View Full Version : Forced Induction
- turbo sizing
- blow off valve with jackson racing supercharger?
- anyone wanna run?
- Boost Creep, Help!!
- T3's Do all of them have....?
- Spark plugs have often do you change them??
- changing boost setting and tuning
- ARP D16 head studs
- OT: pics of turbos with flames coming out
- what areomotive fpr??
- Whoa...did y9u see this??
- Turbo Won't Fit
- Which injectors to use?
- rebuild or not??
- b16a 84+mm bore guys, where are you getting your pistons from?
- Prices on turbo rebuilds/or remans???
- Kinda new to turbo's
- Turbo Kit Installation...NEED HELP?
- Fluttering noice coming from engine bay..help
- OT: Stock SOHC Valvetrains revving to 9k
- Axles
- bike pump testing for leaks
- Sorry guys, another oil change question
- what o2 sensor does the FJO kit use?
- Couple shots of HMT's 2nd Race Car
- map sensor
- Header Setup with JRSC
- fs: jackson racing stuff (vpac, fpr & btc)
- spark plugs
- anybody using saturated msd injectors
- Help me pick my Precision Turbo
- why such large turbos?
- i NEED to RENT your 550's
- Can someone please explain to me whata v-afc or afc hack is?
- B16 boost question...
- CHEAPTURBO.COM now offering 5bolt turbine housing option
- New manifold for Greddy Turbo!
- any help would be great! (turbo install)
- Nitrous Express N-tercooler
- Piping ?'s...
- where can you get a sfp manifold?
- wtt: turbonetics t3/t4 turbo .57 trim, .63 ar
- Help w/ apex egt probe install
- how much would you pay 4 h23 turbo kit?
- The Best of The Best (parts)
- Spark SS manifold.. Any pros or cons.. Manifold gurus enter here:
- Do b-series rods fit d-series? More specifically, LS rods in a d16y7
- Greddy intercooler fitment question
- Could this be used for charge piping? (link and pic inside)
- To lighten or not to lighten?
- Quaife installation - Who should I trust to install?
- Turbo Muffler
- Tough situation, opinions on stock radiators running 12psi.......
- weird sound coming from turbo???
- My new setup vs. My old setup
- Hondata vs. aem ems?
- Anyone heard of a MENG mani?
- Tony1...holla back
- Question for AEM guys
- 94 gsr w/ greddy turbo kit, just installed VAFC and having problems...
- Greddy turbo timer... sort of works now..
- Boring my ZC
- Does anyone know who makes the Turbo in the Drag gen III kit?
- Thinking of leaving the darkside..
- alternative to AEM EMS?
- Turbo Oil Drain part #'s?
- Turbo Kit Install Complications
- is JG Engine Dynamics no more??
- Calling ALL Nitrous GODS....I NEED HELP!!!!
- Smoke/steam? out of my breather!
- question about injector o-rings
- stealth civic wants a color matched intercooler, is it posible?
- Not Honda but still FI...sr20 what...a new 240sx turbo swap.
- Which turbo kit to get?
- nitrous and Jun cams?
- welding intercoolers
- Better?
- Whats an Inline pump look like?
- Hondata obd 0
- 88 prelude 2.0l need parts
- .86 a/r T-25 turbine housing vs. .48 T-3 turbine housing...
- blow off valve with supercharger?
- which turbo should I buy?
- Garrett GT3040
- Where do you get the valve for the DIY dual stage boost controller?
- OK going with braided stainless fuel lines..need some answers
- whats a ntirle connector??
- ACT What ACT clutch is best?
- Intercooler Piping Beads
- made the bov switch :)
- does stock back pressure on turbo charged cars restrict high end power increase?
- Anyone port the WG on a greddy turbo kit?
- Installing my drag III turbo kit
- Some SMC Troubles....
- Turbo Break-In Guidelines
- A little OT [PLEASE read]
- Best Turbo Kit........
- *pics request* looking for 94-01 integra with a/c and a drag turbo kit
- A few questions about Turbo Specs
- boost source
- What else will I need?
- questions on max-rev 3" downpipe?
- FC Injectors
- Just installed SMC+ and 450's and now I cant let my foot of the gas without the car Bucking!
- Problems with MaxRev?
- can i use a warlboro 255 intank pump with an fmu?
- pipe cutter.. where do you get em.
- What will these spearco cores flow(hp wise)?
- vafc on turbo d16z6
- finaly got my turbo on has a few ?s need some help
- just installed turbo...what could be the problem??? HELP
- what loctite will hold up??
- Just got Turbo
- please help !!!
- i want to trade my integra one peice fornt for a 92-95 civic stock front end
- Golden Eagle Adapter help
- Hey does this sound like B.S. or what?
- Manifold question/help
- Hlp urgent , dumptube broke radiator
- What Fuel rail and reg should i get...
- SFP manifold??
- Arent these the turbo manifolds that are known for cracking??
- ... crower rods... any dealers?
- Precision Turbo Monster T-76 GTQ Trim!!1 Pics!!!
- For all you b20vtec turbo read
- Inline vs Intank Fuel Pumps? High Pressure vs Low Pressure?
- ... eagle rods... questions...
- Sohc Turbo Questions
- Will this setup give me 400bhp?
- Where did you take your BOV Flange to get welded on?
- help with oil lines
- NOS sneaky pete kit
- Interesting findings on turbo cams..
- Hondata Tuners in MD/Balti area
- Is it worth the $ to a have turbo manifold jet-hot coated?
- Lean all of a Sudden (I think)!
- BOV Vaccum Line + Boost Gauge Install, Quick Q's
- Direct Port Nitrous or Single Intake Nitrous
- Installing rods/rings/pistons?
- Turbo Experts; need advise in selecting turbo (H22)
- How hard to pull head off to inspect/change valvetrain?
- g soHow much do your "custom" turbo kits end up costing?
- Arias or Wisco Pistons?
- help need wiring diagram for greddy turbo timer
- Fitment Problems w/ Inline Pro Manifolds
- Alternatives to GM 3 BAR?
- Greddy Type S problem/question?
- Searched found Nothing/ O2 Sensor For A SOHC Turbo
- VAFC hack questions
- Can I use a rubber hose for the oil feed line? and a possible good idea?
- Focus / Str manofold fitting Question
- Best overall B18C turbo kit...
- TiAL spring question
- Edelbrock Performer X Turbo System
- Greddy Timer not working... engine shuts off
- Passing Emissions with an FI obd2 car with an obd1 ecu
- fan question
- What bearings is everyone using for their high Hp Boost motors??
- is hondata suddenly an actual engine management system?? <i think almost!>
- GM 3-bar - confirm
- NOOB quest. ---is there a gasket between the turbo and manifold?
- REVHARD MFG doesnt want to help!!! :mad:
- Intercooler piping question
- What spark plugs?
- Race Gas
- ok real jackass question
- what size piping for 35mmhxp Tial?
- turbo del sol
- Spark Racing Manifold Opinions
- Is this a 3 bar MAP (pic inside)
- ARP studs for exhaust manifold and downpipe?
- Guys using Skunk2 on B18B...
- foryou guys with "track only" cars, what's your daily driver?
- vortech FMU
- on a b16 sirII whre is the map sensor located?
- What are vacuum lines and what do they do?
- home built exhaust manifold ????
- Anybody know where to find a TURBO KIT for a 96' non-vtec prelude!
- junkyard turbo setup
- Which standalone supports auto tranny?
- What does it mean when your "check maintenance" light blinks?
- Ngk BCPR7ES-11 Sparky Plugs ????
- How many people are in the 600 club(honestly)
- What is the use of an air filter on the turbo??
- DOHC F-22 JDM Cylinder head?
- got a turbo the other day
- What turbo for a fully built B16???? 25psi at the track
- asking too much for a engine installation?
- Clutch master cylinder going bad? Pressure plate shot?
- Inlinepro manifold bolt question
- Greddy install problem?
- Venom nitrous???
- NA vs. FI
- swapping TD06-20G turbine housing for the TD05/TD06 hosuing from my 18G
- Manuel Boost Controllers
- Exhaust and downpipe question.
- Who has a turbo hx?
- 93 civic hb with 94 h22a1 will the new jackson racing supercharger fit
- Best ems for 1990 civic si
- CEL - Map Sensor... Please Help
- Intercooler with factory fogs?
- Good Machine Shop in San Jose/SF Bay Area?
- Phenolic Insulators
- I found this thread called," finally a honda done right"
- What's up with the DSM Performance page?
- which cars have an obdI that I can pull?
- Si Turbo vs Perlude with NOS
- anybody know the email addy for A'pexi?
- Interesting Idea But Is It A Good Idea?
- kinda ot.. What is it with RX-7's??
- Flutter sound?
- Can someone with a drag 3 downpipe post pics of how they ran their oil return line?
- Clutchnet Chatter! Arghhh!
- Attn: Arturbo
- AFC tuning w/ 450's...(calling all hack-450 guys)
- those with superchargers please
- Oil line fittings
- ever race an all motor car
- Clutch and axles
- JG EdelBrock Turbo coming for the D16Y8?
- Hondata ROM conversion question (P28 to P72)
- Quick question on boost with stock itr catback exhaust
- Tapered bearings on LSD removal
- what's your AFC hack dyno?
- Fuel and Ignition Maps
- Launch Control on Engine Management
- building a turbo
- Air/Water Better than Air/Air?
- code 45......?
- Problems, Clutch went out tonight
- Updated Pics of Engine Assembled, Turbo Mounted, Nice and Clean. :)
- post pics of your welds !!!
- relay diagram for inline fuel pump
- Check out this D series manifold for turbo
- BOV size???
- inline fuel pumps
- JDMDirect?? I need some help Canada people
- best piston/rod combo for b18b
- i think my friend is going to blow his motor
- b16 to b18 swap
- Procharger superchargers
- JRSC with s1 tranny??
- Turbo my F22
- Flame suit on, n20 Question
- hadn't been out for a drive in a while
- Turbo Ex Need to go Hondata ! need info on them
- will i notice a big difference with this
- What intercooler for 450whp....
- Need Hondata Information - Turbo GSR
- Bad to boucne off rev limiter?
