View Full Version : Forced Induction
- WTB: Turbo For d16y8
- need ideas on what turbo manifold to buy for my z6?
- Intake manifold...Aftermarket or keep it stock?
- va tunners??
- needs some advice on boosting my CTR
- Help me build a Turbo
- whats the most hp people are putting down on stock d16y8 with the greddy 18g kit?
- Turbo meets SC in unholy (but oh so fast) matrimony..
- Where can I get a TD04H-15G rebuild kit??
- How much WHP did you put down on your MSD Blaster SS coil???
- Returnless system... for turbo setup
- i just sent my brandnew vortech supercharger kit back to vortech for a new updated kit
- turbo questions
- Speedometer is surging up and down at idle... help!!!!!
- GT3782?
- turbo h22 and h23
- overheating
- Headgasket recommendation for a superchaged 5th Gen lude
- Can anyone explain this pulley
- turbo xs manual boost controller installation
- Pistons & Rods for Turbo B16a2
- ARP head stud install
- fuel pump wont come on
- i NEED HELP....95 ls w/ t3/t4 turbo.. which oil is better synthetic or nonsynthetic??
- Oil Drain Help - Cleanest way to use BARBED FITTINGS
- Big torque
- uberdata bin sixe problem
- Help Me Make 450+whp....
- turbo'in the d
- Mase is going Professional?
- What engine to TURBO???
- check out my plugs
- Finally hit 11's, B18b LS Turbo , Low boost
- Mahle piston issue
- Does anyone know how to get in contact with alpha racing over in New Jersey I think
- difference between CrowerRods/ManleyRods/PauterRods
- Who all is using a Garrett GT32 based turbo?
- Where are you all setting redline?
- Got Car Jacked in Hartford, CT
- EGT hitting 1600+ degrees!.... Injectors maxing out?
- cutout dilemma- atp vs. dmh???..
- Full race T67 429.1 WHP on 14psi , STOCK CAMS STOCK PORT
- boosted teg having trouble with timing belt
- what valvespring/retainer combo do you recommend?
- Best 4 Auto-x/Solo
- opinions on my tune
- turbo accord wont start
- B16a Turbo Setups
- My new setup!!!! what do you think my whp will be?
- GM 3 bar map sensor only for hondata?
- Going from external to internal (searched)
- Question about boost controller and s200b
- Vorteh vs. Jackson
- Ignition went bad, got new one in and now car wont rev over 3500. any ideas
- Open downpipe ----> 3" exhaust = retune?
- AEM FPR DIAPHRAM DESIGN CHANGE??
- AEM FPR DIAPHRAM CHANGE??
- need help with uberdata
- civic upgrade
- car overheating while boosting, wtf
- Stock GSR Crank
- Boost gauges ?
- Vortech vs Jackson Racing
- TurboEdit problem, is My Vafc give me shit of a time?
- Boost gauge ?
- serious problem with car (bad idle... low vacuum, car dies)
- BOV not blowing off- need help
- How do you clock a turbo???
- will it run to rich?
- Dsm vs civic downpipe?
- How to lower a Turbo boost
- need hondata base map for my D16 zc doch motor
- Does UberData Support A Boost Controller?
- Where to buy elbows for turbo manifold?
- SAFC Tuning Problems
- Intercooler piping....
- ONE-FAB...........
- GSR Head Repair
- Searched and cant find
- good pistons for a boosted b16?
- external wastegate, need some advice!
- What about P&P LS Head w/404s on stock JDM GSR shortblock for boost?
- help with the d16z6 and greddy kit
- stealthmode performance diy weldess intercooler piping kit?
- -Greddy turbo kits-
- Garrett BALLBEARING T3/TO4E just around the corner...!
- what times should i expect to do at track??
- How good are inline pro connecting rods?
- Need help guys, valve adjustment
- Problem with VTEC engagement - LSVTEC
- exhaust manifold studs bolts
- Oil Pressure+Oil Changes
- Help with Greddy boost guage install
- wieco pistons
- tial BOV gasket messed up- where to buy new one?
- Quality Turbo Bands?
- Greddy Type S boost controller problem???
- am I detonating or pre igniting need help
- xhaust????
- FORGED PISTONS
- my new exhaust
- My 1st time @ the track w/turbo
- H22a vs H22a4= Opinions on best one for Benson sleeves please! I've searched....
- can it be done?
- Aem and wideband..using 30-1000 on obd2
- how do i make my turbo water cooled..?? and..
- driving w/out charge piping.
- 2.5" Exhaust...ok for now?
- turbo zc
- turbo with bad seals driveable?
- sc61....gt35r?
- Got a DP with EGT tapped on it...
- IAT Voltage to Temp Equivalent
- Can I drive my car w/o boost?
- idle with afc hack and 440's
- How much boost can i run on my new setup?
- Turbo d;s
- Running rich at spool up.
- setup posible for 600-700 whp
- DSM GUYS: Does a Mitsu 16G Bolt Up To OEM 90-94 1st Gen Manifold?
- Machining a Garrett GT 4-bolt housing into a V-Band housing
- Engine break-in without tune
- 3.5 inch downpipe into 3 inch exhaust, will it bottleneck?
- De-pinning AEM UEGO connector
- Help, mauals for my blitz controllers
- car smoking BADLY. Please help
- What is the oil inlet fitting size for a holset hx35??? I've searched but to no aval-
- Should I rehone the cylinders? B16A w/ new bottom end
- D series Head code's/Bore/Stroke/Deck Height/Rod Length/head and block compression combo's
- stock cam on Ls turbo
- turbo oil feed line lenght???????
- Closed vs. Open loop
- best place to tap coolant to turbo....
- have anyone ever heard of this?.....
- G2's with PeakBoost Kits ....Some Questions....
- Difference between Greddy TD04H and ones that come off the cars?
- Looking into boost, should I put in new headbolts or headstuds?
- Size turbo manifold??
- Tial Wastegate 38mm dumptube size?
- Greddy kit just installed..Fuel problems...HELP!!!
- What diesel trucks are easy to modify and have good aftermarket support?(engine wise)
- I'M BACK AND I NEED SOME HELP?
- Greddy Turbo Kit 00 GSR
- What specifically causes a rod to snap in half?
- ??major boost leak, you will never guess where it came from
- Nitrous oxide and exhaust piping diameter
- install of my intercooler
- 96 hatch with a resistor box wtf?
- hondata or chrome?
- Greddy evo tt exhaust ?
- Which alternator?
- 91 octane
- gs-r turbo
- Spooling performance Downpipe
- chrome tuning
- First head gasket install, any tips?
- Need t25 manifold
- Intercooler piping?
- How to calculate intake manifold volume?
- SOHC GReddy turbo...hesitation before boost... What's wrong?
- SUpercharged GSR Question?
- .::oil in the turbo mani::.
- Opinions on 42/.48 Garrett t3 D16
- Endyn Breather instructions, I lost mine
- tuning question?
- Electromotive EMS
- b16a2 burning oil like a champ!
- slim fan question
- thicker headgasket
- Wow...Just wow..Turbo "efficiency"
- accord pillar gauge pod question.....
- Hondata tuning in Atlanta Sept 16-19th - Nopi Nationals
- what does the blue box plug look like?(greddy)
- GT28RS vs GT2871R which one is the best for me....
- juicing on a chipped ecu
- Honda (color coded) OEM bearing chart
- Forced Induction Engine Life
- I NEED HELP!!!!!!
- Nitrous Express Stage One Efi
- d16z6 zex dry kit, stock internals timing/ignition questions
- what kinda header for b18b with vortech supercharger? 4-2-1 or 4-1
- Technical info questions on my current setup.Expert advice only please!!
- which motor to build question
- anybody have 3 bar map with 550 injectors uberdata map that works
- no boost help!!!!!
- help!! my turbo teg is dying..., what's wrong
- Turbo Info for all
- Anybody using a b16 tranny in there boosted civic/integra
- how to take off a 7psi cutoff on hondata stage 2?
- head question lloll
- would like to know
- ITS Turbo
- Turbo install
- lovefab manifold for d series??
- I have the worst luck ever...
- how much boost on stock civic injectors?
- wideband issues
- V-AFC2 opinions and sugestions
- What psi or power on my new setup?
- new too the turbo game
- What type of turbo is this?
- leaf blower at it best
- BOV?
- 250 whp on turbo y8?
- Ebay MBC's...experiences?
- what trim gt28rs for my built motor?
- best places to buy complete turbo kit ***searched***
- JRC 8" IC...Keeping stock grills?
- D15b turbo (what turbo to use, cx gearing)
- i need help with my turbo set up
- Installing turbo tomorrow!! NEED HELP w/ FMU/SAFC questions
- New Autometer boost gauge reading 5psi?
- Oil coming thru turbine outlet/Power questions...LS turbo setup
- S300 question
- major problems with cracking studs with welded manifolds
- Looking for Guidance
- How rich is too rich?
- td04h + hf manifold + ac?
- car dies in boost. need help bad
- `1.5 block but 1.6 crank ???
- Tuning My Setup
- downpipe?
- question for SOHC turbo users
- Kit price?
- not boosting past .2bar
- best turbo for my sohc?
- Best b series manifold for your $$
- Help! Which Turbo For My LSVTEC?
- Breather
- S300 Sensors on screen do not work????
- help
- We have come a long way...
- problems with vtec (GSR)
- What Turbo???
- JR SUPERCHARGER INSTALL QUESTION - NEED IMMEDIATE RESPONSE
- bkr7e-11, bkr7es-11, bkr7e
- LS/VTEC-t lacking power???
- can a dyno be off?
- I need help!!
- Bearing clearance
- Which ARP head studs to use?
- Slight bog/hesitation w/ hondata s200b @ 10in. Hg vaccum
- toluene?
- Decisions, your input?
- pipes
- Best 10 PSI Turbo Kit for B16A2 Whit AC Radiator
- Quick question about turbo fitment on a 99 si...
