View Full Version : Forced Induction
- turbonetics turbo that comes in the drag 3 kit for dc2? what trim/ specs is it? t3/t4...
- debate: disconnecting charge piping vs running open wastegate for no boost on turbo... BAD?
- vortech blower on dc2 or dc2r? water cooler install instructions?
- Website that showed Gen2 Integra Turbocharged
- do i need to re-tourge headstuds again?
- Catch can??? and I searched
- Help me find some coolant fittings for my turbo!
- full-race manifold with sc61
- cant boost over 4 psi
- what shops have good deals on dp nitrous kits
- Turbo Size?
- Neptuned B16....New Numbers.....
- Garrett t3 water fittings size..
- how do i know if my btm is working?
- buying a used hondata S200...will i need to buy ECU hardware?
- Question regarding wastegates...
- y7 boost (HELP)
- Question about our OEM Metal Headgaskets...
- CAN ANYONE LOOK AT THESE PICS AND TELL ME IF THIS TURBO LOOKS NEW??? THERE IS A WHITE MARK AND A NUM
- Looking for a hondata basemap Turbo Dseries super 60
- Another Turbo LS from Velocity
- Which seal to bore out for DSM injectors?? Hard Plastic or Rubber or both???
- 13b turbo?
- Stock map sensor more capable at high altitude???
- Master Seal Kit
- JRSC, what is stock belt size from crank to alternator pulley?
- PTE Turbo is jacked
- del sol radiator with a prelude h22
- Best manual boost controller?
- will a full race manifold make more power then a inlinepro
- Your opinion on this DP for my turbo setup....
- 10.5:1 cr on fmu?
- b20 w/b16 head....
- b20 vtec head studs
- question on GE's oil snadwich plate
- Looking for dimensions on greddy type 31v
- I need advice of what turbo I need for my setup?
- D series turbo questions
- Most HP using nearly stock head... 500whp attainable?
- Maximum safe boost on a stock D16Y8 tuned with Hondata
- When go sleeve a block?!?
- SOHC Turbo....
- need help with my budget build up
- ??Safe boost level for stock jdm b16??
- thumbsup for precision's customer service!
- OBX Intercoolers
- I'm looking for a new Rev Hard Stage 2 Kit.....
- h22 build almost complete but I have a ?
- Revhard IC piping question
- Help! Cylinder to headgasket clearence
- breather filter on catch can VS no filter.
- Aerocharger turbochargers... what ever happend?
- Top Mount Manifold.......All Hype or Not
- fmic
- Do I Need A Half Sized Radiator??
- 2.5" cutout vs. 3" cutout
- greddy td04 kit?
- UBERDATA TUNE
- T25 TURBO TROUBLE
- Is this ebay intercooler any good?
- Is my theory CorrecT??
- anyone know of a short 3" muffler?
- Help me decide on a head setup for my built/boosted b18c1
- Anyone block off the H20 heater hose to the intake manifold?? (b18c1)
- is this a good price for building?
- JRSCed H22. Is Worldsport 2 OK?
- Boost Gauge In Hand. Something not right? *PICS*
- who sell oil lines
- Problem with 3bar map sensor - KOEOV 1.47V - HELP PLEASE!
- im thinking about nitrious....i need some basic info
- Thinking about going turbo, Need some Suggestion's.
- Greddy Blue Box on a b18b?
- ls/vtec bog
- stock fuel rail???
- Flex pipe on downpipe yes or no?
- few odds and ends before starting the fresh built motor...
- driving turbo'd w no boost
- * Catch Can Plan : Good or Bad ? '95 LS-T *
- Troubleshoot my turbo install! Help!
- How well dose the color hold up on a Tial wastgate
- timing question: pulley
- EF hatch LS Turbo
- Anyone have; stock ls gt28rs(disco)? want to know if i will like.
- turbo d16 [z6 or y8]
- Car won't start unless I pump the gas.
- Someone send me their "36" 55shot ZEX jet!
- clueless?!?!
- what is sc61 s housing
- Good Hondata Tuner in Denver area?????
- Ram Horn Manifold for My Greddy Turbo?
- 450 dsm injectors, uberdata b18a turbo 91 hatchback running rich
- what do you guys think of this turbo for a b16a?
- who has a turbo b16 with a t3?
- differance between ls & gsr pistons?
- johnyrace car still around?
- Controlling 440cc Injectors
- Uberdata tunner in norcal/central vally??
- RSX Boosting problem. Help????!!!!
- need help on motor parts
- Anyone install a zeitronix wideband with a LS motor???? Need Help!!!!
- Any problems with an FMAX kit on 02 accord manual transmission?
- Just bought GReddy 15G and JRC 6" FMIC, what HP I'll have on D16Z6 ?
- Why isnt my car boosting? Need help.
- Argue away: Built SOHC or stock DOHC for 275-300whp goal?
- help!
- JCWhitney intercooler piping questions?
- What else do i need besides check valves
- Ahh I love Summit Racing! PICS
- Another NEW Full Race knock off B-Series Mani on eBay
- greyish blue smoke
- JRSC and VAFC
- Missing link with uberdata?
- Build you own turbo kit website
- HELP?!?? ITS EVERYWHERE!
- TURBO BLOWN????
- question on main cap bolts for the 500-600hp crowd
- Making a 3 inch DP... is there some points to take care of...
- Civic vs. Teg chassis for 350whp+ street car
- GT3767
- WOuld like to find someone running a T28 on a b18
- I NEED HELP AND TIPS ASAP!!!
- fmiC w/boV
- pistons and rods mandatory??????
- opinions (best turbo exhaust)
- what size injectors do i buy?
- Fully Ported/Built Head Comparison (B18A/B ::&:: VTEC Heads)
- Power FC tunner in VA
- DOes spoon lsd need bearing
- Update: 388 whp @ 20 psi - B16A
- Boost Controller issues. Causes spikes, but settles to wastegate rating.
- d16z6 + 14b (5 psi) running beerbongs bin
- Phantom grip LSD?
- HELP with my LSD
- OBD2b to OBD1 - what needed?
- Input on turboing a 2001 GSR Civic
- HELP ME. Fuel Pump not working?
- Built B18A soon to be turbocharged, any pointers?
- Drain Line...I want to do this right the first time...Whats your opinion/setup??
- Stupid Apexi Auto timer wiring question
- New Turbo kit that mounts on the back of the car WTF!
- stupid ? but what size t bolts do i need?
- Would you do it?
- How much hp/tq from a stock d16y7 (searched)
- ebay turbo?
- tuned my daily driver: 361hp @ 13psi
- everyday driver (b16a2)
- What would be a Realistic goal on Turboing a stock b18b motor for daily driving?
- SOHC TURBO KIT
- Does HOTTER air BEFORE the turbine - cause faster spool
- BLOCK GUARD...HOW MUCH CAN IT HOLD
- What to do with car at 126k miles?
- where can i find a gm 3bar map sensor
- what do you guys think???
- downpipe fitting...
- Timing question
- Thermal 3"exhaust is it worth it for boost?
- Questions about a Turbo setup..
- garret/airesearch M10 turbocharger
- will this turbo set-up be succesful???
- Greddy 18g pics?
- Got a turbo for my EH2
- internal wastegate spring tension?
- boostin a stock d15b7 with 157k miles on it?
- Ignition Curve
- cant pick a turbo
- NYS OBD2 inspection
- d16a6 auto-x build-up
- need help installing an injector resistor box.
- greddy blue box
- Fuel Cuts-off AT 2550-2700 rpm
- T25/T28 Too Small For GSR??? L@@k
- Help Leaking sleeves
- which b20 block?
- full race guru's lookie!!
- What Flywheel weight for turbo? Reliability?
- Which Turbo should I go with....
- bmcracing
- New England area tuners?
- will this EXEDY Organic Clutch hold 300-400hp?
- Fuel pressure gauge under hood?
- integra type r boost ?
- putting turbo on ? about vaccum/boost lines
- How many miles on your new motors before dyno >>
- Need opinion on turbo piping.
- need a parts list for near 400hp turbo b16
- engine options
- buying turbo, need help
- head work on high hp app?
- poormans typeR + JRSC?
- I need to find a place that sells these bolts (turbo rebuild related - pics included)
- UBERDATA how do I use it and does it really work
- Garrett GT40R part no and smallest genuine turbine housing .
- hard idling
- wider tires on stock rims/ kuhmo mx's
- Oil feed line length GSR
- Fuel Pressure and idle
- boost question
- charge pipeswhat size
- oil feed - block tapping tee?
- sleeves a little low.
- LSD from EG fit into a CRX SIR???
- Turbo Set-Up: Need Opinions
- exedy,clutchmaster??
- Rods for b00st
- full-race stage difference
- fastest turbo d
- SFWD car, 620whp/435tq w/Neptune
- In need of a lilttle intake manifold advice.....
- Anyone mount they're ignition box inside the cabin?
- D16Z6 Project Completed!!!! (lots of pics)
- hvs/ss blaster
- 14b spooling real late
- Port and Polish
- srt-4 turbo on sohc
- How To Install Greddy E-01 EBC on civic SI
- Shaft Play Q and SC61 Q
- Who does good head work?
- 3inch downpipe
- DRAG TURBO MANIFOLD STUDS
- What about the greddy E-manage on 91 da(obd0)???
- who has had a turbo honda without blowing a motor?
- car warms up then cools down.. normal??
- how many of you run your turbo setup without a catchcan?
- what causes broken ringlands when going turbo?
- (help) hf adapter plate
- Half rad ?
- Is 9.75:1 too high compression for a ls turbo set up?
- SC61 or t3/T67
- Who Dumps In the Atmosphere
- Turbo XS dual stage boost controller help
- dp flange with one hole and niche
- Action Clutch..?
- dumptube flange interchangabilitiy
- gt turbo coolant - atpturbo.com??
- good turbo kits for integra gsr have about 2k
- hf mani on a 1st gen crx head
- Let me know what clutch kit you would choose
- Turbo Reccomendations Help!
- Crazy Gains....crazy....???
- turbo timer? anysuggestions
- a little help with spiral locks for pistons and file fitting rings?
- Neptune can u use your jdm p30 ecu
- Kinda bent waste gate...
- t25bb and t28bb max wheel HP on h22a
- Broken fuel fitting for STR fuel rail
- manifold smoking? Help asap!
- oil pan identification
- B16 vs b18a/b for next boosted project, help me decide
- Best Catch can scenerio for me (I have researched and narrowed to 2)
- Want to know how to go to Heaven? Heres how.....
