View Full Version : Forced Induction
- Better the gb prices, for single items!
- ** how often do you guys change your spark plugs?
- does anyone have any experience with a t-58(ts04)?
- Possible cause for gas smell?
- Last Hondata ECU installation question...
- Anyone running an oil restrictor?
- JRSC Boost Upgrade
- Jacobs Ignition KIT for sale
- what is the fasted 1/4 mile time seen with a d16z6
- Ricer question about exhaust...
- My Homemade Turbo Kit(pics,Vid)
- Turbo crx dx project...all advice needed!
- 12:1 fmu and airtex inline running way too rich...
- Eagle Rods / JE Pistons Sale
- just installed turbo, oil light flickering at idle...
- where is your boost knob at on your profec b?
- Looking for D16 dyno charts
- OT: I need a pic
- Turbo timer install question
- Question on FMIC from a starion and also drag piping...
- TOP fuel Products
- gs-r rods
- Questions about Vortech
- Evaluate My Turbo Kit........Input NEEDED
- have u guys ever heartd of an-r.com/
- Difference between NGK BCP7E-11 and NGK BKR7E
- Intercooler options
- Manuel (non-electric) Autometer Water Tempature sensor location????
- need help w/ shiftlinkage and pin
- could check valves be a problem for inaccurate boost????
- I need Apex Turbo timer instructions really ASAP!!
- t3/t04E
- obd-1 distributor wiring
- Aquired another EF going Turbo this time.....
- very annoying idle problem, need help.
- v-afc hack settings
- help with power loss!
- Who want APEXi air filters?
- Spark Plugs and Nitrous
- drag turbo kit
- Brand New AVC-R in box
- FS: LS Tranny w/ quaife, AEM EMS, MSD, AEM Fuel Rail, Thermal 3", Intercooler
- 2 questions: white spark plugs & running hot
- 92-95 civic hatchback
- Victor X manifold on a Vortech SC'ed car
- fmu vacum line
- Anyone w/ hondata and tech edge wb kit? Few questions..
- Walbro install on EF, help plz...
- Help, car throwing code....
- Tech edge wideband kit, with wideband sensor for sale
- ZC Turbo plug gaps (NGK BKR6E-11's); what should it be set at?
- Frankenstein conversion pricing....
- might go auto tranny....
- Auto tranny turbo...
- wastegate opens too frequently?
- Opinions on Rev Hard Turdo kits?
- did i break my boost guage?
- Pressure Relief Valves to prevent overboosting...
- Engine Management Woes
- b18b vs b20b/z for boost
- Crane ignition with hondata 4b...
- will this setup result in a VERY rich mixture?
- compretion test
- looking for a quiet bov .lets here some sugestions
- Hondata guys... need help with ECU
- My tranny is ANNOYING... I need help please !! Sohc Turbo !
- Just swapped on my Inline Pro mani
- SS Valves and Oversized??
- Cheapest Price/Place for a Greddy Turbo SOHC Kit
- What do you gap your plugs at on B18B turbo's?
- a few more quick qiestions
- Anyone have the new greddy full auto turbo timer?
- :( missfire.... hesitation ??
- just installed my turbo!!
- VAFC hack, open downpipe, obdII..... possible??
- Ported DOHC VTEC Head vs. Non-Ported (Boosted) HP!
- question re: NPT fittings
- Best Trans for Turbo Bseries??? I get no time with boost in first and very little in 2nd...
- anyone with the GREDDY kit TDO5 for there TYPE R and hondata?
- Aftermarket Block?
- Can somebody give me a good wire chart for installing an S-AFC into a Teg LS
- people with CM stage 5 clutch I need your opinion pls....
- All Drag crx...need help!!!!
- wiring help
- wanted afc vafc
- FS: AEM EMS w/custom map
- Interesting solution to intercooler piping slippage
- homemadeturbo oil feed? to TD05-14G need help
- base timing for jrsc @13psi?????????
- How much Boost on (D) series... Stock bottom?
- can someone send me the hondata rom editer install prog?
- Turbo rebuild?
- apexi gt spec for integras
- WHat to do if you want to run more than 12 psi on afc hack
- Power problem Part II (Dyno Day)
- Anybody in San Diego have HONDATA 4B? I need some help.
- FS: T3/T4 used for 2000 miles on a gsr (56k friendly)
- Rich during day leaning out at night?
- Greddy FCU
- Test pipe..
- leaking oil, please help!
- Will a b16a oil pan (p30?) fit on a b18c1 (p72)
- Should I use teflon tape for my oil feed and return line fittings?
- b18bturbo (viren) great service and great products
- J&S Safeguard Question.
- quick turbo question concerning exhaust please
- Custom exhaust....what mandrel bends to buy?
- i know this has nothing to do with hondas but i need advise.
- Drive shaft question?
- Finany got a camera her's some pics...
- check engline light cause limp mode?
- Zex Problem
- AEM EMS f/s $1000!!!
- WTB: DriveShaft Shop Stage 3/4 Axles!!
- MSD injectors CLIPS vs RC injector CLIPS
- Greddy Turbo CEL
- Forged Pistons. Car takes a little longer to start up when cold?
- WTB: JE 84.5mm piston rings (oil rings)
- Ls turbo cams
- Running really rich
- quick questions
- In the mood to start on a daily car project......
- ED B uses toda spec B's in his 9 sec car?
- No CAT = more smoke?
- WTF, I'm blowing oil out the compressor inlet!
- Viren & other pro racers, what are you doing with your brake booster?
- Cat is smoking....opinions please...
- Ignition System with Hondata 4b
- where to get autometer cobalt gauges?
- big PROBLEM with the car
- just made the swap from a greddy tdo5--->t3t4 60 trim
- Does anybody know who Bob Norwood is?
- MAX-REV users, you going thru wg gaskets like crazy?
- too many choices.....
- conservative timing vs aggressive timing
- TD05H turbo question....
- blow off valve
- clutchmasters
- Code 41, primary oxygen sensor???
- BOOST PROBLEM: Still the gerbel inside doesn't want to run.
- Anyone smell gas?
- HELP, ZC throwin code (1 I think), and loud tapping/rattling near cam gears..
- WENT dragging w/ azenis's...
- BTM from F-Max kit used without MSD 6AL?
- te04h turbo fit on drag or greddy manifold
- hood clearance issues w/ tial and inlinepro??
- ok this is what i am going with what do yall think?
- te04h turbo
- To install Walbro unit now or not?
- Bay Area Dyno Day Results
- Help with cams..
- Turbo plans! Advice welcomed ;)
- Problem, need information and problems....
- Titanium Retainers.?
- Hks Evc IV???
- did a compression test (crazy)
- Efi Pms
- Eagle Rod Fitment
- wastegate size
- Drag fuel pump setup question......in the middle of a install need quick help.
- Rough idle/rev w/ blown ZC; plz help; and what plugs do I need to b usin?
- turbo install soon, need advice...
- Honda-tech a little too hostile????
- anyone in michigan running an AFC hack on a turbo'd LS????
- is this a good deal on axles?
- B18BTURBO (VIREN) was in the hospital!!!
- SOHC Greddy kit does NOT fit civic B18B1
- new car, sell GSR and move on to a supra? need your help
- Help with Autometer Air fuel ratio gauge
- greddy manual boost controller
- My LS-Vtec started right up today
- Anyone still interested? Toyota/B16A hybrid piston/rod package for SOHC D-series engines..
- GSR cams???
- Kinda OT, but not really...read: FS:17" Silver Volk TE-37's
- will hondata's datalogging work with Windows ME?
- serious concern regarding gt30s and gt35s
- What cc injector's?
- dip switches on the profec b?????
- Recommendation for a good lightweight flywheel.
- Turbo
- inline fuel pump, fuel relay
- Glory Day! Finally tuned and Dynoed my Car!!!
- is this turbo kit too good too be true?
- Everybody's worst nightmare, my motor is officially dead!!!!!!
- ITR Intake Valves
- 371hp B16a Si
- FYI: I have intercooler piping w/ bov for sale in the classifieds.
- Which would you choose?
- Who has a turbo timer and an aftermarket alarm?
- T3 60-1 questions...
- what is going on when i hear rod knock? Rebuild
- b-18 type r in 02 rsx
- Max Rev Turbo Kit Blow-out $2599 shipped
- Anyone know the specs of a td05h-18g ?
- Need help with turbo setup!!
- Need help with T3 specs
- need link to "the old one's" break in procedure
- My weekend with GruvyTune and hondata...
- OT: Is this a good welder to buy for begginers?
- Exotic BOost*vid*
- lots of smoke
- bov flanges
- Darton sleeves. Who uses them? Need some feedback...
- Blue Wire Mod - Black Box
- TURBO lude vs JRSC lude!*vid*
- Just a quick question
- I need Silicon Reducers for my APEX IC..PLEASE HELP
- T3/T04E turbo
- A sad day indeed.....
- T4 ->>> T3/T4 need help!
- turbo kit help
- NPT Flange on a Greddy TD04
- BOV and WG confusion
- looking for some good dyno charts or hp
- Most HP a t3-t04e can support?
- Cant hold Idle. New motor with hondata. Runs like CRAP. Veterans, I need your help
- Those with Moroso Oil Pan.....clutch cover
- final 3" custom dp install pics.....no 56k..
- My turbo... It came today!! I might keep it.
- need b18 torque specs asap. please!!!!
- Will any of of these injectors will fit a '99 integra gs?
- Carsound 3" cat glowing red, need help
- Stft, Ltft & The SAFC...
- Internal Wastegate actuator setting with Electronic Boost control
- someone please explain something to me about wastegates
- stroke & bore for a d16y7 and Combustion on a d16y8?
- Anyone have any experience with JG turbo short blocks good/bad?
- Need Clutch Information!
- ever ran 2/3bar map senser with afc hack
- Overheating problems...Please Help
- idle goes down...hondata question.
- Dumb ? about turboing jdm b18c1...
- NHRA Rollcage (Street car class) specs? Prefab?
- greddy turbo kit install on d16d6 civic
- Who needs turboXS products
- FS: NEW Clutchnet Stage 2 clutch
- Down pipe suggestions for greddy turbo
- afc hack settings??? please post your: psi, afc settings, injector size
- AEM EMS install question
- This is killing me, I can't go much longer without my car...
- Can Somebody Please convince me too keep my SOHC and boost it!!!
- racing with 15s vs 16s
- advantages of J&S v2 over v1?
- Wheel size with turbo?
- oil drain flange. Searched for hours
- High mileage motors with turbo?? who has them
- junkyard turbo builders T25 Map questions.
- d16z6 piston options
- T3 Question
- what headgasket to use?
