View Full Version : Forced Induction
- Apexi Air Filter
- NOS Questions?
- What do i use for IC pipes????????????
- Newest Dilemma (summer engine build)
- Types of Injectors (DSM, Supra, RX-7)
- B18B - T owners - What kinda power & what kinda setups are you running?
- blow off valve install
- Very Imp: sohc + cam gear adjustment for turbo
- Pictures of my boosted CRX with the maxrev kit ! and a few other things..
- Are 24.5x8x14 slicks too big for me?
- What type of fuel pump to run....
- T25 turbo off 2nd gen DSM into B18B1 custom job?
- hondata 2b
- Questions about Blow Off Valves.
- CRVTEC turbo?
- Well I WAS gonna turbo my GSR but...
- About how much does it cost to install a clutch?
- Valve adjustment.
- what to do with 84mm bore
- turbo dx??
- Anyone running the Holley 12-916 fuel pump
- i'm still having fuel problems.....(anyone)
- GM 3 bar Map Sensor
- Anybody with a TurboXS MBC
- B18B or B16
- how much does it cost????
- OT: Does any tire manufacturer make 24" slicks in bigger rim sizes?
- Turbo troubleshooting Chart
- turbo for type r ?????
- turbo my LS?
- B18B turbo
- 13.528@104.40 street tires 7.5 psi
- - PICS - AVC-R scramble button install
- base map for hondata??
- Just postin some pics =)
- Polishing ic pipes..... WHAT A PAIN IN THE ASS....
- Thanks to the HT board, in particular pressurizedSI, for the gauge install instructions
- Can someone please illustrate the differences between turbos in various kits?
- Turbo ZC CRX ?'s
- Tial wastegate install q?
- 2 step....
- Decisions about swaps and turbo
- Joe P Manual Boost Controller Install
- Consequences of using 87 octane in a turboed engine?
- 12.33 @ 117 mph.....full interior civic w/street tires.
- injector question... 30lb = xxx cc? 36lb = xxx cc?
- insurance and turbos
- Where to pass emissions in VA/MD/DC?
- Intake Temperature Sensor
- who is the best hondata dealer?
- max boost on a TD04 Turbo?
- What's wrong with Venom Injectors?
- B20 Turbo
- Took my car too the track....not good, please help!
- PINGING???
- Greddy oil temp & press gauge? help!
- how long did it take for you to get your drag turbo kit?
- Pics of my car
- Maximum Boost owners: Compressor map question
- fuel pressure gauge location?
- can someone post a pic of the flange of the max rev manifold or.....
- BOOST CONTROLERS
- Motor mock-up
- Possible Nor-Cal Dyno Day
- e-manage anyone using it?
- Questions about Autometer gauges
- Ok you real turbo/engine guru's.. here's a real challenge!! (MSD problem)
- advice on tapping prelude fuel rail cap... [pics]
- Turbo problems - wastegate arm -
- Importparts something weird
- Stand Alone
- D series Turbo Setup!
- Question about spool up time?
- ZC Eaglel rod issue
- 48 views later and still no answer
- ---->>>> HOW DO I ROTATE COMPRESSOR HOUSING???
- **TURBO LS: FUEL QUESTION??**
- Post videos of you boosting!!!
- Blow off valve sugestions
- injectors question with the drag kit
- Hondata Datalogger + Mac?
- Any Nor-Cal Group Dyno Days?
- Help with a GOOD turbo kit?????
- Where to buy XS turbo's?
- Need help can't run more than 5psi runing lean
- Simple Turbo questions
- Question for any Turbo H22A????
- quick n easy question, does an inline fuel pump raise your static fuel pressure?
- swapping blow off valves
- CEL. . .
- how can i check my ecu to see if it works
- pics of my motor with intercooler.
- not the fmu it's a problem with the inline pump?(please read)
- Where can I get cheap Intercoolers?
- Avg. life of piston rings under boost?
- Telephone number to DRAG (turbo kits)
- Best Intake Manifold For Turbo Only
- Mugen style side skirts?
- gimmie gimmie some head! <image intensive>
- Who lives in Englistown NJ or close to it
- Polishing Manifold/Ic pipes HELP
- FS: Max Rev Manifold, Downpipe and Turbo
- dyno results in, no pic yet will be up soon.
- Interesting oil pressure discovery.
- long time on H-T, settlement, E-beer time!
- How much hp from a B18b turbo?? (stock internals?)
- Anyone here have a Greddy E-Manage ?
- ? about importparts.com
- Water cooled turbo VS oil ??
- Anyone that has an STR manifold on an H22 PLEASE read.
- e-manage or v-afc
- What's the size of the oil feed fitting on a Garret t3/4e?
- Ballbearing turbos q's?
- Curious who has built h22's with turbo...
- I got Ferra Valve train !!!!!!!!!!!!!! Yea question on my bottom end?
- where's the fuel pump relay
- turbo question
- AEM ECU
- Turbo : What does " A/R " stands for ?
- Leitner & Bush
- Stupid Newbie Question
- Msd dig6+ install questions?
- I'm abt to install a jr supercharger...
- What exactly is needed to put an ls block in my si?
- I did it !! im BOOSTED ! YAY for maxrev ! yay for Booost Video inside !!
- boost controller install questions
- Hmm...oil leaking from exhaust side
- Torque steer issues.....
- vacumn source questions
- Can someone Identify my turbo? Pics inside.
- hondata
- which intake manifold?
- hondata question
- **performance pulleys**
- hondata people please help! (Doug also )
- turbo oil line fitting?
- All you JRSC dudes, need help
- Exhaust place
- custom turbo help
- The power of Hondata
- AEM FPR
- How to find specs on a turbo?
- Help me choose and does anyone make one...
- going to the track tommrow, any prep needed?
- drag slicks
- how to bypass o2 sensor miln when using SP
- Let me know what you guys think of new setup
- would like some pics on where you guys mounted your scramble button
- What to get/do before a dyno tune...
- Silcone adapters for sale once again
- Can I just us an ls block instead of a GSR block?
- Wow!!!!!
- oil return BULLSH*T again
- H23a Valve Train
- problems w/ nitrous kit... help! please
- Max-Rev Turbos, Turbo Manifolds, and Downpipes!!!
- Is .60 AR trim too much of a Lag for a CIvic Si?
- mount inserts energy or prothane?
- How much HP from adding a Test Pipe to a Turbo?
- TO4E turbonetics turbos
- So much for my downpipe
- cometic or stock head gasket?
- Attention Ben @ Importparts.com
- b17a block...with b16crank and rods?
- Hondata=hpr gains????
- I some turbo cars retain their cai, with a bov attached to it, some dont, whats up with that?
- Avyone have ?????
- Fuel pump question
- fmu sticking????is this possible?
- Guage Special DEFI 2002 Lineup gagues These are there standalone guages
- Does anybody have sounds for a BLITZ and Tial BOV
- hondata problem?
- Need some shops in Northern NJ.....
- OT: trash talk - bench racing slang
- Sold out of hte UBAR guys
- My car is down but not out...
- need help on internals
- best cams for a turbo gsr?
- Service Offered: Hondata Street Wideband Tuning
- how many of you consider shooting nitrous cheatin?
- Missing link, 100000 miles
- Headgaskets that lower compression... Scottish or is it CRAAAP ??
- NSX turbo setup?
- Greddy turbo and wastegate
- Damn oil return line......
- H-T Atlanta Meet May 25th
- want to lower boost
- Anyone have pics of the Max Rev kit on their Integra??
- EFI PMS harness....
- **built LS recommendations**
- where can i find a spare block for rebuild
- Please help with choice of turbo (exh) manifold company~~~ THX
- Greddy Type S --- VS ----- Blitz Super Sound ... adjustment/questions
- Oil pressure problem
- When you tuned your Hondata, how much did it cost?
- What better to cool my turbo?
- POLL: Thinking of selling my rims what should i do with the money??
- Looking for a Oil return plate for my turbo, And a Deltagate to HKS adapter for my maxrev manifold N
- **waterpump problems from boost**
- Changing injector clip question
- ZEX nitrous kit for Civic? Need some help!
- Wow....I already got it! Thanks for the GB!
- FS: Brand New Tial 35mm Wastegate!!!!!!!!!
- out of curiosity, what would it take for a honda motor to handle 60psi...?
- new rods and pistons... not sure what i think [pics]
- sfp turbo kit ?
- Quick question about turbine housings and compressor housings on LS
- damn : eagle rods are HEAVY!!!
- How fast is a boosted ITR?
- which manufacturer makes a quality throttle body?
- brand new missing link for sale
- Bad experiences with hondata gasket ??
- oil filter successfully relocated!! PICS INSIDE!!
- need help with greddy manual boost controller
- Searched already...where is that page with stock injecotr flow rates?
- update: Turbo buyers!!!
- OT: Counter-strike V1 .4
- Is anyone else waiting on Turbonetics?
- RC Injectors help!
- Anbody can/want to do another hondata group buy?
- Where do u mount turboXS mbc?
- BOV Gasket
- Polishing your turbo piping help on how.
- who here has acutally built a B!7a
- J&S install q's
- Pusher or Puller Fan?
- Would anyone be interested in starting a GB for Moroso Oil Pans?
- Price on a new crankcase sensor?
- opinions on mr.gasket multi stackable head gaskets?
- Dimensions of drag intercooler?
- Valve guides: OEM or bronze and why?
- ot: TURBOS SUCK...
- Quick question..
- drag3 or vortech?
- Oil Consumption?
- Where to get turbo silicone hoses? 2 1/2 Inner diameter to 2 inch ID
- best kind of ignition upgrade when boosted?
- TURBO QUESTION
- Clutch problem
- Shop in MD/DC/VA
- Check out what came in the mail, I have a couple questions.......
- Tips on installing HKS SSQV BOV
- pics of greddy sp exhaust
- Only getting boost for a second during shift.....then 0psi????
- FI guys what kind of spark plug wires are you using?
- 4000 HP integra inside is it true?
- In need of a Greddy Profec B....please
- HELP - Custom Turbo...
- The truth about air filters for use with turbo's..
- Internal / External wastegate Apexi turbo
