Blackworks 4 Port Catch Can Drain? Need Help
Hey guys I'm running a blackworks 4 port catch can. 2 from valve cover and 2 from the bottom of the block. How do I drain the dam thing!? Need help!
-Intl Steve Krew
Re: Blackworks 4 Port Catch Can Drain? Need Help
<p>It'd also be a good idea to build a 'oil window' out of some petcocks and some clear tubing so that way you know how full it is. </p>
I never narc'd on nobody!
<p>Anything from a reputable company. Like, literally anything else. APR makes a good one. Go Autoworks has multiple options. Hell, if you want to keep it cheap, you can get a JR Race catch can on Summit for like, $75.</p>
Any other companies I could look into? I don't mind throwing this POS catch can away and getting another one. Just can't seem to find a good one with 4 ports 10an fittings that have a drain.
Who is Mr Robot?
Their catch can isn't designed to be a drain back type. I advise strongly against drain back setups anyways. All you wind up doing is sending the moisture and oil contaminating blow by back into the crankcase. After all the entire purpose of a catch can is to alleviate crankcase pressure and separate moisture and blow by out of the engine oil. You basically shoot yourself in the foot by draining back into the crankcase.
Who is Mr Robot?
Not a lot but that's a good thing. I emptied a good pint out of a catch can once. 700hp time attack Z06. Guy couldn't figure out why it was missing and would smoke. Catch can was so full under hard cornering and breaking that it was sucking up **** in the can lol.
so can I just add a drain on mine? im not going to drain it back into the engine, that's for sure but is blackworks a good catch can...?
Who is Mr Robot?
You mean like a petcock to drain it into a container? Sure
However I would suggest something like welding an AN fitting to the bottom and using a length of flexible hose and an AN fitting with a cap or some other means of positively capping the line as petcocks can come loose.
When I get home I'll show you an example of what I mean.
The black works can is probably the same as any other. It's the internal construction that matters as it should be baffled with some form of copper or stainless media to condense the oil vapors into droplets so they fall to the bottom of the can instead of saturating the filters. I'm assuming it's the can with 2 filters on top correct? Take the filters off and shine a light inside and see.
I honestly can't see what the problem could be with the blackworks catch can vs the rest.
I personally uses a T1, I paid $700 for it when he was into Hondas.
at the same Time B&R had the same design for $400
now BWR $300
all are the same stuff just different names, right now locally my boy makes way better catch cans than the above mentioned.
either way concentrate on the problem that is causing your blowbye
now BWR $300
<p>
</p><p>I don't think anyone here is talking about using a drain back, simply a drain. But seriously, if OP is filling their catch can often enough that removing it to drain it is an issue, then there's other problems there. Also, OP, you don't need a 4 port catch can. Two 2 port catch cans with drains would also do the job for you.</p>
<p></p><p>I don't think anyone here is talking about using a drain back, simply a drain. But seriously, if OP is filling their catch can often enough that removing it to drain it is an issue, then there's other problems there. Also, OP, you don't need a 4 port catch can. Two 2 port catch cans with drains would also do the job for you.</p>
<p>What you need to do, is figure out why you're getting that much blowby. Also, please read and understand the entirety of what I posted - You can replace your single (overpriced, crappy) catch tank with two smaller, cheaper, 2 port catch cans that both have drains. Just don't be that cockbag who drives around with the drains open all the time, dropping **** all over the road.</p>
I was under the impression most cans using the block fittings are going to get some kind of oil buildup, not necessary from blowby, but due to the low position of the block fittings close to the oil pan. This is why I figured a lot of people solely using baffled valve cover vents. I have my catch can just running to 2 oem h series block fittings with just a breather over the VC vent. I notice a buildup of maybe a half court in the catch can every couple weeks. I figured this was normal again due to the block fittings.
You see I have two lines coming out of the valve cover and wanted to put two from the block as well, but many people have been telling me I don't need all 4. I'm still debating whether to do it or just keep the two I have coming from the valve cover....
I am using this can with two lines from the block and two lines from the back of the valve cover. Crankcase ventilation is one area where overkill is just right.
2lobes1engine
05-13-2004 07:55 AM
