View Full Version : Forced Induction
- Anyone using CPR "plug n play" OBDII>OBDI injector clips?
- Custom turbo on f23a1 Accord possible?
- homemade liquid intercooler routing setup question
- Little problem with ACL bearings and crank spinning
- Honda-Tech AEM EMS support crew!
- Two Injectors in Series?
- Turbo kit I found on eBay...
- Thinking on H23 turbo
- Whats size turbo should I get for my b16
- fields vafc vs apexi, which costs more, which is better why what how
- curing paint on turbine housing >>
- Best manifold w/ AC ok
- Havin trouble with Hondata... HELP!!!
- OIL PROBLEM ON 99 CIVIC SI TURBO....
- All Tuners (For Archive)
- HONDATA RELATED QUESTION
- exhuast housing .86 too big?
- Found out why turbo b16 was running bad.
- HELP PLEASE URGENT!!!!
- help with boost controller
- Painting the turbine side of the turbo - need info.
- Take at look at my block.. Well this affect anything
- does j&e make a piston for a b16a
- Quick tire size question for the best traction.
- T3 center section thread size for water in/out ?
- fmu disk
- question on lovefab SIDEWINDER manifold
- Exhaust on a turbo prelude
- wont go pass 2 psi
- My turbo hatch runs like shit. help
- no leaks, no boost!
- detnonation
- G2 integra jackson charger?
- 38mm tial wastegate fit on manifold made for 35 mm?
- Overheating?
- Running compressor turbo side with ac compressor attached
- b20 facts sticky if you want mods
- constant misfire after warmup...02 sensor
- *vid* DYNO from Sunday w/ my turbo d16z6
- need oil pump for my b20 set up which to pick?
- LHT Supercharger Intercooler questions
- Hey i might have a problem with my turbo clearance , tell me what u think.
- turbo manifolds?
- Question about my turbine and its size
- how much is a busted td04h-15g worth
- Bigger downpipe for TD04-15G
- my custom turbo setup sofar...
- wtf is going on with my compression?????
- rattling turbo!?
- Mase's Tuning Tour to the West Coast - Earning money for the Laskey Racing Sponsorship
- Need help deciding between a Prelude and Civic Si to boost.
- ACT HC5-HD00 (stock disc) vs. HC5-HDSS (street disc)?
- STock b16a numbers before turbo
- 91 integra B18A1 LS fully built/ turbo in crx what am I in for??? comments???
- ls/vtec turbocharger
- How do I adjust DNA MBC
- Who's Better and Why Debate
- Drag piping vs Revhard piping vs Custom?
- Anyone have experience with AEBS racing - Hondata tuning
- pics of my soon to be a6 setup
- How much boost do you think I can run?
- Need a mentor...any volenteers?!
- Opinions and comments...
- wrapping a/c lines
- What size of intercooler do I need? H23 EG hatch
- Greddy wastegate
- just some recent pics of my setup..
- Boost questions, Need your insight
- Turning car on without downpipe
- need some advice on setup
- tuning question???
- mounting slim fans...
- What cc injectors should I get???
- Fuel pressure for Ls/vtec supercharged
- DOES ANY 1 in here runs an oil cooler with turbo/vtec???
- help dp issues
- Cranks
- Hondata question Using romeditor 3.5.5 & still getting O2a cel (running openloop)
- what the hell is the purpose of an injector resistor box???
- anyone seen this manifold??
- Question for those with the Tial BOV...
- plate/ sheet steel/ aluminum/ etc...
- finaly..my dyno video..
- changing compressor housing to make bigger turbo??
- NJ Tuners Help!
- Let's give it up for our Tuners!-dedication thread!
- Quick answer needed... 3" to 2.5" DP into 2.5" exhaust....
- D Series Turbo Manifolds
- boost, lighten flywheel
- T25 turbine housing to manifold bolt size?
- what do you guys think about this car
- Has anyone used knocklink on there hondas....how well does it work
- ls turbo in hatch, will intercooler fit?
- HKS SS BOV broken end bolt
- blue/white smoke coming out of my exhaust at idle
- Making backdoor on intercooler
- WTF! fake hks ssq bov?? pics..
- Which turbo for my built B20?
- ? bends for a 3" dp on ss t3 inlinepro mani on b series
- gsr/ls block question
- Take a look at this mani
- Turbo Manifolds???
- OIL LEAK... Smoking cat????
- Pics of PT67 for my buddy with a Supra! Thanks Art!!!!
- my setup good enuff for 300whp?
- Headgasket vs. bore size... an issue?
- STOLEN CAR IN WI (Mikeahowski's) KEEP A LOOK OUT
- gsr cams
- Boost source?
- painting downpipe and manifold
- AFC Hack on NSX?
- Side Mount Intercooler on an H23 EG hatch?
- safe to buy used tial wastegate?
- ls/vtec with turbo?????
- Help-Turbo h23 having random problems!!
- How much hp can i put down?
- which LSD???
- EG guys where do u mount your gagues?
- what i need to do to go back to stock
- How to Tune & Modify Engine Management Systems
- Anyone heard of STP manifolds?
- turbo ls hatch prob???
- t25 adaptor plate question
- REVHARD turbos
- LS with Turbo would Overheat with AC on
- Built prelude project almost done!!!!!!
- Part number needed for PLug for o2 sensor
- breaking in turbo engine any tips?
- NGK BKR7E gap question.
- Can i use this wheel like this?
- Downforce over the front wheels theory *pic*
- for all those with Turbo applications on a VTEC motor!!!
- breaking in quife LSD and Titlon carbon clutch
- vw jetta 1.8t stock turbo dyno
- ANYONE HAD TO HAVE A HEADGASKET MADE(NON COPPER) PLEASE READ
- post fmic pics 30x9x3
- what head gasket should i use
- Distributor Vs. Distributorless...
- Precision Sc61 and InlinePro Feed line????
- '97 civic Type R looking for turbo
- Apex BOV - 3 vacuum ports!?!?!?!
- JRSC is fouling oxygen sensors???
- O2 Sensor placement.................?
- Hondata 4b or S200B
- Washed out #1 cylinder, anything I can do?
- Which head would you use?
- High RPM break up need some help guys..
- Turbo a carb'd F20A engine
- what head gasket would fit me best?
- how do you know if the stock fpr is bad?
- Propane injection for gas engines? Is it possible?
- Plx M250???
- BBK mustang TB TPS sensor...
- What turbo to use on stock gsr?
- JRSC & Comp. Ratio
- thread size of golden eagle vtec sandwich plate
- turbo help? how soon do i need to tune it?
- FPR for 60shot on 1st gen b16
- Headgasket!!!
- stock rod vs. eagle h beam rod
- burnt oil in my turbo??? pic inside.......
- MAX psi on Stock B16
- Attn: cheesefrog!
- Toluene feedback
- >>>>>Willem burner - is a 13.8v power supply Ok to use?<<<<<
- Hondata or AEM EMS......Did a search...... Newest opinions please
- GE oil feed line?
- TurboEdit with B18a PR4
- Bigger goals....bigger snail
- O2 sensor?
- Finished my car
- RPS Turbo Manifold SEXY!!!!!1
- Anatomy of the switch from electric to mechanical fuel pump
- Getting closer and closer to feeling LS boost
- 14b alternative wastegate?
- Hows this setup? Opinions needed!
- AEM EMS Question ????
- Starting installing my Tyrus Intercooler
- Nitrous help
- Spark racing and ss autocrap
- Stock base map or tuned base map?
- eeproming geru's have some questions
- What turbo is there for the rsx
- finally get her back up and running. first race on video with 500hp supra
- GT28R a good choice? (Link to map inside)
- revhard vs greddy vs drag vs turbonetics
- very general d16z6 question
- Uberdata burning tuning issues
- Interchangeable Turbine housing?
- Anyone else waiting on Defi D-gauge gauges??
- 3" downpipe compatible with the drag kit?
- Washington Tuners???
- oil return to oil pan, sandwich style setup, will it work??
- Setup 95%complete. help me with the clutch+Turbo!
- recomended headers for a SC engine?
- 720cc + Saturated injectors
- For the Turbo pros, I really need your help.
- What throttle body for Victor X manifold for a boosted application
- turbo setup for D16 hatch
- Is a -3 feed line with a restrictor starving the turbo?
- custom turbo setup?
- Turbo newbie: Need help on junkyard turbo setup....
- b16 turbo not starting...need help pleeees
- reliable boost controllers?
- Kamikaze header-fitment on civics?
- going to dyno but have question
- Need Help --- Turbo Kit I'm Selling for a Friend, whats it worth?
- a few pics of the setup going on my crx
- Turbo Shop ?'s; Who do you get your insurance through?
- anyone running b18a w/ custom 14b turbo setup in their 2nd gen teg?
- Romulator connector help???
- What do u think of this d16 set-up?
- Uberdata turbo d16 do I need injectors and a fuel pump?
- Whats a better turbo for a d15b?
- I need bolts, where to get downpipe to mani bolts!!!???!!??!
- Planning for a turbo H23
- When to use an intercooler?
- Which cat-back system you guys recommend???
- 00 Si w/ JDM b16 + GT35E @ 12lbs=306whp/215wtrq...........
- turbo 4g preludes here??
- Would this turbo kit clear my a/c.... pics....
- I think its time for an upgrade..
- how far to go?
- hmmm
- GSR Boosted..Another Dumbass Radiator Question
- Going Back To N/A Safe After Turbo???
- vti and vto in vafc.
- what does detonation sound like?
- adjusting ignition timing?
- Measurement how to's, cant go any further till i get help
- Piggyback System, Help please!
- OT: just put a huge intercooler on my mk3 turbo supra
- How much WHP are 310cc injectors good up to?
- Very noob question, search=nothing
- i need help
- Need input on D-series Turbo build
- Need Input on D-series Turbo
- B16 turbo what kind of numbers should I expect? Please post
- I need axles for my 89 hatch with b16 turbo
- Manifold, Turbo and Downpipe lining up question?
- 110 octane?
- turbo vafc hack anyone
- Turbo fuel management
- NEED HELP IMMEDIATLY PLEASE.
- QUESTION ABOUT EXHAUST CUT-OUTS ????????????????
- tial flanges
- cheezefrogs car still around?
- SC or T3/T4?
- H22 Air/Fuel Ratio
- how loud is a no-exhaust turbo setup?
