- how big intercooler?
- Having an electrical bug. Dealing w/ Ignition & Autronic difficulties possibly?...
- wiring
- t26 supra???
- Sending a Block To be sleeved by Benson..
- spark plugs to use with my coil on plug setup with cbr coil sticks
- running feedline w/o oil sensor, can i do it?
- differences in cylinderwear between stock sleeves and ductile sleeves
- how will too rich initial starts effect later cylnder wall wear ?
- should i go turbo, s/c, or all motor????
- LS pistons in a GSR block
- help me with my gsr block rebuild
- CoreyR (CCFab) Manifold review.....tons of pictures (56k f**k off)
- which d-series?
- going turbo on my b20 please some tips!!
- turbo h22 guys!
- ERL Turbo Block Startup Oil Pressure Issue
- i need a tuner ASAP!!!
- Golden Eagle studs?
- ITR and GSR cams ?
- what size thread is the oil cooler fitting?
- Dont flame, Im tired of searching.. Wire tuck..I have a turboed car, that counts right?
- first experience turbo honda
- Using Freon Instead of Water in a Air/water Intercooler????
- Back With a New Better Built Setup (400Hp B16)
- H22 plus Nitrous question
- Cali 91oct what kind of power can I run
- 450cc DSM blue tops
- i need to know a good place to get ( HEAD)
- Auto Power Enterprise
- has anyone pinned their motor here?
- b20/vtec turbo
- what size is the AEBS intake manifold intake port? 64mm or 65mm?
- Anyone Turbo with DOHC ZC tranny w/factory LSD
- how much did it cost to build your engine for boost?
- dyno pics
- t-25
- building a kit--what next?
- How did you run the wire for your dash mounted gauges [defi bf] cleanly?
- H22 Top Mount?
- Carbon fiber hoods and turbos, will heat melt my hood?
- Dsm injectors in boosted 5th gen prelude
- Greddy eManage (bluebox) question?
- Integra Rev Hard Turbo Kit
- what is the most reliable manifold for a b series?
- b16 nitrous question
- The Official Dual Cam Non-Jackson Racing Supercharger Thread
- D Series Numbers/Setups
- safe LS/vtec boost
- Junkyard sohc turbo for auto d16a6 ? I want low end...
- hf mani with adapter plate vs log mani
- finally finshed new setup
- Rc injectors , can i use these sl4-750 on GSR , please look
- adapter piece to connect autometer gauge to greddy oil sandwich plate
- I need help sorting out the final details....turbo GSR
- Put turbo kit on 92 civic and now its over heating.
- which arp studs???
- Tunning install PLEASE HELP
- stock ls rods
- Built gsr head
- Why is my setup getting boost creep? Not your typical question....
- thinkin about buying a turbo rsx...
- obd2 to obd1 install now car does different things
- Pics from Turbo Install (no 56k)
- Top Mount vs. Ram Horn
- info about IHI RHF-5.
- Quick question......10.6 compression too high?
- Bar & Plate radiator???
- nitrous help
- PROBLEM....
- PROBLEM....
- best way to build d series for more boost
- BDl Industries Cam Gears
- fuel pump amp supply = fuel pump efficiency?
- Way to go from T3 to T4 flange?
- need DIY info for coil on plug
- car over heating while normal driving
- BAD TIMING
- Completely new to FI.
- EMS for K24 engine?
- H22 Turbo Build Question Help Please.
- p28 chipped with crome for turbo?
- gauges
- uberdata on PM7 OBD0
- Web Cams + Turbo
- max clearance on cp oil control rings?
- filters
- anyone want to donate a stock ls block to me?
- Bad idle after a hard pull!
- I was bored in class today!!!
- Where to buy 40mm tial wastegate valve ring?
- HKS Type 1
- Power results?
- Garrett GT1752?
- running new grounds
- First attempt at boosting my GSR
- Precision 1000's "Round Two" (Update)
- Skunk2 stage 2's + 10.2 compression motor + 100 wet shot = ?
- help me spend this money.. n2o set up
- Having a shop build the motor ... Why?
- VAFC settings
- How much do I need to gap my plugs. I already searched. got notta
- help!!!!, new permacool rad. fan wont turn on and car stays cold!!!
- which Headgasket??
- D series topmount please??
- ring gap
- wideband o2 for SOHC
- arp head stud question
- i have a turbo kit home made and have a question
- Witch Pistons?
- ARP Bolt torque specs....
- P29 pistons
- Oil leak under boost
- Pre Start-up Checklist
- D16z6 turbo setup autox, hpde, time attack GT28RS??
- Oil feed relocation question..
- Nitrous on a H22?
- How come my GT30R looks different than others?
- RSX turbo problem please help
- what makes bullet proof 600plus b series
- 7spi spring but boosting 11psi
- k20a2 turbo kpro question
- StainLess Steel Auto Chrome
- WTB Sc61 turbo.....WHATS SOME GOOD SITES/CHEAP PRICE
- OEM Fuel Filter
- Experienced Engine Builders Got A good Question on one cylinder burnt up
- can i get some turbo advice?
- Professional Engine Builders: Help
- Anyone use this Perma-Cool 12" 2300cfm fan?
- Teg is goin boost soon
- video compilation of my car
- any a/c (air conditioning) setups?
- has anyone ever seen this before??? engine trouble now!
- Another GT28RS Question... Compressor housing
- Charge Piping and Exhaust Piping Theory.....
- What is the 350 Precision IC really good for?
- Precision IC mounting
- Stock Boost
- How much difference would a muffler REALLY make??
- Injector ?
- Webs Site That Sells gt35r For $900
- Motor Goes To RICH Then LEAN
- ***Official B16 Turbo Thread***
- Can i boost my motor?
- My ACL's wont fit my Eagle Rods....?
- Anyone with tdo5 (14b) turbo experience
- lsd?
- Whats the stock pulley size for a JRSC on a 2000 Si?
- guage holder/pod
- hondata s200/s300?
- arp head studs
- Which heatrange do you run?
- chatter in cylinder head
- emissions inspection - hondata to obdII
- Getting car tuned in a week
- topmount manifold!!!
- Need Help choosing DD setup.
- my turbo setup...need help
- my setup! what do i need
- stock valves ok for 400whp?
- PIECE BY PIECE OR WHOLE TURBO KIT?
- JE SRP Forged Pistons Boost or No Boost
- psi question.
- turbo help
- Parts need for a N2O WOT set up
- what turbo manifold should be used here
- Problems after install with idle...
- Post Your Dumptube Setups
- Greddy E-manage Password help
- high boost flutter / cant hold high boost issue
- Turbonectics Turbo Kit For 96-00 Civic
- turbo timer
- Total seal piston ring review..........
- GM 3 Bar wiring on 96 integra???
- uberdata people chime in please
- zc with turbo any one please help thanks
- AEM Replacement Filter
- bov open at idle(tial) normal???
- nitrous question:
- LS crank or Gsr crank in b18c1 block?
- B18b1 head assembling help
- Borg Warner S366 Pictures
- aaroboost's turbo install help thread!
- oil catch cans
- how far are you wastegates from your turbine?
- Injectors are bigger. will they work?
- Random cracked OEM sleeve b18c5 pic I had laying around...
- Is it bad to boost with no o2 sensor?
- DSS Stg 5 owners, anyone have C-clip issues?
- anybody with b16t with the compressor housing on the driver side???
- car hesitates
- TURBO + OBD II = NO INSPECTION?
- oil presure to the turbo
- PICS NEEDED: DC's with Precision 350hp or 600hp IC
- 2 yellow, 2 green wires for the O2 sensor
- Turbo on a 99 si
