View Full Version : Forced Induction
- Sleeved bare block anyone? H22orH23? I need one bad
- First 1/4 Mile times of the season.
- HELP h22 turbo problems
- cheezefrog vs viper????
- LS pistons in GSR block
- Safe boost on stock DX
- Which is Tranny is Better????Turbo
- VAFC with skunk2 ecu
- Blew Somethin what to do now?
- check this out
- SMC+ CEL #43
- Anyone with turbo experience....
- 2.5 or 2.25 outlets on a starion IC?
- Take a look i have some questions.
- Starion intercoolers mounted, pic please
- t3 turbo!!
- BTM boost timing master help again!! HELP!
- i have a few questions... need opinions also please
- Intercoolers
- anyone using an AFC or SMC map controller... question
- DIY MaxRev Piping - to Throttle Body?
- 680CC + EMS + good tuner = way too much fuel? help.
- ... diy ghetto boost control mod for 2psi... what do you think???
- Electrical help please (DIY-WB-O2)
- where to buy Marvels Mystery oil ?
- **Car is Hesitating under part throttle at 1/4 of the pedal**
- Compare My Datalogs: Before and After 255lph Install
- 450-550whp street cars...Tires?
- Turbo H22 Spark Plugs?!?!?
- post your CRX/EF INTERCOOLER setup pics
- fjo wideband +aem HELP!
- I need some stuff.
- greddy flange
- A Turbo mounted sideways..help!
- Which Turbo kit?
- smc + problem
- Anyone ever see a D16A6 (CRX Si Motor) make 200 WHP?
- Inline Pro crew and affiliates....fuel management setup?
- JG Edelbrock 75mm Throttle Body... has it been released yet??
- My BOV is too quiet, how do I make it louder?? (Blitz DD BOV)
- Setting rev limits on Hondata s200, anyone else have problems?
- Need help..Just did Hondata and DSM 450s...
- question on clutch
- knock sensor crazy question guru plz read
- dyno @ inlinepro part II
- anyone know what a DSM wg boost level is set at
- can someone explain how the hell this happened to me?????????
- why is equal length such a big deal?
- GSR sounds raspy when the WG opens? because open dump tube?
- Installed a dart block today. My little review
- Where's Stan? aka Flamenco-T
- Dump Tube
- b18c turbo or h22 turbo??
- Review of uberteg's boost chip on a ls/t
- Dagnabit. This might explain the "sighing" noise after boosting...PICS
- What are crushed bov's
- Meet
- Calling the high horsepower guys... ->traction related
- All boosted motors - plug gap
- Greddy type s flange question
- Help car will not start AEM. Lot of problems and questions.
- what turbo setup will fit on B18C1 CRX?
- how much boost should i consider running?
- LINK engine management troubles.
- ?? turbo install ques.. and how to meas AN fittings?
- How do I make a MAP diffuser w/ check valves and Ts????
- How many people have made equal length manifold on this site?
- Sohc Strange Sound (Continued)
- how to measure my slug
- Just installed kit...couple questions!!! HELP!!!
- When installing a manuel boost controller..........
- Garret t3t4
- What is your EGT at wide open throttle???
- The difference between DragIII and Greddy turbo
- Need help with EMS
- This is a huge turbo!
- first time at the dyno today
- fmu units
- TiAL WG gasket blown after 1 week @ 7psi! WTF!?!
- *%$#@! intercooler
- mix and match
- HT-Dyno Day in VA
- turbo manifolds for b16's
- Differential Bearings... is 99-00 SI Same as 2001 Type r Or Gsr??
- What about the OBX turbo manifold ???
- dsm 450cc injectors
- New to Turbo and I have some questions about applications for a 97 GSR
- couldn't find it in the search.. JRSC with auto tranny bad?
- damn...waited so long..and its finally gettin there~
- beginner tips for ARC welding
- Exhaust leak?+no boost shows up on gauge
- Turbo SOHC D15B7..
- Rev hard kit
- First time @ track w/ boost and slicks.
- Piecing together a turbo kit help
- PIcs of what happens when "MY" thrust washers fall out
- obd ll b18b's with a autometer a/f gauge...which wire is to the o2 sensor?
- Turbo timer install help....calling all 92-95 civics.....
- D16Z2 ??? Anyone heard of this engine???
- New dyno #'s
- Is an ITR flywheel a worthwhile upgrade?
- SAFC *hack* help
- SOHC guys: intake mani's for boosted applications
- Washington State Emissions
- a couple of questions
- Going to dyno tomorrpw morning. SPARK PLUG QUESTION???
- inHG
- Adapter help
- rev hard 2c install help
- 1989 d15b2 how much can it handle?
- Disapointed the update
- Can the greddy banjo bolt be eliminated?
- Turbo mini me
- intake question for supercharged gsr
- using palm pilot with techedge?
- jrsc
- how does a boost controller work
- Integra Ls supercharger for sale on Ebay.
- what size is this turbo
- How do you adjust a maxrev bov??
- I'm friggin retarded , i can't get these damn pics to work!! Help for christ sake
- Got my Manifold, Intercooler, and downpipe today.
- techedge service a+
- switching manifolds - broken stud in the head
- Problems with manual boost controller
- SMC dynos
- Your thoughts on this setup
- Autometer Boost Gauge
- Who can tune hondata 2b and s100 in OH or western PA??
- Air Filters
- does anybody have a integra ls with 300+whp r runing in the mid-low 12
- Where to get good deals on Nippon Denso INjectors?
- Turbocharged bikes?? take a peek. CBR guys
- rev limiter blows
- Ceramic Coating?
- Hks ssq or Greddy type S bov?
- Garett GT30 turbo, anyone running?
- nonintercooled during the summer?
- I'm pissed.. I did a search , no answer ... SRP question .. Gurus please help
- MSD injector and MSD 3bar map?
- Greddy Type S BOV Adjusting Nut?
- Setting Rev Limiter w/ Digital 6
- radiator question
- Can anyone tell me what bov flange is on the revhard charge pipes?
- singlecam turbo??????
- turbo piping....
- Hondata problem
- Pics of your oil pan
- Boost controller parts
- OT funny for the day. Question about Port and polishing.
- pintle cap
- Eagle Rod Bolt Torque........What Foot Pounds??
- Just curious how much C/R helps power??
- what turbo betwen t3 .42 /.48 and a t3/to4e ????
- who's making close to 350whp and what setup?
- anyone know if the Camp1320 H22 manifold is A/C compatible?
- im new at this turbo game,, need some help..
- Fuel pressure regulator with v-afc hack
- anyone from Phoenix AZ? Anyone hear of AGP Turbo??
- sohc head removal... bolt order
- Just boosted my dx problems!!!!!!!
- Is you wastegate loud?
- Best turbo kit for b18c(R)?
- re:any one know.....
- 60mm Exhaust good enough????
- ITR LSD into JDM B16 cable tranny?
- fuel mixture for turbo
- Toulene formula.. what the
- where to get techedge?
- Disabling the Knock Sensor - HOW!?!
- Frequently skimped on items.
- SMC+ settings?
- .54 AR vs .70AR, should I buy, GOOD DEAL!
- anyone got pics of their turbo si with AC
- Turbo identification
- How do i tune it???????
- gauge lights went out?
- Turbo H22a4 Accord Pics inside
- b00st Spike
- VTEC and Turbochargers
- Need 550cc injectors.. Where 2 buy?
- CRX b18, turbo, Ac ?
- greddy sohc kit+greddy si intercooler
- sohc civic/del sol T3/T4 b specs??????
- detonation??
- Where is the best/cheapest place to get these
- PLEASE HELP me with my fuel problem (hondata ??????)
- how to get top end from 15g?
- Golden Eagle block guard
- turbo help
- leaking blower
- Just finished intall. Have a few questions????
- what do you think of this kit?
- smc install need help
- code 22 with nonvtec ecu (hondata)?
- Autometer boost gauge question
- Help problems after JRSC install.
- Quick Fuel Pump Question
- right turbo for my h23
- ok, t3/to4e questions
- Accufab mustang tb on AEM standalone???
- Factual Data 321 v 304/304L...
- Yellow ITR w/ huge FMIC?
- honda tuning junkyard turbo on crx
- if i will change boost from 7psi to 9psi - will it safe ?
- spring loaded clamps?
- B18b with the M62.Cone on in!
- What cams for fully built LS?
- Honda-Tech's Turbo Manifold Challange
- water powered turbo
- LSD people read please
- y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak????
- WHAT is "360 thrust bearing option"?
- Log vs Regular
- different ODB2 for 96-98 and 99-00
- I need another Hondata s200 w/ boost - Who's got the best price!?!
- What happened to the LHT jrsc Intercooler thread?
- safc or smc????
- opinions.... whats the BEST A/C compatible H22 turbo manifold???
- just got my engine all back together and im having trouble with ignition timing
- Got my ecutout
- Turbo charging a D16A6
- Couple questions on my turbo install
- Having a discussion with a friend about turbo sizes.
- Opinions on Inline pro turbo manifold. How good are they?
- Car wont start...?
- Turbo mounted right in front of the left front wheel..????
- Where to find slob of plate for my manifold?
- M’s Fuzzy Logic Boost Controller?
- UberTeg + OBD1 Boost Chips
- Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s
- Exhaust System
- b16 sleeved out to 1.8 questions...
- jimfab traction bar
- help! car wont start
- Anyone using the Apexi AVC-D boost controller....?
- Stumped on what to do, got a gsr and ls motor....
- Heat cycling your newly installed turbo components.
- Went to the track with the Auto again!!
- Products that havent failed me......
- Car Wont Start.......Engine try to escape?
- Should I stay at stock comp, or lower with gasket????
- Lost compression in one cylinder options I have.
- SOHC dyno #'s part 2
- Are these good?????
- turbo d15b7 question
- turbo h22a with aem ems = lots of problems, please look, help.
- please help me with my fuel system problem.
- Problem with SMC install!
- .48 turbine(hot) w/ .60 compressor, good or bad??
