View Full Version : Forced Induction
- where is fabworks?????
- Manual boost controller vs. wastegate spring
- b20 build?
- turbo settings??
- Need Some Advice
- Anyone running 2 fans on there radiator?
- map sensor?
- Turbo parts FOR SALE
- Manual or digital boost controller
- how to prevent detonate help me
- WTB or Trade for some 1600cc injectors
- I need some advice
- are there any F22 aftermarket pistons or rods???!?!?!?!
- T3/T4 turbo??? too big?
- gsr block w/ b16 head, a few questions
- dyno tune or street tune?
- quick question on B16a2 turbo
- B-series ramhorn mani for sale and h22 log mani for sale
- MBC lines....
- Breather Question
- Weeken installs... and also i need alittel help *pics*
- AEM Tru-Boost with EMS?
- boostin y8 ????
- B16A1
- little help with ARP head stud install...
- Too weak of a wastegate spring for my boost levels??
- 2 turbos spewing oil out what coudl it be ????????
- turbo timer question...
- Chrome tuner in San Diego?
- turbo lsv question
- thinking about tryn turbo again
- headgasket question..
- Need some help...advise ASAP. Intake cam seized.
- Will this log manifold fit AC in my SOHC-T? Pics inside!!
- B18B Turbo - need some advice
- White plugs how am i lean
- valves with itr spring?
- How important is it to run coolant lines to the turbo
- Eaton TVS Supercharger thread.....
- Help me get back up and running
- Help with a T4 coldside identification (wheel/plate/housing)
- integra shut down.
- What injectors to run?
- How much can 83mm stock sleeves hold
- torque steer question
- Supercharging a B17 DA
- How many miles do you have on your built motor?
- Block Notching, Engine still in car!?!?
- t3 turbo manifold
- What did I blow???
- Engine went, take a look...engine builders welcome
- Another Spark Plug Q...
- High boost pistons
- Need Opinions & Suggestions with my FI setup (CRX)
- Wastegate boost question.
- Input needed from a JRSC & VAFC Owner
- ITB's, Ok to run on stock b16??
- Quick M62 blower questions. (JSRC related sorta)
- Do i need.....???
- Radiator hose huge HELP
- boost gauge sounds like its leaking air..is this common?
- Can anyone vouch for J-K-TUNING.COM?
- Track times for my recently finished peakboost gsr.......
- Is this Full-Race???
- Need advise for D15B
- good manifolds for around $200-$400
- WHICH ECU TO GO WITH??????????/
- neu ecu upgrade for 15psi- 1 bar ladedruck
- Does the HKS SSQV flange work with Tial Bov?
- removed old ecu's sensor and idle went high??? help
- help........
- Help
- Cast or stainless steel Turbo manifold?
- rsx-s injector set-up problem? please help!
- turbo question
- turbo teardown - why'd it fail???
- code 3 under low boost
- turbonetics gtk-650 or gt40r help
- egt responding very slowly.
- How would you fix this downpipe issue?
- Ls or GSR stock sleeves for turbo?
- sohc turbo setup references
- Log manifold for H23/F22A
- LS transmission VS. 96 Type R transmission
- DRAGLS WE HAVE A TRANSACTION ISSUE THAT NEEDS TO BE RESOLVED!!!!
- turbo set up help muffler help
- Garrett T3/T4 50 trim
- average $$$$
- Where to find knockoff tial wastegate?
- dyno differences this drastic?
- Special size bolts for my garrett turbo?
- oil press. sender hits oil filter- is it a problem?
- Advise for IAT position
- quick ? with 1000cc injectors and my set up
- where can i find some of these last min. parts?
- Car Dies and doesn't wanna start, HELP: screen shot of hondata log.
- Stock GSR 400whp 92 Octane
- zc w/z6 head how many pounds...
- Oil Pan Return Line Question
- Wanting to boost my GSR
- JRSC...possible 200 whp?
- Need help... Greddy turbo kit
- my build UPDATES**
- The Best Flywheel Weight?????
- rc inj. sitting too high?
- Turbo B16 00Civic Si
- Help me Diagnose these crazy plugs!!!!
- do i really need a fmu?
- first timer...making the crossover!!!
- Omni Valvetrain? Feedback wanted and some questions
- **PRoblems with blox gauges***
- which SPARK PLUGS should i use for my h22 going t4
- Hondata S300 base map setup stumpped
- Has anyone delt with AUTOWORKS?
- the turbo hmmm help
- Oil return line questions
- High boost and low comp or low boost and high comp
- got a big problem
- K20/K24 Exhuast Manifold Help/Questions
- b16 boosted headgaskets which ones best??
- I'm looking for a exhaust manifold that faces front...
- Dyno: Pump Gas GSR w/ Peak Boost Kit
- turboing a mini me
- One more Problem.....
- BURST WATER LINE TO TURBO. HELP!!!! (PICS)
- What would you get?
- Revised T1 Cam Trigger Instructions
- Oil pump came apart ony with 400 WHP.... any suggestions?
- Slipping SC belt?
- s2000 IC piping ? anyone know of a good place to get this?
- swapping turbo question
- im stuck need advice
- Best BOV location on a low boost road racing setup
- wastegate break down
- Buying a new CHRA GT35R
- will an ecu tuned for a y8 work on a y7, all else equal..?
- turbo gsr rev limit issue
- Anyone know what turbo this might BE?
- Is it possible to run a DSM T25 on a B18C1 EK with P/S, A/C?
- !!!!!!!Post your stock boosted motors!!!!!!!
- turbo motor help?
- Air research turbos good or bad??
- rod knock?
- GT3076R Coolant line question
- ls build question
- Oil Return line *help*
- LA Sleeves , Los Angeles Sleeves
- oil light paranoia
- For people with 300whp and under.
- * POST YOUR BOV THREAD *
- Chipped ECU?
- treadstone kit for b-series
- First time boosting....
- first time going boost
- What spark plugs are you running for 500whp - 700whp B series motors
- turbo d16
- Supercharge or Turbo
- GSR-T with Type R internals on head
- turbo hatch stolen in leonardtown maryland
- Oil return line help needed
- ANYBODY HAVE ANY INFO ON THIS TURBO TIMER???
- turbo..
- Good tuner in Chicagoland area??????!!!!!!
- Leaving off charge Piping... bad for the turbo?
- engine build question. GSR w/ LS crank vs LS w/ ls crank.
- Boosted 94 INTEGRA LS
- p28 ecu ??? ecu guru's check here
- Turbo XS or Greddy?
- veccon turbo kit. YUea I know ebay.
- Running 9 psi now, can i turn it up to 23 psi?!
- Which is better....
- help with code 15 Ignition Output Signal
- Source for beaded hose to NPT Pipe adapter fittings to get rid of barbed fittings
- Blown K24vtec? been done?
- Synchronic Wastegate Owners Thread
- ***Official F22B Turbo Thread***
- Suggestions on a JRSC motor build?
- never did force induction need help!!!
- SMC Fuel Controller
- HELP PLEASE! My Idle Is Terrible And I'm Burning Oil :(
- Dyno: Stock B16, pump gas
- supercharger and turbo
- Simple questions 4 the engine swap Pro's
- I have two trannys sittin' here... what to do?!
- need info on internal wastegate.....
- Quite 3' turbo exhaust
- 16G??
- tune
- quick ? about turbo vacuum...
- DARTON OR GE SLEEVES ?
- Supercharged D16Y8???
- M2 race systems CNC heads
- burning oil mess up a/f alot ?
- oil restricktor question
- quick turbo question
- turbo craped out, oil in the exaust , will it smoke for ever lol
- Turbo HElp???
- Serious problem with ring gap
- anybody using a sc50 on a ls build
- Is a built head needed or can I keep it stock?
- what kind of timing should i be at
- LSvtec Turbo build
- how can you tell if the turbo is ballbering?
- My boosted H22 EG finally moving. lots of pics
- Post Your Stock Head Power Levels ***HIGH HP CARS**
- this thing work?
- Good Shop in Nor Cal
- Bar and Plate Radiator???
- taping compressor housing for boost controller
- fmu rubber gasket
- mitsubishi injectors
- IS N E one runing LSV-Turbo if so post up pic & some #
- d16y8, first turbo set-up
- Inline VS Intank fuel pump w/ FMU?
- In Desperate Help, car boggs at quick throttle************
- map sensor signal question
- t3t04 turbo identification... and specs...
- slim fans in front of radiator question
- little help turbo guru's
- tuner question...
- all motor turbo cams?
- Injector Question? Still don't know everything :)
- Another piston thread. PLEASE HELP
- in need of a tune/Ks. area
- "Does my Garrett Turbocharger require an oil restrictor?"
- Helpful Suggestions Needed for (sohc/t3)
- NRG frogeyed pod?
- MY TURBO BUILD Pics
- what can i do to take the delay out of my automatic
- tuning dohc zc
- help with boost flucation and flange...
- 84mm vtec motors, whats your total timing???
- air/fuel problem
- turbo fins
- HELP!!!! breaking up bad up high - b16 boosted
- Dyno #'s and First time track times------Turbo GSR
- pre-turbo fuel supply?????
- Best turbo exhaust for a boosted EG?
- Got low compression? Check your intake manifold first. *PICS*
- Cheap Bosch Pumps? Anybody buy from this site?
- Tuning ECU protection need help
- Anyone use Precision Injectors?
- Clocking turbo quiestion???
- fuel setup for 500 whp
- need headstuds for boost... but which ones for a b16b? quick answer pls
- 2001 civic ex turbocharger
- Wideband readings... Help me understand
- has anyone ever used any injectors other then DSM 450cc or RC 440cc
- b18c4 turbocharger choice....plus intercooler size and wastegate
- What to fill the motor mounts with? 94a? 80d? 400whp, daily driver.
