View Full Version : Forced Induction
- New Turbo HP Upgrade
- Mishimoto Intercoolers
- How much does Manufacterer matter? 1st hand experience please
- ls vtec build/help
- Irishflame's offical *PeakBoost Build*
- ABS light on After Drag
- how to tell what cam i have
- CX turbo dyno sheet
- Swap Turbos??
- on an obd2 car with an obd1 ecu...
- Need some help please...
- Lead me in the right way.... just purchased a turbo kit...
- just got some new suff
- Turbo D15B7 build help....
- trusting ebay for a/c compatible downpipe?
- pushing coolant under boost!!!!
- pick my exhaust
- DSM 450's questions???!!??!!??
- wtf? started fine yesterday, now now spark..
- srp 9.1 comp ls pistons in B16????
- rc fuel injectors wrong size?
- BOV issues, I think??? =/
- D15B2 turbo
- billet 62/65
- New Build 2 motors 2 chose from (b18c5 vs b18c1 )
- need manifold advise
- What happens if my ECU harness doesnt have an A11 wire
- Setting Up Water Lines for CHRA?
- what size feed line should I get for my greddy 15g
- Engine building guru's... Need your advice.
- Job of the Flex pipe on downpipes
- peakboost Turbo manifold
- ecu and turbo question.
- b16 turbo build
- hx35w on stock b16
- requesting advice regarding a b20b f.i. build
- bulding d16z6 quest for 350whp+ HELP
- is this block salvageable for boost?
- Judging "Spool"
- Oh boy did I just go all in...
- Anyone using cp pistons
- supercharged GSR is breaking up in mid range
- Wideband placement behind car sound metal core cat how off will readings be?
- PROS AND CONS OF FRONT MOUNT MANIFOLD
- Pusher Fans - Would a shroud help or hurt?
- gt3076 manifold
- 90 degree fitting into catch can. big no no?
- crv crank pulley onto b18c5?
- Edelbrock Performer-X
- flycutting d16 vitaras
- Omni 4bar map instructions?
- Vitara low comp pistons...D15B turbo
- jacskon racing boost question
- .120" head gasket question.
- fluidamper vs. ATI
- does it matter what pipe you use for your i.c.
- 11.84 for $2009, GRM Challenge fun
- b18b1 turbo issues
- Holeset HX35w on a built sleeved D? Has anyone ran one before?
- how much boost on stock internals?? d series
- Help with Dyno Chart Diagnose
- Necessary to upgrade cams in Turbo H22
- Running out of fuel in high rpm's, suggestions?
- 643hp @ 22psi, h22, S372 (dyno video)
- Custom Turbo Manifold
- bwr as we know it...
- RX-7 Turbo 2 Injectors In Civic
- Car won't stay running.....
- clutch? lightend or stock flywheel?
- Moroso or OEM Honda Oil Pan?
- scratched cylinder wall already at 81.5mm
- H22 Dyno results sub par
- 35r vs s362
- Full Race AC manifold B series Anyone?
- Check out my 428whp LS-T!!
- should i upgrade intake manifold and throttle body?
- b18/b18 turbo manifold
- MAC boost solenoid failing?
- car is running hot
- Help with turbo manifold
- the best tranny or gear combo for 600whp+
- h22a turbo exhaust question plz
- H22A turbo build
- Oil restrictor size on T3's. Searched.
- Yet ANOTHER Z6 Turbo Build
- Got tuned today. big surprise inside.
- Oil filter? which one holds most pressure for boost?
- expirence crankwalk?
- Anyone have problems w/aem boost solenoid??
- Drag manifold/ Inline Pro SS/ Blox manifold
- oil feed line angle- Full Race Products
- saab turbo injectors?
- Saab turbo injectors?
- Saab se turbo?
- LS Turbo build... head build questions
- Precision 6262 dyno 683 whp 2.0 VW
- GSR B18C 94 on civic 97 possible 350hp???
- Pistion Advise PICS And Spec.
- ...delete
- catch can thread
- Some turbo advises
- vid of my boosted 10 sec ek
- need tuner in fresno area HELP!!
- F20B PSI & CROME Q's
- gsr cams with oversized valves or typeR cams?
- bought a greedy kit
- d16z6 jrsc
- Greddy vs Garrett
- anyone use this turbo kit??
- Supercharger exhaust question?
- stock injector modification?
- ls piston opinions...???
- turbo b16 shut off
- turbo help
- bolt pattern and twin scroll question on exhaust housing
- which one for boost?
- feul mangement??
- BOV?
- Best place for filters..
- which ram horn exhaust manifold is better to use
- Missed 5th Gear, Went in 3rd, Now Ticking noise
- warmer than normal temperature on long trips
- what best A/r FOR 500+HP
- Washing engine?
- Tuners and street tuners take a look (cracked sleeve?)
- Running without a tune (questions)
- where to buy treadstone intercoolers?
- 450cc dsm injectors to big?
- Upgrading downpipe for Greddy TD05-18G
- My MSD Pro Billet has finally retired... What's next?
- jus got a new turbo
- Reliable turbo kit Help
- Might need a new bottom end D16Z6
- In line "solid state resistors" insted of a resistor box?
- i need help!
- What is this? New Turbo.
- A good 3" turbo exhaust??
- Doesn't Anyone Make Nitrous Cams For a B16a???
- Can Launch Control Damage Wideband Sensor?
- skunk 2 stge 1 cam question
- Will hole in exhaust effect wideband stability?
- I have the supercharger, I have the car, I need the engine. [input please]
- Good injectors 4 mild build
- the Shodan coating, and a question for da Man.
- K20 questions about turboing!
- Resistor Box
- inercooler size????
- 98 gsr turbo breaking up, safc tuned
- Recommend me a Wastegate for my setup. 44mm - H22.
- Q's about tial gate springs, and bov...
- gsr greddy kit in ek?
- Car not running right, suspected running too rich
- Racewon turbo manifold
- Head gasket n studs??
- Pic requests: precision 600hp IC on a 96-98 civic
- just rebuilt motor. not sure about break-in
- is there something wrong with my valves?
- Just released BWR "VER2.0" Turbo Manifold
- td05h g18 setup oil gasket leaking
- Competition Clutch problem with FI integra
- What do you think
- Godawful Idle with DSM 450's
- Video of sleeved motor i bought. ideas?
- Ehaust manifold bolts are breaking
- what about0.708 pin in 700whp car ?
- any experience on Spoolin performance turbo mani<<
- Question about block fitttings "catch can"
- Gt35r
- NA to mild Fi; so many questions....
- Setting timing with high idle?
- Peakboost came through finally
- how to tell the difference b/t s362ETT & s362
- precision 6262 with vband
- Supercharger reliablity?
- help me pick a turbo for my first b16 build
- GT35R w/ 1.06 exhaust housing??
- Cant Decide: 30r or 35r
- Boost problem
- ID 2000s made by Bosch?
- downpipe
- Possible South Florida Group Tune by RLZ
- Badlanz E-Cutout review.
- Those of you looking for a 12 injector setup here is what we have
- Why does my power drop off once it hit 7k rpm? Dyno included
- building bottem end help??
- How to keep from destroying new turbo?
- go autoworks opinions...
- Please Help! Is this block sleeved?
- T25 Flanged Turbo Manifold, T25 to T3 Adapter
- Whats size intercooler???
- how to sleeve an h22 close deck?
- Is this H22A4 sleeved?
- Piston Ring Question
- CEL after boost
- ONEOVER/Modern Muscle Build#2
- Question on intercooler size
- What kind of mani can i use?
- help me figure out who makes this manifold
- TD Autowerkes K-Series EK makes 1000 WHP!
- building boost
- Best street strip turbo
- What transmission to run? (gsr or LS?)
- Turbo's on a B16?
- wastegate help
- b16 internals/btm end boost ?s
- H22 turbo ek?
- 400 whp with just a walbro 255?
- New to forced induction.
- Need some bottom end advice
- few questions about a turbo setup
- Oil line size 4 S372
- low compression for turbo
- engine breaks up after 6k rpm????
- DSM Lower plastic Caps
- Where is the most optimal location to install a wideband oxygen sensor?
- JRSC COMPLICATION
- RPM service throttle body
- Best current Headers for Supercharged engine
- i have started getting things together....but?
- Unfamiliar with EGT, are these safe?
- d16 turbo kit being put on.....need help
- Balance Shaft seal failure?
- Post-boost problems
- Comptech supercharge tsx ecu question
- JRSC PROBLEMS HELPPPP!!!
- Traction Problems, need help
- LS VTEC supercharged
- Bought a Greddy turbo kit from Phantasm Motorsports...
- help plz. sounds like fuel cut after nitrous installed
- b16+jrsc+9psi=slow help needed
- Blow off Springs & Wastegate questions
- stock b16+boost?
- BW S372r not flowing air...(Leak Found)....I hope
- Enclosed air filter box for turbo
- where to buy a greddy type-r bov diaphragm ??
- Brazil Project! Ready to run! 1.76L B16A Turbo
- Fuel Trouble, B18C1 gt35/40
- dual wastegates
- VP C16 in CT/MA
- B17a1 tranny or b18c1 tranny for boost
- anyone running Neukin manifoldS?
- Blowing Charge Pipes!!!!!
- Head Gasket?
- B20Z on FMU setup for the haters
- what size turbo for ac and power steering?
- cutting painted bumper to fit IC piping
- Methanol on a B Series?
- injector question
- i have an integra and need help choosing
- what turbo set up should i use?
