View Full Version : Forced Induction
- Precision Exhaust and Garrett Compressor?
- y8 boost help with evo 550 injectors
- Manual Boost Controller gone bad ??!
- Question for turbo EF Full-Race radiator users
- which one is better to boost?
- gt4088
- Bigger injectors and idle fluctuating BEFORE tune - normal?
- VAC LINES
- Turbonetics DeltaGate
- Time Sert on Benson sleeved block
- resistor box on 99 civic si
- Boost friendly Platform
- car sputters after vtec
- where to buy a turbine outlet flange?
- JRSC Race Version for K20A2 swapped Civic
- T3/T67 turbo where to get it rebuilt or a new cartridge
- vacuum lines on victor x??
- please help!!!! boost
- additional crank load
- turbine shaft .. extra groove ? .. missing seal ?
- Semi-long term compression results for those interested
- can i turbo my mini swap?
- Dual walbro's limit
- turbo questions
- info on my turbo compressor map included
- EVAP setup question
- CTR Direct port questions
- piston break
- precision turbo o-ring
- rhd del sol turbo project
- fuel question
- Couple of questions so i can finish my first turbo install
- Garrett CHRA Exchange Program, GT35R
- Making a plastic electric turbo actually work.
- 3inch downpipe w/ e cutout-->3inch midpipe or stock? Difference?
- B18 turbo questions?
- built dohc d16zc turbo
- What Clutch?
- CT intake with JRSC?
- 95 d16z6 turbo manifold bit the dust
- AEM F/IC issues
- B16a2 Headgaket question.
- Whats needed...
- Need help with exhaust
- Help! single cam jrsc instalation ?s
- ARP Head Stud Difference?
- cant find any info on vitaras. flywheels etc
- JRSC ITR exhaust setup
- Is this Compressor Surge?
- any civic/integra (all year 88-01) front mount turbo
- What code is this?
- Ls/vtec question,wiring harness etc.
- Holy Gigantic Intercooler!
- Tunning question
- Picked up a turbo
- Supra Manifold heat transfer
- Air research m10 wastegate port?
- d16z6 too much fuel! Help!
- Boost trouble
- EG D16 turbo
- turbo return question
- How much boost to run
- Intercooler piping question
- b16 head build for lsv-t
- what could be causing my ignition to cut out?
- Base Ignition Timing Boosted B18c
- Quick question: Is this garrett turbo real or knockoff?
- turbo-ing my civic HELP
- Wastegate's operation...
- a/c compatible ramhorn diy
- hx35 ls-t
- Turbo gods need help
- B18C1 temp sensor question
- exaust manifold bolt wont fit?
- Haaaallpppp, car had sudden toyota moment
- manual boost controller question
- Tial 60mm gate with 3076 overboosting.....ideas?
- Is this clearance acceptable, or did the machine shop mess up?
- Q16 and Precision 1000cc injectors, yes or no?
- fuel lab fuel system
- tuned ls vtec turbo went lean
- Anyway to upgrade an older sc61
- need help gapping rings
- ARP 2000 rod bolts B18C1 Need Torq specs
- question about 1st time fire up
- altanator problem
- Looking for a good turbo mani
- Air/fuel gauge question
- bov vacuum source
- automatic w/ forced induction?
- Turbo LS VTEC Crank Pulley?
- V-band downpipe doesn't flex enough at flex joint, ideas?
- Witch BOV ?? help .
- What kind of Injectors are these?
- 97 hatch boosted!!!!
- Can I use the Hondata S300 with my stock injectors?
- New build won't start.
- Is intercooler + piping engine or chassis dependant?
- Boosted 35R K24/K20 Arp Torque spec help!
- Camshaft advice for boosted GSR
- b16 jr supercharger help!
- 10.0 @ 139 Stock Bottom end (non honda)
- getting oil out of exhaust after turbo failure
- Tial Turbine Housing on Precision Vband Flanged Manifold Fitment???
- is my math correct on this dart block build?
- lean and rough idle after hot start (need more help with this)
- plumbed valve cover
- Max psi with MBC and Wastegate ?
- anyone install an exedy stage 2 lately?
- kit turbo ebay
- New to turbo setup, need help with wideband
- need help! oil spitting out of exhaust
- when running a turbo setup, which to choose(content inside)
- Need help with F22b turbo setup
- pump gas to race gas power gains?
- how to remove OEM fuel rail fitting ?
- what do you think of this motor
- nitrous b18c1 help!
- Swapping motors (Turbo kit installed)
- shaft play?
- 84mm B Series boost spike problem; need help
- NXS Cheap but reliable?
- Rev Limit B16 Turbo @ Springs Supertech
- Ekb18ct to Ekh2bt?
- Question about engine limitations vs psi
- Lost of oil and sometimes coolant?
- Stock Poor Man Type R Turbo Setup
- B18C1 - Damaged Piston - Pic
- what do u need to turbo my mini swap?
- Bad fuel pressure reg. If pressure drop to zero when engine off
- oil restrictor
- Better cooling solutions?
- ls vtec or ls turbo
- Picked up a new project: '95 GSR-T
- Water - Methanol Injection - what mix do you guys use?
- D16 turbo !!!
- Intercooler question
- D15B7 Turbo Line Vacumm Question
- T3t4b and t3t4e
- Knock Monitor
- Any Good SocAl Crome tuners/shops ?
- B series 70mm tb adapter??
- Turbo and E85
- Turbo Question
- bisimoto 3.6 cam require major modifications?????
- Bar and plate Intercooler's Vs Tube and Bar
- compressor blade rubbing against housing
- insulating an intake?
- Corruption of a minor through a turbocharged Honda (VIDEO)
- Any H22 with water-methanol injection guys here ?
- Turbo ID? yes Ive searched..
- New B & R Block Plug Adapter B-Series
- B16 Turbo build...Looking for some advice
- gsr turbo
- Turbo b16 running super lean
- opinions needed!
- turbo gsr not making boost and lack of power
- B20 vtec turbo won't rev past 3grand with dsm 450s and chipped p28
- Question about turbo kit (t28 turbo)
- 550cc for 400whp is good?
- Boost/Fuel cut in 4th & 5th gear at full throttle. Please help!
- Supercharger Rebuild
- blue smoke coming out breather/oil catch can filter at idle ls vtec turbo
- b16a turbo advice
- T3/T4 spool time (no good)
- What is this little doohickey
- **Official Precision 5857 Turbo Thread**
- Boost leak out sparkplug hole/oil pan return line bung :/ ??
- Massive blue smoke,valve dropped,spark plug destroyed piston fried h-t plz help
- Help with block off flange and downpipe
- stealth mode performace drain line
- is my civic ready for turbo?
- What is the preferred BOV for 400HP on a B18C1?
- Leaking oil
- got quick ? on this head
- Oil analysis, does any one here do it?
- air filter for turbo
- Mishimoto OIL COOLER TRACK DATA?
- Turbo making weird noise at high RPM, help!!
- Godspeed GT35-1 Turbo Review
- Civic EK Turbo D16 problem
- Post your boostedd picss!!!::)
- b18b turbo need advice!!!
- JR Supercharger needs some work!
- need some1 who knows there shit please
- oil cooling on turbo car
- recipe for 600whp?
- help/tips intercooler pipe
- HELP!!
- aem fuel pressure regulator
- TURBO WONT BOOST, but it spins at idle and spins faster when revved, whats wrong????
- B20/vtec turbo build setup okay?
- Ef top mount question
- opinions on my build..
- t04e, 50trim stage 5 turbine on sohc
- Gsr or b18 turbo?
- Going from 91ar ehaust housing to a .85?
- im in need of some help in st.louis
- '99 EX 5spd, looking to boost with intended goal in mind
- 4th thermostat to fail in 2 days....wtf.
- GT35r and keeping A/C?
- FMIC.... need to cut bumper support... what tool?
- bone stock 95 civic ex. turbo advice
- Dual v44 wastegates - overboosting issue
- should i vent out my engine some more should i get an extra breather tank/catch can
- puke oil thru filter fom breather tank
- Nitrous B Series HP Records
- proper crankcase ventilation for my ls vetec turbo
- tuning with s300 question
- A2AwA2W setup can this work?
- turbo y7 question
- allstar performance breather tank install
- 5857BB puking oil... options?
- turbo or spark plugs?
- Head Studs
- EGT Question
- not just another gsr turbo but a sleeper gsr-t
- Breather tank
- d16 running a hx40 6 blade turbo opinion?
- turbo on an auto GS 99
- Is this catch can setup ok?
- Used turbo buying tips
- Distributor question...
- Gsr AC compatible ???
- cant go past 4500 rpm
- EFI Wizard 1000cc Injector Dead times
- High pressure blow by
- Oil catch can shooting out oil
- looking for 600whp with my ls
- Defective Cometic HG? Thoughts please.
- te05h mitsubishi turbo questions...???
- Where on motor does water temp sensor go?
- My B18C1 Engine Build/Assembly
- Help "Wrist Pins, rods, and Pistons"
- 97 Ek hatch d16 boosted?
- Spool difference from .81 ar to .68ar ?
- Boost barely hitting 10psi?
- need advice with buying 00 turbo civic ex.
- What are the most helpful gauges?
- Turbo spitting oil. Need advise.
- Big Bore
- Small turbo on B18C1
- stock k20 cam gear same as k24 cam gear??
- helpin my buddy with boosting his car
- t3-t4 adapter
- White smoke only under full boost....?
- Sandwhich Plate with Oil Cooler/Rel. Kit
- BLOX cast manifold on B16 in EG? Do you have to trim or no?
- going from a 50 shot to 75 no2
- Smoking blue, leaking oil from turbo, running a restrictor
