View Full Version : Forced Induction
- New Apexi turbo kit for the 92-95 civic sohc
- just finished the greddy turbo on m 6th gen!!!!!!!!!!
- vortech FPR w/ stock pump
- How much power can H22A tranny & axles handle?
- 95 Integ JRSC Porblems?
- JRSC Porblems?
- 2.5 or 3 inch exhaust with JRSC?
- How much shot of N.O.S. can my GSR take?
- Where can I buy the dump tube for the wastegate??
- Inline fuel pump with stock fuel pump???
- Normal to have a littel oil in the intake pipe of turbo?
- H22A boost levels?
- how much psi can a intercoller handle?
- deltagate for sale $75
- Need a crash course....Please help?
- Anybody used/installed this pump yet?
- inline fuel pump question
- Oil problem - Revisited -- pressure?
- How much boost is this setup good for?
- Head Gasket and Head Bolt Questions
- and KAA BOOOOM
- where do u buy a downpipe flange????
- Well, what I have heard is.....
- Clean IC piping?
- pics of ls with turbo?
- Whats the difference between the D16Y8 and the D16Z6?
- 9psi Update
- Limit on a d16z6 with greddy turbo kit
- turbo help, im sick of this crap.
- t3-04 or t04
- Turbo for the........
- How to read timing marks on a D16Z6
- Damn, my car is STILL running hot!
- MSD 6BTM of J&S Safegaurd
- what causes turbo cars to bog??
- how much for a conquest intercooler????
- went to the track today.... here are the times...
- OT -- Found a new Napster
- 13.64 @ 104 ET , i think i could be better. .
- Which Gauge is better / more accurate? EGT or Air/Fuel?
- Anyone using HP Racing intake manifold?
- jrsc for zc?
- GSR tranny parts on B16 tranny?
- Engine Build-up Costs?
- Turbo for '01 Lude...
- Should I just put the F-Max kit in or do I need something else?
- Best intake for CRX
- how do check valves work ?
- My first Turbo
- Anyone ever had a block fixed that spun a main bearing?
- clean engine bay?
- too much oil.. can it be a problem?
- POP POP! and white smoke!!!!
- God damn oil leek.. oil pan.. lost 3 qts, light on.. shut off immediately...
- turbo on a LS auto?
- what the hell is wrong? TECH ADVICE needed!
- What's the advantage of a bigger fuel rail?
- PISSED OFF!
- Maximum boost with J&S and drag3 in ITR?
- Who makes a good FPR?
- Stock cams w/ cam gears on FI?!?
- Will drag 3 GSR fit all b-series motors?
- Finally putting on my turbo.. EXCEPT...
- RS with DRAG 3
- Grill or no grill?
- Kuhmo tires...
- JR B16 powered CRX
- getting rid of crank case breather filter idea...
- FS: T3/T4 turbo from Revhard kit
- A/F mixture (lean or rich)
- help on a DRAG gen 3 turbo??
- would I win?
- help on supercharging a 94 teg GSR
- turbo for 2k celica gts?
- GReddy EGT probe
- Clutchnet Stage 2 is pissing me off
- FPR mod... What happened to my pressure?
- Exhaust Wrap
- Thermal 3" Exhaust GroupBuy???
- I want to destroy those muscles!! ;)
- How can you tell the engine is dentonating/knocking?
- turbo or supercharger for the ITR
- Zero Pressure Problem
- few ?s for the NX system...
- oil leak suggestions on LS???
- Need HKS SSBOV help
- LS INTEG TURBO KIT ON A 99 CIVIC SI
- Shops in VA, MD, DC area?
- which plugs to run?? help!
- found a pic of my car online
- Don't have a turbo kit, want the blow off valve sound?
- Is my BOV Dead???
- V-AFC+ turbo=I need settings please help!
- Is endyn a real shop?
- HT stuff
- Zex VS. NOS
- greddy turbo comp. wiring?
- welding beads around the IC piping?
- Please help me guys??!!
- test pipe
- Detonation getting worse?
- I need a Rev-Hard Intercooler...
- 4psi @ 4th and 5th gear only
- Infamous header question.
- Autometer A/F gauge malfunctioning??!! Long but need HELP!
- boost dependent timing retard
- Intercooler Piping?
- what are your thought?
- EGT questions attn BEN
- need some help with my kit please, greddy on 6th gen
- should I buy cresent's block?
- How do I find injector duty cycle?
- You may not believe this but...
- what size ?
- Who hear has a gsr intake manifold stock or b16a stock manifold
- Attention all Members!!!!!!
- Nitrous on autos...
- Asked a question about injector sizes but didn't really get a straight answer....
- Help does any have intruction to msd BTM or know how to hook it up to a 6al? THnaks
- Mitsubishi Eclipse Injectors
- 11.9 second Civic In car video
- Hey Art...
- I need some assurence from someone with experience in boost!!!!
- Custom exhaust
- Autometer Warning lights
- when do you build boost?
- compression numbers(2)
- WTF? Fuel pressure "bouncing"?
- Anyone have experience supercharging Del Sol`s
- overheating prob. w/ turbo!
- Does a front mounted intercooler give you away to the cops?
- Does intercooler give you away to cops in CA?
- Just Got My DRAG Gen3 kit!!!
- Wrecked my auto LS, bought a 92 GSR...and now thinking of going all motor...
- Compressor maps for Mitsu Turbos
- egt and boost gauges
- Soft Rev Limiter - MSD?
- SI forced induction
- High Flow Cats???
- OT: What happened to Chris at Xpress Motorsports?
- AIRTEX fuel pumps in Drag 3
- Does anyone want to sell me there Drag manifold, even if it is cracked?
- Adjusting the fuel pressure.
- DRAG manifold = pretty bad a**
- EGT not as hot with larger A/R turbine housing
- help...Blown motor??
- Tach wire on ecu?
- whats the max egt temp you hit on your runs?
- puzzling but innteresting problem.. not in boost??? fuel related...
- Thermal Turbo, Stealth or Apexi WS?
- rumor has it...
- G3 Integs: Ls turbo vs GSR turbo
- boost gauge reading
- T3 turbo flanges
- help do i need a missing link
- Mark C or turbo gurus.. I need your help.
- Air Research T3 any good???
- Penalty for running a turbo in the Bay Area?
- Compression with 2 mil head Gasket?
- What is CORRECT Fuel Pressure?????
- Any turboed GSR's using stock intake manifolds?
- The turbo goes on in 2 wks, which exhaust would be best?
- Cylinder Leak
- 90% Leakage
- where can I get a revhard turbo kit?
- Turbo install @ DRT?
- Piston Indicator?
- Sluggish Car
- What to do with sensor for 96-98 civic
- can a Greddy turbo for GSR be modified to fit.........
- Haltech, Zdyne, Hondata, DFI, etc...
- Clutch recommendation?
- Are all t3/t4 turbos created equal?
- New MissingLink check valve???
- HKS Blow off valve, C CLIP = pain in the ass
- To all Turbo users.......................what color does ur car smoke
- Vortech problems!
- Intake Butterflies w/ Turbo
- HELP! need specs on turbos
- apex afc and/or real gauges
- JRSC Water Injection Kit ?
- adjusting HKS SS BOV
- trying to make the best decision...
- Light weight flywheel with turbo
- avgas
- fuel pumps for turbo
- is anyone using a fluidyne, koyo or c&r aftermarket radiator??????
- What size wastegate spring?
- Fuel Pump
- power vs retard
- revhard stage 2 has 9psi spring, why would joetech tell me 7psi..
- Fmax! drag gen 3 w/ a wannabe fuel system
- Someone give me ways to piece a $1200 Turbo kit together!
- HELP!! Blown Spark Problem HELP !!
- compression numbers..
- In all reality...what will the t25/TD04 turbo do for my LS?
- Best Sounding Blow-Off Valve...
- what to do with my car....
- APEXI Power FC
- racing with shot fuel pump!
- Drag 3 Installed! 1st Impressions...
- Best Street/Strip Turbo for b18b teg? T28 w/ BB? Any input welcome?
- na ----> turbo
- Is a JRSC @ 8 PSI- Safe for a motor with 100K on it?
- clutch woes
- Is this a good book to learn about Turbos??
- Crower Rods
- ClutchNet - LIGHTWEIGHT FLYWHEEL & CLUTCH KIT PACKAGE!!!
- Whats Everybodies EGT's and tricks on how to get them lower.....
- who hear is going to NHRA event in NJ
- JRSC @ 16 psi, rc 310 injectors,should i get bigger injectors ??
- WANTED - New DRAG Turbo Test Vehicle!!!!
- How much fuel for nitrous?
- Delta Gate (6psi spring) but runs 10?
- Best and Safest Turbo for an R...
- Supra Pump???
- best boost controller?
- super charger vs turbo
- Some Pricing for new JRSC goodies
- The Fast and the Furious
- should i sell my Apex'I S-AFC ? ill be running low boost w/ a DRAG 3 kit on a B18C1...
