View Full Version : Forced Induction
- Hondata Question -- What's the biggest injector you can use and retain "stock like" idle?
- b16a2 turbo?? good or bad
- On a turbo how can you tell which is the oil in and which is oil out??
- Building my block, need some specifics
- got pix of a crower blockguard?
- Ic piping for ek civic... question ;)
- Fuel pressure, injector duty cycle, etc.
- where's a good place to find turbo parts???
- Turbo i.d. and couple turbo questions
- how do i tell what turbo i have?
- going b20b turbo how much boost?
- anyone interested in a set of rc 830 cc's injectors.peak and hold?
- Need some help. Thinking of going turbo.
- What's the difference running a 35mm or 40mm wastegate?
- LS turbo breather question
- Jackson People
- Mini Me Turbo Crx... 1/4 mile time..
- Motec Wideband O2 Sensor v. "others"
- intercooler size????
- dustin- DIY wide band
- Power losses due to A/C?
- Where to get turbo manifold?
- ripped off by a fellow H-T member...
- Question about boosting b20
- what size turbo for b16 (trim, a/r)?
- Timing at 24??!?!
- Cad drawing of my air to liquid intercooler JRSC!!!
- quick turbo question
- Static Fuel Pressure for turbo w/Hondata
- can someone tell me something good about the greddy setup
- HELP! I'm trying to find out if this T3 will work for my B18C1
- Anybody with ZEX Kit on a GSR???
- Anyone make kits for a '94 del Sol VTEC model???
- do i need to check clearances (pistons & sleeving etc)
- Saturated 500cc plus injectors?
- Hit the track this past weekend.. unfavorable results...
- Difference Between Closed and Open Loop??????
- charge pipe
- New series for the drag racers f&f style
- Turbo question
- Water Cooled Turbo
- Oil Cooler install with turbo teg
- AFC
- Funny thing about boosting @ hwy speeds..
- I can't take it anymore ! What boost/fuel press ? HELP !
- HKS SSBOV
- Single Cam Turbo smoked a 12 second WRX on street???
- Good Deal
- I need that pic of the oil feed line setup.
- Flywheel?
- Newbie Question!~ need major help!
- Pic/idea req. Greddy kit - 4th G - starion FMIC piping....
- looking for a manifold collector...
- I called Cometic Gaskets and they recommended this size?? please help
- Turning up the boost on b16a2 with stock compression ...
- drag turbo users: public service announcement
- GSR tranny for SI tranny
- 11.99 or better? a little long
- 91,000 Engine blowing oil, How much boost can I run till she pops?
- golden eagle sleeve question...
- look at this pile of misinformation
- need pics of engine bays ( EF's w/ B-series swaps)
- what would you pay for a used kit?
- Hondata Tunes Library now available
- Fmax turbo kit and b16a?
- axle question
- bov question
- pointless question
- Hondata Question...
- Milling and decking??
- Someone should make a AN to stock fuel rail fitting.
- OT: Umm, so how do I get Turbomafia recogntion again??
- fuel pump has to be the prob., i think?
- How to read pressure on AFC
- turbo question
- Anyone got specialy tips for launching and driving a turboed car at the track?
- a few questions about greddy kit
- break in period
- Where can I get an HKS turbo timer wiring diagram?
- hondata interface problem
- my turbo housing is fucked up!!!!
- OBD-II to OBD-I = more power, what happens??
- blitz k3 turbo any good
- blitz k3 turbo
- What's the Spearco part # for the core used in the DRAG kits?
- OT: Pics from NHRA season opener in gainesville
- Hondata issues....Sorta long...hondata users please help!
- NY/New England area Hondata tuners?!?
- can u spray nos on a high compression engine
- GREDDY or APEXi Intercooler??
- Which Nitrious system are u guys using for your GSR???
- what compression is nitrious friendly???
- OBD 2 to PBD 1 swap .....problems??
- are they serious?
- What all is included in jrsc kit?
- Someone PLEASE post a link/site for help installing an AVCR on a Honda...
- Anyone doing a Golden Eagle Groupbuy?
- tranny help...
- Best place to purchase Walbro 255 lt/hr in-tank fuel pump?
- H23 turbo install finally done
- How much to spend on Turbo Installation
- too much fuel pressure
- fmax prelude vs. greddy gsr
- FS: closed loop downpipe....
- where did u mount your HONDATA blue box and shiftlight? post pic if ya got em!
- Need help w/ buildup.
- twin vr6 turbo anyone??*vid*
- up for sale, my custom turbo kit and standalone
- car not starting with inline guel pump......????
- Where to get a water pump for air to water intercooler?
- Turbo kit for S2000?
- Best head gasket for turbo itr???
- i just got my new blown block today but...
- Maximum fuel pressure....
- revhard stage 2C
- Supra Pistons in D16z6
- Talon injectors and tuning
- Tial wastegate bolts SUCK!!
- #4 runs rich! Everything else okay
- Where?
- doing away with power steering
- H22A T3 Question???
- HEAD BUILD...CROWER OR PORTFLOW? WHAT SS VALVES?
- sorry for posting here but thought maybe some of u FI guys might be looking for an apex ebc
- Can you identify this BOV?
- Clutch chatter
- what car did the p28 ECU came from???
- Turbo Exhaust Manifolds
- how much boost with 75 shot direct port nos?
- Car Lags In Vacuum?/
- Anyone Running HKS supersequential BOV?
- Anyone could suppy a fuel map for EMS?
- boost controller installation
- Very High Idle after spraying
- ecu?
- JG Edelbrock Manifold results
- Which oil and coolant to use?
- backfire
- Anyone here have or know of a T3 setup on a DOHC B-series engine?
- N.O.S purge kit on zex nitrous kit...install questions
- Help me out here guys...
- will GSR oil pan fit B16
- Need help ASAP. K26 turbo?
- Best Turbo Setup For GSR?
- Another fuel pump question... inlet and outlet size...
- FS: Accel DFI V6
- Just a ? ... is this bearing wear normal? (56K beware)
- i have an rc injector question
- How do i get a turbo honda to shoot fireballs like a supra? just asking
- is the sr20 turbo any good?
- B20
- **need HELP from auto tranny experts**
- New and Improved Greddy Turbo Kit Carb Sticker
- j&s users HELP!
- thanks for the help 11.5@135
- help! i think they sent me the wrong rc 440 cc injectors! installing now :(
- Bent valves!!!!!
- is the ecu socket on a auto 2000civic the same as a manual?
- any JDM Gsr turboed?
- Blitz sbcid install problem
- How bad is runing a turbo on stock block?
- Don't tap oil pan?!
- Fittings
- anyone know how to read compressor maps?
- importpoweronline...
- ENGINE REBUILD: GSR or LS oil pump??
- just a thought on in-lines....
- AAARRGGGGG... damn nos inline fuel pump....someone help!!!
- my full stainless custom IC and downpipe for my h22a accord
- BLITS BOV ON GREDDY IC??
- For those who bought a DRAG kit
- Where do you install an inline fuel pump?
- the ultimate machine
- Whats a good cheap turbo manifold for the D series?
- Intercooler maintance
- Where to buy Moroso oil pan?
- What to put on the PCV oil valve from the engine?
- JRSC people!!
- AEM EMS Price. Good?
- Drag Gen 3 Turbo Kit for '99 Civic EX?
- my fuel rail =) ...
- Which Turbo Kit Would You Buy??????
- please help me
- drilling a stock fpr
- pistons : endyn 9.5:1 or JE 10.0:1 for jrsc h22a
- EGT Probe, where to put it?
- NEED QUICK ANSWER ON INJECTOR INSTALL
- Rev Hard Turbo kits
- Track time. What do you think?
- Bottle Pressure???
- How many PSI on stock map sensor??
- Can stock R clutch take it?
- Would bad/no knock sensor cause this?
- new clutch is on
- What dictates a lot of boost?
- Anyone have contact information for MAXREV turbo kits, search function doesn't work.
- Turbo map for DSM T25? Where can I find them?
- dyno numbers, Hell yeah!!!!
- (experienced mechanic only) cam timing?
- a/f ratio according to Lambda value?
- ** WHAT NEXT FOR TURBO LS SETUP?? **
- 10 Lb JRSC H22A: Dyno graph and tuning notes
- Some pics I did a while ago......
- Compression test on GSR
- Loosing compression
- Turbo Lagg/Fuel Problem??
- Quick fuel question
- hondata users: shift light dimly lit....
- Another b18b/turbo question??? PLEASE READ
- Intercooler
- I know I know, not another turbo timer question..
- any one have more than 10/1 compresion on a fully bulit turbo motor.
- Help me find someone!!! Red Civic Coupe with black bumper that is boosting
- What's the difference between the Turbonetics big shaft & standard shaft???
- 'n00b' questions...
- questions on turbo h22a accord
- Shot peened LS rods.
- New toys, check them out
- engine management for 4th gen
- why does everbody say itr motor are so bad for turbo
- b20+drag turbo kit, have a coupel questions
- what water temp do you run at?
- exhaust with turbo...
- Overheating in turbo EG hatch
- Is anyone going??
- cost of turbo ls
- turbo ls
- What plugs for 55 shot with the zex kit?
- Fuel setup
- fuel questions
- NEED HELP ASAP TRANNY
- Sumitomo connector for NTK wideband o2
- turbo lag? wtf
- search isnt working now guys, how do i adjust bov?
- Questions, advice, blah blah..
- timing belt??/turbo
- Just installed 370's and AEM FPR.... Now car is hard to start
- Is it okay for the blade/shaft to wigle up and down a lot?
- Installing Block Girdle?
- OT:ranting about prices!!!sorry, I have to
- V-AFC instead of AEM
- Help with ZEX install
- OK we all want a hondata setup. but who wants to pay $200 for the harness, let make one here!!
- Turbo kit power
- Injectors for last gen SI with jrsc.....?
- custom mandrel benting in so. cali ?
- Re-sleeving block from GE
- How many PSI??
- re-sleeved block
