- boost cut symptom...PLEASE HELP ME...
- Oil for built h22
- FPR question.. Turbo GSR
- Power Steering bracket for Top Mount
- Turbo Engine Back Pressure
- What do i need to tune a car *Newb*
- cracked sleeve
- turbos on EBAY
- TURBO SMART dual stage electronic boost controller
- tuner in twin cities MN or WI
- e manage whoes
- boost guestion
- Questions for the cam gods.............
- motor blew could it be over torque headstuds
- 2 Years in the making... Thanks to Slowmotion Motorsports!
- start-up woes....
- Boost Solenoid Placement (Pics)
- supercharger question?
- IC Piping vs. IM height
- **HELP with AVC-R settings**
- FUEL PUMP HELP PLEASE!!!!!!!!!
- T25 vs. 14b?
- Turbo for K20A
- nitrous motor damage!!!
- BOV vacuum
- smokes a little by the turbo manifold?
- 90 DB1 Build up
- spring in wastegate Q
- Given Imports a Chance!!
- Need some advice on boosting a stock ls motor
- boost problem
- what turbo exhaust flange is this?
- high idle after doing a valve job....
- why cant i hear my BOV??? HKS SSQV?????
- radiator civic gsr??? need help... my turbo pierced my gsr one!!!
- car doesn't hit boost HELP!
- HELP oil retern and oil feed ??
- how to build a "reliable" turbo setup?
- ATI damper 7" race version for B-series streetability issues
- blown turbo?
- JRSC Question... ( Bypass valve )
- 96 civic hatch making 340 whp at 4psi in stock internals??????
- What's this part?
- what turbo?
- why cant i feel VTEC with my turbo kit
- Has anyone slanted their radiator to make room for a downpipe?
- fresh off the dyno...
- Gt28 for Sr20det... What do you Guys think ?
- trying to find out who makes this turbo bell. i need your help!
- 12 second turbo eg for $5300...
- NOS activation
- Installed fully built head then turbo blows up
- Opinions on STOCK RODs, FORGED PISTONs
- need help with turbo qustions
- VHT flameproof coatings?
- 96 Integra Type R Cams?
- Greddy Profec B Spec II help
- Am i running it a little too lean?
- How does boost by gear work? s300
- Black box plug???
- loss of torque with light flywheel?
- what fittings do I use for Oil sandwich?
- need a little help on some info
- Looking 4 A Semi-Buit DD..
- am i forgetting anything?? sleeved b16 build
- Turbo help? t3/62-1 BB
- cooling down supercharger help
- whats your honest opinion for this kit?
- NEED HELP PROGRAMING APEXI AFC CONTROLLER FOR 450CC'S
- what tq wrench would be best for my engine build?
- turbo problems
- Need boost solenoid information
- Are Sears Craftsman 110v welders any good?
- Introducing the new and improved Bullseye Power Race cover
- Avid solidmounts/ s372/ fullrace top mount. It will bearly fit.
- Thermodynamics and Heat Tranfer
- gm 3bar help
- How can i contact TiAL?
- low impedance injecotors with resistor box
- Any JRSC B20VTECs?
- another vacuum question... turbonetics evo wastegate???
- will a 125 direct port NO2 shot be safe
- T1 Cam Trigger Kit
- blew new turbo due to failed oil pump bad day at dyno
- Have 5 gauges to power...where can I draw from without blowing a fuse?
- A big thanks
- d series topmount
- B20 Turbo sizing.... T3/To4b?
- f22 tuning
- fjdistributors? good parts?
- Bad idea for nooB to get turbo?
- Wraping a turbo in heat wrap????
- HELP!!! OIL FEED LINE D15?
- HOW MANY PSI CAN STOCK EK GSR HONDA MAP SENSOR HANDLE
- jdm type r pistons
- B16A or B18C cams?
- Never enough wont start after swap posts
- K-series Catch Cans
- Chrome Pipes HELP!!!!!!!!!!!!!!!!!!!
- Help me decide on a clutch
- 11.5:1 compression too much for JRSC and 93oct?
- NEED ADVICE ON CHOOSING A NEW MOTOR FOR MY LST SETUP!
- any one know about "facetuned" ?
- Greddy EK Bolt On turbo Kit on B18B1 LS Motor
- ls-t setup?
- d16 injector question dsm or s2000 for boost?
- Ok so I have looked around the forums, Need advice for the correct A/R and fuel return?
- ***The right turbo for lightly modded stock block b20vtec.....*****
- any have any experience with the force performance HTA gt3076?
- TURBONETICS DELTAGATE MARKII WASTEGATE need help
- need help with my d15 b vtec
- ok my turn want to run dsm 450"s with inline resistors.
- turbo timer dont auto count
- Napa sleeving
- Autometer gauge questions
- any BW t3/t4e users out there???
- turbo question
- Intercooler Size!!! HELP
- New Project:Boosted CRX
- Does GE Sandwhich adapter have two ports?
- type-s setup??
- Looking for some advice please
- HKS Hi Power too restrictive for turbo? searched...
- what clutch?
- PCV/breather port to intake side of the turbo..good idea??
- Have u gus ever used or heard of
- Cometic Head gasket thinner than stock?
- b18b bearing clearances for DD turbo?
- Turbo speech tomorrow plz guy need help!!!
- Please Help Me!!!!
- gauge location suggestions
- D16 Forged H beam connecting rods
- boosted b16 fuel cut?
- Turbo Selection (need suggestions)
- CAR KEEPS DYING OUT NEED HELP
- What size turbo most beneficial for a JDM ITR 4.7 tranny?
- Are Auto meter oil pressure sending units junk? mine keeps dying..
- hurry supercharger question!
- Turbo LS Tuning
- LS turbo's...whats your oil pressure points??
- ARGH lost bov spring sigh, where to get another??
- ls turbo
- Turbo Help!!!!! Please!!!!!
- Need some advice , deciding on a turbo
- smog legal turbo piston
- Rage Big Tube Header or Kamikazee 4-1 for JRSC setup?
- Has anyone ever Lost power after doing a valve adjustment?
- Wiring in gauges...Please HELP!
- Poor Throttle Response after swap
- Couple Turbo Problem Questions
- heres my new setup... any opinions
- Installing Head Studs?
- ????? Can You Turbo a 1988 Accord Lx-i ?????
- car almost dies out! NEED HELP!!
- aem coil drivers?
- is it worth taking the factory A/C and P/S on a boosted D?
- dart block and stroker kit.....??
- Need Help Finding End Tanks!
- New Build seems hard to crank over...
- Catch Can Set-Up
- Highest HP on B16+.50 trim+ pump gas?
- Calling All users of NGK wide band OR PLX-M300 Click here
- Resistor box removal?
- NRG tech + gt35r, pump gas and s2000 = 541hp and 357tq
- hesitation need help fast
- map sensor for hondata s200
- Got 4" K&N filter...good size for GT35r?
- need to order some parts, where can i get it all in one place?
- boost pressure and flow rates
- Boost it or not?? what compression
- pics of special fin&tube intercooler
- New eBay 57 Trim Turbos. . .
- 99-00 SI obd1 coversion questions!
- Need help on motor brake in
- tunning programs
- what rods should i to go with crower or eagle???
- aftermarket fuel filters?
- Question about Hondata
- b16 stroker
- New plugs...very white?
- OPSU Broke in Block PLUS.....
- Clutch and Flywheel suggestions (97 GSR 250whp)
- b18c1 boost
- quick o2 sensor question
- Some noob questions widebands...
- p75 w/ s200 hondata on b16a turbo?
- Question about Timing belt tensioners
- venom intake? any good
- What to tune with??
- 94-97 oem fogs+ intercooler=???
- B20 Turbo
- brand tial bov doesnt blow off
- CRX new charge pipe and battery relocation.
- stock b16
- installing Tilton twin with OEM throwout bearing, where to trim TO bearing? (pic)
- Have question about heavy black soot coming out of wastegate!
- hondata s100????
- Emanage-air flow adjustment map
- Question on installation of ATI damper 7" race version
- walbro burning out after one pull?!?! help!!!
- im getting to much fuel
- greddy knockoff bov spring question
- turbo question
- Turbo spark plug wires????
- looking for turbo housing
- b18c5 on 125 wet shot!!!!
- VECCO Turbo Kits? Anyone?
- my next upgrade!!
- edelbock gt28r turbo info
- problems PLEASE help
- Xenocron Help please
- my 450whp stock motor goal
- FS Holset HX35
- turbo too small for topmount manifold?
- noob FI questions
- car keeps dying out need help
- Plx m500 wiring
- Oil burn on left hand turn.
- capability of greddy 18g (max power and on what size injectors)?
- b16 boost
- noob? about turbo
- boost problems...
- HELP!!! Broken exhaust stud gone wrong!
- Opinion XS engineering cams
- WI emission testing question on 94' turbo dc2 ls
- chiped jun p13 vs. chiped skunk2 p72 ECU for GSR eng.
- Intercooler damage caused by high pressure car wash?
- trim?? 57 or 60?
- manuals
- no compression, low compression......whats the difference haha
- Universal question??
- H22...Missing a few pieces of some pistons...need your thoughts?
- turbo b18b1 help
- Turbo selection for daily driven b16a2
- Overheating issue....need help!!!
- Help! How do you differentiate a TD04H-15G turbo from a TD04H-19T?
- Precision Turbo's "Boosted Technology" ?
- threaded hole in block
- precision turbo rebuild
- turbo for the goal
- what race fuel do you use on your turboed honda
- wanna go sohc v turbo!!!!!!!!
- D16a6 1mm oversize valves
- rrrr... i found gold treasure.
- NRGtech Jason 800hp+ dyno run with spec's "tech forum"
- build your own manifolds?
- Need help
- Passing Emissions in NJ
- 1st gen CRX si D16A1 turbo *having SMOKE PROBLEMS!!!* ~motor rebuilt~
- msd 2 step
