View Full Version : Forced Induction
- 575WHP SI ... Need More Torque!
- BOOSTED D15B VTEC
- Making a B18c head flow better
- good or bad setup
- which backhousing to use 48 0r 63 A/R
- AEM 5 Bar Problems?
- 108,000 horsepower
- turbocharging a 07 honda fit
- compression ratios on boost
- Spun a bearing...Looking for ideas for quick build.
- is my turbo done?
- whats the best turbo to run on a stock b16 while still retaining a decent powerband
- need help on turbo parts
- Air to water intercoolers. Looking on a definitive answer on efficiency.
- Materials Recommend for fuel usage?
- Can i use this line for fuel?
- How damaging is a -4 oil feed line w/o restrictor?
- Which ECU?
- aem EMS problem
- HKS SSQ vs BLITZ
- 450's on 90 b18a and engine health.
- Crank Case Ventilation Plans & Questions
- Fuel smell normal during boost? (ext wastegate + open dump tube)
- In Search For Parts...
- Dont care about WHP or BHP, i want to hit 200lbs of torque.
- TD04-specs
- anyone here run a b-series cable tranny in a eg.. 1-2 shift killed my hydro tranny....
- volvo turbo
- question about blue printing
- where to find mitsubish 14b TD05 discharge flange?
- crvtec on my del sol
- P06 ECU codes
- dsm 450
- Need Oil Restrictor for turbo....
- Rod adjusement on wastegate
- Place to get engine built in VA?
- cylinder hone
- MSD Tach Adapter??
- T3/T67 vs T4/T67 - has anyone compared spoolup times and power output?
- Air Water I/C on a big hp setup (700-800whp) - who has run them on the street?
- Garrett turbo with 70 miles is SHOT!
- Overpriced? What are your opinions
- Head gasket and timing belt question
- identifying turbo size?
- align bore
- oil ?
- Built block ?
- XTD clutch
- Raw gas leaking out of my manifold??!?!?!?!?!
- stock b16a turbo
- turbo on stock h22
- dumptube bends
- post your pics of your side exit exhaust or downpipe....
- wich oil is the best for turbo b?
- Why does the t3/60-1 turbo have the -1?
- Ported turbo
- zex nitrous kit ..help
- might part out the car or sell it outright..?
- What type of Oil pressure gauge should I Get
- 74mm Supra vs. HPF M3 vs. Stock M3 (video) "closed course" ;)
- ect correction in cromepro
- -4an 10 micron pre-turbo oil filter
- Noob Question: How To Turn Up BOOST
- twin loop muffler on turbo setup ?s
- what is the purpose of the spring in Tial BOVs?
- Upgrade to VictorX or keep my AEBS... ?
- Piston rings
- 97 Civic EX with a homemade turbo kit need help
- New Integra Looking to Turbo
- Blox, Skunk2, or Edlebrock VictorX manifold for boosted B series?
- looking for the zero1000 top fuel ctr info
- gassy?
- Selling XS Power T3 Turbo ( Needs a new Turbine)
- Testing E-bay Turbo *vid*
- 1 psi loss by red line ok?
- resistor box install. just dont get it.
- honda fit cat/converter o2 sensor
- whats the best intake manifold for a turbo b18a
- Wiseco Piston Coating
- eliminating condensation in open breather catch can setups?
- question about evolution wastegate
- DANG..JUST BROKE 2 HEAD BOLTS
- AEM EMS Repair Cost?
- ecu management
- noob question?
- all 60-1 guys post your #'s
- which brand forged pistons is better for boosting honda???
- Oil Drain Flange Gasket [ I need one ]
- stock valvesprings vs psi??
- Question about intake air temps
- tial knockoff
- engine building
- Open Header
- Sprung disk
- Jackson Racing Blower Pulley Questions (LS/CR-V)
- axle replacement gone horribly wrong =[
- HorsepowerFreaks Turbo M3 vs Single Turbo Supra Video
- oil lines....
- When is a Adjustable FPR needed??
- T1 Red integra video
- Intsalling a Turbo setup on a D16y8 Problems!
- h22a turbo?
- LS-T// B18A/B // Max power on stock sleeves?
- apexi vs greddy??
- T4 hotside .53 A/R Gt35R characteristics?
- possible compressor surge need help
- Portuguese Civic Vti Turbo
- H & I beam rod differences
- backfiring in downpipe?
- boost not building-up :(
- help!! clearance problem...do i have room to upgrade??
- Question about my OEM bore size (OEM Pistons say PR4 .8 on them)
- Idle tuning question/problem? AEM EMS
- engine builders opinions
- turbo charging a 07 honda fit, concerned about 10:4 comp ratio
- Nitrous/ignition???
- fuel pump question
- look at my turbo ITR project.
- LS VTEC, quick hone and rering?
- T3/T4, 0.48/0.50 A/R, 50 trim: Good match for my little A6?
- Using NGK sparkplugs on turbo b18
- how much boost can a stock d16y7 handle?
- Ls Vtec turbo build on my ek
- ITS (innovative) turbos
- ls/vtec........ what turbo? ....... opinions needed
- Anyone ever look into using a larger roots s/c case?
- CTR cams VS ZEX Turbo stage 1s
- Hondata s300 install - need to add any wires to engine harness?
- 6.5psi to 10psi with power FC on stock B18c
- Turbo ????
- Will 4bolt downpipe bolt up to 5bolt hotside?
- What do you thiink of the PCS piggy back vs the greddy e-manage?
- B18c1 stock sleeves T67/t3 bb 18-19lbs on 93 octane
- Purchased a used TB0356 (Garrett T3) but have an Issue with it
- Eagle rods, install.............
- Are these DSS axles??
- gt35r v. gt30r on b16... spool time
- intercooler core selection
- Another Downpipe thread...making my own
- going turbo need alot of help
- Rumors GT42R banned for 2007 and 2008?
- CTR questions
- what does it take?
- 14B Questions? WHP ?
- h22 Turbo EG???
- head porting question about finish
- has anyone had experience or used this wideband kit
- Building D16 Z6 turbo block and other stuff
- Finally 474 whp on 18-19lbs B18c1 93 octane
- Short Runner SFP manifold, GOOD?BAD? with SC34 turbo
- Comptech Supercharged S2000 just made 305 @ 6 psi
- Looking for 275-300whp on daily driven B18C-1
- got back from dyno today
- scammed....????
- whats the proper way to adjust two wastegates?
- Crazy VTEC dyno vid
- To build, or not to build
- How to tell the difference between Tial W/G 35 & 38
- Anyone make a 7/16"-24 -4an .035" oil restrictor in stainless steel?
- Northwest honda dyno day
- How is my piston
- Winter boost creep problem??
- MSD Digital 6 Trigger Wiring
- Endyn AIR manifold problems, help!
- Stock Valves or Crower????
- post up your cars with a drag turbo kit on it
- F22( G series) Build Need help Ordering Custom Pistons
- Turbo size, specs, FMU?
- turbo engine white smoke
- Can Anyone Tell Me if They Know Who Makes This Manifold?
- STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD?
- GT42R vs. PT-76GTS
- first time turboing
- need an 87.5mm head gasket...
- What do your neighbors think?
- new to turboing so i got a few questions
- How to pick a wastegate.
- wastegate lines
- JRSC
- stock PR3 vtec head hp boost rating
- Good budget turbo for 6-8 psi JDM H22A stock internals HELP MEEE
- walbro 255lph (hp)??
- please help!!!
- Anyone got any fabs/hacks for Honda stock konck sensor?
- HERMSFAb TURBO MANIFOLDS....ANY GOOD....
- rp head studs into my b16a2Arp Headstead socket question
- t3/t67 .82 a/r vs .63 a/r?
- catch can question
- Can't find 1/8" npt barb fitting
- kteller 3" exhaust w/ magnaflow muffler
- force induction gaskets
- Spark plugs and oil to use for Greddy turbo on Integra
- Need help guys.....poor mans r turbo
- Looking for a tall FD for a b-series tranny...who makes one?
- FMU Question I need Helpy
- what best rod bearings and main bearings for b20 vtec turbo?
- Garrett GT28RS vs GT2871
- Eagle Rods or Crower Pro Billets help me out opinions needed
- gm 3 bar map scaling values
- LS pistons?
- need cam gears for turbo install?
- Saturated Injectors better then peak and hold?
- My car sucks on the dyno, but then pulls like a raped ape off
- will fogs fit on my eg/ej with intercooler pipes
- Oil line problem Please help.
- ls crank
- turbo?
- Charge piping issue
- Right turbo for my build
- In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use
- Blown Engine
- CATCH CAN GURUS, would this be possible??
- Contact phone number for Garrett
- LS turbo...problems...LOTS of problems
- Turbo Timer InstallationHelp!
- what map sensor and parts do i need for it
- where did you get valve cover an fitting welded on and for how much?
- Highest SC50 (50-Trim) numbers on PUMP GAS?
- Exhaust Question.
- DEBATE! B16 Supercharger, or B16 TURBO!
- Having trouble locating T3 2.25" downpipe flange
- 75 shot on K20A2? (searched)
- What camshaft..?
- 400 hp?
- B18B1 nitrous questions!
- JRSC Will My New Pulley Setup Work: CTR Crank + Stepper + Smaller SC Pulley
- T3 turbo or T4 turbo ?
- SLOW Vacuum and less boost
- topmount turbo manifolds??
- Russell Endura fittings - best place to get them?
- Noob alert. Help this noob buy a turbo!
- My Bronze Turbo GSR! Finally got her running..
- Turbo CAMS
- Performance Shops in Los Angeles?
- sleeved block runs hot?
- wastegate for 600+ hp?
- External Wastegates & Boost Controllers, Question
- map sensor
- My filter came apart and my turbo is shot! pics inside.......
- what would be the best sohc turbo mantifold w/ac 4 bolt t3/t04e turbo set up?
- Is it Safe to Turn on ur car, move it, then turn it rigth off w/o warm up / turbo timer?
- what is the best oem cam for turbo b16?
- My new turbo upgrade project
- 3rd question: Which do I Boost? b20b or b18c1??
- what exactly is this fitting for??? black box???
- Tire Spinning
- Best price for a B series Greddy turbo set-up?
- what kind of hp can i get with a 42/48 trim turbo
- Lookin to build my head(F23A1)
