View Full Version : Forced Induction
- new to turbo forum...have questions?
- b16A Turbo and smog issues?
- how much boost on a 1999 b20z
- In what intervals are tial springs available? 10psi?
- has anyone heard of a civic with a JRSC and nitrous running 10s in CT/NY?
- jrsc bypass valve
- hondata tuning
- intercooler size.. will it fit?
- ACCEL DFI Gen 7 software
- How is this turbo gunna spool?
- where to get clamp and bolt kits for t3 turbo??
- Will a drag manifold for an ls teg fit a....
- equal length mani question
- need info from all who installed a premade turbo kit (ex greddy, f-max, revhard, maxrev)
- compressor housing size of the td05-18g?
- ? about the vortech and a b18c5
- Has anyone done the ENDYNE mod to their JRSC?
- tial wastegate
- will this radiator fan positioning work...
- where do i connect the boost guage on a jrsc?
- having problems
- help me decide on a turbo setup
- FMU...how much boost is it good for on stock injectors???
- Why do people say that its bad to buy a lightened flywheel with a JRSC?
- Td05 18g little shaft play okay?
- Is an oil feed flange needed (for t3/t4)?
- C&R drag civic radiator and fan fitment (need input asap)
- ........ 5 RIB belt for the JRSC ?????????
- catch can and charge pipe
- B18 Head Measurements Needed
- Needed: Hondata/Standalone users with wideband results
- If you are running N.O.S kit, please help.
- Mig welding on car--damage ecu & other electronics?
- recommended motor build for sc
- Being told to upgrade my td04-15g, any thoughts for only boosting 10psi.
- Whos gotten Hondata Tuned at Inline Pro yet?
- H-T members...Did i get ripped off on my DownPipe??!!??
- i just boosted my h22 but...? need help
- kkk series turbos qwestion
- Need Suggestions, Turbo Z6 overheating during cool downs...
- more compression or..
- finaly boosting 10psi
- Can someone recommened a site on spark plugs, and the definition of the colorization?
- Anyone with a KKK turbo here ?
- Can someone help me with this turbo fitting?
- WRX Turbo
- How do i wire in two fans?
- safc wire colors?
- whats the thinest fans u can get..
- Can I hit 350whp?
- what do u think about this exhaust setup..
- Moroso Engine Block Filler: anyone have any experience with this product?
- Running open turbo, and another question.
- inlinepro manifold users??
- Greddy kit inlet size?
- VAFC users with cold start problem....please look here!!!!
- Some constructive critisizm on my plans
- Simple Fuel management question
- nitrous and high compression?
- Oil sending Tee broke off in block
- ... traction bars... options...
- boosted road racers
- what tranny (need suggestions)
- Help! My boost is acting all weird cuase I fiddled with my Boost Controller! How can I fix it?
- Equal Length manifold and Greddy Oil cooler
- My Car is smoking really really bad........
- Check engine light ?'s
- piston question...please help!!!
- Fuel Pressure Guages ??'s
- Custom turbo OR turbo kits?
- Nitrous or Turbo
- Compression tested my ZC tonight....
- Anyone using the precision SC32?...
- lets build the rest of my turbo setup.. :)
- JRSC - 2.5inch or 3inch exhaust?
- Can you guys help me with this argument concerning exhaust cut outs.
- Hit 12's today!!
- Installed my Type 24 intercooler and Profec B *pics*
- Fuel System problem
- where to find O2 sensor weld bungs?
- Fuel Pump electrical question
- When you fully rebuilt your motor, which parts from the old block did you use on your new block?
- apex'i sohc turbo kit
- Apex AVC-D boost controller reviews
- Anybody want to trade there AEM EMS for a 3b?
- Will this turbo fit?
- about to change oil ....need help....
- Greddy Kit Safe?
- anyone calibrated a techedge unit?
- SPAL slimfans... where to buy???
- Tech Discussion: Ignition setup w/ boost
- can a Precison T3/60-1 make 500whp on an H22???
- is the apex turbo kit as safe as the greddy kit?
- ok to use wd-40 to clean out turbo oil feed/return??
- LS rods, how much power can it hold?
- where r all the turbo singles at speak up
- Precision SC61?
- turbo clocking
- This sucks!!! Head gasket question.
- will this turbo support me
- new track times last night!
- Which garrett model is this ?
- LoveFab turbo mani. looks great
- Rota's + tire size - who is using what?
- SOHC guy's - help with settings for Ubers boostchip
- What bends for downpipe?
- what is going on when you feel the "loss of power"
- Full Race Turbo Kit
- Turbocharged Integra LS
- Missing Link? Greddy blue box
- DSM Resistor Box???
- alternative to oil feed T?
- Tech Thread: D-series, ITB's and boost
- do d16y7 & y8 oil pans interchange?
- anybody know what check engine code 43 means???????
- Has any1 used a greddy kit on 95 gsr?
- just got BTM, too many opinions
- power - lsd -camber=?
- Compression tested tonight, huge difference since boost
- any turbo users using an ES oval muffler?
- Went to the track today with V-AFC Hack!!!!
- Cam gear settings?
- can any wideband o2 sensor be used with the techedge v1.5???
- where to get ARP head bolts? sohc y8?
- homemade turbo, oil return line
- Anyone using accell 48lb injectors on obd1 b-series??
- Smoke out of exhaust when i Idle for over 5 mins
- do i need bigger injectors with a jrsc?
- Question about Boost Controller!! SHARP AND MILD settings....
- GM 3 Bar Map, VS Stock Map......Questions....
- JRSC on a 1st gen B16a/CRX
- I'm joining the darkside! Any final tips before installation?
- Oil dipstick blowout
- SMC Issues >>>
- Intercooler/ Foglights
- Walbro 255 fuel pump making scraping noise
- Remember me... =)... Ok give me the cliff notes on the last 4 months.. whats happened
- Help me identify some ports on this turbo.
- Eagle Rods, do people really use them?
- td05-18g vs t3/t4?
- d16y8 turbo
- Nitrous on hold!?
- how to clean turbo and intercooler (some gunk inside from possible blown head gasket)
- Testing Waters: GSR front / rear brakes complete. GSR Blade Rims powdercoated black professionally
- H22 Turbo HB
- MAP Sensor Help
- Electronic Wastegate?
- running around 14.0 on apexi a/f gauge, lean out, richen up, or stay?
- Best place to buy fjo wideband???
- Blowoff in neutral?
- new rods
- why is a/c warm???
- Is JRSC more reliable
- Garret gt series
- S-AFC Hack won't lean out!?
- anyone here have a single fan radiator on an integra
- Type R cam and Boost...
- 99-00 Civic Factory Fogs and Intercooler Piping compatibility?
- rods vs.pistons
- alamo motorsports in florida?
- Fuel management question!
- baffling in a catch can
- Couldn't find it via a search (quick RX7 injector question)
- BOV Question
- Daily drivers: If you could do it over again, would you have turboed your car?
- what should compression numbers be on b18b1???????????
- Which Walbro Fuel Pump for turbo b18b???
- big pics of turbo si 56k go away
- IC Fitment...
- Quick question about Hondata and basemaps.
- what will the greddy kit put out?
- How many U bends for my IC piping?
- t3/60-1 or t4/60-1
- what piston to use..
- 81mm vs 84mm
- fuel pump for crx?
- JR supercharger????
- almost done!!!!!!!!!!!
- Blown HG, Turbo D16y8 what to get:
- Anyone swap A turbo H series in a CRX?
- Drawbacks to running near zero boost?
- Upgraded to Rice-Tech.com Phat!!!
- What Injectors Can I Use
- anyone know the specs????
- autometer egt gauge buggin out!!!!!!!!!!! :mad: wtf!?!?!?1
- One of those ANNOYING which is better ?'s. Between T3 and 14b turbo.
- T3/T4 Hybrid VS. T25
- equal length H22 manifold Qs??
- Any suggestions on shops in NC
- What FMU do i need?
- what manifold should i buy for AC use?
- JRSC on D15B7
- Okay i have my compressor off... what do i measure to determine my turbo's numbers?
- 00si with SMC500 set to 0% on stock setup *idling and bogging problems*
- B18C GSR Turbo Compression Ratio
- Omori gauge experts...
- hooked up my manual boost controller and boost gauge today, is this right
- My sad dyno day : (
- 14b turbo, oil receiving line size
- where r the turbo singles my friend dont think turbo single can be fast please post your single
- Starion/Conquest Intercooler install on Integra Q's!!!
- Greddy Blue Box ???
- reducing boost
- b16 SiR 1 turbo build up!!!
- replacing the compressor wheel on an 18G turbo?
- bosche inline part#?
- What is a good clutch?????
- What do you guy's do to prevent pipes from seperating while boosting?
- Fuel delievery (searched)
- Should I stud the exhaust side of the head?
- ls drag 3 install
- Who has made their own MBC?
- picture of a t25 flange?
- Where to set Vtec crossover on boosted B16?
- 6 Bolt FLANGES!!!
- JRSC bypass?
- anyone know the factory d16z6 rod bolt torque specs???????????
- how much does a rubber elbow cost?
- S-AFC hack settings...
- 200 Post
- Running very rich at partial throttle and nice at .45 bar.
- installing 450cc dsm injectors in a gsr
- DRAG turbo kits group buy
- Full-Race Manifold W/ Hot Jet Coat + Tial and Precision Turbo!!Pics!!
- Modified JRSC on a J-Spec or US-Spec B18C1?
- MotorMatrix/GR Ford Escort 416whp+80shot Direct Port!! Pics!!
- Shops with dyno in nyc
- Whats the difference between a Wideband & Narrowband o2 sensor voltages?
- Please help with compressor surge
- question for SOHC turbo ppl
- Turbo blew oil out the exhaust, but is it OK?
- Looking for help picking large turbo, yes its a vw but you guys know your turbos :)
- jackson racing supercharger setup?
- Car missis or makes a werid sound when i down shift and gas it?
- Post your Turbo Integra 1/4 Times
- oil in coolant reservoir
- is it safe to tap your bov into a secondary?
- best turbo cams
- Will altitude affect compression #'s?...
- catchcan or breather filter....
- what BOV's will fit what flanges
- Valves
- AEM CAI for piping, help please!!!
- compression numbers
- How many people using the greddy oil cooler?
- Profec B Setup
- sohc turbo fellas I need your help.
- Has anyone seen this Defi a/f gauge???
- Fuel Pressure Gauge options?
- My Tranny Blew Up.. pics
