View Full Version : Forced Induction
- what would be the downside to adding a oil cooler?
- Will this headgasket fit?
- car wont stop boosting?
- ? about tip-in detonation
- Static Fuel Pressure & Base Fuel Pressure
- Question about NOS and Turbo
- Need your opinion on what tranny to use?
- no exhaust on CRX?!?!? idle issues?
- Pics Of my buddy's New H22 block back from Benson
- turbo specs
- blitz racing meters/gauges...
- Whats the best exhaust for a b16 turbo?
- Wh has dynoed their Greddy turbos on their GSR's?
- Low Compression Disadvantages
- max rev kit ques
- Where to buy Aluminum sheets for Intercooler end tanks?
- haltech ek6 on a b18c1 ek boosted street car?
- help with internals??
- Cruzenpeformance injector cleaning
- silly focus... 19psi and 300whp
- Should I Put A Vtec Head On My Boosted LS
- I need intercooler piping for a......
- Which Spark Plugs for my B18c1? BKR6E or BKR7E?
- Pass emission test with turbo car?
- greddy e manage
- My car is faster than bitch ass danny's hatch
- jacson racing super chargers
- how much did it cost you to build your precision turbo kit?
- rsx cybernation stage 1
- Wastegate Open at idle. Please read !!!!!!
- Anyone have a p28 bin for a d16z6 with boost?
- 1g dsm BOV questions
- tial wastegate quest..
- Let me get the FI guru's opinions on this new allternative to a turbo charger before a friend of min
- B16 block B18c1 head. which pistons?? Which oil pump?
- 880cc injectors with VAFC temporarily????
- Looking for shops in California to build block....Have used search, can't find
- exaust manifold
- Denso Irridium spark plugs....
- octane vs. boost
- What kinda of Axels????
- how can u dial overlap out????
- can a type R handle boost
- which headgasket?
- gauge question
- Anyone contacted Motormatrix lately????
- 27C256 - did I get the wrong chip?
- VAFC HACK Problems Please Help ASAP Search in archived no good 411 found
- Vacuum lines...quality...???
- What is the potential hp with this setup? This thread is for experienced F.I. users
- valve settings for turbo???
- is 20psi achievable with this setup??
- B18C Block Conversion
- Greddy turbo on Integra GSR....
- whats a better charger for a d1y8
- Down pipe question
- UBERDATA: b20a engine: LS stock w/5% more fuel and 2 degree retard overall decent base - suggestio
- anybody tune there own car?
- what degree mandrel bent do i need
- Moisture from PCV normal?
- how to hook up this fuel pump.....pic
- Custom Precision Turbo T71 GTQ Just In!!! Preview Pics!!
- Spark plug gap with stock heat plugs
- Replacement for GReddy Blue Box
- dynojet results at 6lbs
- 550 cc injectors , 400 hp??????
- Rev Hard Intake Manifold
- >LS rods in a D16, who has done it??????<
- check out drian line..
- EGT probe placement - I think there is confusion
- resistor box UNINSTALL???
- not Honda related, but involving nitrous.....
- Tests on the PCV system - How Honda intended it -
- High Horse power SOHC - What axles, IM, etc???
- Techniques for finding vacuum leaks?
- Completely stock B20 turbo guys..opinions, complaints ?
- avcR ?
- Car Overboosting In Cold Weather
- fuel pumps? intank or inline?
- Can someone tell me something about my turbo?
- JE vs. Arias 9:1 Pistons.... which is better?
- baseline fuel pressure?
- oil leaking between DP and cat flange - help
- adjusting internal wastegate
- p28 ?
- Full-Race AC kit DYNO results
- OBDII and turbo..?
- rc 310cc injectors
- Turbo Mani with A/C (SEARCHED)
- HAHAHAHA
- Concerns wit da EGT gauge???
- 9psi with STOCK b16 motor and.....
- ITBs on turbo engine?
- hondata help... w/ h22!?!?!!!
- Where can I get the bung for an Autometer EGT gauge?
- 9.1 compression??
- Fuel sump alternatives?
- TurboXS RFL (PERFORMANCE)
- Best head for boosted ls vtec
- anybody live in Tacoma,Wa
- turbo vaccum
- DP D or B?Will it fit....
- Edelbrock Turbo kit
- boost upgrade simple question
- Quick VFAC hack question
- When did this come out?
- turbo spec. question?
- JRSC QUESTION????????????????????????????????????
- my 400hp project inside, words advice welcomed
- Help my vafc wont initialize!!!
- sohc turbo/supercharger
- For those with sleeved Blocks
- Sc61 and Inlinepro ???
- Pusher Style fans?
- golden eagle fuel rail questions....
- Can my block be saved? Pics inside
- help me build my d16z6 for boost!
- Map sensor, pins
- gsr cams
- Wierd exhaust sound - please help diagnose!
- Uprading fuel system for turbo?
- Built motor: nitrous question.
- LHT S tube vs stock JRSC S tube?
- please help me cant boost
- Holley 255 walbro in my H22A
- Building up a motor??
- please help
- spark racing mani?
- revhard mani?
- uhm k wtf?
- anybody running water injection?
- anybody snapping axles?
- 10-12psi on a stock GSR?
- 550cc Injectors too big for this setup?
- Junkyard turbo selection, input needed
- 440cc or 550cc saturated injectors for...
- what has the same bottom foot of a greddy type s?
- Well 03 is coming to a end, where does your project stand?
- After market IM for D16Z6 with SC50 .63 ar .... ????
- how much boost can you run on a stock automatic tranny.
- can i chip my ecu rather than buy an fmu?
- Great news for NYC and east coast tuners, new dyno shop opening.
- zex wet ?
- t3 from a saab to a sohc zc
- what are good vacuum sources on the IM?
- Which BOV is this, Greddy R or S??? Whichever it is, how loud is it??
- how many HP stock head bolt can handle??
- 81mm vs. 83mm
- Flow of the Fuel Pump from Drag3 Turbo Kit?
- Exhaust Manifold flange on a 13g turbo
- SC61 e/s vs. t3/t67 (full-race) POTENTIAL....
- Greddy Front Mount - NEED help!!
- Ain't that SEXY... nice turbo kit
- anyone have pics/info on full race kti on gsr motor w/ sc60-1?
- TO3/TO4e turbo good with b16a?
- Laskey Video from ATL Race
- hondata tuners in oregon, souther washington
- greddy turbo questions
- -3AN stainless oil feed line is good enough for Drag kit?
- greddy fuel management question
- CM clutches yes another one, but please help
- OS Giken Clutch lineup
- avcr and tial waste gate?
- REV HARD HIGH V-FLOW INTAKES NOW AVAILABLE!
- precision injectors vs seimen deka injectors
- liquid cooled turbo?
- 55 shot Zex nitrous kit what kinda spark plugs to use?
- K series
- How do I find a crack in my manifold?
- RC injectors VS Precision injectors?????????
- b16 vtec head on ls
- Nitrous lines
- Got my hondata tuned yesterday.
- Code 14 (usually IACV) - Can leaking headgasket cause this also?
- Engine Stands
- will ko3 work with d16
- leaking vacume
- DO I NEED A FUEL MANAGEMENT SYSTEM?
- DSM injectors help!!!!1
- Motor's FINALLY done and installed (56k go away)
- Pics of my turbo'd 6th gen accord coupe
- Thanks VaporTrail (Full Race and TiAL)
- oil restricter or not
- Doing vacuum leak test, need to know the diameter on my cold pipe.
- V-Band
- Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata?
- Vaccum lines turbo?
- Junkyard turbo search
- Hondata tuner
- DSM injector install HELP!!!!
- What is the biggest downfall of the AFC Hack?
- turbo installed
- Over 10 psi on stock H22 :: Personal experience only, not what your "friend" did/said
- turbo guru's need your help identifying this turbo.
- kkk turbo
- Need Sugestions for new turbo
- Slightly off topic. A small video of our stores Supra's trip to this years USCC3...
- Opinons on Uberdata
- Walbro 255 vs. Supra TT Fuel Pump
- MBC: Best way to set up Vacuum Lines ??
- Walbro intank fuel pump question
- The Real Electric Blower
- EMS/Hondata Vs Generic
- Tilton carbon twin disc on road course?
- Anyone running a Turbo Dohc Zc in their crx/hatch? Wanna see some setups
- help with nitrous...
- HELP!!! DRAG charge pipe+ hks bov
- Question for those running 3" dp and exhaust
- CRX intercooler pipe
- PWR Intercoolers
- 499 hp busa FOR REAL
- Very odd problem with GSR just developed..
- JE Rings ok with Wiseco Pistons?
- OEM Turbo Specs
- Can't go past 5000 with nitrous!?!?
- Rev Hard manifold
- Ls tranny or JDM ys1 ???
- ARP head studs????
- Any Events happening in Florida between 16-30 Jan 2004?
- Manley Rods?
- stutter at part throttle wtf????
- New Race Videos
- compressoin/turbo selection for my gsr with full race kit
- Rc Injector O rings
- need to contact HMT members - shitbird, BMC
- whoa found something cool, sorry if repost
- 499 HP TURBO busa
- Premium Gas at Exxon vs. Sheetz
- 1989 Honda Civic Si built by NASCAR driver delivers 480 HP!
- Question about FMUs
- -hks wastegate spring- 6psi
- Skunk2 Manifold on LS
- looking for a place to buy gauge pods/cluster from...
- NEED HELP
- Whats the biggest Injector thats been used on Hondata?
- AEBS intake manifold + boost?
- Opinions on useing stock bore pistons.
- Welding my own piping, what size piping do you recomend?
- anybody use a spool on the street?
- AEM FPR drain back fitting help.
- How would these four turbos compare to each other?
- Does anyone know what happened to Pac Motorsports in Colorado???
- Bored in class today, made this...
- Got my Johnnyracecar.com IC mounted up...[pics]
- Four probes, one EGT gauge, and a rotary 4-pos switch
- Small Garrett gt2252 for b1ã2?
- crazy drop in hp and increase in af ratio dyno inside
- greddy 18g turbo...what do you guys think?
- new version of uberdata
- Full Race t3/67 (56k go away)
