View Full Version : Forced Induction
- what size boost pipe?
- AEM EMS please HELP!!!
- jackson racing charger on my EM2 need sum BRAINS here
- tuning ?
- Need a turbo for 750whp
- ughh 3rd ecu gone bad..
- Need help with Holset turbo??
- Common to overheat with just water? NEED HELP ASAP
- B16 GT28R??
- Where to buy screen or cover of Turbo inlet??
- TUNERS...I have a no start issue....Precision 880's, CROME Pro, LS/vtec...battery offset possibly?
- how do i know if i received the right turbo?
- Garret GT28 turbo???
- To sleeve or not to sleeve!
- Running Higher Fuel pressure to get better spray pattern and bigger temperature drop.
- is putting a gauge on the turbo and bad idea
- Where to buy oil restrictor oil fitting converters??
- Stock ls/vtec turbo?
- i need a basemap
- having a problem making boost
- shaft play
- Toyota CT26?
- Walboro makes a 320lph pump?
- My 2.0 Liter Forced Induction Write up Motor-Rebuild time. Advice please?
- weird noise after revs drop
- NEED HELP...TURBO CRYING..
- attn 99slammedcivic
- All in 1 Gauge Readouts. Need to find one to replace all my gauges!
- Drag Radial for 16' wheel?
- little arp head stud questions before i install them
- b20b/v turbo
- My D16Y8 300-350 whp Build up
- Slimfan user's
- ZEX dry kit w/boost?
- Prepare motor now - install turbo later?
- 2.5-3 BAR map sensor.
- Which turbo gt3582r or t3/t67ho
- cams
- Dyno #'s: SLS B16 57 Trim Turbo Kit
- Holset HX30??
- Blow-Off or Waste-Gate?
- Oil return line???????
- Turbo wrap??
- Dyno: GT35r, Pump Gas
- Affordable wideband poll... sorry to whip the dead horse...
- Few questions on my new turbo build.
- 2) 500whp Dyno's and 1000cc/Walbro information
- I have oil on my driver-side motor mount!!!
- turbo pistons??
- Air/Fuel Ratio meter hook up
- what block to go with ?
- twinscroll turbo on non divided manifold????
- 4rm fully built all motor to fully built turbo Lots of ?'s need help plZ
- Main Studs Necessary?
- turbo ques
- compressor surge with synapse bov
- What size injector???
- SS turbo gasket...?
- Plug gap question...??
- ITR Engine Check Light
- Manual boost Controller. Before of after the BOV?
- guessing game, who knows ther stuff???
- question about moroso oil pan
- Which Clutch?!
- built motor now what turbo.
- H-T i need ur help... possible serious problem
- Looking for turbo for Honda FRV(Edix)
- My 1st head gasket replacement...FAILED. HELP
- AC and PS turbo kits post pics please
- inlinePRO turbo kits?
- which tranny?
- noob question
- Boost on B18C with 82mm bores?
- Turbo set up
- Skunk2 Mega Power "R" Dyno -RSX Turbo
- Boosting the h22
- Thats Whats up..
- oil feed line
- Turbo oil issue ??
- JRSC +crank puly =more boost ?
- cca fmic good for 400hp?
- b20+Nitrous???
- Greddy Profec B help please!
- 2.4l block in need of the right turbo
- Code 41/3 fuel supply and Map, Upon reinstalling enginemount...
- I have a fully built h22 turbo looking for a top mount turbo manifold.
- Quick question: Part number for the fitting on the stock fuel filter
- How Much WHP You Think I Will Make
- Built motor...start up issues
- What intercooler will fit my DA
- Borg Warner S372 or GT 4298????
- anyone ever used brian crower LS cams?
- divided vs open inlet T4's
- Quick Hondata S300 boost controller question - Q20 transistor orientation
- What Should I Spray My Intercooler With?
- high 12sec B16T
- turbo feed line size?
- ~11:1+100shot+race gas = how much timing retard???
- Searched TD04 Turbo Questions
- d16 turbo QUESTION
- 100 octane?
- has anybody used this product???(wideband)
- PROBLEM....please help.... wierd sound?!?!?
- gt35r for sale
- 400whp goal - Turbo advice?
- leaning and stumble at idle
- whats with the blue fog? oh its me.
- how much hp can stock ignition hold
- Advice on turbo H22 cams?
- Apology to HPC (Full-Race header ceramic coating incident) (lots of pics)
- Johnny racecar intercooler
- idealest size IC
- turbo question?
- boost creep like mad??? need help
- whats the min oil pressure to activate the oem oil pressure gauge on dash?
- resonator sound and cats
- how to clock a 14b greddy turbo??
- Koyo Radiator cap?
- T3/60-1 ball bearing on a built motor(dyno inside)
- ow to tune with hondata s300
- Question for AEM Tuners - Im trying to convert v1.03 to v1.11
- couple of nitrous backfires
- Going turbo, would like some opinions on my parts list so far.
- hello all (some new turbo questions.)
- anyone have picture of greddy turbo kit in a gsr?
- waste your gate
- got a ? about wasted gaters
- B16.. 14b... need a manifold w/ external WG
- F20B6 Accord engine
- Built Motor, first start up question
- D Series Turbo Manifold
- B16a2 motor
- So I got my car back from my builder
- anti-lag damage?
- BE-COOL catch cans - Info needed on how theyre vented
- how much is too much?
- Looking for a good qaulity but not popular turbo manifold for d-series
- b16a turbo choice
- how old will a walbro 255 fuel pump last?
- Well finally
- b20vtec turbo questions
- fuel cuttin between 6-8K replaced 50 trim turb0 with 60 trim
- thought i blew my engine!
- 2 step help??
- all motor car goin turbo, which turbo ?
- Traction Help
- quick question about piston
- JRSC Boost/Vacuum at idle?
- rev speed turbo
- need some guidance on rebuild, then turbo d16z6
- ZC Build what suggestions
- ls/vtec, B18C....?
- Another DAMMED what can i expect out of my setup thread.
- Boost Problem. Engine won't hold boost
- Looking for the Turbo 4door Accord
- spoolin performance manifold question
- GT35R v. GT37R for 600hp app?
- need downpipe and turbo manifold
- running a turbo basemap without a turbo
- Divided T4 Turbine Housing for P-trim wheel?
- gauges galore
- first turbo setup have some questions
- Motorola map sensor
- Trying to figure out what to do with the D series and turbo
- Rotrex S/C
- Is anybody using this water cool kit...gt35r
- Blowd Head gasket 2 liter turbo
- Integra Type R Boost Spiking
- Lsvtec turbo engine Q
- whats the cheapest most sufficant turbo?
- supercharge a jdm b16a?
- Want boost!!!
- issues with injector sizing with s300
- AEM wideband question
- AEM WIDEBAND
- searched looking for the thread that tells you how to read plugs
- INNOVATIVE TURBO Horror Story Please Help!
- OIL COOLERS WORK? MFactory??
- Running turbo setup without downpipe
- B-Series B18C5 ITR TB w/Boost Any HP Gains?
- Clutch Clutch and more Clutch. some info from HT members please!
- Hondata thermal style throttle body gasket?
- Going Turbo..
- d15b-t expected figures anybody??
- is my turbo upside down
- boost gauge help? (stupid noob question)
- Wouldn't go into 4th gear
- Opinions on AEM Widebands?
- Manual boost controller installating
- odd wet nitrous kit
- JRSC need upgrade boost pulleys?
- GSR TURBO PROBLEM!!!!
- preloading?
- Need torque specs for an SR20DET.
- Has anyone here had experience with FSM and how was it?
- my first turbo setup
- Question about Chrome
- DynoJet Owners - I need software
- 7psi spring boosting 8-9psi?
- Anyone used this wideband?
- D16 Eagle rods help
- what tranny to use
- Turbo repair secrets!!! Even a cave man could do it.
- Looking for a local Machine Shop in Northern California
- need to know if the setup is good for daily driver... ???? anyone
- DIY topmount, how well will this work? General topmount ?????'s
- has anyone heard anything about KMS engine developement?
- d16a6 turbo
- Going to dyno tune saturday, need last adjustments!
- GT35R Compressor Housing still rotates when bolts tightened
- How much power will this setup make?
- Boost Being WeToddid Not Spiking, Boosting all over besides my spring stage
- My first boost project!
- JRSC ITR w/particular build questions
- 2000 Accord turbo question
- Cylinder head removal questions.. need help asap
- Could it be done??
- Which knock off BOVs to stay away from?
- few ?'s bout my turbo setup
- Sea Foam - In supercharged application?
- S.F.P turbo manifold
- planning to turbo my accord
- need help shop pin??
- How long did your boosted stock B series last?
- Help again!!! thanks:)
- what form of protection do you use?
- What flows faster?
- aem uego wide band o2 sensor problem help please
- SuperCharger Belt
- 1017awhp/634awtq DSM Video.
- Which to use????
- ANYTHING TO LOOK FOR????
- used turbo
- Heat and Resistors for Injectors
- twin screw supercharger?
- gt28 or T3/T4
- GSR nitrous question?????
- where to install oil feed and oil return lines.
- eg greddy turbo kit..NEED HELP..looK !!!!
- stock b16 with VP-110 ~ 300whp how much timing
- Nitrous Help!
- is smoking common in turbo cars?
- Tuner in/or willing to travel to Orlando area. Vouches needed
- need assistance with dsm 450 cc injectors
- Reflanging a dseries top mount for a bseries motor...insites, opinons, ideas
- CDN SiR B16A2 Swap
- Timing Table help (pic inside) - Crome, stock JDM H22A, 9 psi (spring)
- HELP WITH AFTERMARKET INSTALLATIONS....NC
- 2.75" Aluminum Piping
- Detonation in 4th and 5th gear???
