- Can anyone help me start my Vouch post?... =)
- How much does a Quaife LSD go for in Europe??
- where can I get a 2.75 to 2.5 ruber piping adapter?????
- Any garrett turbo dealers look this Pt# up???
- Reverting to stock P28 maps from Hondata
- car is almost finished!!! pics inside......
- OBD1 P28 ECU - Injector Impedence?
- setup
- TURBO ?
- edlebrock IM power gains with turbo setup??
- Flex piping for a cheap downpipe?
- Broke my Greddy EGT Gauge can I fix it?????????
- 1000 HP SUPRA build up video!!!!!
- what is the turbo that comes with the drag turbo systems?
- headaches headaches...help pls
- Anyone ever use MSD injectors with an STR fuel rail
- arp head studs?
- hks ground earthing system
- Can I use old pistons in a new engine ???
- Please Identify........
- turbo'ing my GS-R, list of preparations - am I right?
- T04b/60-1 and stock LS??
- Who's converted their OBDII d16 to OBDI?
- 3bar sensor 00 civic si help!!!
- Pics from when I first built my turbo EK4. I wish it still looked this clean!
- Ball bearing turbos.....
- Measuring Turbo Housings
- mercedes vs ford turbo differences
- biggest bore turbo pistons?
- HKS GT2510 downpipe...HELP
- Hondata tuning in 1st gear?
- Helpme turbocharge my b17for less than 500 dollars
- greddy turbo intake or bigger intake? sohc
- need help with this TURBO SET UP!??!
- Using a manual boost controller? Info needed.
- Got a t25 on a 1.5/1.6?...Do you like it?
- i my first turbo build! ef hatch ls vtec built
- precision SC61
- Anyone running Crower Valvetrain in there D series?
- 2 bar VAFC settings
- who all is running a DSM setup with there stock D??
- what size down pipe
- Injector identification help
- turbo question what are these holes??? (pics in post)
- What Boost Controler should i buy??
- Attn: Those making 400+ on stock sleeves...
- breather box on a B20vtec yay or nay
- Crank Caps?
- building B18B head
- will integra piping fit on my setup..please help
- Pics of GE Intake manifold & DSS 500 hp axles -(56k not allowed)-
- Finally got willems burner to work...got a quick question?
- Who makes the tightest 4" radius??
- Help me build my B18b for boost
- tuned prelude...started to bog BAD today...wtf
- what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!!
- What ecu work on my 99 Si when running hondata.
- Sohc Greddy Turbo Manifold.....
- Searching for WORDS of Wisdom, Experience, Comfort/Consolation, etc. etc.
- reading boost gauge??
- Skunk2 IM + D16Y8
- need help on piston
- What turbo came on the Nissan 300z twin turbo car?
- 75shot dry vs. 75 shot wet
- Block Gaurd: Whats it for?
- newb question
- msd with stock wires...
- My turbo hatch was stolen last night!!
- What do you use to retard your timing for n2o?
- Anybody here open their own tranny??
- Piecing together my own Sohc turbo kit with spare parts... HELP
- map sensor seeing too much voltage
- How does the MAP sensor and o2 sensor work together?
- Precision 880 Injectors a question!!!!!
- turbo and n20?
- Need help again with JRSC Install
- SC34 or SC61 on stock b16????????
- oil light on, and the car wont start.
- how much power at 15 psi with this setup??
- STAN the fitting man....
- AVC-R control fuel to?
- Uberdata Download
- Wideband or EGT>?
- pistons (ive tried search)
- Another incooler question...a little differnet though!
- Intercoolers : Taller or Wider?
- LS/VTEC Turbo?!?
- where do check valves go??help ASAP!
- turbo project
- Anyone have info on the Z10 catch can set up ?
- Question for turbo Preludes
- help me out picking out a setup!!!
- Turbo Idle l Issues
- jrsc gasket between blower/manifold?
- flushing a honda turbocharged engine?? de coking??
- thermostat
- what would be the best manifold for a Ls turbo...
- Look at this European JRSC dyno
- pics: downpipe cut by me and welded by project_dc2
- lsvtec civic on dyno
- AC Compatible SST?
- Butterfly valve on JRSC manifold
- 400whp SOHC
- Please Help ASAP Intank 255 lph Walbro Pump Install gone bad?
- Finishing up a turbo install......QUESTIONS------need help
- Uberdata Basemap b18b
- need some advice on the turbo d16
- oil feed line on an ls vtec
- Best Tranny For My Setup
- Any good installers in socal?
- where's somewhere that has good price on JE pistons
- Cracked turbo manifold
- JRSC help please.. alternator upper bracket bolt size
- How to tell if it's a tial wastegate
- possible parts?
- Boost leak or creeping backwards?????
- HKS A/F Knock Amp
- What is the difference between a b18a and a b18b ??
- HKS Dragger Exhaust for a turbo?
- Should i Keep?
- tuning for idle problem
- anyone have 5 lug on their turbo car??
- reading material.....
- BOOST questions
- 2.4L turboed with a t3
- Supercharger...INJECTORS WONT FIT? ***help***
- Adjustable fuel pressure regulator question..
- dammit I screwed myself!!
- Idle problems(vid inside)
- DIY bottle blanket?
- Bell liquid-to-air Intercoolers
- JG edelbrock w/ Vortech SC
- Adjustment of BOV
- Boring and sleeve strength
- Full Race Manifold Clearance
- where to get a block assembled in ohio.
- Top/Bottom vs. Side/Sides intercooler
- Buliding a transmission for Boost?
- trying to get to the bottom of things about the lovefab sidewinder
- saab sidemount intercooler
- tial wastegate question
- Oil in turbo....
- How much power to be expected?
- sohc turbo, who has a drag kit??
- Symptoms of a ROM/Hondata gone bad?Something not right? Help!
- ls vtec turbo setup
- Anyone have specs for turbo off a VG30eT?
- Need Help With Finishing This Set Up
- Little OT but has to do with turbo
- need help!!!!!!!
- P13 rom editor
- JRSC cont... upper alt bracket washers
- Turbo Kit
- nda CiWhat Turbo??
- Exhaust Cam Cap
- How much power can a b16 handle?
- Need Help ASAP Searched Already (Boost Gauge)
- Turbo with ITB?
- how much boots?
- New to FI
- Need help finding stealthy mufflers
- Fuel Pressure Regulator question?! TECHnical question, TUNERS please help!
- lovefab vs. full race?
- MSD 2 stepper HELP!!
- Finally got it done!!!
- Another road block .. wire from main harness?
- Pondering Questions About Building Head For New Setup...
- Show us your gauges...
- HELP!!! white smoke out of engine bay
- Rise rate of a JRSC FMU.
- Shocks and struts!
- OMG PLEASE HELP
- Sleeves dropped?
- Which precsion for my setup? SC-32 or SC-34???? (researched tons)!
- help with bov...
- t3\to4e turbo
- Question about building my block...?
- downpipe specs
- Loosen A/C Tensioner Bolt
- anyone running an 8" tall intercooler?
- Is the t25 ballbearing?
- No Boost????
- What is the biggest cam for JRSC?
- any one have experience with a ETD turbo manifold?
- Civinco Engineering supercharger...repost?
- FMIC (Tyrus)?
- Noob Question, how can you tell if pressure plate is going bad?
- where to buy turbo heat shield. Bling bling
- Hondata Questions
- nitrous install question about tps and 12 volt accesory source of power ...
- Looking for a local tuner around the Tennessee area!!!!!!!!!!!!!!!!!!!!!!!!!!
- oil change for turbo?
- Tried a gutted cat and
- Boost Controller no worky?
- running open downpipe? mandrel or regular 3 inch? will it matter?
- turbo Ls trouble
- blown head gasket (turbo related), need some reassurance
- Mandrel piping DIY ? and shop talk is it true?
- HAPPY BIRTHDAY ARTURBO!!!
- Car acting strange after taking Hondata out...
- OT: Mitsubishi unveils new Lancer WRC
- anyone run the volvo 740 IC
- FS: 1/2" to -10AN 45 degrees angled steel adapter(for turbo oil return)
- In a bind. need some help. piston to wall clearance.
- anyone have expierience with this slug?
- OIL return look alright?!?!?!
- Removing intake manifold gasket
- WAT SIZE I SHOULD RUN??
- Help me with friends set up please
- greddy vs. edelbrock turbo kits
- anyone have pics of the inline pro collector?
- Leaky injector tip?
- OT: Look at this wastegate!
- What's stopping you?
- HF/GSR factory oil coolers info ?
- using DSM injectors
- Stolen B20 Turbo Civic in VA
- Can I use a Ford Map sensor instead of a GM 3Bar....
- Has anyone ever uses this Valve spring compressor tool ?
- b18 swap question
- Props to Spoolin performance(project DC2)!!!!!!!!!!!!!!!
- Hone the H22a1 before dropping pistons?
- spark plug gap with msd
- cast manifold comparison!!! HELP
- Some Video from "St00pid" Tuning Session in Tucson
- I just received my SC50 yesterday how do I know if I got the good one ??? look...
- Anyone using the b16 Rod/Supra pistons from turbopanda in their D series?
- sc34 or sc 44?
- cam gear settings for GSR cams on b16
- Stock oil cooler from starion or eclipse?
- what map sensor can i use with stock ecu and boost?
- 10K setup?
- boost leak tester
- Boomslang Fabrication Conversion Harness? Yay or nay?
- were do i go?
- Just wondering what a/r. is?
- new setup suggestions
- Max-Rev on Ebay for $2000!! Brand New?? Real??
- Boost Controler...
- woulda hondata intake manifold gasket help with turbo?
- Who has the heaviest or is running a full interior 10sec. daily driven cars.
- p28 or p72?
- What ever happend to 9psihybrid and his baby blue hatchback?
- Obd1 conversion on turbo Si
- 2004 civic DX( worth moding?)
- haltech ex6 install
- t25 manifolds where can I get em ??
- Hondata and the base maps question.
- Question About the SC-61 and spool time?
- Anyone running a Greddy 2mm HG on a d16?
