View Full Version : Forced Induction
- B16T not making correct power? Im baffled...
- gsr-t underboosting.. why please help
- where to buy Aluminum 90' elbow
- 2000 SI SUPERCHARGED QUESTIONS
- Need a radius plate for T25 turbo asap...
- Headgasket? Pics inside...
- air fuel gauge
- Final Prep Question For Turbo
- Putting a turbo into my Integra
- Just got my head back from CNCPort.com
- XRS BOV-Any good for the price???
- Intercooler Pipes and Vacuum Source Questions?
- Blown engine pics: Diagnosis, and are the pistons still good?
- How do you know when the seals in your turbo go bad?
- I need turbo kit for my 05 accord EX 4cyl.
- turbonetics log and inline pro log manifold question?
- Arias pistons ????? Eagle rods????
- any IDEAS on performance plan for 1990 honda civic ........!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Wideband shows rich but plugs show lean....EGT? Need help asap
- s300 question
- How DOes Your WASTEGATE Sound ?
- off car or aftermarket injectors
- Intercooler Piping
- need some imput please
- how to baffle vented vc?
- Good kit for a jdm h22a?
- Educated* Noob Q: Turbo Setup?
- LiL' sohc i tuned today
- The Definitive Answer for Turbo Cams...SK2...Blox...BC...
- My turbo setup for my sohc zc crx.
- #3 piston looks different. should i be concerned?
- performance axles
- 18g turbo with stock internal wastegate assembly?
- ls vtech turbo help?
- transmission ?'s for turbo
- ecu frying
- oil restrictor?
- help idnetifying turbo
- Spark plugs
- eagel or manley
- so confused
- check engine light on but doesnt give a code!
- Funny starting
- injectors cant find out what kind or size they are please help!
- Need a tuner in VA, prefer west of Richmond
- Holset WH1E Turbocharger
- can some one identify this top mount manifold?
- 586 WHP Single Cam @ 35 psi
- obx lsd
- Vibrant Performance Boost Brace
- Skunk2 stage 2 and boost?
- CRX: Which OEM radiator fits?
- Idle too lean for a few minutes after warm start
- cracked block. can i reweld??
- car not making power?
- does this coolant route seem fine
- Oil Pan Difference?
- Is 4" Exhaust overkill on my current setup?
- greddy air/fuel ratio HELP!!!
- ls crank
- new tune??? bigger intercooler and bigger radiatior???
- Skunk2 Intake Manifold on a D-series turbo anyone?
- Help me out with RC injectors (won't plug and play)
- sc61 on a stock b20.
- Boosted Accord... Help !
- Oil feed line won't connect to my t3 turbo, do i need to buy an oil feed flange?
- Why would my turbo housing be drilled and tapped?
- GSR Intake manifold B16 head
- I need turbo kit for my 05 accord ex coupe,
- turbo b16
- need help finding gasket
- Boost spike then settling towards redline: helper spring or new actuator?
- Stock block B20Z w/boost
- Running a GT35 or GT4x on the street?
- at what horsepower rating do heads start lifting?
- Recir Valve-Open Intake???
- Apexi AVCR new on ebay for 365? Would you risk buying it?
- 2 questions since installing drag 3 turbo
- 3" exhaust?
- AEM TRU Boost Controller
- co2
- Does anyone know if MemoryFab carbon "whale pennis" intake will fit a JRSCed GSR?
- high hp boost applications, what spark plugs are you running?
- tb2522 turbo fittings?
- ballbearing turbos?
- AEM EMS Tuning in Ohio
- oil restrictor
- whats better a built block or an eficient turbo kit
- turbo?
- VORTECH FUEL MANAGEMENT UNIT
- Tuning question, fuel!
- Quick Q B16a1 with t3/4 ... what to tune to? 12:1 ?
- high impedence to low impedence product
- which ARP head stud kit do I need for a sohc zc?
- Can someone identify, and how to connect this?
- Engine building question
- CRX Radiator VW Golf or Del sol?
- 2 step or 3 step colder plugs?
- rc injector o ring
- good turbo for a 15psi in an ls vtec (t3/to4e 50 trim)?
- small h22 turbo question XD
- How did you decide??????
- Has anyone seen something like this??
- When should your wastegate open for a 7psi spring.
- moroso catch can help
- Anyone got d15 ignition maps for crome?
- where can i get my turbo installed and tuned?
- how high of octane is TOO much on boosted motor
- after all that overheating the hg decided to give out (56k beware)!
- Stock JDM B16 OBD1 turbo - Want modest hp, better low-end, reliability - where do I start?
- Single nitrous setup question
- Umm... I dont think this is normal.
- no reading on dipstick???
- how much Boost?
- Good businesses that have turbo replacement parts (Greddy)
- Help, Exhaust sounds like wrx, loss of power...
- JRSC w Stock Injectors??
- turbo ls
- ls tranny?
- what turbo do i need
- fixture for ccm-measurements of fuel injectors
- radiator thickness vs width....
- afr 12,5
- which LSD
- Got rebuilt turbo back, but i have no idea what fitting is needed for oil feed. help?
- Boost Gauge
- what piston and rod combo for 600+ HP
- Did anyone try this idea?
- b16 with 60-1 hp and timing questions
- supercharger help
- Forever To build boost...??
- ls turbo part????
- Your ideal setup: how would YOU build this
- car will not start?
- oil feed line leak....hondabond?
- BOV's and high boost (type-s)
- crome wont "put" to romulator will "get" though
- how do i get my acura integra b18 tuned "neptune"
- how many hp
- PCV Question???
- E-cutout = How lean ?
- help with choosing turbo 450hp+ built engine
- 94 GSR
- vtec b20z turbo
- Adding more fuel?
- SEARCHED, wiring my turbo timer problems
- open wastegate
- well 380.00 a mnth latr, log mani looks like ish imo ____________________________
- If I lower the compression, do i get less vacuum?
- what do u guys thinks this is worth?
- Easiest to use oil lines??
- DSM injectors on D15bvtec
- 4 nitrous people: 100 wet shot on a sohc safe? or 100 dry shot with larger injectors?
- NEED HELP FINDING NITROUS THREAD!!!!!!!!!!
- Help with Blitz DTT install.
- quick question
- stock internal b16a2 + gt28rs and full ATS geared tranny w/ 4.9fd
- ANY HONDATA TUNERS IN THE BAY AREA?
- Sat nite drive, Bronze Teggy vs Gsxr1000 vs SC vs 700+hp evo vs EVO MR! vids..
- Just did a compression check
- oil lines for turbo
- fuel pump help
- where to buy snow performance water/meth jets?
- turbo pistons
- FREE BOOST GAGE
- Will a JRSC fit in a B18 EF hatch?
- anyone ever have a g-e oil sandwich plate go bad??
- nitrous plates
- The massive boost leak *pic*
- oil feed fitting for integra
- Question about turbo ls
- Block Girdle?
- 06 S2000 Turbo Kit?
- b16T Ramhorn Overheating?
- spark plugs
- compression b16 turbo
- Water-cooled turbo questions.....
- gsr turbo dyno question???
- turbo b16 (9psi) overheated
- will i have clearance issues with full-race traction bar??? pictures inside!!
- Adapter Flanges?
- 8.5:1+93octane+25psi = O.K with methanol injection
- How far will a botton end go
- td05h. how do i know what the wheel size is? 16g? 18g? 20g?
- MSD Ignition setup worth it?
- aem 1020 or hondata s300
- safe bore on stock sleeves
- Compressor surge?!?!
- Want Love fab Excaliber manifold info
- b16 t3 thunderbird turbo question
- Anyone know of a very fast reacting temp sensorand gauge for air intake temp
- Boost and PCV system
- EGT 880 degC Supercharger+S2K
- upgrading injectors...?
- Injector lag/dead time for Precision 50 lb/hr injectors
- PLX wideband not reading
- How much can i safely boost with this setup???...
- cutting out!!! help please!
- What Piston Size for .050 Over Bore?
- Bronze Teggy Dynoed! 502 HP 331 TQ on Mustang dyno! Vids and Pics!
- high boost issues
- B turbo head for All motor
- COMPRESSION NUMBERS
- need help optimizing p28 ignition maps for a d14 engine -CROME-
- Who out there is using water/meth injection
- Quick Tuning ?
- Coupler pops off even with t-bolt camps...
- Misfiring bad in the upper RPM range, gap the plugs less or go 1 step colder?
- FMU questions...
- wastegate
- Got some first time shakedown passes 1/8mile with our new project
- Need advice on 600whp b series build
- Anyone check out this electric boost controller? gear dependant ghetto style?
- AVCR wont turn on all the way? buttons illuminate but no display unless I hold down a button...
- Need help buyin a wastegate..
- Meth injection?
- High Mileage Setups!
- Crome 2 step in EF chassis. what needs to be done?
- Benefits of a performance valve job on a FI motor?
- h22 turbo build ~ no top end.
- Cometic Head gasket thickness B16a Turbo?
- nitrous jets
- Clearance issue with Synapse FPR
- Can a violently loud 2 step cause motor damage?
- official gsr-t thread?
- Whos using S300 and AEM UEGO?
- dsm injectors + honda lower seals? will it work?
- OBD Ecu's
- Overboosting!!!.....Why won't boost stay where it was tuned at??
- Injector Efficiency
- installing bkr7e's without boost?
- Ebay Turbo kits?
- dyno: 3 cars and 13 hours later
- Power Steering elimination kit ???
- witch t3t4 for turbo can push 600hp?
- Manifold Question
- Which turbo for stock GSR?
- Throttle cable gets caught causing high idle. HELP!!!!
- turbo inlet
- 10.6 full interior ek hatch @nopi
- 11:1 CR turbo on 8lbs?
- Civic radiator in Integra need help!!!
- pic request of throttle body cable bracket on a jrsc b18c1 help !!!!
- H22 Turbo (20psi)520hp - RPM Kickdown (no redline while boosting)
- 295whp and 248lb/ft @ 15 psi, my sohc-t build!!!!!
- is this worth 5 grand?
- Turbo Car Overheating....Old 1986 Turbo (Part 2)
- thickest y8 head gasket?
- Need Help!
- Is this common? Valve keepers fused / stuck to valve stems
