View Full Version : Forced Induction
- OBX Stainless Turbo Manifod/Downpipe
- Any new on the Edelbrock T-Kit
- Tall Dart! (stroking)
- overheat
- Started her up and.....
- ls turbo overheating please help
- press gauge km/cm2
- break in with or without a chip
- Hondata costs...
- who makes intercooler piping for B series into EK??
- HKS GT3040 and Garrett GT3040R
- B16 swap vs turbo d
- setting profec spec b II
- custom setup is coming together ;D
- Finished up, Burned a Base tune...and she runs like shit...
- LS TURBO, Do I have to remove my AC Fan?
- Where else can I find these cut outs?
- Why won't my SC61 line up with lovefab T3 flange manifold?? HELP
- exhaust for my turbo setup
- My options.. (input please)
- Looking for TONY
- pigtail for 3 bar map sensor
- which gauges?
- custom turbo setup time ! (part 1)
- Fixed injectors on turbo teg now.....
- retarded timing+rich+3"dp= overboosting?
- 3" T3 .82 A/R downpipe on a .63 A/R Turbine
- Another Stock LS Dyno
- Built B16 head turbo'd ?
- AEM EMS Auto Fuel Mapping... is it as easy as it sounds?
- pivot turbo timer wiring ?
- the age old question.......
- D15 Turbo Q's
- map sensor voltage for psi help!!!!!!!!!!!!
- egt sensor HELP
- Compressor Map for T04R or T67
- Reading Compressor Map for my turbo - Check my Math Please
- turbo'd prelude
- boosted LS tranny...myth???
- Please help with BOV.
- What size turbo? buiilt ls
- D series shift forks reniforcement pics and info
- small turbo crx
- Which is the best aftermarket b series oil pan?
- Any one here use garrett t3t4 57 trim 0.50 0.63 stage 3?
- wastegate sizes
- Supercharging question
- Idle fluctuating after JRSC install
- LS turbo
- degreeing a camshaft
- what manifold is this?
- how does the computer change the ignition timing? the distributor is confusing me
- Thanks Av Engineering!
- No Spark?
- New form of e-cutout
- SC34 vs. GT32E on a GSR
- Hit Boost for the first time
- Need 5 bolt flange bad!!!
- 92 ls turbo how do I hook up the map sensor with the check valve?
- need help quickly!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- I need your opinion
- pics of my setup, also some track times to go along
- Everything is set. Now how do i burn it to chip?
- Need help ASAP! Pressure sensing relay or for JRSC!!!
- Turbo LS/VTEC help me choose the right turbo.
- putting nitrous on my gen4 lude (h23a) in oz
- 2000 gsr greddy turbo overboosting
- Has anyone tried PVC for intercooler piping?
- Any one know why my car stumbles at WOT while in boost? HELP!
- Which Magnaflow muffler for 4" exhaust???
- 400whp turbo honda, still getting misfire after msd box install?
- part number?!? help
- Question for tial bov users
- blue smoke at idle only
- d16z6 srr final drive
- Help - What is a Tial 35mm wastegate with an open dumptube supposed to sound like?!
- How to Remove H series Balance Shafts Properly
- Interesting find today...
- What dumptube will fit revhard manifold and Tial WG???
- internal wastegate question!! help :(
- Advise a manifold
- T3/T04E 57trim with .50A/R compressor and .63 or .48 A/R turbine????
- Smoking problem...need D series or anyones help
- turbo b series manifold
- running lean with greddy kit?
- What should my A/F be for my car../
- oil type
- T70 b16a needs Reliable StandAlone ?? Easy-to-use ??
- O2 sensor problem
- How much valve cover vacuum is normal?
- Greddy MBC TVVC Users...Please Help!!! Install Question
- Has anyone use the Moates chip burner with Hondata?
- B16A or B18B for boost?
- dsm 450CC install help please!
- Endyn catchcan pain
- turbo'd stock manifold
- B18a1 turbo setup help!! I SEARCHED!!
- AEM EMS and UEGO wideband question
- Dyno Plots (9:1 Compression Greddy 18G GSR)
- WTB: SST B series NON-AC Manifold or Mini-Me B-Series Non-AC manifold
- who is using a T3 .42 .48 turbo or similar on a d or b series let me know!!!!
- The Car Gods have been good and bad to me :( :)
- IM mani for gsr with boost...
- Radiator Fan?
- cryo treating crank...before or after balancing
- B20B with JRSC setup problem...
- Where are the times???
- Do I need a slim fan with my setup?
- Milled head
- what's the difference between a big shaft garrett 60-1 and T61?
- Best way to Get Oil feed
- Help!?! (labor charges) does this sound right?
- jg manifold question
- upgrade to sc61?
- Question: What are the best sparkplugs to use with turbos?
- I give up / some please help a turboed d16 >>
- B20B/PR3 CRVTEC turbo owners Please Read ... Or gurus.. THanks..
- Tools for a build...
- cheapturbo.com turbo rebuilding should i use them
- Auto Tune??
- how can i tell if its a 10psi spring for a 35mm tial wastegate???
- Turblog!
- Cold start misfire
- safe boost for a sohc vtec?
- S2000 Turbo pics... AEM EMS equipped
- where to find high temp L shaped Silicone hose at?
- AEM EMS gurus... please look at my log
- experienced people-please answer
- Good tuner needed in Central OH
- greddy turbo tunning Question vafc also hondata
- Spark Plugs
- non honda - how much spray can Z06 hold?
- how does the hks ssqv sounds like?
- Reading a Twin Screw *lysholm/Whipple* map ?
- How to match a turbo for your app. (we need a sticky)
- Is this what I need to build my GSR longblock with LS guts?
- highest CC honda which is cheapest to build up...
- Sleeving B16a
- storing car artical
- FOUND A TURBO CHART. COMPARE THE CFM'S
- Went to the track **Boosted stock GSR**
- valve seal replacement
- Hondata
- FMIC with NO bumper support?
- Intercooler Pipe Integra
- Oil line question
- 350 hp on 600cc injectors?
- Tuning tips
- jdm d15b, need to find a complete turbo kit
- speedpro tuners!! what system would be best ??? Looking for system for subaru
- DIYers: What'd you use to make additional valve cover vents (to catch can)?
- getting fpr what should the fuel pressure be set at?
- Propane injection w/ nitrous kit
- b+m fpr how crappy is it?
- Engine Help
- need some helping on turbo size for a K24/K20
- Protecting/rerouting a/c lines for DRAG turbo kit
- power loss
- wideband O2 sensor, which is better?
- Is this block ok? how about the crank... (56k - no way)
- TURBO MANIFOLD for a K-series EG/EK???
- wastegate dilema
- Dyno numbers with Uberdata v1.7
- Benefits of a tubular shorty
- oh Dninja fellas help me choose my boost level!!!!!
- Question about the RevHard Kit
- cybernation
- flip intercooler upside down
- what are some Realistic numbers for my set up. PLZ help!
- turbo for 1995 civic
- is it time for rings???
- My Setup. Finally Coming Together. DVDA 56K.
- Greddy kit showing 4.5psi while reving in neutral?? Wait, it gets better...
- Drag Turbo Kit
- nomex?
- I'm N/A and I need guidance...
- 1300$$$ for tune and p28 IS this for real???
- Installed Wideband...Getting Rid of O2 Heater Code?
- how much would it cost me to take my z6 to the machine shop for this work?
- Boosted, Tuned, B16A2 seems to have a lot of power dropoff =\
- do i need a HP or LP fuel pump for my setup?
- .60 A/R and .70 A/R compressor housings interchangeable?
- Knowledge Base
- Few boost questions
- Greddy Turbo Kit!!!!
- For those of you who pieced together your own kit
- cutting out under boost
- T4 GT35R Questions....
- Turbo Help
- Any o-ring head gaskets for d series?
- Who will be the testbed? Someone test this to end the debate.
- stumped on an issue: would changing gear ratios mess up a tuned setup?
- Pix of new RPS carbon fiber clutch for the B
- hMm..safe boost for b16a
- need opinions on block problem
- Not Starting after Turbo Installed
- precision sc61... too big for my setup?
- bouncing tach post #983745. but with more detail and different symptoms! search no good
- Greddy Gauge Cluster Mod Write up...
- can u break in a fresh motor w/ turbo installed?
- Cheap Wideband
- Plug Issues
- HELP w/b16 turbo setup
- Any way to run a 3 bar sensor and a safc???
- Blue Box Wiring
- Missing NX part that fits into intake where fogger is mounted??
- head work needed?
- 9psi DRAG Civic Vids
- Film on top of coolant
- Autometer electronic Boost gauge help???
- Plugs are pitch black
- What size is this fitting? (water in/out on a wet T3 CHRA)
- turbo oil lines
- Picture request - EF Turbo setups
- need advice: popping noises from intake filter at idle
- Opinions from SOHC stunnas
- turbo rebuildq
- 35 mm sealing ring
- Tuning Questions (Camshaft Setting Discussion Only)
- turbo cam??????????
- Greddy evo 2 for my drag 3 at 7psi
- Best supercharger for B16A
- What outside temp is too cold for 15wXX oil weight?
- why is low compresion piston not good?
- car doesnt turn over...and has whinny sound like belts off?
- are the length of vtec valves bigger than ls rev valves?
- car doesnt turn over...just whinnes like the timming belts off?
- Prep for Long-Term Storage of Turbo Car...
- ls rod specs?
- what turbo do you have and when do you reach full boost?
- Retard timing with distributor box, how much
- Skunk2 Cams turbo charged
- Tip for Greddy Spec II users
- AEM EMS HELP. SYNC TIMING??
- Random startup problem.....
- Looking for basic turbo set-up
- OBX Intake Manifold
- boosted civic running lean >_<
- Which is a better start?
- GT35R Users - Check in!
- AEM OR FJO
- VAFC/Engine trouble
- whats the best BOV for a d16 custom turbo kit???
- Wastegate is fluddering, avcr boost controller, searched....
- hondata s200b question
- does anyone know where i can hear the GodZilla blow off?????
- Built 2.0L GSR NA Tuning
- changing cam timing alters A/F ratio?
- b16a3 built block swaped in, stuck in gimp mode now? :(
- d16 cometic headgasket
