View Full Version : Forced Induction
- pic request: thermal r&d muffler on eg hatches !!!!!!!!!!!!!!!!!!!!!!!
- engine build?
- new to the turbo world and i need some help
- Precision Turbo Which model to chooose???
- Need help with my internal wastegate
- Post your Blow Off Valve sound clips
- what temp should my egt run at??
- Sc50 and Downpipe Gasket
- apexi turbo timer wiring help
- heres the new tial 44mm WG bad ass units with v-band
- Comptech Ice box with Jackson
- Wastegate Spring boost values?
- whats the max psi can a t3t4e .48 turbo push
- Custom Piping? Connectors
- Most effective way to check for boost leak?
- fuel pressure regulator and fuel rail what is better for up to 20psi (already searched)
- Does 'clocking' turbo throw off ballance of turbo?
- DIY WB o2 builders!!!!! What is the deal with the calibration resistor?
- Lets see some pics of Inlinepro mani setups.
- Anyone have any results or info with these manifolds. This is not SSAUTOCHROME
- n.o.s?
- Oil light on!?!?! no oil flow!!!
- wanting to boost my gsr
- want to get away from SAFC setup and re chip original honda ECU....
- Can you rebuild an FMU???
- where do you guys get your compressor housings polished?
- ls vtec???help
- Crap i broke this
- should i get this rebuild kit?
- Boosting And VAFC Question...
- Has anyone had this Turbo Timer problem...
- Basemaps for B16A1 Turbo
- Mounting IDeas for IC in a ef civic.... Cut or not?
- Anyone using a saab/volvo or their intercoolers? And how is it working out for you?
- Help on putting together my JRSC Map controller
- twin turbo single cam any1?
- Tuniing Question....GReddy blue box and v-afc?
- ihi turbo gurus
- aftermarket pistons
- Making room for a filter?
- oil return angle ok?? pic
- Question about the safc-2 tuning i can do b16a 15g turbo
- Exhaust 3" or is 2 an a quater ok????
- why lower compression?
- Turbo, honda tuners help me out!
- anti-lag help
- Intercooled JRSC?
- NOS Install question??
- which turbo to get
- y8 turbo vids
- JRSC blades??
- are all b-series flywheels interchangeable?
- inline pro T4 manifold question
- question about the vafc2
- greddy down pipe
- J's Racing intake with JRSC?
- When do you really need engine management like Hondata?
- Split-inlet exhast housing
- Will TurboXS RFL fit Drag Pipe w/any flange?????
- hks turbo timer install - wtf?
- First Pix..Lexus with 4 Honda Engines
- Where to get turbo stuff?
- TURBO TIMER ???
- A bit of progress on my end! the build
- What are the top 3 parts you should not go cheap on when building a turbo kit?
- Test Fitted my intercooler today (pics)...
- new street gas b16a2 / 60-1 dyno numbers
- Great for a laugh
- SMOKE??
- Intercooler: Powercoated?
- greddy turbo timer? any turbo guru please help.
- Why is an upgraded fuel pump really necessary for my setup?
- Turbo internals question
- T25 and td05 Same Flange???
- need help greddy blue box
- Which Turbo Timer and Boost Controller to get???
- Plastigauge and ARP/AEBS rod bolts/main studs?????
- Wastegate porting on the 18G...need some links.
- what downpipe...lovefab related
- where to buy t3 60 trim...external WG
- Oil Feed Question???
- What is the best Wastegate that I should get?
- Twin Charger Setup
- GE Vacuum Manifold quick question
- Motor Flush
- Greddy Type S VS HKS SSQ BOV
- Turbo lag on a b16
- Gredy turbo kit knock-off
- how to distinguish turbo's???
- turbo d16
- how those other guys boost - my new wallpaper
- Custom Turbo Manifold Q's?
- my dyno chart and pics!
- What Boost should be run with 9.8:1 pistons?
- Critique my turbo setup..almost complete!
- Anyone ever buy the Turbine Upgrade?
- i have questions about lightweight flywheel on SOHC turbo civic
- intercooler suggetions-i need help
- Precision turbo warranty?
- Final drive for turbocharging
- good 3 inch exhaust
- downpipe gasket for 92-95 greddy kit....
- i need to know where i can buy a testpipe!!!!!!
- Just a update Tease picture.!!
- Turbo flanges, DP pipes, IC pipes. what site?
- help! need help finding a part
- South Florida Welders?
- Old turbo condition
- nitrous tuneing with wide band and cafc?
- Finally tuned SOHC numbers inside!!!!!
- What fits a Greddy B turbo manifold?
- anyone ever come out w/a good turbo cam for the h22?...crower, ef-1, skunk2, crane?
- Thicker Headgasket opions (from those who have had them)
- programming smc+ ???
- boosted hatches with typeR motors suck??
- nitrous bottle nut adapter
- greddy type s doesnt work?
- which clutch to get?
- Stainless Steel Donut 3 inch !!!!!!!!!!!!!!!!!
- Exedy Organic Racing clutch OK for less than 200whp?
- help with idle problem...
- Turbo R almost complete
- anyone damaged rods w/o damaging pistons?
- NOS Question
- Am I missing anything in this setup?
- 3 bar map sensor w/ e-manage???
- benefits of open downpipe
- ATTN: Arturbo , Question about my turbo choice
- MAP? stock map over 10psi.
- oil feed line for 98 ex apex turbo kit
- slave cylinder in the way?
- ????t60-1 on a b16a2
- Catch Can questions?
- quick easy hondata basemap question...
- whos running stock intake manifold??
- NOS WOT switch
- 2 quick wastegate questions...
- Turbo Intake Hose?
- Aeromotive Q
- DA tegs...where to tap oil feed?
- Intercooler Info
- What is the grippiest tire that is not DR?
- intercooler inlet/outlet
- b16 im gasket the same as b18c5?
- Hondata Releases Their K Series ECU's
- victor reinz head gasket
- turbo question for d16
- size of plug in back of head for lsvtec>?
- anyone know where to find 3.5" to 2.5inch reducer
- WRX turbo
- How much boost on Forged Rods+Pistons in an LSVtec with 9:1 cr + Hondata?
- MSD BTM....Are the settings slightly off????
- Cheapest Place for CP pistons (search sucks)
- Nitrous tuners - A/F ratio's
- Fuel Management?
- turbo timing and fuel?
- does aem ems have this one hondata feature?
- Question about greddy setup??
- Throttle body sizes?
- ACT 6 puck clutch harsh engagement?
- Oil feed line & oil return line on B16A???
- B16's out there with Turbo I need ur opinions
- upgrade my turbo kit??
- MSD 6AL wiring with standard honda coil, should i upgrade?
- Oil return help... scavenge pump? Custom manifold pics...
- Dyno'd Today...
- Turbo B16 or B18c "Hmm"
- AFC hack ?'s for high altitude
- Autobahn Raser
- Turbo Unclocking itself
- headgasket for boost?
- 1st gen b16 oil line
- how to tell if an internal wastegate is bad???
- Turbo Timer Install on 04 WRX
- JRSC on ZC (searched)
- Serious yet simple question, Worth the switch from drag mani to other? info inside
- Wastegate?!?!?! Internal or External
- pics of manifold and turbine ceramic coated
- Boosting newb
- b16 w/ drag turbo kit problems
- overblownmotorsports.com Intercoolers? good deal? good quality?
- custom turbos
- Quick BLOCK question-
- SOHC TURBO...N E ONE???
- Stainless MIG welding hints?
- B&M w/vortech fmu or AEM Reg??? which to choose????
- stock b 16 head on a bored out ls
- Sorry for the non-Honda topic, need help with an SRT-4 question
- b16 with Drag kit, Swap to to LS Vtec, What kind of power increase?
- My new street car
- where's this post at?.....
- D-Series :: T3 Super 60 ?
- white smoke
- anyone knows the size of........
- which manifold for gn turbo
- Mase-A-Palooza tuning day bash official sign up thread! in VA baby!
- Anyone with a vortech s/c w/aftercooler on a GSR?
- Cleaning Tools
- which oil catch can do u use??
- ODBII code p172 HELP
- Apexi ihi turbo problem!
- 225/50/15 tires work on boosted 93 dx hatch?
- RC 650cc and 750cc SATURATED Injectors NOW AVAILABLE!!!
- Which turbo
- Vortech on a gsr
- Attn: Mase hondata tuning in va (is it happening)
- Garret Or Turbonetics????
- Resistors or OEM Resistor Box?
- muffler or straight on track?
- 350hp 300 ft lbs Turbo LS
- EF-1 cam???
- OT:Please post your D series head code
- B16 boost on stock motor. Help
- Problem with my BOV
- fake turbo XS RFL bov?? ebay
- Cold Start AFR?
- Can we get a GB on FR turbo kits??????
- More Batronix problems...
- Explain how a timing belt falls off....
- Turbo 80mm/3in Exhaust - Made in Japan!!!
- sc61 o sc50 on a k20a3???
- has anyone used this new MSD boost control module(turbo launch controller)
- Sway bar and 3in exhuast
- Symptoms: Boost is laging
- OBX Oil Pans
- thread tap size for direct port nitrous
- what else should i get to help my boosted setup to run properly and safely?
- possible to make a 3 inch custom exhaust setup quiet like the apexi WS?
- Trany issues. what would you do?
- Best B16 Turbo Manifold?
- HELP! DID I BLOW MY PISTON RINGS ?????
- Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains?
- OT: Thank god i knew Import FI before i got my mustang.....
- Intercooler for EG civic
- where to buy hondata?
- Disadvantages of hondata 2b
- Greddy VS JY/Custom Kit?
- Batronix question...how to place the chip and jumpers...
- H22 Turbo Cams??? Are they worth it? OEM Head Gasket?
- Pulled my plugs today. Little bit of green on cyl1?
- Safe fuel pressure?
- wiring ZEX bottle heater
- Mounting N20 bottle?
- JRSC: 94 sunoco or 93 shell
- Which audis have an external wastegate????
- t3 plate
- Motorsports Job Opportunity
- Stage2perf.com turbo kits...
- i have a d16a9 engine from europe (UK) it has no o2 sensor does that mean open loop?
- blow off valve operation question
