View Full Version : Forced Induction
- using a smaller compressor on garrett t3/t4 hybrid?
- another GSR TURBO QUESTION
- Help me pick the correct V Band clamp size.
- HKS EVC4 help
- Bseries oem flywheel torque spec?
- B16 turbo sputter! and die
- help with 3bar calabration
- engine rpm goes up and down over 2000 rpm
- Max Bore for Dart Block? (or can it be re-sleeved)
- hondata s300 tuners users, how do i raise up the 2 step
- Overheating/compression question/problem
- crome wont connect data logging. car on dyno right now
- D16 help
- map sensor ?
- WTF is this bracket
- Trying to get tuned in Jersey area where should i go?
- just bought part of my first turbo
- im thinking turbo!
- (searched) gsr-t fuel pressure issue
- spacer for t4 housing?
- Has Anyone tried the Coolingmist Vari-Cool Commander?
- Turbo Honda civic wagon having serious problems, blue smoke and slipping clutch...
- whats the largest fuel injectors i can use without boring out the fuel rail?
- what is everyone running for a thermostat?? oem???
- if LS rods fit d16.... can i use ls EAGLE rods on a d16?
- crower vs skunk2
- help with valve seals please.
- Boost and A/C (to hot to work)
- 90 crx hf manifold
- Can some one post there drivers side intercooler piping near Wind shield washer jug 96-00 civic
- Tial/Garrett GT4202 1.00 AR V-Band Housing (pics)
- Project LS - Only the beginning...
- Fuel Pressure??
- Basic exhaust question
- Oil in compressor housing, GT35E couple questions.
- fuel and compressrion ratio question...
- Just some FI motor carnage
- resistor box to use with precision 1000cc injectors
- Who has used Megasquirt? What Ignition trigger did you use?
- I'm Tapping my oil pan and i have a quick question!
- Really need help with a JRSC, please before I go insane. Belt Problems
- turbo for cheap
- gt2876r on a b16. any numbers? opinions?
- turbo civic vacuum line help
- Who has the PTE 350HP intercooler?
- Not your average SSAC thread
- AutoMeter Oil Pressure Gauge wiring help
- T4/T67 DBB (GT37R) vs GT4088R
- which hondata systems are tunable by the user?
- greddy 310 injectors
- My Ls-Turbo setup
- TD Autowerkes SFWD EK gets new goodies! Lotsa Pics!
- No fuel to 2 injectos?
- bfg drag radials , feedbacks
- Quickest E/T on D/R
- b20t b16t and a few other questions
- T4/to4e how much hp
- o2 sensor enabling question?
- boost controllers
- wastegate question
- Need help on wiring dual walbro's
- Sohc guys, wheres the best place to tap your oil pan?
- turbo oil supply ?
- vx manifold
- What would you guys recommend? Tune wise
- Motormatrix Mike surfaces
- Turbosmart MBC not working
- are theese real skunk2 pro1 cams?
- Best way to upgrade w/ Jackson Racing Supercharger
- oil restrictor?
- window weld
- Is this thread correct? H22 rings?
- Need ideas for a good engine build.
- Aero Exhaust question
- Oil Pump and Rear Main Seal Question
- c16 bad for wastegate valves?
- is this rods and pistons are good? ( vid inside )
- Do all turbo car stink? Cause after the FPR installation, its running hella rich... and Stinks
- Exhaust Question....
- Which turbo for this setup?
- need help with problem
- Still have a problem w/BOV
- Weird Idle Problem
- Where to get this V-band?
- what do bad rings look like?
- Trying to Find Internally Oiled Turbo? VETS HELP PLEASE..
- tapping oil pan
- Sorry, second question.
- Crank for b18b
- need help, power fc, turbo si wont rev over 4000 rpms
- headgasket size
- Crome Tuners in Colorado/Utah area
- Blox HSL cams + Boost
- about to turbo my b16, got a few questions
- Holset ? for custom kit guys...
- injector types/spray patterns
- which is a stronger block b18a or b18b?
- tuners?
- 550s big enough for 350+whp?
- need help with tuning "tip out?" in crome.
- Oil Pan Gaskets - Keeps blowing out in boost
- civic vs. 3000 GT
- Eng builders please help analize... Head removed pics
- Does exedy make the cerametallic for the D16's?
- need your opinion
- DOHC BOOSTED RIDES/Post mods list and pics of your BOOST FED rides
- eBay radiators... Mishimoto vs GodSpeed
- building my b18c1
- what kind of intake manifold is this?
- anyone have info on this Del Sol?
- Turbo Car over heat issue
- Need help
- Would this catch can set up work or no?
- HELP Car is breaking up in high rpms in boost?
- racing axles or stock whats better??
- xspower turbo how good of a brand compare to other turbo
- Jackson Racing Super Charger CARB sticker, what is it made out of?
- MSD Boost master w/ Hondata s200?
- crane ignition question
- base fuel pressure keeps changing. whats up
- weird oil issue...broken pump? PLEASE HELP I"M BUMMED! happened twice
- Need Help! Which rebuild kit for smoking turbo?
- clocking turbo questions
- ***OIL PUMP BREAKING???***
- fan for eg turbo
- Skunk2 Turbo cams.....
- Need help selecting a turbo.
- d16y8 turbo kit?
- RC Engineering Lucas style Disc injectors
- Moly Rings
- what would be the best motor?
- Misfire in Boost
- So, you think you know Air Filters...
- engine management?
- Trying to get in touch with Howard @ Speed Innovations
- TURBONETICS TV.. the youtube for boost cars..!!
- Car leaning out and misfiring NEED HELP ASAP!!
- gt35r hp
- oil dip stick
- Question?
- 94 Civic need advice
- Running a intank and inline fuel pump on the same setup??
- Help with Greddy SM Integrate
- How much can it hold
- Vortech Supercharger on B16A2
- cell 1, 20 ?
- spark plugs wire
- supercharger
- how to put on turbo kit?
- Oil catch can setup!
- Blox manifold A/C
- precision sc61e turbo question??
- Sponsors READ please.....I need some parts
- turbo b20???Any doubts
- ITR intake mani. on boosted GSR
- 14b TunerToys oil feed fitting problem!!!!!!!!!!
- how much does temp effect hp on a dyno
- free chrome ,uberdata?
- XTR6 or Action 2MD for my new power goals
- XS-ENGINEERING D16 Turbo Kit
- what to do
- Possible to run full 4" on DC2?
- finishing my turbo set up .. i have a few questions that i need answered
- LST VS LS/VTECH TURBO !!!!!!!!!
- Another dummy question by me
- 440whp H23a Preliminary Dyno
- 400WHP Street Car 4-Puck or 6-puck?
- HOW MUCH POWER YOU THINK I AM GONNA MAKE
- gt35r with inlinepro manifold
- Manual boost controller installation question.
- Defi Link Gauges
- VAFC or AVCR better for tune on boost
- inline pro contact info
- CEL and P75 hondata system
- Greddy kit
- WASTEGATE QUESTION
- full-race manifolds
- dsm 450 injectors
- my boost gauge reads 9psi (not right)
- Does anyone make a divided T3 housing for a stg5 wheel?...
- my future setup
- IHI VF 39 turbo Anybody
- Honda-Tech's Highest Horsepower on a Stock Block Thread *OFFICIAL*
- Turbo Coolant Return Line and thermostat flow
- ? sc61 t4 v-band flange size
- moroso oil catch can help plz help
- which is best? victor x or skunk2 pro intake manifold?
- Calling all AEM EMS users: car wont start, & no spark
- Garrett T3/T04E or Garrett T3 Super 60?
- my b20 vtec dyno day
- Is AFI still in business?
- Searched, How much HP are Eagle Rods good for?
- I'm just checkin... (fuel pump)
- whats the best half sized radiator I can get for my EG?
- Can't get my idle down, and AVCR/Tach are don't agree...
- walbro fuel pump install question.......
- what can I reasonably expect to make for reliable power on this setup?
- car wont start
- where can you order new turbo housings from?
- honda head gasket
- BOV Tial vac problems
- waste gate question
- First 10sec D16 Vitara Setup!!
- turbo oil return line help!!
- Kamikaze and S2000 donut gasket
- oil drain line HELP!
- Where to buy rubber o-ring gasket for compressor housing?
- CAN ANYBODY HELP
- B16a with T3/T4 turbo, fuel pressure test to determine injector and/or fuel pump?
- Two questions about ECU + Clutch
- DYNO: E85, GT2871r, 84mm gsr, b16head
- HKS SSQV HELP
- B16 Leakdown Results
- problem with the s300 (timing)
- help me diagnose, burning oil PICS
- Went to the dyno yesterday....
- Generally, what causes hesitation on vtec xover when using engne management sys.
- turbo setup
- Car runs warm after high rpm's
- resistor box install on 96 hatch
- greddy rs leak
- new dyno results.. b16 84mm 8.3:1
- getting a code 1, but i have my o2 disabled, whats causing it
- bolt on turbo questions
- What's the best psi on slicks with turbo?
- Blowby Questions
- port -n- polish
- ls/vtec gasket fitment question
- Can someone explain this IDLE fuel pressure/ AFR situation?
- B16 block build
- wheres the best place to purchase new arp headstuds?
- SC6176E rebuild kit?
- quick head gasket question
- aem fuel pressure regulator question
- stock injectors
- A/R Question
- ramhorn on a crx vtec
- How much gas do you burn 1st-5th gear pulls at 400whp+ (video inside)
- Precision GT35E/T4 Weird problem... center section loose, bolts are tight
- Fuel Sump line question
- fitment issue with fmax manifold and wastegate? stud question.. 95 accord
- dumptube bolts for deltagate????
- wondering what i should do to upgrade my turbo system.
- boosted D16 vs B16 stock vs B18c stock swap in 94 dx coupe...
- will b20 head fit on b18 block?
- which intake manifold is best for DRAG
- Question about Crome and 2 step
- Extendin/ moving AC lines for turbo manifold?
- Which A/R is best??
- wat do u guys think?
