View Full Version : Forced Induction
- 2 step rev limiter
- Anyone have pictures of JRSC bypass zip tied? For forced out of boost.
- stock clutch/transmission ok??
- where to get this act clutch best price to
- Hondata question
- Any interest in ITB's for RSX type engines
- turbos in the winter
- how to tune the untunable!!!! blue box q's
- Greddy Turbo Timer VS. HKS Turbo Timer
- best way to break in engine after going turbo?
- Tire fitment question
- IHI Turbo
- SAFC and Boost gauge read different boost levels
- my RE-dyno(mustang dyno vs. dynojet)
- wierd electrical shit going on!!!! might be smc related
- CRVTEC turbo?
- Going Turbo this summer.. couple questions
- G-Force Drag Radial psi
- which intercooler would YOU buy??
- How to lower carbon monoxide to pass test?
- Methanal pros and cons
- NOS brand injectors?
- block shelf life?
- Turbo R guys
- what size i/c do I need
- what should i buy??
- afc hack for 8 psi
- just boosted... good for a week, now i get white smoke.... please help..
- Fuel pressure regulator.
- What is the reason for raising VTEC??
- Questions about A/Rs
- apexi bov
- 2.5" or 3" downpipe?
- injector question
- Install the bulk fitting????? WTF...where,....how....what
- just modify stock SOHC manifold???
- Need help, for the love of god help
- anyone using the dart blocks yet
- SAFC 2 install
- Just installed D16y8 intake manifold+GReddy kit .. won't idle !!! PLEASE help!!
- No spooling sounds?
- Need Help Not Boosting
- times on the turbo yo!
- electric turbo? You've got to see this
- Do you notice your hood gets super hot?
- VAFC help, plzzzzzzzzz.......
- inline pro mani and a/c?
- Show your EK intercoolers,brand, and dimensions Please! pics
- Recent dyno graph...
- B16 with 60-1
- Which turbo kits with AC??
- Any of you guys stock Aeromotive or SX FPR?
- My current little project...
- confused about VAFC and other piggyback computers...
- Theres no way the management unit is gonna fit under my hood.
- Anyone buy from "js236"?
- radiator clearance...
- DBS for AFC hack users
- what wastegate should i get?
- DIY Wideband
- Wastgate and BOV springs.
- crx+boost+FMU+fuel pump = bigger injectors?
- who did your dart sleves
- what standalone greedy emanage or aem ems
- Turbo hesitating in VTEC?
- hondata question...i think im lean :(
- turbo exhaust ???? please reply....
- 94 b18b block with 97 b18b head?
- Will I need a wideband O2
- where can i order 60mm mandrel bent exhaust tubing??
- external wastegate question
- OBD2 enigne codes? help..hondata install
- radiator fans..
- quick question about next mod ....
- Greddy 18g Downpipe....
- Electrical problem on Gs-R (BATTERY GONE IN 4 DAYS) HELP!!
- Fabricators and DIYers, what kind of welder are you all using
- Setup on B16A
- Anyone with Crower 402T cams in an LS turbo setup???
- what TB to use with Victor x manifold?
- New to Hondas, but want to turbo an 2003 Civic Ex D17
- JRSC and the map sensor controller
- JRSC GSRs...what compression are you running with 8-10psi?
- How reliable is your boosted engine...?
- your opinion on bov's
- JRSC and aftermarket cams
- finally 00si turbo project underway..
- Fmax or Maxrev?
- Altenator gone bad or Boost problem?.. help me out...
- wtb stock 94-01 integra shifter
- whats the most boost i should run?
- unusual motor swap question
- Hondata tuning question
- Hondata Base map help
- Another HP prediction Q...
- Ballpark A/F #'s (
- Boost problem
- i think my topic would be better in this forum
- Ready For A SC61 Ball Bearing Turbo??!?
- throttle body size for turbo? already searched
- Which guages to get?
- Wet shot jet size!!! PLEASE HELP
- -4 oil feed or -3 oil feed?
- What's the most boost you'd run on a sleeved LS 84mm block?
- Drag Bolt Sizes
- Is this a good manifold?
- Essential Speed rsx turbo kit soon to hit the market
- Boost gauge problem
- what manifold is this?
- intercooler color
- code cel 16, lumpy idle, acceleration choking!!!!!!!!!!!
- downpipe for a 98 GSR
- New 440 injectors gave me CEL 71 - 74
- By any chance, anyone know if someone has a hks manifold?
- oil in my intake charge pipe!!!
- BOOST controller HELP
- coolant burning smell sweet? yes or no?
- Compresion test = I need pistons :(
- part throttle hesitation
- 2gen DSM injector clips question?
- Check out my new CHEAPTURBOdotCOM
- anyone know about the ETD Racing manifold?
- Does anyone remember who sells the RevHard intake piping?
- 85F today, car running hot ... need ideas/help please (pics+hondalog)
- Other chip need to run the Uberchip?
- JRSC Water Cooler with Turbo?
- How do I fit the c-clip for HKS BOV in?
- Help! Need help ASAP! Car losing fuel!
- i'm confused now...
- Potentiality of stock D16 + greddy turbo?
- how much boost is FMU good for??
- D16Z6 Turbo
- how much boost from this T3?
- vortec system on crx
- does anyone on this board have a boosted dc5???
- Wastegate problems
- 3bar map + AEM EMS
- Im having 2nd thoughts about making my turbo comeback! *set up inside*.
- Best Engine/Turbo Combo
- v-afc hack, what injectors to use?
- Turbo Specs..I'm sure this would help a lot of people!!!
- Log Manifold & dipstick... questions
- checking ecu codes...
- max psi on stock head??
- ::Ground Zero Motorsports:: [Brian's Dyno Plot on 22lbs...]
- map sensor
- Not a honda, but boosted nevertheless - 56k go somewhere else
- Opionions on recently bought turbo ?
- drag 3 turbo on ss lude
- Head gasket comparison?
- walbro pump with stock fuel system
- Debate: 1G DSM BOV vs. Greddy Type-S BOV vs. HKS SS BOV
- LoveFab Cast Stainless manifolds?
- Bolts for oil return line?
- O.K. I finally finished (T28 Dyno numbers)
- Detonation with greddy blue box?
- KKK K24/26 turbocharger
- Techedge Question?
- Me vs 3" exhaust
- Video of my 13s run.
- Need Help Guys.... My friend's TEG got stolen......
- maxrev piping question
- Interooler for JRSC
- VAFC or Hondata on JRSC and the best header?????
- spraying on a turbo...
- My car was stolen.......it's like a bad dream.........
- got my car tuned by girl-racer (part II)
- Q's on the cometic i got ?
- Exhaust manifold-Turbo gasket
- JRSC v.s. Greddy v.s. Revhard Stage 2
- Good deal, or not?
- Help me decide which Precision turbo to use
- Can I install turbo and have 0 boost?
- Strader perf. tuning seminar in nor-cal on 8/23
- JRSC please help.
- when hitting 14psi at this setup
- problems after revhard installation
- took the beast to the track tonight
- turbo?
- help me diagnose the headgasket leak... AGAIN
- Info: Ford Probe GT 2.2 Liter injectors 310cc with Fields Boxer SFC-VTEC controller hack.
- Freaking AMAZING tool I found for turbo geeks.
- blowoff in neutral?
- What should I upgrade before I add a turbo
- What is the 'resistor box' // DSM injectors ???
- Another SC61 success story...
- what are the causes cylinder misfires?
- Turbo Camshaft for Integra ?????
- is fuel pressure at filter the same as rail?
- I just installed new injectors and 30 minutes later I get CEL #16
- Updated pics of the project.
- Turbosmart wastegate has two vacum sources on it,Where do they go
- locking hood pins
- fuel question im confused
- does built motors suppose to have "blow by"?
- Boost Sucks
- Kill Switch Kills the turbo timer??????????????????
- Who dyno tunes in the MILWAUKEE area?
- does anyone make an oilless turbo?
- anyone with '99-'00 Si have a Drag or GReddy turbo kit?
- supercharging civic
- Blitz BOV? I heard it sticks.
- which would be the most likely problem, piston rings or turbo seal?
- 2nd gen integ--best turbo???
- What is the best exhaust to run.
- vortech fmu in black??
- T/25 DSM turbo on b16
- HKS SSQV and c-clamp problems?
- Manley vs Eagle rods
- to big of injectors
- how do i hook up a catch can?
- Turbo noob here... and I need some advise from you..
- Turbo specs, what PSI can this run?
- white smoke
- What's a good price for DSM 450 injectors?
- building head for boost
- hondata install....please help quick :)
- RHB5 Turbo specs?
- Tranny Building (mine blew up)
- dohc f22b turbo ?'s
- How to get 200whp w/a jrsc?
- Boosted Prelude, Numbers???
- Trim size and a/r...
- 99-00 civic EX super charger for sale!
- Original ?s on Engine rebuild
- LHT Intercooler for the JRSC
- new to boost...bad head gasket?
- Intercooler pipiing metal?
- fuel question
- Wastegate won't open?
- 2000 civic dx hatchback turbo help......i need one what do i need to do??
- who makes a muffler with 3'' inlet
- Need help with Turbo setup.
- Spooling large turbo faster
- Took my auto civic ex turbo to the track last night...
- DSM Injectors, Resistor Boxes, and Hot Start Problems
- Tuning by Inline Pro???
- Nitrous Jetting on dry gsr setup.
- SRT-4 vs TUrbo Si Vs Turbo Ex
- Confused about catch cans! (who isn't?)
- anyone using Greddy Si blue box on Gsr?
- Enlarging turbine
- JUN 3 and 75 shot- Opinions and experiences wanted
- Would a b16 turbo exhaust mani bolt to a d series block?
- NEED a dyno shop that has experience in mf2 PLEASE HELP!!!
- turbo on my 100k+ civic
- Timing question...
- Looky here - DIY EMS
- New to turbo....few questions.
- nitrous jet stampings=hp conversion chart?
