View Full Version : Forced Induction
- Turbo, Spool Times, Ect
- Help. I DESPERATLY NEED A BLUE DELTAGATE SPRING !!!!!!
- turbo b16 problem need help asap
- Johnny Race Car Didn't send intercooler for 3 weeks?????
- Likelihood of TIAL 38mm diaphram bustin on 9psi?
- Crome: Errors with BoostTools
- thinker head gaskest or stock for h22 turbo guys only!
- ITR oil pump vs B16 oil pump
- Quick question about knock sensor and CPS censor.
- what better t25 from a 97 eclipse or a 1994 nissan 300zx
- best turbo for h22?
- sleeving a block $$$$ how much?
- how much nitrous should I use? on a turbo sohc
- Hondata stage3b...DA turbo downpipe clearence!
- Those who have experience with the .63ar T3/67 on a stock block B16 post here....
- gt28rs or gt2871 for my d16 motor?
- Need help deciding on a turbo kit or should I piece it together myself?
- Leaking cylinder = boost leak = headgasket? Please HELP
- What turbo would you get? And Why?
- ngk part number for vortech supercharged b18b
- Turbo still getting too much oil, even with "Nitrous" restrictor.
- Fuel problem!
- Max Rev
- hey the boost controller installed right?
- dry nitrous vs. wet help me out
- Stock Shot Peened Rods vs Eagle Rods
- Boomslang Harness Question
- turbo ??
- Oil Cooler's
- My friend dyno'd his hatch yesterday. Not too shabby for a stock block GSR.
- Want to go to bypass valve instead of blowoff valve
- Turbo SOHC RESPOND PLAESE
- Part list for going turbo to all motor
- bad turbo noise
- One-fab...problems
- 400 to 500 hp goals
- Thinking of building it...What did you guys pay for machine work?
- blox turbo cams
- honda fire
- Possible to weld 4" vband flange on 3" vband housing?
- high whp cars what intake manifold are you using?
- Does full race have warranty on there turbo's ????
- problem w/ oil return HELP PLEASE!!
- Is it ok to wrap charge pipes??
- need some help guys running rich at idle
- what to do ls v-tec turbo set
- HKS SSQV
- Is this turbo to big.......
- Aeromotive A1000 with Ethanol???
- Pushing the 18G
- T3 .42/.48 efficiency??
- Wastegate O ring Help
- 450 injectors + SAFC..... Resistor box help.
- want more boost!
- Which turbos will fit? T3 to ... ??????
- Has anyone used Q45 TB?
- smoke from exhaust
- is there a good guide as to what parts i should rebuld my motor with?
- Would it be worth getting a cam gear for a sohc
- Injector size on OBD1 b16?
- Boost not holding for some reason?
- Eg wire harness?
- wiseco 8.5:1 or cp 9:1?
- could someone explain why advancing timing on a boosted car is bad?
- best d-series manifold?
- motor is gone, questions
- resistor box install help continutity testing??????
- anyone running a T3 super 60?
- Need help car smoking ever few days
- Where can i buy Turbo/wastegate Gaskets ?
- DIY: Repairing damaged head stud hole threads
- how can i set my timing back to stock with uberdata?
- smoke coming from valve cover breather filter???
- Pushing it to the limit.
- Eagle vs Crower billet rods..why is Crower 2x price..are crower really that much better for boost.
- Action clutch question... users please give some advice!
- ef fmic mounted
- Greddy downpipe broke :(
- EF Top Mount Update
- Gauges/Controllers....
- 654 WHP Mase tuned street Car
- greddy turbo kit question
- Best Hondata Tuner in Virginia for FI Setups?
- intercooler sprayer
- advice needed on gsr setup
- What turbo does WRX Sti uses in their stock motor?
- turbo b16
- 1/4 times and whp...
- 10sec h22 ek civic setup?
- burning oil!!! smokin in full throttle!!
- UBERDATA tuner needes in va/dc area
- Inlet flange for a t3 chrysler turbo
- boost making brake problems
- Need Smog this week Running 92-95 Greddy Kit with Crome on a EK??? In Socal???
- Missfire (maybe?) when boosting
- Tach Jumping in higher rpms?? HELP
- Why do Full-Race manifolds use Mild Steel Flanges?
- ls turbo?
- Fuel Rail Gauge install question
- Shooting flames?
- Flywheel Myth
- setups...
- what turbo intercooler piping sizes?? 2,2.25,2.5,3"????
- throwing code 1 after turbo install
- OBD-O tuning
- Do any of the vendors keep 83mm head gaskets in stock?
- AMS-Tuning?
- what can cause boost hesitation?
- built motor (no turbo yet) losing power, engine makes a warbling sound
- Hondata Basemap Questions.
- B16 turbo, new times + videos
- post here your video..
- Is an SAFC2 usefull for tuning a JRSC on a b20b?
- My New Project: Massive Data Collection
- which rod size do i use for ls/vtec?
- Is a GT42R too big?
- turbo civic fuel cut/rev limiter early?
- Under the hood temps too high? Running hot!!
- ricer hood may help with cooling?
- Greddy Profec-B Spec 2, I'm so lost...
- Anyone in So CaL that can tune Emanage??? Also question on timing control
- Not your typical exhaust question...
- help oil leaking out of cylinder#3 between head and turbo mani
- Blox Missing Link check valve
- How long has your turbo'd car lasted???
- Manual boost controller install...
- turbo cams or ctr cams
- Turbo seals toast?
- JRSC set up with 1/4 mile time...
- Building an Turbo B18c Motor....
- HELP!!! GSR turbo is leaning when VTEC engages....
- Ghetto Piping
- Is your 400+whp honda kinda scary to drive too?
- omg...my intercooler end tanks curve in and i need it to go straight.
- Which bov?
- Turbo Accord KIT... screw the H-22!!!
- best turbo manifold for GT28R/71?
- Is a T3/ Super 60 too big?
- OVERHEATING ..... Need ideas why??
- supercharged vr6? (first post, and its a little long)
- turbo or supercharge?
- Ignition problems after Boost
- Hondata, adjustable FPR's and base maps..
- question about tial 38mm wastegate fitment with revhard manifold...
- Trying to lower EGTs
- Alternative to Defi link display?
- Horrible Boost Question
- Necessary to resize rods after changing bolts?
- head gasket problem
- First time building an engine for turbo... need some advice on the block build
- High Comp Piston Question
- JRSC in an EF?....
- who is doing 250+whp on SOHC, stock everything
- walbro 255 installed but now not working
- Non honda...but boosted
- nitrous backfire
- intake air flow optimizer ?
- Missing link necessary?
- sheet metal intake install now won't idle
- bypassed an ignitor w/ MSD 6A?
- HKS SSQ bov is causing a surge!
- Oil leak??
- B20 vs B16 crank pulleys
- Yo! FI H22'er in here please!
- should i trade my d16 turbo kit for a ls/vtec swap?
- How do you guys calm down after working on your car and realizing 70% of the parts you got dont fit
- injector question
- Need AFC hack settings QUICK.... VAFC just reset
- Turbo Question
- Turbo Edit? Anybody heard of it?
- dms bov what is needed to remore them
- need expert tunning advice on nos..
- Direct Fuel Injection - Anyone look into this?
- what kind of fuel regulator shoud i use?
- i got locked
- 94 gsr b18c1
- lovefab mini me vs. shorty
- Having problems spooling quicker
- What Kind of Full Throttle Switch for Your Nitrous?
- type r turbo or gsr turbo
- nx nitrous kit
- b18b jdm or usdm?
- stock gsr boosted....7psi=>9psi....street tuned by self...safe?
- CEL misfire code.....
- Turbonetics t3-t4? Is this there compressor housing?
- Oil leak
- Has the T67 compressor map been released yet?
- quick 550cc uberdata question...
- gAy nOOB questions about N2O setups
- Need some advice for a high horsepower D-series
- First boosted gsr
- gap and plug
- Stock motor making good power? Look in here:
- Help hooking up BLITZ EBC and Tial WG
- BOV question
- Tuning problem
- S14 200SX 485whp PICS and VIDEOS
- Car dying out of nowhere!! Help please :(
- B16 T3
- K-series: custom intake manifold w/ 105mm TB
- Turbo h22 w/ oil pressure problem????
- is it ok to fill a nitrous bottle with co2??
- B16b turbo
- - Limits of Cryo treatment
- How much nitrous do u think a fully built B18C1 would take safely?
- ls turbo problem
- LS T25??
- what do ya think
- fab-work turbo kits
- where can i find a 5 blot turbo flange quick
- Poor Man's Type R + JRSC
- Opinions for Cams/Valves/Valve Springs for boosted GSR
- cleaning out the catalytic converter ?
- Raceline Tunings latest creation: EG hatch
- Turbo and stock diffs?
- 1320 track times from a crx...JRSCed...pics included
- Tuners available in short notice CT/RI/MA/NH area?
- turbo muffler
- only running 4 lbs of boost is this normal?
- gt28rs fitment w/ hks t25 manifold
- too much boost?
- those that used vitara pistons...
- Does a dumptube need to flare out to larger diameter if welded to downpipe?
- Which Radiator Cap for a PWR radiator?
- Blue Box Need Help!!??
- Total noob question about getting into entry level turbo setup.......
- RMS Nitrous System
- Bout to pickup my turbo swap, need some advice
- Recirculating BOV
- What turbo management/piggy back system for obd-0
- Shop to rebuild a H22 in NJ/PA
- Intake manifold ports
- My catchcan after one week of boost (pic)
- Turbo setup for road racing??
- running rich.... oil in pcv ?
- Planning to go Turbo !!!
- WTB GT or T6?
- open 02 housing no downpipe
- d-series turbo on a b-series?????
- Putting new exhaust housing on garrett T3 ? Garrett experts help!!!
- blow off valve location???
- Any dyno's of Peakboost kit on a D16?
- Ignition Probs, need help ASAP!!
- GSR SC61 is overheating ??
- top to bottom flow intercoolers?
- lookin for opinions on a manual boost cont. ball and spring?
- who is using the Hondata Intake Mani gasket...is it worth it with turbo?
- Need uberdata tuner near VA/DC area
- gsr jrsc iat overheat
- Help me with me deltagate!!!
