View Full Version : Forced Induction
- Maxrev kit DIY setup
- which oil?
- Help picking out turbo stuff
- Can the techedge wideband system be used with Hondata s200??????
- Auto / Automatic LS Dyno - 196.83 HP / 171.57 TQ at 10 PSI
- which schedule 40 stainless steel is the best??
- smc tuning?
- my tranny grine like hell on third and fourth gear
- who here has a boosted h22a civic swap?
- Waste Gate Dump Tube?
- whats a good BLOW OFF VALVE
- Who wants an eCutout downpipe?
- How to???
- Wacky Video (Must See!)
- switch from all motor B20Vtec to a B16 turbo?
- Anyone blown a torque converter???
- H23 Iron sleeved block for sale or trade for some stuff....
- filter on a t3/60-1
- Dowel Pin height?
- turbo install .. NO FUN AT ALL .... picsc ...---- NA-T supra
- Getting out....Everything must go!!!
- Where to get Flex Pipes?
- turbo help
- dx exhaust, cat?
- Jackson Racing S/C.........
- Do I need to change from my B&M fpr to a better one..say AEM??
- timing
- Type-R tanny anyone?????
- turbo size that comes in a DRAG GEN III kit for 99+ Si
- CP Pistons?
- Want to FI my GSR, need opinions
- Uberchips
- blowing oil from the valve cover *help*
- Trying to get tuned in NJ
- Stay B or go D
- Intake/Exhaust housing size for b18c1/b16a
- Sleeves, Forged Pistons, and knock sensor
- Finally Dynoed!(Thanks Howard!)
- Homemade downpipe, what do I need?
- DP flex pipe?
- Tubular VS Log
- overtightened BOV...
- T3/T4 or T60-1 TURBO for H22A ?
- How to get 11psi on a jrsc???
- Got boost?
- Fuel Management for D series A'pex kit?
- LS jrsc install questions
- Question for C&R or PWR radiator owners
- Anyone with a SOHC turbo setup using 3" exhaust piping???
- Car shuts off with turbo timer set
- Car turns off even when timer is set
- SOHC clutch questions
- filter for turbo
- Comparing prices on kits
- Event pics(Moroso)
- Hondadata Tuners In Canada?
- Turbo Inlet velocity stak ?'s
- Help! Car won't start with SMC + 450's
- boost without sleeves!!!
- Oil inlet threaded on a Precision SC34?
- 310cc injectors with 12:1 fmu
- td04-15g on b16
- OBX equal length manifold for B series question.
- Turbo pics
- Updated pics of my setup
- Turbo Air Guide (TAG) ???
- 14b techs please help, need part name
- code 45 and some more shit
- system to lean or too rich (code 45) and some more
- upgrading turbo, ideas?
- archive disabled, anyone have turbo H22a dyno plots?
- looking for the 45$ Oil Feed Line kit
- Supercharger idling and still has 12psi?
- How much hp can my setup pump out
- opinions on a block gaurd please
- coolant feed lines for turbo
- Fuel Pressure regulator problem
- ... kinda ot... meng style manifold with guarantee... who was selling?
- Messing around with ZEX and Intercooler setups, have questions because I'm retarded.
- Questions Running DSM injectors, please help-- did a search!
- Help!! turbo doesnt spool until 6000-6500K
- fs: t04e turbo snail by garrett
- Resistor box install
- Any Use the Emanage?
- Does anyone know how to install the LS/Vtec oil line kit from Golden Eagle.
- stock b20z, what turbo should i use?
- wastegate setup????
- hondata or greddy blue box?
- Help! Can't get blower pulley off JRSC!
- turbo manifolds
- search down...plz help.
- Import Survival Series 2 (E-Town, NJ)
- Full Race Manifold and jet-hot
- nice manifold option
- Anyone know the shop in Waldorf MD?
- Just thought I share the equal length manifold I made, be kind this the the first eq lenght one I ma
- Accel DFI Standalone Gen 6 Question!
- need help with turb setup
- gauge bezels?
- N e one with a b16 turboed
- Millionth HACK problem...wiring diagram ?'s?
- Suspension Setups for lots of power.......
- 1/4 times...EG...SI/EX?
- GE oil feed Kit.
- t3 exhaust housing question
- building for n20...suggestions please..
- walbro fuel pump...howmuch?
- HELP-->Forced to sell car need to know how much i can get
- What bov?
- http://www.turbohoses.com/
- Diff between GS-R and LS for turboing.
- anyone in tampa??
- T3/T04B vs T3 vs T4/T3
- homemade turbo done, has a few problems, have questions
- Current status 56k beware
- Anyone have hondata S100?
- Most boost run on stock sleeves with hondata?
- ********Turbo Piping Size*********
- is anybody using this?
- Street Tires and wheels combo - lightweight + sticky
- Big hondata problem, help!! thanks
- Project turbo type R
- Tired of downpipe bolts... studs or v band?
- 14b wastegate
- street cars hitting 10s
- turbo b20 or turbo b18.......wich is better??
- don't know why my rpm fluctuate. it goes up and down and don't idle good. help, help,
- garett and precision
- F*^#!!!!! um, my intercooler is too big, it wont fit, help!!!!!!!
- car wont start HELP!
- 3 inch downpipe
- How safe?? Turbo R
- DIS Ignition with AEM standalone
- what does this CEL code mean?
- blew pistons.... oil in turbo, etc.
- Help please!!! Nos for D16Y8...
- ... bov flange... deltagate and tial... are they the same...???... (wish archive wasnt diable)
- The Jotech guys are the greatest.....!!! Love you guys man... :)
- Couple of Hondata questions? (crank angle sensor, basemap)
- what to do with turbo
- What turbo do I have?????????
- Bore Size
- GSR cams + Boost + B16 = Cam timing question
- Wut ECU are u using for ur JRSC
- Crank pulley bolt = 0wned!
- Can you weld stainless steel and mild steel together?
- Fuel system - good plan? (archive disabled)
- Any downsides to running a Blitz DD BOV w/o a horn or filter?
- When boosting more than normal one should....
- turbo check valve install.
- What Spark Plugs? What Gap?
- What kinda slicks should I get and/or from where?
- Which cat. converter are you using w/your FI swap??
- jrsc setup questions
- Where does my Air Intake Temp Sensor Go?
- Greddy Turbo Kit CARB Papers....I have them for you!
- My fuse blew out
- Pics of Sleeper, what do you think?
- motor swap + turbo ?s ( will it work)
- ITR LSD in an LS Tranny..
- Turbo 95 Civic Type-R Leather|Spoon Sports|Volk|Apexi|AEM|HKS|ITR|JDM
- Did you double-nut your ARP studs?
- Fuel upgrade
- RPM increases infinitly on idle?
- Well I figured out my overheating problem.... for those who care
- boost creep?
- Wheres the cheapest parts at?
- CARB question.
- good post like these ?
- Sir2 turbo hp number????
- Confused About Turbo housing?
- Thermal R&D Turbo Cat-Back
- SMC installed, sluggish around 5k+?
- which is faster with turbo b16 vs b18b
- greddy e-Manage installation
- Greddy Turbo LS/Vtec Which One?(All Turbos Price Drop?)
- Type R LSD how much power? can it hold
- apexi guages??
- smc question
- Homemade turbo and Turbo kitted owners?
- Need to know everything for turbo d15
- austrian type-R's boosted ITR in action - VID
- (Chicagoland Tuners) How much tuning/ money will this take?
- I think Kwai F#$(%# my engine!!!! HELP
- HKS vs. Tial BOV?
- Saenz Connecting Rod Bolt Torque Spec
- URGENT! Arias Piston Ring End Gap
- My car is a big fat pig!
- Best Place to buy OEM tune up parts??
- Please Verify my MBC hookup
- ls pistons in b16 motor?
- T3/T04B Downpipe Flange help
- rebuilding my engine , question question ....
- Manual or Electronic Boost Controller........Boost Spike?
- Dyno graphs of my B20B Integra & Civic..
- MaxRev exhaust manifold users...
- ls or b16
- How much does HP cost?
- calling all stock block turbo guys...
- Rod and Crank bearing Clearance for 550 whp B18C1...
- Finally boosted, finally washed!
- greddy turbo on gsr?
- need help, don't know why boost drop from 10lbs to 6lbs when rpm reaches 6
- blue box question
- Help me prove this MECHANIC wrong please.
- T3 Internal wastegate with revhard manifold
- JRSC Feul set-up Question
- Comparision between .63 and .82 a/r housings
- FS D series turbo manifold and Garrett T3
- Cooling Question
- Ordering Jackson Racing Parts?
- Balancing an Engine
- Spark Question.
- Progress
- boring a motor
- Building LS Boost - Project underway
- Experience with Bosch 1000cc Injectors?
- DIY catch can : check it out
- What Should I Do Next????
- Engine Spooge?
- I am at a cross road, please help
- 14s OK or too lean for a/f ratio..?
- tial boostspike?
- what lets you breathe?
- Interfacing FJO into Hondata write-up
- question on the sound you get when you crank an already running car ...
- wheres does this pipe go?
- Blitz BOV
- wtf is that.. link inside
- My LS-T project: 4bolt Garrett w/ InlinePRO mani.
- need to know something on EGT
- Opinions on Electromotive Tec II?
- Funny vid. ----an official lock me thread
- I need to get a second opinion on my motor from a shop in MD/VA area..
- ITR Turbo on 5 psi dyno inside
- Civic radiator in the Teg to make room 4 turbo, mounting problems!!
- GEM Sleeved B18c1
- knock sensor
- B18a1 Turbo Prep
- Why is water draining from my catch can?
- Anyone heard of this manifold?
- Ghetto rig i/c piping...
- Nitrous kit install:fuel pressure saftey switch?
- ***********Boost and OEM Ignition System**************
- HT Dyno Day in NorCal.
- ProCharger Fro 99-00 SI and GSR integra????
- any d.f.i user????h22a turbo
- Can I do this?
