View Full Version : Forced Induction
- is the weight of pauter rods that big of a deal?
- EGT probe placement?
- breaking axles or tranny's?
- purpose of a factory turbo
- AEM UEGO pricing and wideband availability
- Nitrous topic questions
- For those of you running 12psi on a d series
- good place for oil pan tap?
- Performance gaings from JG throttle body?
- how big is yours?
- HP Limits of a Log Style Manifold ?
- 1998 teg + C&R radiator + turbo = fitment?
- any street cars here hitting 10s already
- anyone have any pics of a non obd check valve or missing link? will i need either?
- Hondata
- greddy oil catch can in a eg with a b series motor
- can someone please explain the whole check valve thing?
- greddy gasket
- Stock block ls-vtec with garrett t3 turbo questions please help???
- Proper Tapping of the Oil Pan?
- Head gasket done/ V-afc installed= v-tec won't engauge
- I think I just destroyed my FMU - need help
- B16a + SC34 + Inline Pro = GRINDED! :) 56k? Maybe! Nine 640x480 pics within.
- Can someone explain this craziness to me????
- Safc and Stalling
- Writeup: JRSC B16A CRX w/ Hasport Mounts
- how much boost can i run
- what kind of...
- 440 injectors and 12:1 fmu
- Ok im looking for any help i can get at this point.
- overheating problems while dyno tuning...help please!
- opinons on tonites turbo install...
- Using low compression pistons..
- Loud 1st start up
- OEM exhaust gasket & boost?
- hks or generic from ebay
- Please Help a kid with his fuel management
- piping size for a T3 on a sohc ?
- 14b wastegate
- Profec Spec 2 is hooked up
- Purpose of Timing being retarded??
- "Nissan" Garret T28 turbo Questions
- Got my car TUNED with VAFC HACK today!!!
- failed smog w/ Greddy kit- please help!
- afc hack and aftermarket chip
- Turbo's FORSALE?????
- Tial WG users..problem with the fire ring...need your input
- what kind of power should i be making
- compression #'s?
- Turbocharging a DOHC ZC...
- blitz bov
- Anyone heard of "cryogenics" or the process of "freezing" rods??
- cam gears for turbo... useful or not?
- very quick question
- Give me your tips on weight reduction.....
- rc 440's on obd1....can i just hook them up???
- Garrett T3/T04E GROUP BUY $520 Shipped, limited time, quantity
- Keep JRSC or go ALLmotor
- SMC, JRSC, and Stock FPR ???
- will i need a missing link?
- Need bottle heater in the summer?
- How bad is it to leave bottle open on a dry nitrous kit?
- engine demand charts?
- Drag in a EF hatch?
- boost newbie question
- are these compression numbers good.
- anyone know where to get revhard installation pics?
- Crank Hesitation.........
- jg turbo cam specs
- Coupling size
- Will a GSR Greddy turbo kit fit a 99-00 SI
- yupieeeee, new awesome dyno numbers for me!
- car idles weird sometimes.
- T3 from Le Baron worth the time ?
- where can i fined some used turbo?
- Sprung an Oil leak at first start up
- Why are long high speed runs not good? Road racing questions..
- Hondata Tuning Newbie Questions....Gruvy, Vapor, Anyone with Hondata Tuning Experience
- Official Homemade Turbo Thread - Tips/Pics/Parts Lists
- SOHC Greddy Turbo Kit on LS engine
- OT: Jimfab cantact #?
- which stock cams to replace jun3's for turbo?
- NGK Spark Plugs....Everything You Ever Wanted To Know and More...
- OBD0-OBD1 home made converter
- Where did -max and revhard's website vanish to?
- Do I have a 2bar or 3bar map sensor?
- Is it worth sleeving??
- What's a Good Radiator........
- what size do drag 3 kits use for piping need help fast
- what BOV's will work on the greddy flange
- TE04H rebuild kit
- bearings?
- GM 3Bar MAP + EMS ?'s Too long
- any info on NOS(holley) fuel pressure solenoid?
- turbo timer and alarm???
- FMU question
- Clutch Break-In, Action 1MDS (6-puck, ceramic)
- Too good to be true? *Ebay*
- Whats the difference between these 2 types of Greddy Type 31 intercoolers?
- Turbo Advice
- ATTN:OT:All people who are trying to IM me...
- anyone know where i can get this sticker??
- what's the lowest boost level when using vafc 'hack'?
- JG turbo cam in N/A setup
- Apexi Power FC Tuning Seminars??????
- Apexi PFC 3 bar Map Sensor
- Where should I replace the two lambda sensors of my B16A1???
- PICS Maxrev GT3040 Custom 3" downpipe New IC pipes + Welding pics
- Big boost + valves??
- what does a stock block handle in boost(JDM b18c)
- Alarm+turbo timer: can i put a relay between the shock sensor?
- finally boosted... not liking it too much
- Preping for turbo. 1st step: thinline radiator fan
- How much oil?
- Just installed Action Clutch....
- Need to know if i should get this trans? gotta pick it up tomorrow if i want it!!
- camp1320 turbo manifold
- can boost creep occur suddenly?
- Filing a lawsuit with Autometer.......
- Turbo Accord with Stock ECU.. can it be done??
- why am i stalling?
- nitrous jet chart
- for those of you with EGT's after the turbo
- Urban Import ..... share ur experience with me please
- Fuel Trim/Map Low input malfunction P170/P107 Codes
- where to mount the EGT probe????
- wastegate on intake pipe?
- downpipe question?
- 99-00 Si owners with DRAG gen 3 Turbo kits I need your help
- wastegate ?
- Which bearings ????
- driving without boosting
- could o2 sensors too far apart cause code13?
- Boosting in 5th gear ?
- what kind of plugs should i use w/a turbo setup?
- Installing Uberchip
- How accurate are the dynos at the car shows?? ?
- Starting motor for first time.
- What exhaust manifold gasket should I use
- Blown head gasket???
- Hytech manifolds??????
- best blockguard????
- Vouch thread for rbmoore
- what fuel setup and engine managment are obd2 or auto turbo cars running? TIA
- inlinepro vs prospeed-performance head gasket
- my d16y8 is dead with only 37000
- Spark Plug Wires...
- nhra gainesville raceway
- What aftermarket exhaust system? 3 inch or 2.5 inch?
- it's alive again!!!
- motor came back from VS on friday have 1 question tough
- Axels?
- turbo on h22a
- new turbo smoking
- is my air/fuel gauge hooked up wrong?
- 3" dp without having to shave/grind the block??
- has n e one go to turbo Tune in NC
- Show me your Profec B spec mounting spots
- Greddy Turbo Manifolds Cracking ???
- Oil Return Flange on Turbo Where can i buy one?
- oil supply for the greddy kit.
- anyone here have a turbo EK hatchback??
- What happened at Bradenton, FLA ????
- couple runs at the track.... video turbo si
- TURBO HONDA in Europe ? Let me know who u are...
- i think my turbo is going, need suggestion for new turbo
- A VERY dedicated Honda driver makes his last run
- what turbo comes in rev hard 2 kits? turbonetics or precision?
- anyone using rps street/strip street max sreis...help needed ASAP
- Anyone dyno without breaking in the motor?
- new best today!
- Need wiring diagrams
- finally made a 10 second run
- Next step after dyno
- Smoke from v.cover breather?
- What Exhaust
- dashpot and fast idle: are they needed?
- Should be running in no time. :P Pics of Engine dropped, Turbo Mounted
- Resistance after wiring resistor box?
- Eg..Drag or gready??
- rev hard kit
- VAFC and Timing
- First dyno with Turbo LOOK
- long, but need much help on why car won't start.
- EGTS hitting 1600 degrees while going down the track!
- Need an answer about using the batronix software...(HELP ASAP)
- wastegate spring
- NOPI 2003 Day 1
- Turbo Timer help
- where to mount SMC
- Stumped. Oil burning problem.....but not the norm.
- Profec A Users!!! need help!
- BOV for superchargers
- Converting the main fuel line to AN fittings..how to?
- help with safc please
- turbo newbie question?
- Drove an Evo yesterday
- Water Cooled Revhard 2C
- new 96lbs msd injectors in a venom intake help please
- Interest in complete EEPROM burner kits?
- what to do about my hondata
- Engine not seeing boost....
- homemadeturbo
- waste gate at fault?
- What's the big deal with down-pipes
- yeah i was taking my turbo off last night and went to the jacksonville airport at midnight
- Pistons and rods selection help
- Turbonetics Wastegate Springs...Which is which?
- How to mount DSM BOV and SMIC to greddy SOHC kit?
- Installing HKS EVC + exactly how?
- great vid for gearheads, check it out
- Hondabond
- anyone w/ uberchip or software seen uberteg.. hes starting to piss me off
- USED: AEM EMS needed ASAP 4 1995 Integra GSR
- proper gap for ngk plugs
- non turbo prelude dsm 450cc injectors vs stock vafc hack
- Hondata Ign Maps (pics) Opinions (vids too)
- boost = worse than drugs
- SMC+, 450 Injectors, no boost...rich??
- Emanage with turbo do I need map bypass??
- another victim of white smoke from tailpipe...
- Pistons carbon build up question.. clean before install??
- Super AFC
- Show me your guages..
- I need a Hondata Base Map, please.
- How much PSI on these Guages
- hey, my junkyard/ SUPER low budget turbo project- not honda u dont like dont read!
- Hondata Tuning
- h22 fuel injector cc's
- TURBO MANIFOLD : what are the differences ?
- CEL Code 3!
- turbo kit while keeping my a/c?
- What engine is this for?
- Low Compression?
- Installing my DRAG kit tommorow where can i get some instructions?
- blue box wiring help
- nos not engaging?
- turbo rebuild question
- What is the advantage of "twin inlet"
- Help! Turbo Glows red
- Jackson racing
- What tap to use on block. for oil feed line.
- Anyone tried UberTeg's chip+AFC over 11psi??
- h22a turbo question
- Greddy Turbo Install Instructions in PDF
- 3bar Map Problems!
- SOHC Greddy Fuel Management
- How to install wastegate......
- Forum for nitrous, where is SDstreetracer
- Vtec controller +drag gen 3 kit
