View Full Version : Forced Induction
- what would you do?
- Using a Newer Motor(obd1 gsr) in a 91 crx(obd0) ecu question.
- A 57 Trim in a .50 Housing T3/O4E
- white bluish smoke from exhaust
- Greddy E-manage Ultimate
- Upgrading Boost on JRSC B20b, ditch the FMU for SAFC2 and 301cc injectors?
- Quick Question ... BOOSTIN b16 w/ t3 garrett....NEED HELP QUICK
- what turbo is this????
- building: pistons rods sleeves block guard for my LS turbo motor
- K-series: 2525cc - the 105mm crank is going to see boost!
- Black Ef Hatch with Red Gt3s running 11s
- GT30R, JDM FE conversion, and topmount = fitment q's.
- Is my exhaust side for a "P" trim wheel?
- Tuning Rates in the Bay?
- who has Greddy Carb stickers FS? and papers?
- Drag Radials on a Boosted Car!?
- more boost out of 18g
- JE and SRP whats the diff.
- More Power From B18b Turbo
- Running a greddy bolt on turbo kit on a 98 dx do I need to upgrade the injectors and pump?
- Uberdata application?
- High temp Hose? Where can I buy it at?
- 7 psi or can i run 9.5 psi
- Intercooler Mounting???
- What turbos do Mitubishi GSX's have?
- 1st Turbo Project
- New pics of my EF
- Legit TO4B V-Trim?
- h22a4 type s
- Zeitronix wideband, MAP reading incorrect....
- Can the center section of a turbo be a little angled?
- Good tuner in NW Florida?
- Precision 1000cc and 1600 injectors. Help
- anyone one running a venom fuel pump
- XTSS Break In
- ACL race bearings OR regular ones ???
- bov question..
- SOHC vid, video
- ZHY turbos...are they any good?
- one-fab.....once again
- Water getting into head, milkshake
- 1/8" nipples for APEXi AVC-R solenoid
- OLD SCHOOL TUNING AT ITS FINEST!!!
- Need a response ASAP, is this a .48 or .60?
- New setup after blown motor
- Is there a way to program ECU to shut off based on a signal? say low oil pressure or pyrometer?
- how often to change out bkr7e's?
- Will running closed loop has significantly better mpg?
- What turbo and wastegate would be best for this?
- Need Opinions Please: Turbo Kit
- lossing power on turbo setup
- when is a complete 4" exhaust system a must?
- temporary charge piping.
- .60 a/r ported shroud compressor housing on GT32?
- HKS/Garrett T04Z Pictures ?
- hybrid holset hx40 on a sohc
- LS head test
- Anyone Running a GT35R?
- normal egt
- are they the same ?
- difference between 4 bolt and 5 bolt housing? advantages?
- Using oversize bore headgasket?!?!
- Overheating on the hignway
- SOHC LIVES AGAIN NEW SETUP. PICS
- painting intercooler
- My HKS ssqv Doesn't have a screw on the end. Is that normal?
- V-AFC on non-vtec car, use as a nitrous turn on ?
- Non-VTEC better for Fordced Induction?
- Can i run 10psi on a d16y8 with just a blue box... or fmu
- Turbo H22? 14B?
- Anyone Used Underground Racing Camshafts: EVO 264/272 Specs?
- PLEASE HELP! Oil light came on tonite and dont know why.
- Manual boost controller
- Anone seen this ECU code before
- ARP head studs, and Cosmetic HG worth it?
- not sure if this is the right forum but.....
- car bogging, sputtering, hesitating, everything @ around 3000rpm
- Should I shim my oil pump?
- Motor has 105,000 miles on it should I still turbo it?
- turbo timer harness
- cheapest turbo mode
- Boost question
- No spark on K20
- t04e help
- vafc wires
- Return line questions on 90 integra w/crossmember
- Turbo wont go past 7psi
- i want to turbo my gs300
- Turbo B16 or B18?
- SC34 .63 ar 57 trim, will the t3/t4 oil lines from stealthmode fit?
- B16 Engine Build; Ring Gap Problem
- VTEC eliminating turbo single cam?
- Garrett t3/to4e ?
- Hadn't posted an update in a while.
- Where to get a copper headgasket?!
- Defi D gauge install confused please look...
- LS-V Turbo want to find a good turbo
- Over-rev my motor….. Bent Valves?
- Look at my plugs
- Why do I suck with the AVC-R?
- Race gas does wonders
- is it worth it...or even possible..
- which FPR with set-up?
- RC Injector Clip Install
- 99 civic ex going to convert to obd1 but until then what do i use for fuel managment??
- Turbine won't spin at idle! Blown turbo? Bad oil lines?
- Where to get Backdoor Intercoolers
- Colder plugs
- damn these orings!!
- AMS EVO Puts down 808 awhp (video inside)
- oilan fitting- cant find the right size
- Manual boost controllers
- piston clearance
- "Homemade" supercharger kits?
- my 11psi ignition timing map (picture), D16Z6, P28
- worst thing happened.. some one help me~!!!
- superchargers
- starting to put together my setup.
- ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s
- fmu problem.
- Finally pulled apart my built b17... pros, please help me with these questions!
- Corrected or not corrected? Dyno info that might make sence......
- Fun times, Fun Times indeed......
- Remove engine or head???
- cutting down 60foot time?
- VAFC...acting a fool....anyone had this problem.
- SC61 turbine housing inlet smaller then my old SC44 inlet? what's the dealio?
- need trubo help
- very odd turbo problem
- What injector to purchase for my h22a setup??
- can't get more boost!!!
- a few sohc greddy turbo install questions
- modifying drag intercooler piping
- IC Piping Size
- Anybody make their entire engine harness custom made?
- what valve springs?
- How to stop td05-18g from spiking??????
- help me choose a turbo for mountain car
- 8-10 psi on stock b18a
- help ID this BOV
- Oil pump overkill..? Whats too much on a factory oil pump?
- If you can read this post you are cool!
- H23/VTEC build underway, final checklist.
- what turbo do i NEED...?????????
- Please experience/tech question, not for beginner thanks
- D16Y8 Turbo Hatch good or bad?
- Nitrous and propane? instead of fuel?
- What is the most effective cheap boost controller?
- After all the corrected and uncorrected convos....
- Reverse water flow through the block
- Thicker headgasket your opinion! yay or nay ?
- what does this civic got?
- external wastegate and o2 sensor question.
- turbo repair
- JRSC on B16a in a Del Sol
- need some help on 2000 integra ls turbo?
- Over sized valves
- Question on tuning...price
- going from copper to OEM HG: how will this effect my tune?
- Check this Intercooler Out...modded supra smic w/ welded end tanks...
- All motor B20 or force fed turbo B20?!?!?!?!?!
- lowering boost
- Suggestions for more power
- So im gonna be swapping out my lx engine and i dont know which way to go?
- Precision SC 50 Turbo... need info quick
- what kind turbo is this?
- Someone help me identify this Garrett turbo?
- thoriated tungsten
- 300whp possible??
- Just another "what size turbo thread"
- New to Turbos: Links to any informative threads
- 2000 miles on built motor still running NA--starting to sound like a Subaru
- Couple questions about reving a b16.
- wastegate dump-tube into downpipe ??
- Darton Block vs. Sleeving Block?
- fluidampr w/accessories vs. fluidampr w/o accessories poss close to 10k revs
- FPR Q
- The alternative to the inserts/rigid mounts for those who hate them. ( small write-up )
- Advice need on broken cam caps
- It's started, $7,000 out of my account today.
- Cheapest place to get a t3/t67 Fullrace turbo?
- 10 AN oilreturn line - what exactly does it mean?
- Manual boost controller?
- What Drag turbo kit for ek?gen3?
- 14 psi on stock internals?
- are drag manifold any good
- i found drag manifold are thet any good
- AVCR tech question
- do i need to upgrade fuel and ignition for turbo at low boost?
- Mase'd GSR 621 whp / 430 ft/lbs Street Car
- best turbo kit for sohc zc
- What Turbo should i use for my b18b1 setup
- new manifold install...charge piping question.
- V-Band For I/C Piping
- anybody know the part no. for the GM boost solenoid
- Quiet Turbo exhaust for a B16a DC4?
- Bracing the Turbo? (searched)
- HELP: what size is the oil drain flange on my precision sc61
- very hard time timing this motor with skunk2 cam gears
- bov
- Cams for Turbo H22
- What is THE best Electronic Boost controller. PERIOD.
- 84mm b16, t3t67 h.o. .70/.82 can gsr cams get me over 600 whp?
- Overkill??
- Need some help, car running like shit now...
- Turbo clocking and housing strength question
- Help!!! car wont rev past 2000 rpms
- K series Turbo Manifolds. DC5
- Precision GT35/61 ???
- Top mount turbo setup in EFs?
- Steering rack question
- GT series with a T25 based housing running an external wastegate?
- Fuel Pressure Drops? What could it be?
- 35mm Tial Spring ?
- more boost from greddy kit?
- b series manifold help???
- Im going LSV-T.. help
- Copy Cat of every major manifold...
- SOHC, what's better for 7 to 10 psi?
- Im finally done with my project... here is a small review.
- Apexi Power FC users! Need yr input here
- recommended max psi for b20?
- wideband questions
- built d16a6 stumbles a bit in top end...?
- Tuning a nitrous engine... optimal Air Fuel Ratio
- is it worth getting sleeves?...its my daily driver running on 91 octane
- Anyone using Blitz SBC i-color?
- Anyone w/pics of GT40
- How do I set my timing? 9:1 low compression pistons...
- New to turbo: need a honda-tech turbo lecture !!!!!!
- boostin my 94 integra
- vortech supercharger
- How to build an engine in less than 10 minutes...
- AEM EMS 1000cc Startup Issues
- question
- valve springs and retainers?
- max rev dp what manifold will fit
- choosing a wastegate
- choosing a turbo
- overfill oil on turbo cars...
- edelbrock Victor x intake manifold and stock cams
- is it safe to paint your intercooler
- D16Z6 DYNO GRAPH AND 121MPH TIME SLIP
- Bad track experience... Now my car sucks...
- Gotta T3/T4... and I want quicker spool! and do I need an FPR?
- This might be a long shot but..
- LS/VTEC SC61??
- DSM 450's on a 98 civic?
- will i need a turbo timer
- fuel pressure with boost
